In my expresions I have an integer, nx, which actually has values of only +1 and -1 but I do not specify which.
THe results come out as powers of nx, say nx^n, where n is a positive integer.
How do I reduce the expression nx^n,= 1 for n even and nx^n,= nx for n odd?
I have the following system
pendsys := { diff(x(t),t) = a * x(t) + y(t), diff(y(t),t) = -x(t) + a * y(t) }:
with critical point being (0,0). After plotting the phase portrait, I found out that (0,0) is (asymptotically) stable when a<0 and unstable when a>0. Also, (0,0) is a center when a = 0. Also, as initial condition, I have x(0)=0, y(0)=1. I was thinking we have Hopf bifurcation at a = 0. My question is, how do I plot the bifurcation diagram for this system?
tes_A.mwtes_A.mw
Maple 2018.2.1, using Physicsupdates 266.
I undertsand method=Fourier needs boundary conditions to work, but I do not think this error message is right. Compare
pde := diff(u(r, theta), r, r)+diff(u(r, theta), theta, theta) = 0;
iv := u(2, theta) = 3*sin(2*theta)+1;
pdsolve([pde,iv], u(r,theta), method = Fourier)
With
pdsolve(pde, u(r,theta), method = Fourier)
Error, (in pdsolve/info) wrong extra arguments: {method = Fourier}
pdsolve should return no solution instead. The way it is above, I thought at first I had wrong syntax with the "method = Fourier" settings and I think this error message can be misleading to a user.
Why doesn't PlotVector plot the arrows all in one size?  (as seen in the Maple help page here)
Dear Maple users
Sometimes I use the Explore command in order to watch how plots containing parameters change when the parameters are changed via sliders. I tried to do the same with an odeplot. I can make it work, but I cannot do it the same way as I use to do with ordinary plots: I like to define the plot outside the Explore command, because those Explore commands can be quite cluttered and hard to overview. It is not that bad in my attached example below. Sometimes I have display commands handling several plots ...
In the attached file I show first how it works when the odeplot is inside the Explore command, but when I later move it outside, it won't work. Why this difference between ordinary plots and odeplots? Or maybe there is a workaround to make it work having the odeplot command outside ...
Erik
odeplots_in_an_Explore_command.mw
Dear Maple users
Some ODE's like the Lotka Volterra system can only be solved numerically. I would like to solve some equations based on the numerical solution to that system. Let the x(t) and y(t) be the solutions to the ODE system.
Now, obviously it won't work afterwards to write an equation like solve(x(t)=60,t), since the solution of the ODE only exists as a procedure. Of course I can make an odeplot and zoom in to get an approximate solution to x(t)=60. I would however like it to done automatically. How is this done in the most convenient way when the soltuion of the ODE is given as a procedure?
Example attached.
Erik
Lotka_Volterra.mw
Initially I tried to find pemutations of 1..9, ie [[1,2,3],[4,5,6],[7,8,9]],[[1,2,4],[3,5,6],[7,8,9]],...etc, But maybe not all of them?
I wonder if someone out there can change my code to reflect the following:
1/According to the pdf excerpt, there are a total of 199 unique sums, the smallest sum is 774 and the largest 2556.(From displaying 280 outcomes, the code got the 774).
2/Show which sums have the greatest probability (specifically, 1566, 1575, 1638, 1656, 1674, 1692, 1755, and 1764, each of which can be shown with effort to have a 3/280, or 1.07%, probability – the calculations to determine this probability is a brute-force computation, and requires enumerating all outcomes of the sample space within a computational software package). We then finally reveal the prediction, which of course is correct..(I don't get it)
predict_perfect.mw
I want to divide every element of A1 list by every element of list A2. Lists are unequal length.
Example:
A1:= [a1, a2, a3];
A2:= [b1, b2];
Output would be:
[a1/b1, a2/b1, a3/b1, a1/b2, a2/b2, a3/b2]
I managed to do this by this means:
LinearAlgebra:-OuterProductMatrix([a1, a2, a3], [1/b1, 1/b2]); convert(%, list)
My questions are:
  1. Is there a more succinct, practical method?
  2. How about if I want to use a different operation like say adding or just use a function f?
Thank you all in advanced.
I've been using the following syntax to set boundary condition which is a derivative, when passing it to pdsolve. Say we want to set u(r,theta,t) to have insulated boundary conditions at r=1. So the BC will be
For example, to set derivative of u w.r.t. "r" to zero when r=1
       eval(  diff(u(r,theta,t),r), r=1) = 0;  #(1)
or using this syntax
       D[1](u)(1, theta, t) = 0;  #(2)
But now I find, on one example below, that the above no longer works.  I have to use this syntax (which I did not know about) for it to work
        D[1]*u(1, theta, t) = 0;  #(3)
Has something changed? why when using (3) pdsolve now gives result, but when using (2) or (1) it returns unevaluated? are the three semantically equivalent? when to use which syntax?
