This is my first post here, and any help is really appreciated.
I have two complex polynomials
f(w)= w^8+w^6+4*w^4+w^2+1 , and
g(w)= w^16+2*w^14+9*w^12-2*w^10+44*w^8-2*w^6+9*w^4+2*w^2+1 .
I want to plot the roots of f in blue, roots of g in red and a unit circle in black at the same picture.
Thanks in advance for your help.
There are two questions:
1. I have an ODE system solved numerically, but it has a singularity at Pi because of cot(x). I need to know whether the solution goes to infinity at this point or it has some value. I tried the limit operation, but it doesn't seem to work. Am I doing it wrong or is there no way to do such thing? See details in file 1 1.mw.
I know I can evaluate the function at point Pi - 10^(-10), Pi - 10^(-9) etc, and it has really close values there, but still I doubt it is a strong proof of the function not going to infinity.
Also the following "technical" question: why is Maple building the plot from 0 to Pi (or from -Pi to Pi symmetrically), even if I enter different range? For cot(x) it builds the plot normally, not just from -Pi to Pi, althouth cot(x) has singularity at Pi AND at 0, but my plots are somehow broken off at Pi.
2. I have 2 similar procedures and I need the plots of both of them. But first plot is built correctly and for the second there appears an error: "Error, (in plot) procedure expected, as range contains no plotting variable". I tried entering other ranges, including very small ones, but it didn't help. It calculates the values at points of range nicely though. See details in file 2 2.mw.
And one more time "technical" question about warnings in the procedures. I tried typing "local" or "global" before variables, but Maple gives me an error. How do I get rid of the warnings correctly?
I know it is difficult to see into those problems, but I strongly look for help! Thank you for your time!
As the title states, i want to have an automated logging occur of the details of the executions, including code content, origin worksheet,date the execution was attempted. I think i know a way to do it but id prefer if there was an option that already exists in the maple interface
My goal us to show that equation (11) is exactly (q^n-1)/(q-1)*y^(n-1),   a  simplification must be introduced and so that we obtain the necessary (q^n-1)/(q-1)*y^(n-1).
Note that the operators are not commutative.
Question.mw
Than you for your help
In previous version of Maple (e.g. Maple 2015) I was able to copy
"2D Output" equations directly from a Maple Worksheet to MS Word.
These equations could be edited for fine element placement. In the 2017.3 version
it is does not seem to be possible anymore. When I copy the "2D Output" the image
is not copied only the text.
Is this a feature that was removed or a configuration problem ?
LL
Coding_Equilibria.mw
Hi, the coding answer I generate from maple is different from the real answer. Any solution?
The solution should be S=pi/mu*(mu-P*pi*mu+phi/mu+phi+vartheta) and V=pi/mu*(P*pi*mu+vartheta/mu+phi+vartheta)
interface(imaginaryunit = j);
I
lambda := k*tau*(C*Upsilon+I)/N;
eqn1 := (1-p)*Pi+phi*V+delta*R-(mu+lambda+vartheta)*S;
(1-p)*Pi+phi*V+delta*R-(mu+k*tau*(C*Upsilon+I)/N+vartheta)*S
p*Pi+vartheta*S-(epsilon*k*tau*(C*Upsilon+I)/N+mu+phi)*V
rho*k*tau*(C*Upsilon+I)*S/N+rho*epsilon*k*tau*(C*Upsilon+I)*V/N+(1-q)*eta*I-(mu+beta+chi)*C
