         I'd like to draw a graph with its  vertices  of 3d style.  Just like following image:
  I did not find the desired choices for this graph.
Hello All,
I have an autonomous system of ordinary nonlinear equations. In order to investigate it near the fixed points, I would like to reduce it to the normal or hyper-normal form. I see in the literature that some authors developed unique algorithms for the very specific differential systems (e.g., the systems with two/three eigenvalues), which is not my case.
Maybe you know, if Maple has any specific commands that may conduct such type of reduction?
Thanks in advance,
Dmitry
I’m trying to animate the volume generated by rotating the function curve around the Ox axis. the Solidofrevolution command with animation output generate a disk volume
QuestionAnimationVolumeOfRevolution.mw
I am solving coupled PDEs under various BCs and ICs on the (x,t) domain, to obtain momentum p((x(t),t) solution plots of the within a MAPLE worksheet.
However, I am getting JAVA memory overload (> 2GB), which brings MAPLE to a halt when plots are displayed in the worksheet.  Is there a way of writing the graphical plots directly to a file on my computer, so that the plots can later be view separately on my computer screen, thus avoiding JAVA memory overload within MAPLE.
If this is possible, please could someone send me MAPLE code to create external plots...perhaps using simple examples in MAPLE?
Melvin .
with(DEtools); with(plots); with(plots, implicitplot);
LC := [diff(x(t), t) = x(t)*(1-x(t)^2-y(t)^2)+y(t)*((1-x(t))^2+y(t)^2), diff(y(t), t) = y(t)*(1-x(t)^2-y(t)^2)-y(t)*((1-x(t))^2+y(t)^2)]
p1 := DEplot(LC, {x(t), y(t)}, t = 0 .. 100, [x(0) = 1, y(0) = 1])
Error, (in DEtools/DEplot/CheckInitial) too few initial conditions: [x(0) = 1]
Download mm.mwmm.mw
I am trying to generate a compiled c function
dc_test := proc( a :: Array(datatype=float[8]), b :: Array(datatype=float[8]), c :: Array(datatype=float[8]) )
c[..,..] := a . b;
return 0
end:
cdc_test:=Compiler:-Compile(dc_test, optimize):
a := Array(1..2, 1..2, fill=1.0, datatype=float[8]);
b := Array(1..2, 1..2, fill=1.0, datatype=float[8]);
c := Array(1..2, 1..2, datatype=float[8]);
dc_test(a, b, c);
cdc_test(a, b, c);
This doesn't work because it doesn't recognize the "." symbol. Also if I were to take the transpose, for example Transpose(a), then it doesn't recognize that either. Are there commands for this that I'm unware of or do you have to program them from scratch?
How to animate a plot with Shadebetween command?
AnimationShadebetween.mw
Hi, I am currently working with Maple on school, and I wanted to use the diff(); function to find the partial derivative with respect to x. Anyways; I noticed when I was not using the multiplication sign I got the answer 0 as seen below:
diff(2*sqrt(xyz), x) = 0
But when I used the multiplication sign as seen (x*y*z instead), I got the correct answer.
diff(2*sqrt(x*y*z), x) = y*z/sqrt(x*y*z)
Why so?
Adrian
hi daer
i am trying to run the following but error came
acually the boundry conditions are periodic
x=linspace(0,1,50);
t=linspace(0,1,50);
m=0;
eqn=@(x,t,u,dudx)transistorPDE(x,t,u,dudx,C);
ic=@(x)transistorIC(x,C);
sol=pdepe((m,eqn,ic,transistorBC,x,t);
function [c,f,s]=transistorPDE(x,t,u,dudx,C)
a=0.1;
c=1;
f=0;
s=-a*dudx;
end
function u0=transistorIC(x,C)
L=1;
u0=exp(-(x-L/2)^2);
end
function [pl,ql,pr,qr]=transistorBC(xl,ul,xr,ur,t)
pl=ul;
ql=0;
pr=pl;
qr=0;
end
Hello Everyone
I have solved the equation below numerically and now I want to integral p(x)
ode := diff((b+5)*((1/6)*(diff(p(x), x))*h^3+(1/2)*c*h^2)/(b+2)+De^2*((1/10)*(diff(p(x), x))^3*h^5+c^2*(diff(p(x), x))*h^3+(1/2)*c*(diff(p(x), x))^2*h^4+c^3*h^2)/(b+2), x)+diff(h, x) = 0
ics := p(0) = 0, p(1) = 0;
solnum := dsolve({ics, ode}, numeric, method = bvp, maxmesh = 600);
                solnum := proc(x_bvp)  ...  end;
odeplot(solnum, 0 .. 1)
but when I write evalf(int(p,0..1)) I get this result:int(p,0..1). What should I do to have the value?
