for example, there is an expression exp1=(a+b)*(a+c),  I want to find all the position in DAG of a specific operand, such as 'a' ; also I want to find the position in the DAG of  sub-expression which type is '+' .
 is there any function in maple which can return the  integers indicating position of an operand or type in an expression? i.e. with this function, assume its name is 'find',then
find(exp1, a) will return  [1,1],[2,1];
find(exp1,'+') will return  [1,0],[2,0];
hi
i got a problem to solve 2 nonlinear  pde equation that are not coupled but there is 8 coupled boundary condition. i can use pdsolve in maple.anyone can help me in numerical solving of these pdes?
How can I set the range (bounds) of all of the function's variables to the same range at once? Here is a simple exaple:
Input:
Minimize((x[1]-1)^2+(x[2]-1)^2+(x[3]-1)^2, {8 <= x[1]*(x[2]^2+x[3]^2+1)}, x[1] = 1 .. 2, x[2] = 1 .. 2, x[3] = 1 .. 2);
Results:
[0.693290283715211841, [x[1] = 1.53166579937811,  x[2] = 1.45311243719790, x[3] = 1.45311243719790]]
My function have 15 variables x[1] -> x[15]. How can I set their bounds to a global range, say: x[i]=1..2 ?
I'm using Maple 17.3 at work.
Thanks, and sorry for the bad English.
This is from the documentation of ?plot3d,light:
light=[phi, theta, r, g, b]
    This option adds [my emphasis] a directed light source
    from the direction phi, theta in spherical coordinates.
The "adds" in that sentence seems to imply that
multiple light sources are possible, but it does not seem
to work that way.  Each subsequent light option overrides
the previous one as we see in the following illustration
where we render a ball three times by illuminating it
(a) from the north, (b) from the south, and (c) from
both the north and south.  In (c) Maple accounts for only
the south light.
with(plots): with(plottools):
ball := sphere(1, style=surface, color=gold):
display(<
    display(ball,light=[0,0,1,1,1])   |
    display(ball,light=[180,0,1,1,1]) |
    display(ball,light=[0,0,1,1,1], light=[180,0,1,1,1])
Download light.mw
When I try:
X≔Statistics[RandomVariable](Normal(0,1)):
Statistics[Sample](X,10);
I get:
Error, (in Statistics:-Sample) invalid input: expected distribution or algebraic expression with random variables, but received X
What am I doing wrong?
I am trying to parallelize the output of my Maple18 program, such that it is able to write into multiple smaller output files at the same time, rather than into one unique big file spending much time in this operation...
This is the code:
As you can see from the code, I have tried with different combinations of options. The errors that I get are:
(only one file: "rows-1 < 10000")
Option1A = Error, (in fprintf) string expected for string format
Option1B = Error, (in unspecified) Too many levels of recursion for display
Option2A = OK (but there isn't parallelism here....)
Option2B = OK (but there isn't parallelism here....)
(more than one file: "rows-1 > 10000")
Option2A = Error, (in StringTools:-Split) first argument must be a string
Option2B = Error, (in StringTools:-Split) first argument must be a string
Instead, if I simplify the definition of D_vol to one single sum (for exemple 2+2), this is what I get:
Option1A = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option1B = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option2A = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option2B = OK (but there isn't parallelism here, and the example is trivial 2+2=4)
Option1A = OK (but the example is trivial 2+2=4)
Option1B = OK (but the example is trivial 2+2=4)
Can you please help me? Any advice wil be really useful....
in maple, i can't use print? Help me. Please.
I'm trying to make a Least-Squares curve fitting plot.  I need to sequence two rows from a data file I imported (see attached worksheet GR10_20190130_PSA_TESTS.mw).  More specifically, I need to sequence the data in
X:=Row(T,1) with the data in y:=Row(T,2).  It should look like
([41115.0,6.97],[41257.0,18.9],[41270.0,15.67]...[43495.0,4.06]) when complete.  I tried seq[X_k,Y_k], that didn't work.  Also tried using an index of 1 to 25 (the number of elements in each row), that didn't work.  Any help with this appreciated, thanks in advance!
Les
For educational needs; I try to animated some statistical concepts with simple statistical commands of Maple on 2018. The WorkSheet  in appendix, gives the desired animations, but with rather heavy procedures. Thanks for your help.
