I couldn't find a command or tool for searching a value in a multi-dimensional list/array/matrix. Does it exist?.
I wrote this:
where
pSearch: proc for searching
A: list, array, vector or matrix
Examples with a list:
> ss := [[1, 2, 3], [2, 3, 5], [2, 4, 5]]
> j:=1:
># search first index i such that ss[i, j]=2
> nPos :=
# search next index i such that ss[i, j]=2
> nPos :=
But I am not sure if this procedure is efficient for large lists or arrays and I would suggest (if this tool does not exist yet) a more efficient one.
César Lozada
ok i think they are called "nested" sequences, i will normally do something like:
seq(seq(seq(F(i,j,k),i=1..Ri),j=1..Rj),k=1..Rk)
but in this circumstance the number of variables and the ranges for each are specified by the user in combo boxes and text windows etc, so i need to use foldl. The below doesn't work, so i was looking for a hint on what i am doing wrong:
This guy thinks the Cayley-Dickson Construction cycles back at 1024D? I don't actually use Maple, is he just encountering a precision error?
https://www.mapleprimes.com/posts/124913-Visualization-Of-The-CayleyDickson
quote in question
I found no new mathematics after 1024 because higher hypercomplex numbers greater than 1024 are cyclic (they repeat all over again).  I do not offer dimensions higher than 256D to the publc Maple Application Center because the mathematics is very slow and time cosuming past 64D.  However, I did keep the code up to 256D in the public Maple Application Center.
I received a program for constructing Cayley-Dickson tables for my own use, but it's actually written in bc (arbitrary precision). I'm assuming Maple supports this to some extent but maybe he's encountering a precision error that looks like it's repeating? I can't verify yet because he's right about the one thing, even a 256 table took DAYS to compute. The snapshots are intriguing too but I'm assuming even a second-long video at low resolution would take forever as well.
But I still have the bc code and constructing Cayley-Dickson tables is only a few lines of codes/conditions, it's one of those 'easy for a computer, impossible for a human' kind of deals. I don't see enough complexity in the code where it would suddenly start cycling. It's kind of important to me because the implications of the Cayley-Dickson Construction going on forever are more exciting in my opinion.
By the way I'm actually personally using the bc generated tables for making music sequences/MIDI. It's not the usual multiplication and such though because that even when normalized would "stick" so to speak? It's a bit of a secret, sorry
I know how to use numapprox to fit polynomial and rational polynomial approximations to trig functions.  I would like to fit a rational expression using numerators and denominators like this:
a*x^(1/3) + b*x^(1/2) + c*x^(2/3) + d*x + e*x^(3/2) + f*x^(2) + g*x^(3)
# About twenty years ago Joe Riel posted
#printing_just_for_fun.mws   by Joe Riel 30-6-‘98
#As part of this he had:
 d_string:="D*e*v*o*u*r*e*r":
#eta:=symb(217):
print(cat(`Does `,d_string,` = `));
eta;
#Is it possible to put the eta symbol on the same line?
#   Yes,  …but without the comma??  And…
 printf("Does %s = %a\n",d_string, eta);
#  does not give the Greek letter eta, but just eta,  while
eta;
print(eta);
#...both give the Greek letter
#  Is it possible to use printf (or similar?) to obtain output
#  of:  Does D*e*v*o*u*r*e*r = h
#  Oops!  In Word the h was a Greek letter eta!
#  ...and lastly, can it be done in Maple 7?
Pretty much the title.
At first I thought something's wrong with my vectors, but even something like <1,1,1>.<2,2,2> produces this error.
I have restart in the very beginning of my worksheet and with(VectorCalculus): right after.
I'm using the 64 bit version of Maple 18 on Windows 10, if this matters.
Say I have an expression like
diff(f(x),x)*cos(f(x));
and I want to evaluate it where the function f(x)=0 (without a priori knowing f(x)). Since cos(0)=1, I expect the answer to be simply diff(f(x),x); in general this won't be identically zero. However, if I try
eval(%,f(x)=0);
it replaces f(x) with zero everywhere, including in the derivative (as expected from the documentation) and returns 0.
So, my question: is there a way to evaluate an expression at a known value of a function (f(x)=0) without knowing the function?
