   I need to integrate x with a<=x<=b and k , l are constants.
I input foolowing code , it did not work. Maybe you have some good ideas to solve this! thanks!
int(sqrt(1+((k*Pi)/l*cos((Pi*x)/l))^2), x = a.. b) assuming x>=a, x<=b
I am trying to solve the pde:= (d/dt)^2v+(d/dx)^2v+v=0 with initial boundary conditions v=xexp(x^2)
I use pdsolve to get v but I wish to tell pdsolve to use a different numerical method because my output of v is coming out like a step function.
The time taken for thread is comparitively higher in following case. how to decrease time in threads
thread_time.mw
Dear reader,
Have to create digital questions in Mobius on quaternions. Aim is to teach students of robot engineering about rotations besides the matrix rotations. Made some code, it works but very simplistic. I could not load a quarternion-toolbox.
Any suggestions?
# quaternion product
# define two vecotrs p and q:
$p0=range(3,3,1);
$px=range(1,1,1);
$py=range(-2,-2,1);
$pz=range(1,1,1);
$q0=range(2,2,1);
$qx=range(-1,-1,1);
$qy=range(2,2,1);
$qz=range(3,3,1);
$p=maple("Vector([$px,$py,$pz])");
$q=maple("Vector([$qx,$qy,$qz])");
$displayp=maple("printf(MathML:-ExportPresentation($p))");
$displayq=maple("printf(MathML:-ExportPresentation($q))");
# p.q=p0.q0-(p.q)+p0.q+q0.p+p*q
# scalar part
$dot=maple("LinearAlgebra[DotProduct]($p,$q,conjugate=false)");
$scalar_part=$p0*$q0-$dot;
# vector part
$cross=maple("LinearAlgebra[CrossProduct]($p,$q)");
$p0q=maple("LinearAlgebra[MatrixMatrixMultiply]($p0,$q)");
$q0p=maple("LinearAlgebra[MatrixMatrixMultiply]($q0,$p)");
$pq=maple("LinearAlgebra[VectorAdd]($p0q,$q0p)");
$vector_part=maple("LinearAlgebra[VectorAdd]($pq,$cross)");
$displayvector_part=maple("printf(MathML:-ExportPresentation($vector_part))");
# unit vectors
$i=maple("Vector([1,0,0])");
$j=maple("Vector([0,1,0])");
$k=maple("Vector([0,0,1])");
# generate answers
$x=maple("LinearAlgebra[DotProduct]($vector_part,$i)");
$y=maple("LinearAlgebra[DotProduct]($vector_part,$j)");
$z=maple("LinearAlgebra[DotProduct]($vector_part,$k)");
Best regards,
Nico Booij
I have recently received a doc from my friend in privete group in maple cloud, the table showed both eye(view) icon and download icon).When I downloaded and run, the document does not run (maple 2019).
When I sign in maple cloud and see the doc (only view button is ahow), the same document works fine. What could be the error?
I attach  a document extract showing the errors (unable to delimt   .../  identifiers).
Can any one help us please?
Thanks. Ramki.
"Refraction Demonstration          restart:with(plots):  RefractionDemo:=proc(theta1, n2)  local theta2,ainput,ainside,aoutput,box,line1,line2,H,n2text,theta1text,theta2text;   if(theta1<0)or(theta1>Pi/(2.0001)) then return end if;   #theta1:=theta01*Pi180.;   theta2:=arcsin(1/(n2)*sin(theta1));   ainput:=arrow(?&ndash;cos(theta1),&ndash;sin(theta1)?,?cos(theta1),sin(theta1)?,color="Red"):   ainside:=arrow(?0,0?,?1,tan(theta2)?,color="DarkBlue",width=[0.05,relative=false]):   aoutput:=arrow(?1,tan(theta2)?,?cos(theta1),sin(theta1)?,color="Red"):   line1:=plot(0,x=&ndash;1..0,thickness=4,color=black);   line2:=plot(tan(theta2),x=1..2,thickness=4,color=black);   H:=1.8:   box:=plottools:&ndash;rectangle([0,&ndash;H],[1,H],color="LightBlue"):   n2text:=textplot([0.5,1.5,sprintf("n_2=%1.3 g",n2)]);   theta1text:=textplot([&ndash;0.5,0.4,sprintf("theta_1=%4.3 g",theta1)]);   theta2text:=textplot([0.5,&ndash;0.4,sprintf("theta_2=%4.3 g",theta2)]);   display([ainput,ainside,aoutput,box,line1,line2,n2text,theta1text,theta2text],scaling=constrained,view=[&ndash;1..2,&ndash;1..H]);   endproc:        Light enters from the air into a medium at an angle of theta1 relative to the normal. It is refracted to an angle of theta2and travels through the medium, returning back to the air.      You can vary two parameters:       theta1the angle of incidence       n2the index of refraction of the medium*(assuming the index of refraction of the air is essentially 1.0).     To do: Let it execute and start manipulating the sliders.     >Explore(RefractionDemo(theta1,n2),parameters=[theta1=0..Pi2.0015,n2=1..3.]);6""