I am using Physics updates 265, Latest Maple 2018.2
Here is an example showing the (1,2)  syntax no longer works, but the (3) syntax works
#articolo example 6.9.2
#using (1) syntax
pde := diff(u(r, theta, t), t) = (diff(u(r, theta, t), r)+r*(diff(u(r, theta, t), r, r))+(diff(u(r, theta, t), theta, theta))/r)/(25*r);
bc_on_r := eval(diff(u(r,theta,t),r), r=1) = 0;
bc_on_theta:= u(r,0,t)=0, u(r,Pi,t)=0;
ic := u(r,theta,0)=(r-1/3*r^3)*sin(theta);
pdsolve([pde, bc_on_r,bc_on_theta,ic], u(r, theta, t), HINT = boundedseries(r = [0]))
does not solve it.
#using (2) syntax
bc_on_r := D[1](u)(1, theta, t) = 0;
does not solve it.
#using(3) syntax
bc_on_r := D[1]*u(1,theta,t)=0;
I've used syntax (1) before many times and it works. Here is an example where all three syntax work
pde:=diff(u(x,t),t)=k*diff(u(x,t),x$2);
bc:=eval(diff(u(x,t),x),x=0)=0,u(L,t)=0;
ic:=u(x,0)=f(x);
sol:=pdsolve([pde,bc,ic],u(x,t));
pdsolve gives
 Using syntax (2)
bc:=D[1](u)(0,t)=0,u(L,t)=0;
ic:=u(x,0)=f(x);
gives same answer as (1) and using syntax (3)
bc:=D[1]*u(0,t)=0,u(L,t);
ic:=u(x,0)=f(x);
The answer also looks like different and simpler, but I assume they are equivalent for now without looking too much into it.
Which syntax should one use as now I am really confused.
It looks like (3) is the one that should be used? Why the others did not work on first example? i.e. pdsolve did not give an answer at all?  And if (1,2,3) syntax are supposed to be equivalent, whysecond example gives slightly different looking answer when using one syntax vs. the other?
And finally to make things more confusing, here is an example where syntax (3) does not work, but syntax 1 and 2 work:
#articolo example 8.4.3
pde := diff(u(x, t), t) = (1/20)*(diff(u(x, t), x, x))+t;
bc := u(0, t) = 5, (u(1, t)+ D[1](u)(1, t)) = 10;
ic:= u(x, 0) = -40*x^2*(1/3)+45*x*(1/2)+5;
pdsolve([pde, bc,ic], u(x, t))
gives answer.
bc := u(0, t) = 5, (u(1, t)+eval(diff(u(x,t),x),x=1))  = 10;
gives same answer. But
bc := u(0, t) = 5, (u(1, t)+ D[1]*u(1, t)) = 10;
does not work.
Clearly there is something I do not understand between these 3 syntaxes and when to use which.
Using 265 version
Physics:-Version()
 "C:\Maple_updates\Physics+Updates.maple", 2018, December 22,
    10:41 hours, version in the MapleCloud: 265, version
    installed in this computer: not installed
downloaded today.
In this code k=2 and Beta=2 has been cconsidered
Loading Optimization
Loading Student:-MultivariateCalculus
ISO ELASTIC DEM ADD ERROR
y := proc (p, e) options operator, arrow; alpha-beta*p+k*e end proc:
G := g(p):
g := proc (e) options operator, arrow; (1/2)*mu*e^2 end proc:
Lambda := proc (z) options operator, arrow; int((z-u)*phi(u), u = 0 .. z) end proc:
Step 1  Integrated supply chain
THE EXPECTED total PROFIT FUNCTION w r t LINEAR DEMAND
PI := proc (p, e, z) options operator, arrow; (p-c)*(y(p, e)-z)-(p-v)*Lambda(z)-g(e) end proc
PI(p, e, z)
(p-c)*(-beta*p+e*k+alpha-z)-(p-v)*(int((z-u)*phi(u), u = 0 .. z))-(1/2)*mu*e^2
FIRST PUT ALL PARAMETER VALUES AND THEN GO FOR THE DIFFERENTIATION
RUN THE OPTIMALITY AND THE SUBROUTINES FOR DIFFERENT Beta and K values
CASE 1:   Put k = 2 and beta =2
beta
Int_Profit := simplify(eval(PI(p, e, z), [k = 2, beta = 2, alpha = 50, mu = 10, c = 5, v = 1, phi(u) = 1/2]))
-2*p^2+(1/4)*(-z^2+8*e-4*z+240)*p-5*e^2+(1/4)*z^2-10*e+5*z-250
Int_Profit[1][1]
(-2*p^2+(1/4)*(-z^2+8*e-4*z+240)*p-5*e^2+(1/4)*z^2-10*e+5*z-250)[1][1]
Optimization:-NLPSolve(Int_Profit, p = 0 .. 60, e = -1000 .. 30, z = -10000 .. 25, initialpoint = {e = 0, p = 10, z = 0}, maximize)
