I'd like to populate a listbox from elements of a matrix, but need some help.
I created an empty listbox with name ListBox0, and try to add a name from the matrix.
DataSet := Matrix(3, 3, [[Tim, 21, 80], [Tom, 23, 86], [Tinker, 25, 90]])
with*DocumentTools
SetProperty("ListBox0", DataSet[1, 1])
I want to optimize a function f(g(e(x),x))  where g(x) is interpolated and e(x) is not known when the interpolation object is created. I found the intpolation Methods of Maple 2018 very helpful to quickly change the inpterpolation method.
Unfotunately the optimization fails when the interpolation object receives an expression as input.
It works if I just use x. Do you know my the first approach fails?
Is there maybe a way to convert the interpolation object to a piecewise function?
Thank you for your help
# Optimize with Interpolation Object
points :=  <<0.4000|  10.0000>,
            <0.7000|   10.0000>,
            <1.0000|   10.0000>,
            <0.3000|   30.0000>,
            <0.4000|   30.0000>,
            <0.5000|   30.0000>>;
Data := <0617,0767,0220,0444,0692,0789>*0.001;
intmethod := LinearInterpolation;
g := Interpolation[intmethod](points(1..-1,1),Data):
Matrix(6, 2, {(1, 1) = .4000, (1, 2) = 10.0000, (2, 1) = .7000, (2, 2) = 10.0000, (3, 1) = 1.0000, (3, 2) = 10.0000, (4, 1) = .3000, (4, 2) = 30.0000, (5, 1) = .4000, (5, 2) = 30.0000, (6, 1) = .5000, (6, 2) = 30.0000})
Vector[column](%id = 18446884324022199230)
LinearInterpolation
plot(g(x),x=0..1)
e := x/sqrt(2);
(1/2)*x*2^(1/2)
f := 5+g(e)*x^2
"5+(module() ... end module)(module() ... end module,1/2 x sqrt(2)) x^2"
f_simple := 5+g(x)*x^2
"f_simple:=5+[[["a linear interpolation object"],["with 6 points in 1-D"]]](x) x^2"
op_f := Optimization[Minimize](f(x),x=0 .. 1);
Error, (in Optimization:-NLPSolve) non-numeric result encountered
op_f_simple := Optimization[Minimize](f_simple(x),x=0 .. 1);
[HFloat(4.999979117244145), [x = HFloat(0.028901647183245588)]]
Download convert_interpolation_object.mw
I received an (automated) email, which called attention to an update.
Where can I find the update?
Thank you, Jan Drösler
Hi there,
I have been using Maple for a while now.
I installed Maple on my Desktop PC, but I am experencing horrendous loading times, and just in general, a slow client. When I look in Task Manager I can see Java Platform SE Binary run at 0% CPU or close to 0% CPU. It uses about 600 MB of ram. I think this is the issue. On my laptop it runs much higher, and I experience no issues. My Desktop PC is significantly better than my laptop. I am running a i7-7700k with a RTX 2080, so there shouldn't be any hardware worries.
Does anyone know what is causing this? Simple math like 1+1 takes time to execute. It is very slow.
Hope someone knows what to do.
Kritix.
Hi everybody
My question comes back to singularities within a differential equation.
Consider a Non-Linear differential equation of y(x), say Eq1.
When we solve this with dsolve ({Eq1, ICs}, type=numeric) we can extract the value of y(x) for each independent variable x.
Now if Eq.1 admits a singularity (for example at x=x0) that can not be removed the following message appears:
Error, (in unknown) cannot evaluate the solution further left (right) of x0, probably a singularity.
By left(right) Maple means that the solution cannot be evaluated for x<x0 (x>x0).
However, in some situations, the Linear form of Eq.1 behaves regularly for all of the values of x, I call the Linear equation as Eq.2.
Now my question is:
How can I make a conditional expression with proc and for commands that do the following requirements:
1. Detect the singular point x0 by running a loop over x for the numerical solution of Eq.1 and write the value of x0 for different initial conditions , since the value of x0 depends on initial conditions.
2. Find the value of y(x=x0) by solving Eq.2 as the linear equation is no longer singular at x=x0.
I want to find out the suitable algorithm through which I can perform the above procedures.
Thank you very much and best regards.
Hadi
Hope that no one minds a beginners question.   How do I enter non-null k=0 robertson-walker tetrad in the physics package?  Not the tensor package as that has depreciated or the differential geometry package as notation is different there.
why is  the figure  so weird ? How can I get the smooth trajectories of the ode system?
