(Context: As part of a EU consumer watchdog report I've been asked to re-validate a number of publically stated APR rates for various consumer loan. )
(Apologize if this should have been posted to some bug-tracker but I was unable to find such a forum.)
System: MacOS 10.14.6, Maple 2020.1
Summary: Some simple exponential summations entered in 2D Input seems to crash the kernel and it is dependent on the numerical value of the exponent. The same expressions entered in 1D plaintext Maple Notation works fine. The numerically/expression evaluations are also significantly slower in 2D Input in a Document (x10) as compared to 1D Maple Notation in a Worksheet.
The attached worksheet is a "killer" worksheet and will on OSX 10.14.6 + Maple 2020.1 kill the kernel connection (crash the kernel).
kernel-crash.mw
Example:
A trivial example, entering 2D Math (assume PV & C are positive real numbers), say
will cause a lost connection to the kernel after 40-50s entering the epression and the UI being busy (unclear what it is doing since no real calculation is performed) which I assume is a sign that the kernel crashed. It seems to dependent on the exponent in the divisor. So for example the following variation will not crash the kernel
Doing the exact same calculation with a worksheet in old plain maple notation both varianta are both significantly faster in the numerical operation (solving for 'r') and assigning 'eq2' and never crashes (regardless of numerical value of exponent).
The workaround is of course obvious but it would be nice if this bug could be adressed.
It seems that whenever I try to give the 2D-UI a chance (since it is actally easier to visually view complex expressions)  something always comes back and bites me...
Update: The crash is only repeatable with the "sum()" command and not the "add()" command.
I working on wavelets method to solve fractional partial differential equations. The problem when I solved and create a system of algebraic equation using Newton itertaion method the system not solved becuase its appear as amtrix forum when I substitute a collcetion points as follows :
for i from 1 to N do           # calculate left side of equ. at a collection points
    for j from 1 to N do
        ll[i,j]:=eval(q(T[i],T[j]));
ll:
sys := []:
                   # create the system of equations
    l[i,j]:= eval(ual(T[i],T[j])+ ubet(T[i],T[j])+uth(T[i],T[j])+ uwt(T[i],T[j]));
    sys:=[op(sys),(evalf(l[i,j]-ll[i,j]=0 ))]:
sys;
Coefficients:= fsolve(sys);
the results appears as:
[Vector[column](1, [0.92016313e-1+.38891735*c[1, 1]-.24496159000000003*c[2, 1]-.3889173499999999*c[1, 2]+.24496159000000003*c[2, 2]]) = 0., Vector[column](1, [-.9381081886+1.24805825*c[1, 1]-.66648505*c[2, 1]-.4702235500000001*c[1, 2]+.17656187000000007*c[2, 2]]) = 0., Vector[column](1, [2.131874035+.76110696*c[1, 1]-.12722801999999994*c[2, 1]-.76110696*c[1, 2]+.12722802*c[2, 2]]) = 0., Vector[column](1, [.355172452+1.5700572*c[1, 1]+.3444861000000001*c[2, 1]-0.47843280000000044e-1*c[1, 2]-.59894214*c[2, 2]]) = 0.]
please can you help me fix this problem
Hi Everyone!
Considering the Figure (3_span_elastic_support) given by the paperwork (https://www.diva-portal.org/smash/get/diva2:837061/FULLTEXT01.pdf) I try to build the matrix based on the following references:
- https://www.sciencedirect.com/science/article/pii/S0045794913000138
- https://www.sciencedirect.com/science/article/pii/S0022460X07009017
- BOOK: Moving Loads - Dynamic Analysis and Identification Techniques_ Structures and Infrastructures Book Series, Vol. 8-CRC Press (2011)
My questions are:
- when I consider the coefficients kt = 4.881*10^9 and kr= 1.422*10^4 the following message appears. What Is the limit of MAPLE? 10^6?
- Because of this "fsolve" take to a long time to compute the values. If the message above appears I can trust in the "fsolve" values?
9_07_2020_Mode_shapes_matrix_12x12_Figure_3.23_artigo_2.mw
Back in 2000 there was a Maple programming toolbox to buy
Can't find it ?
This is a programming question.
