Dear experts
I am interested to solve the following equation numerically by Maple. I would appreciate it if you let me how I can do and what the boundary conditions and initial values are needed
eq:= diff(2*diff(eta(x,y,t),t)+3*eta(x,y,t)*diff(eta(x,y,t),x)+(1/3-1/epsilon/B)*diff(eta(x,y,t),x,x,x),x)+diff(eta(x,y,t),y,y)-1/sqrt(Pi*R)*int(diff(eta(x+zeta,y,t),x,x)/sqrt(zeta),zeta=0..t/epsilon)=0;
where
1) epsilon, B and r are constant
2) 1/epsilon/B is not equal to 1/3 at all
choosing lightmodel=none and shading=none, produces a dark grey grided surface
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, lightmodel = none, shading = none)
adding the style=wireframe option gives a blank plot.  Grid probably white?  Changing style to patchnogrid the surface is indeed white. However chosing both shading and style options to none regardless of the lightmodel will produce a plot that appears empty.  Is this to be expected?
However, just the style=wireframe option produces a colored grided wireframe as to expect
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, lightmodel = none, style = wireframe)
Dear users
All my recent questions are removed by "mapleprimes" automatically. who knows the reason?
I am having problems with Maple. I am new to the software and I am looking to use it for tensors. I am working with the Alcubierre metric, for more details, click the images below.
https://i.imgur.com/OvBywO6.png
https://i.imgur.com/2D9Y73x.png
These images should provide more clarity with the metric. My problem is that in Maple, I have successfully entered the metric, however whenever I use for example the Christoffel command, it states that all the Christoffel symbols are equal to zero.
https://i.imgur.com/VRDQM8d.png
I believe the reason why this is happening is because I have not defined the functions properly. I should be getting an answer like the example in the last picture below.
https://i.imgur.com/tn8HpIE.png
Would anyone be able to assist me in this? I would appreciate it greatly.
Many thanks.
Each term of the following sequence is derived using the sum of all preceding terms following a simple algorithm. I have tried to code it but without success (keep getting error message "too many levels of recursion").
Definition is as follows:
a(0)=0, a(1)=1;  for n>=1,
a(n+2) = n + Sum{k=1..n+1} a(k).
it starts: 0,1,2,5,11,23,47,95,191,767,1536,3071,6143...
(Looks like every prime term is of the form 3*2^m-1).
Cann anyone suggest a solution?
David.
While computing a simple sequence of numbers, I remarked a small difference between the result obtained with $ and with seq.
Digits:=20:
u:=proc(n) evalf(((n+1)/n)^(n+1)) end proc:
a:=[u(n)$n=1..10]:
b:=[seq(u(n),n=1..10)]:
a-b;
The result is:
[0., 0., -4.*10^(-19), 0., 0., 6.*10^(-19), -9.*10^(-19), 0., -3.*10^(-19), 0.]
I have no idea why there are nonzero values in the output. Does anyone have an explanation?
It seems I get the correct values if I quote the expression before $:
a:=['u(n)'$n=1..10]:
However, it's not clear to me why this makes a difference in evalf.
As the title says, I'd like to  divide Non-isomorphism  graphs of order 7   into 6 parts according  diameter of graph.
I write following codes:
with(GraphTheory):
for i from 1 to 7 do
D||i:=[]:
prc:=NonIsomorphicGraphs(7,output=iterator,outputform=graph,restrictto = connected ):
graphmark := prc():
while graphmark <> FAIL  do
    if Diameter(graphmark) = 1 then
         D1:=[op(D1),graphmark];
      elif Diameter(graphmark) = 2 then
         D2:=[op(D2),graphmark];
      elif Diameter(graphmark) = 3 then
         D3:=[op(D3),graphmark];
      elif Diameter(graphmark) = 4 then
         D4:=[op(D4),graphmark];
      elif Diameter(graphmark) = 5 then
         D5:=[op(D5),graphmark];
      elif Diameter(graphmark) = 6 then
         D6:=[op(D6),graphmark];
      fi:
     graphmark:=prc():
But I think  conditional statements  if.. elif are used to many  in  above maple  codes,  it is not concise.
How to write better?
Projection will not work with orientation.
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, projection = 0.2)
plot3d(x*y, x = 0 .. 10, y = 0 .. 10, projection = 0.2, orientation = [55, 75, 0])
After setting:
Digits:=20;
result of:
evalhf(9.3653976306373904636884810627704*10^(-315));
is:
-9.0813464423699167205*10^(-315)
This looks nonsesnse. What is going on?
how to show which region of the plan belongs to the argument points between 0 and Pi/2 and the module points between 0 and 2 ?