with(DEtools)
with(DEtools)
with(plots)
with(plots, implicitplot)
[implicitplot]
with(MatrixTools)
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received MatrixTools
with(LinearAlgebra)
with(VectorCalculus)
R := PolynomialRing([x, y])
p1 := phaseportrait([diff(x(t), t) = x(t)*(1-x(t)^2-y(t)^2)+y(t)*(y(t)^2+(x(t)^2-1)^2), diff(y(t), t) = y(t)*(1-x(t)^2-y(t)^2)-x(t)*(y(t)^2+(x(t)^2-1)^2)], [x(t), y(t)], t = 0 .. 50, [[x(0) = -3, y(0) = .5], [x(0) = 4, y(0) = 2]], x = -4 .. 4, y = -4 .. 4, dirgrid = [13, 13], stepsize = 0.5e-1, axes = BOXED)
p2 := pointplot([[1, 0], [-1, 0], [0, 0]], symbolsize = 20, symbol = solidcircle, color = black)
display(p1, p2)
solve({x*(-x^2-y^2+1)+y*(y^2+(x^2-1)^2), y*(-x^2-y^2+1)-x*(y^2+(x^2-1)^2)}, {x, y})
{x = 0, y = 0}, {x = RootOf(_Z^8-6*_Z^6+11*_Z^4-6*_Z^2+2), y = RootOf(_Z^8-6*_Z^6+11*_Z^4-6*_Z^2+2)^5-3*RootOf(_Z^8-6*_Z^6+11*_Z^4-6*_Z^2+2)^3+RootOf(_Z^8-6*_Z^6+11*_Z^4-6*_Z^2+2)}, {x = 1, y = 0}, {x = -1, y = 0}, {x = RootOf(_Z^2-2), y = RootOf(_Z^2+1)}
subs({x = .5, y = -.5}, x*(-x^2-y^2+1)+y*(y^2+(x^2-1)^2))
-.15625
sys := [x*(-x^2-y^2+1)+y*(y^2+(x^2-1)^2), y*(-x^2-y^2+1)-x*(y^2+(x^2-1)^2)]
A := Jacobian(sys, [x, y])
Matrix(%id = 18446746647299284134)
latex(Matrix(2, 2, {(1, 1) = -2, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0}))
 \left[ \begin {array}{cc} -2&0\\ \noalign{\medskip}0&0\end {array}
 \right]
A1 := subs([x = 1, y = 0], A)
Matrix(%id = 18446746647299319918)
A2 := subs([x = -1, y = 0], A)
Matrix(%id = 18446746647176545934)
A3 := subs([x = 0, y = 0], A)
Matrix(%id = 18446746647213830142)
r1, e1 := Eigenvectors(A1)
Vector[column](%id = 18446746647213811102), Matrix(%id = 18446746647213811582)
r2, e2 := Eigenvectors(A3)
Vector[column](%id = 18446746647299291126), Matrix(%id = 18446746647299291246)
Download as22a.mw
Dear Sir/Madam, I am new in maple and willing to use an old (yet tested) Maple V code. The program first evaluates two integrals numerically, which depend on the values of "d" and "s" (user-defined), and then computes the values of a cumulative distribution function. The problem is that, when running the code on Maple 2018, the evalf(Int) of the first integrand (named "ex1") results in "Float (undefined)". I would really appreciate your help. Thank you in advance.
#Maple V program
assume(x, real, y, real, c1, real, c2, real);
d := 3:
s := .9:
ex1:=(1-exp(-(d-y)*I*x))/I/x*exp(y*I*x/(1-I*x)):
ex1:=simplify(Re(evalc(ex1))):
f1:= unapply(ex1,x,y):
ex2:=(1-exp(-(d-y)*I*x))/I/x*exp(y*I*x/(1-I*x))/(1-I*x):
ex2:=simplify(Re(evalc(ex2))):
f2:=unapply(ex2,x,y):
t1:=evalf(Int(f1(x,s),x=-infinity..infinity));
t2:=evalf(Int(f2(x,s),x=-infinity..infinity));
cumulativeprob:=evalf(subs(c1=1/2,c2=1/2,1-((c1*t1+c2*t2)/(2*Pi)+c1*exp(-s)/2)));
cumulativeprob:=.2503779941
I get the same result here where I expected a difference to be acknowledged by the split command. Is there a more efficient way of handling this problem other than the substitution for another character, followed by executing the split  command, then substituting the substituted character with the original ?(here ":")
StringTools['Split']("fdsg543656fgh:576fghs:dsfg::657ufdgdsg", "::")
["fdsg543656fgh", "576fghs", "dsfg", "", "657ufdgdsg"]
StringTools['Split']("fdsg543656fgh:576fghs:dsfg::657ufdgdsg", ":")
Download split_help.mw
How can I set Maple 2019 so that all inputs are of the color red?
I am using a Lenovo Notebook 64-bit.
Plot the "moment curve" f(t)=(t,t^2,t^3) over the interval 1≤t≤2 and a tangent line at the point when t=1. Include both plots in the same display, with the moment curve red and the tangent line blue.
Plot the boundary of the rectangle with bounds 1≤x≤4 and 2≤y≤3 by parametrizing and plotting all four boundary segments in the same display
How do I simplify KdV equation in Maple by using =fxt))xx)?)