It seems using convert/D manages to solve it, but I imagine there's a better way to do this. I've tried using RootOf(f(x)), but can't seem to make that work.
I'm trying to make a comparison between simulation data from CST and calculations done in MAPLE - the best way to do so is have both plots on excel so the formatting matches. I can export the data from CST as a text file, but am stuck when it comes to getting the data from MAPLE (specifically trying to record kz, dispf, and dispbeamf all together in one text file).
My implicitplot code works (the code for it shown below). Both dispf and dispbeamf are functions of kz.
implicitplot([dispf, dispbeamf], kz = -150 .. 150, f3 = 0.18e11 .. 0.25e11, color = [red, blue], numpoints = 5000)
Any advice would be greatly appreciated.
I want to adjust values in a matrix. In the example matrix you will find some measurement errors (values around -4000 or 1). But these are definitely measurement errors. Is there any possibility to adjust these values to the surrounding values (~1500)...like in an interpolation. Can someone help me how I can do this with maple?
Ps.: the matrix is exported from maple into .xls
Matrix:
O233.xlsx
Thank you very much!
Dear users!
Hope everyone fine with everything. I want to chage the format of x-axis in the attached file. I need the x-axis in degree like (-180^o, -120^o, -60^o, 0 , 60^o, 120^o, 180^o). Also I want the lable on y-axis as:
I am waiting your positive respons.
Help_new.mw
If I try to use unapply on a composition of functions, I seem to get the result in one of two forms:
unapply(f(g(x)),x);
# Result: f@(x -> g(x))
unapply(2*f(g(x)),x);
# Result: x -> 2 f(g(x))
I need the second form (without the @ composition operator): is there any way to instruct Maple to output the first result without the @ sign? Or is there some way to convert the first form to the second form (i.e. x -> f(g(x)))?
I would love to produce a fixed double cone but a movable plane so I could illustrate the various kinds of conic sections which are the intersection of the cone with the plane.  I would think this has been done, but I can't find and haven't been able to make much progress myself.  .......Edgar
I have installed in my UBUNTU 16.04 system matlab 2018a already, I have recently acquired maple 2017.3 (through my university).
Now while trying to install maple in my computer I am at the matlab configuration option, I picked the directory where the matlab installation is situated at, and I get the following error: The directory /home/alon/MATLAB/R2018a/bin/matlab is not writable by the current user
I searched google for this occurrence of error, and found the following suggestion: https://askubuntu.com/questions/265381/how-to-make-a-directory-permanently-writable
the first answer suggests to write in the terminal the following line: sudo chmod 775 /home/alon/MATLAB/R2018a/bin/matlab
which I did but I still get after executing this line in the terminal the above error; what else can I do to fix this problem?
Hi everyone.
I am trying to build a package in Maple out of a bunch of procedures that I have. To create the procedures, I write them on a Vim editor, than copy and paste into the Maple worksheet to test. In this way, it works (I end the procedure with ; and then I see all the text in blue and I afterwords test it).
I then gathered these procedures to a module, option package, and I do the same: edit on Vim, copy paste it to Maple worksheet and press enter to see a blue message "module() ... end module" in blue, and then I start playing.
However, I decided to add some more procedures to the module that was working. I have a new procedure that works (meaning when I copy to the worksheet it gives the blue text and I can call normally), but when I copy the contents of this new procedure inside the package, with all the others, and I copy everything to the worksheet, the package now fails to work. It gives a message "Error," in pink, no more text, and that is it. Does this sort of error sound familiar to anyone? Thanks in Advance,
Marcelo
I wanted to make a 3d plot with lines linking points, but I am struggling with it
(I couldn't find anything in the plot3d documentation, so it might not be supported, which would be odd as its such a normal thing to want to do)
I have tried with no success:
plot3d([1, 2, 3], [4, 5, 6]);
plot3d(Matrix(2, 3, {(1, 1) = 1, (1, 2) = 2, (1, 3) = 3, (2, 1) = 4, (2, 2) = 5, (2, 3) = 6}))
Any thoughts?
First 879 880 881 882 883 884 885 Last Page 881 of 2459