Proc1limitmgf_(1).mw
Hi !
I made a program that solves a series of system of linear equations of increasing dimension.
Equations with rational numbers. I have a list of equations "liseq1" and a list of variables "lisvar1".
I use the following command :
solve(liseq1,lisvar1) ;
When the equation system reaches dimension 32, Maple gives me the following error message :
"Error, (in LinearAlgebra:-Modular:-IntegerLinearSolve) invalid arguments to iratrecon" .
It is an overdetermined system with 33 equations and 32 unknowns .
The variables are defined with the command:
 x: = array (0..31) ;
I managed to work around the problem by replacing the variables with the following commands :
lissub: = seq (x[i] = x||i, i = 0..31) ;
lisvar2: = subs(lissub, lisvar1) ;
liseq2: = subs(lissub, liseq1) ;
solve (liseq2, lisvar2);
If you run the file I sent, Maple sometimes gives the desired answer but in a random way
because if you run the last 3 lines in a different order you will get the answer or the
error message .
Something remains in memory. Sorry, but it's a bug.
I have Windows 10, 64 bit with Maple 2018.2.
Regards .
I'm a long-time Maple user and have used the CodeGeneration package in the past, but with a recent download of Maple 2018, I'm now getting an error I have never gotten before. Even when I do something simple (see below, for example), I get an error that reads "Error, (in clear) argument `` is incorrect or out of order". And I get this error no matter which language I choose. Any help would be much appreciated.
> with(CodeGeneration)
> R(exp(x))
I do know how to define the finite field F_q=GF(p,k). But know I am looking at the residue class ring R:= \F_q[x]/(f) with f an arbitrary polynomial in F_q[x]  of degree(f)>1. And I need all the calculations over R. My f will be reducible, so R wont be a field. Can anyone help me how I tell Maple to do the arithmetic in R? With the right remainder calculation? And with [f]=[0], so that the sesidue class of f is the same as the residue class of 0?
Thank you very much for any help!!
I would like to evaluate a funktion f in \F_q[x], where \F_q is a finite field with q=p^k. My algorithm is based on the fast multipoint evaluation algo in J. von zur Gathen/ J. Gerhard Modern Computer Algebra Edition 3. My proc FastEval does the right thing, but I dont know how to reach any of the calculatet values. And I will need all of the values for further procs! I tried it with lists, but (because of the recursive call??) I only get 1 value in the list... Does anyone know how to solve my problem? The return call only stops my proc after the first value has been calculated, that is why i used print.
Please, can anyone help me?
This is my first question asked in mapleprimes.com, so please excuse any mistakes.. Also I dont know how to put the maple stuff in here correctly??
I would be really really happy if anyone can help me...
Kind regards from Germany
Melanie
\sourceon Maple
istZweierpotenz := proc (n::posint)  #checks if n=2^k for any k in N
local k, nTest;
k := 0; nTest := 1;
while nTest <= n do
    if nTest = n then return true
else nTest := 2*nTest; k := k+1
 end if
 return false
with(ListTools);
SubProdTree := proc (n::posint, u::(seq(anything)))
local k, j, i, M::(polynom(integer, x)), leftList, rightList, kList;
if istZweierpotenz(n) = true then k := log[2](n);
if nops([u]) = n then