[230.512568949745969, [e = HFloat(2.274015113534025), p = HFloat(16.370075567375324), z = HFloat(-1.4795080892429795)]]
Int_Profit
Calculate the Value of q
q := z+y(p, e)
-beta*p+e*k+alpha+z
qopt := simplify(eval(q, [e = 2.27401511353403, p = 16.3700755673753, z = 1.47950808924298, k = 2, beta = 2, alpha = 50, mu = 10, c = 5, v = 1, phi(u) = 1/2]))
23.28738718
Step 2  Decentralized supply chain
Retailer's profit
`#msubsup(mi("&Pi;",fontstyle = "normal"),mi("R"),mi("d"))` := proc (p, e, q, w) options operator, arrow; (p-w)*(y(p, e)-z)-(p-v)*Lambda(z)-g(e) end proc
Re_Profit := simplify(eval(`#msubsup(mi("&Pi;",fontstyle = "normal"),mi("R"),mi("d"))`(p, e, q, w), [alpha = 50, beta = 2, k = 2, mu = 10, c = 5, v = 1, phi(u) = 1/2, w = 10]))
-2*p^2+(1/4)*(-z^2+8*e-4*z+280)*p-5*e^2+(1/4)*z^2-20*e+10*z-500
Optimization:-NLPSolve(Re_Profit, p = 0 .. 60, e = -1000 .. 30, z = -10000 .. 25, initialpoint = {e = 0, p = 10, z = 0}, maximize)
[129.081143396165999, [e = HFloat(1.7075918734530873), p = HFloat(18.537959441958364), z = HFloat(-0.9736548233351249)]]
Optimal q value for decentralized supply chain
qd_opt := simplify(eval(q, [e = 1.70759187345309, p = 18.5379594419584, z = .973654823335125, k = 2, beta = 2, alpha = 50, mu = 10, c = 5, v = 1, phi(u) = 1/2]))
17.31291969
Manufacture's Profit
`#msubsup(mi("&Pi;",fontstyle = "normal"),mi("M"),mi("d"))` := proc (p, e, q) options operator, arrow; (w-c)*qd_opt end proc
(14)
M_Profit := simplify(eval(`#msubsup(mi("&Pi;",fontstyle = "normal"),mi("M"),mi("d"))`(p, e, q), [qd_opt = 17.31291969, alpha = 50, beta = 2, k = 2, mu = 10, c = 5, v = 1, phi(u) = 1/2, w = 10]))
86.56459845
(15)
Total Wholesale Profit
`#msup(mi("&Pi;",fontstyle = "normal"),mi("d"))` := proc (p, e, q) options operator, arrow; M_Profit+R_Profit end proc
(16)
Whole_Profit := eval(`#msup(mi("&Pi;",fontstyle = "normal"),mi("d"))`(p, e, q), [M_Profit = 86.56459845, R_Profit = 129.08114339616599])
215.6457418
(17)
step 3 find the t value
t := (In_Profit-R_Profit)/(w-c)
(18)
topt := eval(t, [w = 10, c = 5, In_Profit = 230.512568949745969, R_Profit = 129.08114339616599])
20.28628510
(19)
Hence range of t is 17.31 to 20.28
Download Code_1.mw
I have
a:=-(diff(x(t), t))^2*h^2/(x(t)^2-2*d*x(t)+d^2+h^2)^(3/2);
How do you collect the denominator to get
Hello. Is there a built-in function to determine the required sample size for different distributions in a population?
When I try to install (as an example) physics update using Maple 2018.2.1 on windows 10, it keeps hanging in the middle as shown above.
I closed Maple, starting again and tried again, same thing happens. I waited for more than 10 minutes and nothing happens.  I click on the install button in the clouds windows from Maple itself to install it as I always did.
Do others have problem installing this?  I'll try again in few hrs, it might be the Maple server is having some issues but thought to ask.
given is the lower, partial differential equation. I have solved this (hopefully) correctly. I was given the tip to do in Maple a simple control in which the solution is inserted into the original equation. Since I'm quite inexperienced in maple, I would like to ask you for help on how I do that best!
Thanks a lot!
Basis equation:
Solution:
Could anyone explain why Maple doesn't calculate the Killing vectors for the metric below?
Thanks in advance!
killing2.mw
First 739 740 741 742 743 744 745 Last Page 741 of 2428