The goal is to solve an equation such as eq:=x^2+2*x-1=0; and obtain the solution as list with x= on each solution, like this
                       sol := [x = sqrt(2) - 1, x = -1 - sqrt(2)]
The command  to start with is sol:=solve(eq,x) which gives
                       sol := sqrt(2) - 1, -1 - sqrt(2)
But to have x= show up, the command is modifed to be sol:=solve(eq,{x}) by adding {} around the variable to solve for, and now Maple gives
                       sol := {x = sqrt(2) - 1}, {x = -1 - sqrt(2)}
Which is not yet the goal.. Changing the command to sol:=[solve(eq,{x})]  gives
                       sol := [{x = sqrt(2) - 1}, {x = -1 - sqrt(2)}]
Which is still not the goal. Changing the command to sol:=solve(eq,[x])  gets closer to the goal.  it gives
                      sol := [[x = sqrt(2) - 1], [x = -1 - sqrt(2)]]
To remove the extra pair [ ] the list is Flattened like this
eq:=x^2+2*x-1=0;
sol:=solve(eq,[x]);
sol:=ListTools:-Flatten(sol)
Which gives me what I want, which is one list (not list of lists), and with x= in there
Is there a better way to obtain the above form of result than what I have above?
Hi Everyone
Just to put you in the context: during an internal turning operation, the overhang (ratio Length/Diameter of the tool [L/D]) is really important to guarantee the stability of the process (minimal vibration as possible). Having said that, it is desirable to increases the overhang to do deep holes, because of this the ratio L/D varies depending on the necessity and consequently the natural frequency of the tool will change.
As you can see in the attached Picture_A and B, I am trying to find the Eigenvalues when the overhang (ratio L/D) changes. Is it possible like in Figure 2 in the attached paper (link below)?
https://www.mdpi.com/2076-3417/9/15/2996/pdf
Consider:
L1 = ratio L/D (changeable);
L2 = Fixation of the tool (content)
L3 = the remaining part of the tool out of the fixation (changeable)
Tool length is content = L1 + L2 + L3
13_07_2020_Eigenvalues_3_span_beam.mw
How do I write this in logical notation in Maple? Is it even possible?
Show logical notation that expresses the following statement: If one dice shows an even number of spots and the second dice shows an odd number of spots, then the total for the pair is less than or equal to 9.
I've somehow understood that sequences are extremly powerful so far. However I have to admit that they are quite complicated to read and understand, and I still am a bit confused how to work with them properly.
The attached example shows a very simple sequence.
My question is - how can I use its results further on?
What I for example would like to have, is a plot, where the first results in the array are the x- values, and the second are used as the y-values. Before that I need to extract both of them into vectors.
Could this be done in one operation, or can I somehow iterate throught the members of the returned values?
exprseq.mw
Hello to all, does anyone create an example for me that how to calculate and plot streamline of fluid flow.
I solved these equations numerically but I need to solve it by Runge-Kutta fourth order Method. Kindly help me in the coding of the same.
N1 :=1:N2 :=1: N3 :=0.1 :R := -1:
EQ:={(1+N1)*diff(f(x),x$4)-N1*diff(g(x),x$2)-R*(-diff(f(x),x)*diff(f(x),x$2)+f(x)*diff(f(x),x$3))=0, N2*diff(g(x),x$2)+N1*(diff(f(x),x$2)-2*g(x))-N3*R*(f(x)*diff(g(x),x)-diff(f(x),x)*g(x))=0}:
IC:={D(D(f))(0)=0, D(f)(1)=0,f(0)=0,f(1)=1,g(0)=0,  g(1)=0}:
sol:= dsolve(EQ union IC, numeric,output=Array([0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1])):
Some rewriting for a general equation , how to do ?
Transformation of eq 1 in wanted eq 2 form
A*x^2+B*x*y+C*y^2+D*x+E*y+F = 0 (general form 2)
After complete square for x and y and some rearrangment (general form 2) ,  i got this equation eq1
(A*(x + (B*y + D)/(2*A))^2 + C*(y + (B*x + E)/(2*C))^2)/(-C*y^2 - E*y - 2*F + (B*y + D)^2/(4*A) - A*x^2 - D*x + (B*x + E)^2/(4*C))=1;
(A*(x+(1/2)*(B*y+D)/A)^2+C*(y+(1/2)*(B*x+E)/C)^2)/(-C*y^2-E*y-2*F+(1/4)*(B*y+D)^2/A-A*x^2-D*x+(1/4)*(B*x+E)^2/C) = 1
eg1:= (-4*A^2*C*x^2 + (-4*y^2*C^2 + (-8*B*x*y - 4*D*x - 4*E*y)*C - (B*x + E)^2)*A - (B*y + D)^2*C)/(4*A^2*C*x^2 + (4*y^2*C^2 + (4*D*x + 4*E*y + 8*F)*C - (B*x + E)^2)*A - (B*y + D)^2*C) = 1;
(-4*A^2*C*x^2+(-4*y^2*C^2+(-8*B*x*y-4*D*x-4*E*y)*C-(B*x+E)^2)*A-(B*y+D)^2*C)/(4*A^2*C*x^2+(4*y^2*C^2+(4*D*x+4*E*y+8*F)*C-(B*x+E)^2)*A-(B*y+D)^2*C) = 1
(1) wanted form of eg1
"A x^2+B x y+C y^2+D x+E y+F=0*("general form 2))
for M ≠ 0
(x+(B*y+D)/(2*A))^2/X+  (y+(B*x+E)/(2*C))^2/Y = 1
Note : what X and Y could be ? :   M/A and M/B  ..