for j to nops([u]) do M[0, j-1] := x-u[j]
for kList from 0 to k do leftList[0, kList] := [M[0, 2*kList]]; rightList[0, kList] := [M[0, 2*kList+1]]
 for i to k do for j from 0 to 2^(k-i)-1 do M[i, j] := M[i-1, 2*j]*M[i-1, 2*j+1]
 for kList from 0 to 2^(k-i-1)-1 do leftList[i, kList]
:= Flatten([[leftList[i-1, 2*kList]], [rightList[i-1, 2*kList]], M[i, 2*kList]]); rightList[i, kList]
:= Flatten([leftList[i-1, 2*kList+1], rightList[i-1, 2*kList+1], M[i, 2*kList+1]])
if i = k then kList := 0;
leftList[i, kList] := Flatten([[leftList[i-1, 2*kList]], [rightList[i-1, 2*kList]], M[i, 2*kList]])
end if
return leftList[k, 0]
return false
end if
else return false
end if
GoDownTree := proc (f::polynom, n::posint, l::list, p::posint)
local func, prim, k, r0, r1, newLeftList, newRightList, numberPoint, newList;
func := f;
prim := p;
numberPoint := n;
k := log[2](numberPoint);
newList := l;
newLeftList := newList[1 .. numberPoint-1];
newRightList := newList[numberPoint .. 2*numberPoint-2];
if not isprime(prim) then return sprintf("%a ist nicht prim", prim)
if numberPoint < degree(func) then return false
 if numberPoint = 1 then print(func)
r0 := evala(`mod`(Rem(func, newLeftList[-1], x), prim));
r1 := evala(`mod`(Rem(func, newRightList[-1], x), prim));
GoDownTree(r0, (1/2)*numberPoint, newLeftList, prim);
GoDownTree(r1, (1/2)*numberPoint, newRightList, prim)
end if
FastEval := proc (f::polynom, n::posint, p::posint, u::(seq(anything))) local l;
l := SubProdTree(n, u);
GoDownTree(f, n, l, p)
G := GF(11, 2);
a := G:-extension;
aOut := G:-ConvertOut(a);
alias(alpha = RootOf(aOut));
l := SubProdTree(8, 1, 2, 3, 4, 5, 6, 7, 8);
GoDownTree(x^2+x+1, 8, l, 11);
                           GF(11, 2)
                     / 2          \
                     \T  + 6 T + 7/ mod 11
                          T  + 6 T + 7
                             alpha
[x - 1, x - 2, (x - 1) (x - 2), x - 3, x - 4, (x - 3) (x - 4),
  (x - 1) (x - 2) (x - 3) (x - 4), x - 5, x - 6, (x - 5) (x - 6),
  x - 7, x - 8, (x - 7) (x - 8), (x - 5) (x - 6) (x - 7) (x - 8),
  (x - 1) (x - 2) (x - 3) (x - 4) (x - 5) (x - 6) (x - 7) (x - 8)
                               7
                               10
                               9
                               10
                               7
FastEval(x^2+x+1, 8, 11, 1, 2, 3, 4, 5, 6, 7, 8);
                               7
                               10
                               9
                               10
                               7
\sourceoff
Trying to simulate tossing 10 coins. What  am i doing rong? Thanks
a := Vector[row](1 .. 10)
Vector[row](%id = 18446745395177063238)
randomize()
for k to 10 do r := rand(1 .. 2); if r < .5 then a[k] := "H" else a[k] := "T"; print(a[k]) end if end do
proc () (proc () option builtin = RandNumberInterface; end proc)(6, 2, 1)+1 end proc
Error, cannot determine if this expression is true or false: r < .5
a
Download CoinToss.mw
