I try to solve ODE with conditions, but it give answer only without conditions:
SOT.mw
Hi, I'm trying to plot the following functions in 3 dimensions using the following:
plot3d(kappa*sech(kappa*(-k^2*t+x)), x = -10 .. 10, t = -10 .. 10)
plot3d((2*(-K^2+k^2))*(K*cosh(k*(-k^2*t+x))+k*cosh(K*(-K^2*t+x)))/((K+k)^2*cosh(k*(-k^2*t+x)-K*(-K^2*t+x))+(-K+k)^2*cosh(k*(-k^2*t+x)+K*(-K^2*t+x))+4*K*k), x = -10 .. 10, t = -10 .. 10)
plot3d(2*(diff(arctan(lambda*sin(mu*((-3*lambda^2+mu^2)*t+x))*sech(lambda*((-lambda^2+3*mu^2)*t+x))/mu), x)), x = -10 .. 10, t = -10 .. 10);
Each produces an empty plot with a message similar to the following:
Warning, expecting only range variables [x, t] in expression 2*(lambda*cos(mu*((-3*lambda^2+mu^2)*t+x))*sech(lambda*((-lambda^2+3*mu^2)*t+x))-lambda^2/mu*sin(mu*((-3*lambda^2+mu^2)*t+x))*sech(lambda*((-lambda^2+3*mu^2)*t+x))*tanh(lambda*((-lambda^2+3*mu^2)*t+x)))/(lambda^2/mu^2*sin(mu*((-3*lambda^2+mu^2)*t+x))^2*sech(lambda*((-lambda^2+3*mu^2)*t+x))^2+1) to be plotted but found names [lambda, mu]
in each case kappa, k, K, lambda, mu are real constants
Thanks for any help with this
Is there any facility to apply Finite Volume Method to Partial idifferential equation on MAPLE?
Any comand?
Any Code?
I know abut semilogpot - it gives a semilog scale on the horizontal axis.
Is there any way to get semilog scale on the vertical axis?
Season's greeting
Modify the procedure that implements the secant and tangent routines in such a way that instead of the number of iterations in the beginning give the given accuracy E, with which the approximation is to be determined.
As a result, the procedure should return the last approximation along with the iteration number.
I need help.
How can we remove 0=0 from the above by single comand if it lie in any position from the set?
How to eliminate the I in the numerator?
Suppose we have a set of quadratic equations of the form:
U_11 * a * q + U_12 * b * q + U_13 * c * q + U_14 * d * q + U_15 * a * w + U_16 * b * w + U_17 * c * w + U_18 * d * w + .. = C_i
Where terms in uppercase means constant while lowercase letters correspond to unknowns.
Now, I want to make a change of variable, so instead of having non-linear term `a * q` we would have `s_ij`, meaning i-th equation and j-th unknown after the change was done.
I'm trying to do so, because in my case I will be left with a linear system with a small number of unknowns(relative to N) and N equations, and so I could then solve it easily.
Any help is appreciated, thank you!
I have a worksheet that creates many dynamic GIF images.  They use up a huge large amount of RAM, causing MAPLE to grind to a halt.
Instead, on its creation, I would like to export each image file to my external file system, and then delete it from my MAPLE worksheet.  I wish then to use commands in MAPLE to start up and view the image files using IrfanView outside MAPLE.  This would, significantly reduce my RAM usage. (I.e. I wish to export the iGIF mage viewing to IrfranView.)
Can anyone help please?  (I have tried to follow MAPLE documentation, but have been unable find a working solution.)
I am running under Windows 7.
MRB
Typesetting:-delayDotProduct(with, DEtools, true):
with(IntegrationTools):
z := 'z';
z
whattype(z)
symbol
eq := proc (z) options operator, arrow; evalf(Int(-(2*I)*exp((-1)*.5*I*t)/(sqrt(t^2+1)*exp(sqrt(t^2+1))), t = -500 .. z)) end proc
f(500)
f(500)
a := 2*t^2+5*t
2*t^2+5*t
s := t^2+t+1
t^2+t+1
d := t^2+t-9
t^2+t-9
sys := {diff(x(t), t) = eq(z)*y(t)+a*x(t), diff(y(t), t) = s*x(t)+d*y(t)}
{diff(x(t), t) = (Int(-(2.*I)*exp(-(.5*I)*t)/((t^2+1.)^(1/2)*exp((t^2+1.)^(1/2))), t = -500. .. z))*y(t)+(2*t^2+5*t)*x(t), diff(y(t), t) = (t^2+t+1)*x(t)+(t^2+t-9)*y(t)}
IC_1 := {x(-1) = 0, y(-1) = 1}
dsol3 := dsolve(`union`(sys, IC_1), numeric, parameters = [z], method = rkf45, range = -500 .. 500, output = procedurelist)
"dsol3:=proc(x_rkf45) ... end proc"
dsol3(parameters)
[z = undefined]
dsol3(parameters = [500])
Error, (in evalf/int) invalid arguments
dsol3(500);
Error, (in dsol3) parameters must be initialized before solution can be computed
Download eslam_().mw
Hi. could anyone help on this code? fsovle doesn't solve it;
12.mw
Dear Users,
I have difficulty in finding numerical integration of a function f(r,t) which is a function of position r and time t. Function f(r,t) consists 100 terms (for example : BesselJ(0, 151.5793716314014*r)+BesselJ(0, 151.5793716314014*r)*r^2+......100 terms). For a particular time t=t1, f(r,t1) is calculated and then integrated as follows:
I am using evalf(Int(f(r,t1),r=0..1)
Maple takes a lot of time  to evaluate it as it is integrating it in one shot!  Is there a way to
a) pick the terms individually and integrate it
b) then sum these individual terms up together
c) How reliable is evalf(int(f(r,t1),r=0..1)) is? Is evalf (Int()..)  the best way to evaluate integration?
thanks.
Greetings, any one help  me to remove the error  in plots display,here is the codes
i want 2 rows and 2 columns graphs with 9 lines in each graphs.
i am attaching the maple questions also  like this i want
 https://www.mapleprimes.com/questions/224443-How-Do-I-Get-A-Legend-Only-Three-Curves--In-Maple
https://www.mapleprimes.com/questions/225078-How-To-Remove-Error-In-Plot-Display
 h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
 K1:=((4/h(z)^4)-(sin(alpha)/Gamma2)-h(z)^2+Nb*h(z)^4):
 lambda:=unapply(Int(K1,z=0..1), Gamma2):
 L1:=0.2:
 alpha:=Pi/6:
 display
  ( Vector[row]
    ([seq [ seq
        ( plot
          ( [ seq
              ( eval(lambda(Gamma2), Nb=j),
                j in [0.1,0.2,0.3]
           d1 in [0.1,0.2,0.5])] ],
            delta2=0.02..0.1,
            legend=[Nb=0.1,Nb=0.2,Nb=0.3],
            labels=[typeset(`δ1`), typeset(conjugate(`Δp`))],
            title=typeset("Effect of ", ''alpha'', " when ", Gamma,"2=", Gamma2)
          Gamma2 in [10,20,30,40]
I need Maple code of Bisection method.
First 740 741 742 743 744 745 746 Last Page 742 of 2428