So it must be possible to transform eq1  in this form  above ?
Some background info
If B= 0 in (general form 2) you get (general form 1)
(2) In book for M ≠ 0 as example we get this form
 Ax^2+Cy^2+Dx+Ey+F = 0(general form 1 )
(x+C/(2*A))^2*A/M+  (y+D/(2*B))^2*B/M = 1
Download vraag1-herleidingconics2.mw
I need to check if expression is "special" kind of polynomial. Where powers are allowed to be non-integers and can be fractions. This is not polynomial in the mathematical sense ofcourse so can not use type(expr,polynom) on it, and did not see a way to tell type(expr,polynom) to accept non-integer exponents.
For an example, given p(x):=x^2+x^(1/3)+3+sqrt(x)+x^Pi+1/x*sin(x): it will return false, due to sin(x) term there. Without this term, it will return true, since all other terms have the form x^anything.
Currently, this is what I do
expr:=x^2+x^(1/3)+3+sqrt(x)+x^Pi+1/x*sin(x):
if type(expr,polynom(anything,x)) then
   print("Yes, normal polynomial");
   what_is_left:=remove(Z->type(Z,{`^`('identical'(x),algebraic),'identical'(x)}),expr);
   if has(what_is_left,x) then
      print("Not special polynomial");
      print("Yes, special polynomial");
   fi;
fi;
While with
expr:=x^2+x^(1/3)+3+sqrt(x)+x^Pi+1/x:
It will print "Yes, special polynomial"
Is the above a good way to do this, or do you suggest a better way? It seems to work on the few tests  I did on it so far.
It is always "polynomial" in one symbol, such as x. So if it contains any function of x, other than  x^exponent, where exponent can only be numeric, or other symbol, it will fail the test. So this below will pass the a above test as well
expr:=x^2+x^(1/3)+3+sqrt(x)+x^a+1/x:
I was just praising Maple for not rewriting/simplifying  expressions automatically without the explicit user asking for it, when I found the following strange result
expr:=arccos(a-p) does not cause any change in the input. Good.
But when I change the letter ordering to expr:=arccos(p-a) now Maple changed it to Pi - arccos(a - p)
I have no idea why. Is there an option to tell Maple not to do that, even if it is mathematically correct?
expr:=arccos(a-p);
expr:=arccos(p-a);
It seems to use lexicographical ordering to re-write things. Is it possible to turn that off?  Notice that I did not ask for simplification or anything.
Maple 2020.1, Physics 724
I was checking my solution against Maple. Maple gives solution with integral and RootOf. I am not able to simplify it to better compare.
ode:=y(x)=ln(cos(diff(y(x),x)))+diff(y(x),x)*tan(diff(y(x),x));
sol:=dsolve(ode);
It is the second solution above I want to simplify/evaluate. So I tried
sol:=dsolve(ode);
sol:=[sol][2];
DEtools:-remove_RootOf(sol)
But this did nothing. Then I tried adding useint in the dsolve command
sol:=dsolve(ode,useint);
But this also kept the integral there. Then I tried eval
sol:=[dsolve(ode,'explicit')];
eval(sol[2])
The solution I obtained is
y(x) = -ln(_C1^2 - 2*_C1*x + x^2 + 1)/2 + ((-2*x + 2*_C1)*arctan(-x + _C1))/2
Which does verify to zero OK using odetest.
Any suggestions/tricks to use to get an more explicit solution from Maple I am overlooking?
Maple 2020.1 , Physics 724
I can post/attach my full solution if needed.
I have a particular problem that I haven't managed to find the solution to by googling.
9/10 times that I open Maple 2020 I can't seem to open any of my saved documents. it opens the start tab, and I'm still able to open a new document or worksheet, but then when I try to change to text instead of math, it won't let me. I can type, but I can't press backspace or enter.
I have tried restarting and shutting down my computer, but every time I have to just force quit Maple because it won't respond half of the time and it won't quit normally.
I'm running the latest version of Maple and using macOS Catalina version 10.15.5.
First 558 559 560 561 562 563 564 Last Page 560 of 2459