Does anyone know how to open .mm file in Maple, as well as using the program or function in .mm file in Maple? Many thanks.
Hello colleagues,
I would like to get a suggestion on how to utilize an existing `simplify` function or to define an operator, which allows the following simplification:
O(x^n)/x = O(x^(n - 1))
— Alexander
I need to test a huge amount of subsets and for doing that I was thinking of using combinat:-subset, since it avoids allocating memory for all subsets.  The problem with subset for my specific application is that it generates sets with all possible sizes and I just need subsets with a chosen number of elements.  Can that be done in maple?
Many thanks
Ed
I have a plot of points in a graphical plot on the domain (x,y).  At each point xi (i=1..N) , there is a numerical value yi = S(xi) from which I plot a series of points (xi, S(xi)) in the (x,y) domain.
Each point (xi,yi) represents a transient plot of two variables u(x,t) and v(x,t) in a plot file.  Is it possible to define a graph of the points (xi, S(xi)), such that clicking on any such point in the graph opens up a graphical file which is parameterised by (xi, S(xi))?
Would welcome help on this...
Melvin
when running a for do cycle the first two solutions are exact the same numbers, which is not correct. Can someone plesa help me fix this problem?
Thanks a lot.
tmin:=10: #°C
tmax:=70: #°C
Tmin:=tmin+273.15:
Tmax:=tmax+273.15:
T:='T':
i:=0:
for T from Tmin by 2 to Tmax+1.25 do
i:=i+1:
a12:=2305.28444347652 - 9.14490843016421*T + 0.00680052257590234*T^2:
a21:=-6665.24838284836 + 46.0897018087247*T - 0.0694991633494123*T^2:
alfa:=0.3:
x2:=1-x1:
lng1:=x2^2*(tau21*(G21/(x1+x2*G21))^2+tau12*(G12/((x2+x1*G12)^2))):
lng2:=x1^2*(tau12*(G12/(x2+x1*G12))^2+tau21*(G21/((x1+x2*G21)^2))):
G12:=exp(-alfa*tau12):
G21:=exp(-alfa*tau21):
tau12:=a12/T:
tau21:=a21/T:
lnga1:=subs(x1=xa1,lng1):
lngb1:=subs(x1=xb1,lng1):
lnga2:=subs(x1=xa1,lng2):
lngb2:=subs(x1=xb1,lng2):
r1:=lnga1+ln(xa1)=lngb1+ln(xb1):
r2:=lnga2+ln(1-xa1)=lngb2+ln(1-xb1):
r:=fsolve({r1,r2},{xa1=0..0.22,xb1=0.22..1}):
assign(r):
xA1[i]:=xa1: xB1[i]:=xb1:
print(i,T,xA1[i],xB1[i]);
unassign('r1','r2','r','xa1','xb1'):
1, 283.15, 0.4086195757e-1, .7650860222
2, 285.15, 0.4086195757e-1, .7650860222
3, 287.15, 0.4109304612e-1, .7564109743
4, 289.15, 0.4094687104e-1, .7455613500
5, 291.15, 0.4092946881e-1, .7345259571
6, 293.15, 0.4103899093e-1, .7233142804
7, 295.15, 0.4127502108e-1, .7119337099
8, 297.15, 0.4163857511e-1, .7003892047
9, 299.15, 0.4213210541e-1, .6886831535
10, 301.15, 0.4275956094e-1, .6768151230
11, 303.15, 0.4352648605e-1, .6647816285
12, 305.15, 0.4444014482e-1, .6525760020
13, 307.15, 0.4550971743e-1, .6401880864
14, 309.15, 0.4674655982e-1, .6276039487
15, 311.15, 0.4816452203e-1, .6148056135
16, 313.15, 0.4978038925e-1, .6017705621
17, 315.15, 0.5161445760e-1, .5884711603
18, 317.15, 0.5369126350e-1, .5748739966
19, 319.15, 0.5604059678e-1, .5609387793
20, 321.15, 0.5869882131e-1, .5466171048
21, 323.15, 0.6171072215e-1, .5318505354
22, 325.15, 0.6513208559e-1, .5165679944
23, 327.15, 0.6903339246e-1, .5006820935
24, 329.15, 0.7350533414e-1, .4840835134
25, 331.15, 0.7866732744e-1, .4666324128
26, 333.15, 0.8468127263e-1, .4481446382
27, 335.15, 0.9177527543e-1, .4283678555
28, 337.15, .1002878317, .4069372077
29, 339.15, .1107594115, .3832836608
30, 341.15, .1241550103, .3564111567
31, 343.15, .1425634130, .3241972432
Download lle.mw
lle.mw
First 562 563 564 565 566 567 568 Last Page 564 of 2428