Dear Users!
Hope you would be fine with everything. I want to evaluate an expression (diff(u(y, t), y)+diff(diff(u(y, t), y), t)) for various values of b at y = 0, t=1. Please help me to evaluate it. Thanks in advance,
restart; with(plots); a := .7; L := 8; HAA := [0, 2, 5, 10];
for i to nops(HAA) do
b := op(i, HAA);
PDE1[i] := diff(u(y, t), t) = diff(u(y, t), y, y)+diff(diff(u(y, t), y, y), t)-b*u(y, t)+T(y, t);
PDE2[i] := diff(T(y, t), t) = (1+(1+(a-1)*T(y, t))^3)*(diff(T(y, t), y, y))+(a-1)*(1+(a-1)*T(y, t))^2*(diff(T(y, t), y))^2+T(y, t)*(diff(T(y, t), y, y))+(diff(T(y, t), y))^2;
ICandBC[i] := {T(L, t) = 0, T(y, 0) = 0, u(0, t) = t, u(L, t) = 0, u(y, 0) = 0, (D[1](T))(0, t) = -1};
PDE[i] := {PDE1[i], PDE2[i]}; pds[i] := pdsolve(PDE[i], ICandBC[i], numeric)
Here's the recurrence equation I'm trying to solve and the weird answer that Maple 2018 gives me on Windows 10.
Out of curiosity, I started my old computer with  Windows 2000 and Maple V release V (1997 version).
I typed the same lines as before. I got the answer I was looking for immediately.
Answer which I easily improved.
What's happening ?     What am I doing wrong ?
I am often excited by the the latest versions of Maple but recently I have been rather surprised by the things it cannot do.
When that happens, I remember the story of the guy who wants to sell a great watch to another guy.
"This watch is full of new gadgets:
 gps, heart rate, body temperature, outside temperature, micro camera, voice recorder, email, internet ...
Only one problem . It doesn't tell time . "
Best regards .
Réjean
I would like to determine if some lengthy expression F is linear in one of its inderteminates X.
 I use to use type(F, linear(X)) to do this but I've just found that if F is piiecewise defined, then type(F, linear(X)) returns false even if E is linear in X...
For instance, let  F := a*X+piecewise(Y<0, X, b)
then type(F, X) returns false.
I do not pretend it is a bug: at first sight I would say that F is linear with respect to X but maybe the notion of linearity with respect to an indeterlinate must be interpretated as "linear on each branch" ?
For the moment I've circumvented the problem by doing this :
dF := diff(F, X):
has(dF, X):
# returns {\emptyset} if F is linear in X
But, as I said, F can be a rather lengthy expression invoking a lot of piecewise constructors, and I don't think that computing dF is an efficient way to do the job.
Do you have a better idea to proceed?
Greeting for all members in Mapleprimes
could I have a simple procedure to plot the following figure
See the attached file.
Amr
Squares.mw
If
p_{x} = a*p + u*q;    (1)
q_{x} = -conjugate(u)*p - a*q;  (2)     # where a is complex parameter, p_{x} mean derivative of p w.r.t x
Define, u=p^2+conjugate(q)^2,  (3)
Now take the derivative of (3) w.r.t x and by using (1) and (2), we get
 u_{x}=2(a*p^2 - conjugate(a)*conjugate(q)^2) + 2*(p^2 + conjugate(q)^2)*(p*q - conjugate(p)*conjugate(q)).  (4)
How to calculate the results (4) on maple?
123.mw
First 595 596 597 598 599 600 601 Last Page 597 of 2428