Error, unable to delimit strings/identifiers
"Refraction Demonstration          restart:with(plots):  RefractionDemo:=proc(theta1, n2)  local theta2,ainput,ainside,aoutput,box,line1,line2,H,n2text,theta1text,theta2text;   if(theta1<0)or(theta1>Pi/2.0001) then return end if;   #theta1:=theta01*Pi180.;   theta2:=arcsin(1/n2*sin(theta1));   ainput:=arrow(&acirc;ï¿&frac12;&uml;&ndash;cos(theta1),&ndash;sin(theta1)&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;cos(theta1),sin(theta1)&acirc;ï¿&frac12;&copy;,color="Red"):   ainside:=arrow(&acirc;ï¿&frac12;&uml;0,0&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;1,tan(theta2)&acirc;ï¿&frac12;&copy;,color="DarkBlue",width=[0.05,relative=false]):   aoutput:=arrow(&acirc;ï¿&frac12;&uml;1,tan(theta2)&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;cos(theta1),sin(theta1)&acirc;ï¿&frac12;&copy;,color="Red"):   line1:=plot(0,x=&ndash;1..0,thickness=4,color=black);   line2:=plot(tan(theta2),x=1..2,thickness=4,color=black);   H:=1.8:   box:=plottools:&ndash;rectangle([0,&ndash;H],[1,H],color="LightBlue"):   n2text:=textplot([0.5,1.5,sprintf("n_2=%1.3 g",n2)]);   theta1text:=textplot([&ndash;0.5,0.4,sprintf("theta_1=%4.3 g",theta1)]);   theta2text:=textplot([0.5,&ndash;0.4,sprintf("theta_2=%4.3 g",theta2)]);   display([ainput,ainside,aoutput,box,line1,line2,n2text,theta1text,theta2text],scaling=constrained,view=[&ndash;1..2,&ndash;1..H]);   endproc:        Light enters from the air into a medium at an angle of theta1 relative to the normal. It is refracted to an angle of theta2and travels through the medium, returning back to the air.      You can vary two parameters:       theta1the angle of incidence       n2the index of refraction of the medium*(assuming the index of refraction of the air is essentially 1.0).     To do: Let it execute and start manipulating the sliders.     >Explore(RefractionDemo(theta1,n2),parameters=[theta1=0..Pi2.0015,n2=1..3.]);"
``Dear Prof.
The following code seems not copying properly (my communication error be allowed please)
"ainput:=arrow(?&"
"ainput:=arrow(&acirc;ï¿&frac12;&uml;&ndash;cos(theta1),&ndash;sin(theta1)&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;cos(theta1),sin(theta1)&acirc;ï¿&frac12;&copy;,color="Red"):ainside:=arrow(&acirc;ï¿&frac12;&uml;0,0&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;1,tan(theta2)&acirc;ï¿&frac12;&copy;,color="DarkBlue",width=[0.05,relative=false]):aoutput:=arrow(&acirc;ï¿&frac12;&uml;1,tan(theta2)&acirc;ï¿&frac12;&copy;,&acirc;ï¿&frac12;&uml;cos(theta1),sin(theta1)&acirc;ï¿&frac12;&copy;,color="Red"):"
"I checked by typing separately. It works as below."
a1 := arrow([-cos(theta1), -sin(theta1)], color = "LightBlue")
``ainput := arrow([-1, 0], color = "Red")
"But the copied from your code does not work."
"ainput:=arrow([-1, 0],color= "`Red"`)"
Download forScotgould_Error_arrow.mw
I have two functions that I took the inetgral of their product (1.3 and 1). Then i multiplied the resulting naswer with the variable and integrates again however the inetgral did not evaluate (3,4, and 5).
I was able to calculate both inegrals using tables of integrals, MATLAB & Mathematica were able to evaluate.
any insights on why this may happening?