   I am by using =2*difffxtxx)
    My aim is to get the form
   diff((f*(diff(f, x, t))-(diff(f, x))*(diff(f, t))+f*(diff(f, x, x, x))-4*(diff(f, x, x, x))*(diff(f, x))+3*(diff(f, x, x))^2)/f^2, x) = 0
restart; with(PDEtools); with(DEtools)
alias(u = u(x, t)); declare(u(x, t)); alias(f = f(x, t)); declare(f(x, t))
u
` u`(x, t)*`will now be displayed as`*u
u, f
` f`(x, t)*`will now be displayed as`*f
KdV := diff(u, t)+6*u.(diff(u, x))+diff(u, x, x, x) = 0
diff(u, t)+6*(u.(diff(u, x)))+diff(diff(diff(u, x), x), x) = 0
KdV_f := eval(KdV, u = 2*(diff(ln(f), x, x)))
2*(diff(diff(diff(f, t), x), x))/f-2*(diff(diff(f, x), x))*(diff(f, t))/f^2-4*(diff(f, x))*(diff(diff(f, t), x))/f^2+4*(diff(f, x))^2*(diff(f, t))/f^3+6*((2*(diff(diff(f, x), x))/f-2*(diff(f, x))^2/f^2).(2*(diff(diff(diff(f, x), x), x))/f-6*(diff(diff(f, x), x))*(diff(f, x))/f^2+4*(diff(f, x))^3/f^3))+2*(diff(diff(diff(diff(diff(f, x), x), x), x), x))/f-10*(diff(diff(diff(diff(f, x), x), x), x))*(diff(f, x))/f^2+40*(diff(diff(diff(f, x), x), x))*(diff(f, x))^2/f^3-20*(diff(diff(diff(f, x), x), x))*(diff(diff(f, x), x))/f^2-120*(diff(diff(f, x), x))*(diff(f, x))^3/f^4+60*(diff(diff(f, x), x))^2*(diff(f, x))/f^3+48*(diff(f, x))^5/f^5 = 0
df := collect(KdV_f, f)
6*((2*(diff(diff(f, x), x))/f-2*(diff(f, x))^2/f^2).(2*(diff(diff(diff(f, x), x), x))/f-6*(diff(diff(f, x), x))*(diff(f, x))/f^2+4*(diff(f, x))^3/f^3))+(2*(diff(diff(diff(f, t), x), x))+2*(diff(diff(diff(diff(diff(f, x), x), x), x), x)))/f+(-2*(diff(diff(f, x), x))*(diff(f, t))-20*(diff(diff(diff(f, x), x), x))*(diff(diff(f, x), x))-4*(diff(f, x))*(diff(diff(f, t), x))-10*(diff(diff(diff(diff(f, x), x), x), x))*(diff(f, x)))/f^2+(60*(diff(diff(f, x), x))^2*(diff(f, x))+4*(diff(f, x))^2*(diff(f, t))+40*(diff(diff(diff(f, x), x), x))*(diff(f, x))^2)/f^3-120*(diff(diff(f, x), x))*(diff(f, x))^3/f^4+48*(diff(f, x))^5/f^5 = 0
factor(simplify(df, size))
2*(12*(((diff(diff(f, x), x))*f-(diff(f, x))^2)/f^2.(((diff(diff(diff(f, x), x), x))*f^2-3*(diff(diff(f, x), x))*(diff(f, x))*f+2*(diff(f, x))^3)/f^3))*f^5+f^4*(diff(diff(diff(f, t), x), x))+f^4*(diff(diff(diff(diff(diff(f, x), x), x), x), x))-f^3*(diff(diff(f, x), x))*(diff(f, t))-10*f^3*(diff(diff(f, x), x))*(diff(diff(diff(f, x), x), x))-2*f^3*(diff(f, x))*(diff(diff(f, t), x))-5*f^3*(diff(f, x))*(diff(diff(diff(diff(f, x), x), x), x))+30*f^2*(diff(diff(f, x), x))^2*(diff(f, x))+2*f^2*(diff(f, t))*(diff(f, x))^2+20*f^2*(diff(diff(diff(f, x), x), x))*(diff(f, x))^2-60*(diff(diff(f, x), x))*(diff(f, x))^3*f+24*(diff(f, x))^5)/f^5 = 0
Download KdV_simplify
Is there lifting function for polynomials or algebra use?
expect input a list univariate polynomial , then output a list of polynomials of two variables.
it should be the reverse operation of projection.
Which library has this function in maple 12 or maple 2015?
I am a beginner of MapleSim. I study the MapleSim User Guide. I follow the Tutor 8:Modeling Hydraulic System. But the following issue occurs, as shown in the picture. I bet I follow the guide carefully.
Also, I find that if I open the User's Guide example,Chapter 6, Analysis of Simple Hydraulic System Network, which is the standard example,I simulate it and it works well. But if I delete the probe, and attach a probe at the same place , selecting same values to measure, and simulate again, it failed, giving the same error description. I need your help,please.
problem_with_Analysis_of_Simple_Hydraulic_Network.msim
First 593 594 595 596 597 598 599 Last Page 595 of 2428