solve({12 beta k^2 w alpha[2]+k alpha[2]^2, 56 beta k^2 m w alpha[2]+4 beta k^2 w alpha[1]-4 A k^2 alpha[2]+8 k m alpha[2]^2+2 k alpha[1] alpha[2]0, 104 beta k^2 m^2 w alpha[2]+16 K beta k^2 w alpha[2]+16 beta k^2 m w alpha[1]-20 A k^2 m alpha[2]+28 k m^2 alpha[2]^2-2 A k^2 alpha[1]+14 k m alpha[1] alpha[2]+2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2], 56 k alpha[2]^2 m^3+42 k alpha[1] alpha[2] m^2+6 m (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+96 w k^2 beta alpha[2] m^3+40 w k^2 beta alpha[2] K m-40 A k^2 alpha[2] m^2-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]+4 w k^2 beta alpha[1] K+4 (8 K beta k^2 w alpha[2]-2 A k^2 alpha[1]) m+24 w k^2 beta alpha[1] m^2,70 k alpha[2]^2 m^4+70 k alpha[1] m^3 alpha[2]+15 m^2 (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+5 (-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]) m+80 w k^2 beta alpha[2] K m^2-40 A k^2 alpha[2] m^3+44 w k^2 beta alpha[2] m^4+4 w k^2 beta alpha[2] K^2-2 A k^2 alpha[1] K+k alpha[0]^2+2 k alpha[1] beta[1]+2 k alpha[2] beta[2]-2 w alpha[0]+16 w k^2 beta alpha[1] K m+6 (8 K beta k^2 w alpha[2]-2 A k^2 alpha[1]) m^2+16 w k^2 beta alpha[1] m^3-4 w k^2 beta beta[1] m+2 A k^2 beta[1]+4 w k^2 beta beta[2],56 k alpha[2]^2 m^5+70 k alpha[1] alpha[2] m^4+20 m^3 (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+10 (-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]) m^2+80 w k^2 beta alpha[2] K m^3-20 A k^2 alpha[2] m^4+8 w k^2 beta alpha[2] m^5+4 (4 K^2 beta k^2 w alpha[2]-2 A K k^2 alpha[1]+k alpha[0]^2+2 k alpha[1] beta[1]+2 k alpha[2] beta[2]-2 w alpha[0]) m+24 w k^2 beta alpha[1] K m^2+4 (8 K beta k^2 w alpha[2]-2 A k^2 alpha[1]) m^3+4 w k^2 beta alpha[1] m^4+2 k alpha[0] beta[1]+2 k alpha[1] beta[2]-2 w beta[1]-4 w k^2 beta beta[1] m^2+4 w k^2 beta beta[1] K+4 A k^2 beta[1] m-8 w k^2 beta beta[2] m+4 A k^2 beta[2],28 k alpha[2]^2 m^6+42 k alpha[1] alpha[2] m^5+15 m^4 (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+10 (-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]) m^3+40 w k^2 beta alpha[2] K m^4-4 A k^2 alpha[2] m^5+6 (4 K^2 beta k^2 w alpha[2]-2 A K k^2 alpha[1]+k alpha[0]^2+2 k alpha[1] beta[1]+2 k alpha[2] beta[2]-2 w alpha[0]) m^2+16 w k^2 beta alpha[1] K m^3+(8 K beta k^2 w alpha[2]-2 A k^2 alpha[1]) m^4+3 (2 k alpha[0] beta[1]+2 k alpha[1] beta[2]-2 w beta[1]) m-8 w k^2 beta beta[1] K m+2 A k^2 beta[1] m^2+2 A k^2 beta[1] K+2 k alpha[0] beta[2]+k beta[1]^2-2 w beta[2]+16 w k^2 beta beta[2] K+(8 K beta k^2 w beta[1]+4 A k^2 beta[2]) m,8 k alpha[2]^2 m^7+14 k alpha[1] alpha[2] m^6+6 m^5 (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+5 (-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]) m^4+8 w k^2 beta alpha[2] K m^5+4 (4 K^2 beta k^2 w alpha[2]-2 A K k^2 alpha[1]+k alpha[0]^2+2 k alpha[1] beta[1]+2 k alpha[2] beta[2]-2 w alpha[0]) m^3+4 w k^2 beta alpha[1] K m^4+3 (2 k alpha[0] beta[1]+2 k alpha[1] beta[2]-2 w beta[1]) m^2+2 (2 A K k^2 beta[1]+2 k alpha[0] beta[2]+k beta[1]^2-2 w beta[2]) m-4 w k^2 beta beta[1] K m^2+4 w k^2 beta beta[1] K^2-8 w k^2 beta beta[2] K m+4 A k^2 beta[2] K+2 k beta[1] beta[2],k m^8 alpha[2]^2+2 k m^7 alpha[1] alpha[2]+m^6 (2 k alpha[0] alpha[2]+k alpha[1]^2-2 w alpha[2])+(-4 A K k^2 alpha[2]+2 k alpha[0] alpha[1]+2 k alpha[2] beta[1]-2 w alpha[1]) m^5+(4 K^2 beta k^2 w alpha[2]-2 A K k^2 alpha[1]+k alpha[0]^2+2 k alpha[1] beta[1]+2 k alpha[2] beta[2]-2 w alpha[0]) m^4+(2 k alpha[0] beta[1]+2 k alpha[1] beta[2]-2 w beta[1]) m^3+(2 A K k^2 beta[1]+2 k alpha[0] beta[2]+k beta[1]^2-2 w beta[2]) m^2+(4 K^2 beta k^2 w beta[1]+4 A K k^2 beta[2]+2 k beta[1] beta[2]) m+12 w k^2 beta beta[2] K^2+k beta[2]^2},{k,w, alpha[0], alpha[1], beta[1], alpha[2], beta[2]});
Error, missing operation
First 727 728 729 730 731 732 733 Last Page 729 of 2428