Integrals_Sheet2.mw
I am trying to use Maple to evaluate the recursion series as below, but I am getting an error when I try to call c: Error, (in depends) too many levels of recursion
Recursion.mw
b := proc (k) options operator, arrow; (-1)^k*GAMMA(1+(1/2)*k)^2/factorial(k) end proc
c := proc (k) options operator, arrow; piecewise(k = 0, b(0)^N, 1 <= k, (sum((q*(N+1)-k)*b(q)*c(k-q), q = 1 .. k))/(k*b(0))) end proc
b(2)^N
(1/2)^N
c(1)
F := proc (s, kmax, N) options operator, arrow; sum(c(k)*s^k, k = 0 .. kmax) end proc
powcreate(c(k) = (sum((q*(N+1)-k)*b(q)*c(k-q), q = 1 .. k))/(k*b(0)), c(0) = b(0)^N)
c := rsolve({c(0) = b(0)^N, c(k) = (sum((q*(N+1)-k)*b(q)*c(k-q), q = 1 .. k))/(k*b(0))}, c(k), makeproc)
c := proc (k) if k = 0 then return b(0)^N else return (sum((q*(N+1)-k)*b(q)*c(k-q), q = 1 .. k))/(k*b(0)) end if end proc
c(1)
Error, (in _factorial) too many levels of recursion
F(1, 2, 2)
Error, (in unknown) too many levels of recursion
Download Recursion.mw
I have this equation
x3l := -(1/2)*g*(f[3]*m[3]+f[2]*(m[2]+m[3])+f[1]*(m[1]+m[2]+m[3]))*tau^2/(m[1]+m[2]+m[3])+x30
f_i are Heaviside function of x3l, so I get  recrusive error
how can i avoid it ?
A fouth order system is described by the differential equation
          (d^4 y)/(dt)^4 + a_3  (d^3 y)/(dt)^3 + a_2  (d^2 y)/(dt)^2 + a_1  dy/dt+ a_0 y(t)=u(t)
Where y(t) is the output and u(t) is any input
  • Determine the matrix A.
  • Using the condition det[A – λI ]
Determine the eigen values λ.
  • Compute the state transition matrix using maple.
I'm plotting some simple plots such as
plot(frac(x^2/3)*3,x=-5..5, discont=true);
Some discontinuities are connected. Using numpoints, resolution, and Digits doesn't help. Sometimes it will produce a plot with no connections but then other times it does. I need a general solution that is simple. Is there any way to refine the quality of discont?
discont=[usefdiscont=[bins=35]],
I have tried that and it seems to work but I haven't put it through the ringer. Is that all I have?
I'm using MAPLE 2019 and I'm sometimes surprised by its behaviour.  For example, I appear to have an example where it evaluates the integral of each of two terms but not their sum...  What's going on?  Please see the attached.
g0 := exp(r*cos(theta))/Pi
G0 := `assuming`([int(g0, theta = 0 .. Pi)], [r > 0])
BesselI(0, r)
g1 := exp(r*cos(theta))*cos(theta)/Pi
G1 := `assuming`([int(g1, theta = 0 .. Pi)], [r > 0])
BesselI(1, r)
g := g0+g1
exp(r*cos(theta))/Pi+exp(r*cos(theta))*cos(theta)/Pi
G := `assuming`([int(g, theta = 0 .. Pi)], [r > 0])
int(exp(r*cos(theta))/Pi+exp(r*cos(theta))*cos(theta)/Pi, theta = 0 .. Pi)
Download Maplesumint.mw
I wrote a code.mw for a numerical method for a PDE. (You can find the numerical method, exact solution and error between them in the code.)
The method depends on parameters k, M, which are any positive integers, and also depends on teta, beta>-1 which are real numbers.
According to the used method,
when k and M increase, we expect that the error (exact-numeric) generally decreases.
In the code, I selected k=2, M=2, teta=1 and beta=1. And so k=2, M=2, CPU time is low. Error is not bad.
But for k=4, M=3 and also for bigger values of them, CPU time is high. I can' t get the solution.
Question 1:
I don't know, but it may be possible to simplify the code in order to calculate for k=4, M=4?
Question 2:
I want to find optimal values of teta and beta for minimizing the error between numerical and exact solution, when k=2, M=2, or k=3, M=1 etc.
How can we write a Maple code for finding optimal values of teta and beta?
You can download the code.mw
Hello, I'm using free 15 day trial Maple 2019.2 on my Macbook (Macos 10.15.3).
I can't work Maple. I enter some inputs (2+3) and press enter. It works. But when I write plot, version(), f, sin.. or something else it didn't works. And no response. When I click enter, nothind happen. What is the problem? Please help me..
   I download one  file about  all 5 connected graphs with graph6  (total 21 graphs). format from http://users.cecs.anu.edu.au/~bdm/data/graphs.html,and I want to import it in Maple. Since platform restrictions , I can not attach the file .   Please download it by yourself,very thanks to you !
   I put the file  in the installation path of  Maple in my computer:D:\\ Program Files\Maple 2019. (my computer system is Window 10 )  And I import it like following:
  But it  only imports the graph of  the first row in the file. How to import all graphs in a file of graph6 format one time?
I get quite an annoying "bug" that messes up all the presentation aspect of my document.
I want to assume some variable is real so that calculation are simplified at several parts of the document.
But I get this:
Whener I use U__LL I always end up with this ugly form that would make anybody think U__LL is multiplied by itself.
How do I get around this?
First 592 593 594 595 596 597 598 Last Page 594 of 2428