(1-rho)*k*tau*(C*Upsilon+I)*S/N+(1-rho)*epsilon*k*tau*(C*Upsilon+I)*V/N+chi*C-(mu+alpha+eta)*I
beta*C+q*eta*I-(mu+delta)*R
{C = -RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*(eta*q*rho+alpha*rho-eta*q+mu*rho+eta)/((Upsilon*eta*q*rho+Upsilon*alpha*rho-Upsilon*eta*q+Upsilon*mu*rho+Upsilon*eta-beta*rho-mu*rho+beta+chi+mu)*tau*k), I = RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*(beta*rho+mu*rho-beta-chi-mu)/((Upsilon*eta*q*rho+Upsilon*alpha*rho-Upsilon*eta*q+Upsilon*mu*rho+Upsilon*eta-beta*rho-mu*rho+beta+chi+mu)*tau*k), R = -RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*(-eta*mu*q*rho+alpha*beta*rho+beta*mu*rho+chi*eta*q+eta*mu*q+beta*eta)/((Upsilon*eta*q*rho+Upsilon*alpha*rho-Upsilon*eta*q+Upsilon*mu*rho+Upsilon*eta-beta*rho-mu*rho+beta+chi+mu)*tau*k*(mu+delta)), S = (-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*chi*epsilon*eta*q-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*alpha*beta*epsilon-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*alpha*chi*epsilon-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*alpha*epsilon*mu-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*beta*epsilon*eta-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*beta*epsilon*mu-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*chi*epsilon*mu-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*epsilon*eta*mu+N*beta*mu*phi+N*chi*mu*phi-tau*p*k*eta*epsilon*Upsilon*Pi+Pi*beta*epsilon*k*p*rho*tau+Pi*epsilon*k*mu*p*rho*tau-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*epsilon*mu^2+N*alpha*mu^2+N*eta*mu^2+N*alpha*beta*mu+N*alpha*beta*phi+N*alpha*chi*mu+N*alpha*chi*phi+N*alpha*mu*phi+N*beta*eta*mu+N*beta*eta*phi+N*eta*mu*phi+N*beta*mu^2+N*chi*mu^2+N*mu^2*phi-Pi*Upsilon*epsilon*eta*k*p*q*rho*tau-Pi*Upsilon*alpha*epsilon*k*p*rho*tau+tau*q*p*k*eta*epsilon*Upsilon*Pi-Pi*Upsilon*epsilon*k*mu*p*rho*tau+N*chi*eta*mu*q+N*chi*eta*phi*q-Pi*beta*epsilon*k*p*tau-Pi*chi*epsilon*k*p*tau-Pi*epsilon*k*mu*p*tau+N*mu^3)*N/(k*tau*(-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*Upsilon*alpha*epsilon*rho+RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*Upsilon*epsilon*eta*q-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*Upsilon*epsilon*mu*rho-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*Upsilon*epsilon*eta*q*rho-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*Upsilon*epsilon*eta+RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*beta*epsilon*rho+RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*epsilon*mu*rho+N*Upsilon*epsilon*eta*q*rho*vartheta-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*beta*epsilon-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*chi*epsilon-RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)*epsilon*mu-N*beta*epsilon*rho*vartheta-N*epsilon*mu*rho*vartheta+N*Upsilon*mu^2*rho+N*Upsilon*eta*mu+phi*eta*Upsilon*N+vartheta*eta*epsilon*Upsilon*N-vartheta*q*eta*epsilon*Upsilon*N-q*phi*eta*Upsilon*N+N*beta*epsilon*vartheta-N*beta*mu*rho-N*beta*phi*rho+N*chi*epsilon*vartheta+N*epsilon*mu*vartheta-N*mu*phi*rho+N*Upsilon*alpha*mu*rho+N*Upsilon*alpha*phi*rho-N*Upsilon*eta*mu*q+N*Upsilon*mu*phi*rho+N*Upsilon*alpha*epsilon*rho*vartheta+N*Upsilon*epsilon*mu*rho*vartheta+N*Upsilon*eta*mu*q*rho+N*Upsilon*eta*phi*q*rho+N*mu^2+N*chi*mu+N*chi*phi+N*mu*phi+N*beta*mu-N*mu^2*rho+N*beta*phi)), V = (Pi*Upsilon*eta*k*p*q*rho*tau+Pi*Upsilon*alpha*k*p*rho*tau-Pi*Upsilon*eta*k*p*q*tau+Pi*Upsilon*k*mu*p*rho*tau+Pi*Upsilon*eta*k*p*tau-Pi*beta*k*p*rho*tau-Pi*k*mu*p*rho*tau+N*chi*eta*q*vartheta+Pi*beta*k*p*tau+Pi*chi*k*p*tau+Pi*k*mu*p*tau+N*alpha*beta*vartheta+N*alpha*chi*vartheta+N*alpha*mu*vartheta+N*beta*eta*vartheta+N*beta*mu*vartheta+N*chi*mu*vartheta+N*eta*mu*vartheta+N*mu^2*vartheta)*N/(k*tau*(Upsilon*eta*q*rho+Upsilon*alpha*rho-Upsilon*eta*q+Upsilon*mu*rho+Upsilon*eta-beta*rho-mu*rho+beta+chi+mu)*(N*epsilon*vartheta+mu*N+phi*N-epsilon*RootOf(-N*Pi*Upsilon*k*mu^3*p*rho*tau-N*Pi*epsilon*k*mu^3*p*rho*tau+N*Pi*Upsilon*alpha*k*mu^2*rho*tau+N*Pi*beta*delta*epsilon*k*mu*p*tau-N*Pi*beta*delta*epsilon*k*rho*tau*vartheta+N*Pi*beta*delta*k*mu*p*rho*tau-N*Pi*beta*epsilon*k*mu*rho*tau*vartheta+N*Pi*chi*delta*epsilon*k*mu*p*tau-N*Pi*delta*epsilon*k*mu*rho*tau*vartheta-N^2*mu^5+(-Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau-Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau+N*delta*epsilon*eta*mu*q*rho*vartheta-Pi*Upsilon*alpha*delta*epsilon*k*rho*tau-Pi*Upsilon*alpha*epsilon*k*mu*rho*tau+Pi*Upsilon*delta*epsilon*eta*k*q*tau-Pi*Upsilon*delta*epsilon*k*mu*rho*tau+Pi*Upsilon*epsilon*eta*k*mu*q*tau-Pi*Upsilon*epsilon*k*mu^2*rho*tau-N*alpha*beta*delta*epsilon*rho*vartheta-N*beta*delta*epsilon*mu*rho*vartheta+N*chi*delta*epsilon*eta*mu*q+N*chi*epsilon*eta*mu^2*q+N*chi*epsilon*eta*mu*q*vartheta-N*delta*epsilon*eta*mu*q*vartheta+N*delta*eta*mu^2*q*rho+N*delta*eta*mu*phi*q*rho-Pi*Upsilon*delta*epsilon*eta*k*tau-Pi*Upsilon*epsilon*eta*k*mu*tau+Pi*beta*delta*epsilon*k*rho*tau+Pi*beta*epsilon*k*mu*rho*tau+Pi*delta*epsilon*k*mu*rho*tau+Pi*epsilon*k*mu^2*rho*tau+N*alpha*beta*delta*epsilon*mu+N*alpha*beta*delta*epsilon*vartheta-N*alpha*beta*delta*mu*rho-N*alpha*beta*delta*phi*rho+N*alpha*beta*epsilon*mu^2+N*alpha*beta*epsilon*mu*vartheta+N*alpha*chi*delta*epsilon*mu+N*alpha*chi*delta*epsilon*vartheta+N*alpha*chi*epsilon*mu^2+N*alpha*chi*epsilon*mu*vartheta+N*alpha*delta*epsilon*mu^2+N*alpha*delta*epsilon*mu*vartheta+N*alpha*epsilon*mu^3+N*alpha*epsilon*mu^2*vartheta+N*beta*delta*epsilon*eta*mu+N*beta*delta*epsilon*mu^2+N*beta*delta*epsilon*mu*vartheta-N*beta*delta*mu^2*rho-N*beta*delta*mu*phi*rho+N*beta*epsilon*eta*mu^2+N*beta*epsilon*eta*mu*vartheta+N*beta*epsilon*mu^3+N*beta*epsilon*mu^2*vartheta+N*chi*delta*epsilon*mu^2+N*chi*delta*epsilon*mu*vartheta+N*chi*epsilon*mu^3+N*chi*epsilon*mu^2*vartheta+N*chi*eta*mu^2*q+N*chi*eta*mu*phi*q+N*delta*epsilon*eta*mu^2+N*delta*epsilon*eta*mu*vartheta+N*delta*epsilon*mu^3+N*delta*epsilon*mu^2*vartheta-N*delta*eta*mu^2*q-N*delta*eta*mu*phi*q+N*epsilon*eta*mu^3+N*epsilon*eta*mu^2*vartheta+N*epsilon*mu^4+N*epsilon*mu^3*vartheta-Pi*beta*delta*epsilon*k*tau-Pi*beta*epsilon*k*mu*tau-Pi*chi*delta*epsilon*k*tau-Pi*chi*epsilon*k*mu*tau-Pi*delta*epsilon*k*mu*tau-Pi*epsilon*k*mu^2*tau+N*alpha*beta*delta*mu+N*alpha*beta*delta*phi+N*alpha*beta*mu^2+N*alpha*beta*mu*phi+N*alpha*chi*delta*mu+N*alpha*chi*delta*phi+N*alpha*chi*mu^2+N*alpha*chi*mu*phi+N*alpha*delta*mu^2+N*alpha*delta*mu*phi+N*alpha*mu^3+N*alpha*mu^2*phi+N*beta*delta*mu^2+N*beta*delta*mu*phi+N*beta*eta*mu^2+N*beta*eta*mu*phi+N*beta*mu^3+N*beta*mu^2*phi+N*chi*delta*mu^2+N*chi*delta*mu*phi+N*chi*mu^3+N*chi*mu^2*phi+N*delta*eta*mu^2+N*delta*eta*mu*phi+N*delta*mu^3+N*delta*mu^2*phi+N*eta*mu^3+N*eta*mu^2*phi+N*mu^4+N*mu^3*phi)*_Z+(-delta*epsilon*eta*mu*q*rho+alpha*beta*delta*epsilon*rho+beta*delta*epsilon*mu*rho-chi*epsilon*eta*mu*q+delta*epsilon*eta*mu*q-alpha*beta*delta*epsilon-alpha*beta*epsilon*mu-alpha*chi*delta*epsilon-alpha*chi*epsilon*mu-alpha*delta*epsilon*mu-alpha*epsilon*mu^2-beta*delta*epsilon*mu-beta*epsilon*eta*mu-beta*epsilon*mu^2-chi*delta*epsilon*mu-chi*epsilon*mu^2-delta*epsilon*eta*mu-delta*epsilon*mu^2-epsilon*eta*mu^2-epsilon*mu^3)*_Z^2+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*mu*p*rho*tau-N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*epsilon*eta*k*q*rho*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*q*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*q*rho*tau*vartheta+N*Pi*Upsilon*delta*k*mu^2*rho*tau-N*Pi*Upsilon*eta*k*mu^2*p*tau-N*Pi*Upsilon*eta*k*mu^2*q*tau+N*Pi*Upsilon*k*mu^2*phi*rho*tau+N*Pi*beta*epsilon*k*mu^2*p*tau+N*Pi*beta*k*mu^2*p*rho*tau+N*Pi*chi*epsilon*k*mu^2*p*tau+N*Pi*delta*epsilon*k*mu^2*p*tau+N*Pi*delta*k*mu^2*p*rho*tau-N*Pi*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*tau+N*Pi*Upsilon*delta*eta*k*phi*tau+N*Pi*Upsilon*eta*k*mu*phi*tau+N*Pi*beta*delta*epsilon*k*tau*vartheta-N*Pi*beta*delta*k*mu*p*tau-N*Pi*beta*delta*k*mu*rho*tau-N*Pi*beta*delta*k*phi*rho*tau+N*Pi*beta*epsilon*k*mu*tau*vartheta-N*Pi*beta*k*mu*phi*rho*tau+N*Pi*chi*delta*epsilon*k*tau*vartheta-N*Pi*chi*delta*k*mu*p*tau+N*Pi*chi*epsilon*k*mu*tau*vartheta+N*Pi*delta*epsilon*k*mu*tau*vartheta-N*Pi*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*k*mu^3*rho*tau+N*Pi*epsilon*k*mu^3*p*tau+N*Pi*k*mu^3*p*rho*tau+N*Pi*Upsilon*eta*k*mu^2*tau-N*Pi*beta*k*mu^2*p*tau-N*Pi*beta*k*mu^2*rho*tau-N*Pi*chi*k*mu^2*p*tau-N*Pi*delta*k*mu^2*p*tau-N*Pi*delta*k*mu^2*rho*tau+N*Pi*epsilon*k*mu^2*tau*vartheta-N*Pi*k*mu^2*phi*rho*tau+N*Pi*beta*delta*k*mu*tau+N*Pi*beta*delta*k*phi*tau+N*Pi*beta*k*mu*phi*tau+N*Pi*chi*delta*k*mu*tau+N*Pi*chi*delta*k*phi*tau+N*Pi*chi*k*mu*phi*tau+N*Pi*delta*k*mu*phi*tau-N^2*chi*delta*eta*mu*phi*q-N^2*chi*delta*eta*mu*q*vartheta-N*Pi*Upsilon*delta*epsilon*eta*k*q*tau*vartheta+N*Pi*Upsilon*delta*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*eta*k*mu*p*q*tau+N*Pi*Upsilon*delta*eta*k*mu*q*rho*tau+N*Pi*Upsilon*delta*eta*k*phi*q*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu*q*tau*vartheta+N*Pi*Upsilon*eta*k*mu*phi*q*rho*tau-N*Pi*beta*delta*epsilon*k*mu*p*rho*tau-N^2*alpha*beta*mu^3-N^2*alpha*chi*mu^3-N^2*alpha*delta*mu^3-N^2*alpha*mu^3*phi-N^2*alpha*mu^3*vartheta-N^2*beta*delta*mu^3-N^2*beta*eta*mu^3-N^2*beta*mu^3*phi-N^2*beta*mu^3*vartheta-N^2*chi*delta*mu^3-N^2*chi*mu^3*phi-N^2*chi*mu^3*vartheta-N^2*delta*eta*mu^3-N^2*delta*mu^3*phi-N^2*delta*mu^3*vartheta-N^2*eta*mu^3*phi-N^2*eta*mu^3*vartheta+N*Pi*Upsilon*alpha*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*delta*epsilon*k*mu^2*p*rho*tau-N*Pi*Upsilon*epsilon*eta*k*mu^2*p*q*tau-N*Pi*Upsilon*eta*k*mu^2*p*q*rho*tau+N*Pi*Upsilon*alpha*delta*epsilon*k*rho*tau*vartheta-N*Pi*Upsilon*alpha*delta*k*mu*p*rho*tau+N*Pi*Upsilon*alpha*epsilon*k*mu*rho*tau*vartheta+N*Pi*Upsilon*delta*epsilon*eta*k*mu*p*tau-N^2*chi*delta*eta*mu^2*q-N^2*chi*eta*mu^2*phi*q-N^2*chi*eta*mu^2*q*vartheta-N^2*alpha*beta*delta*mu*phi-N^2*alpha*beta*delta*mu*vartheta-N^2*alpha*chi*delta*mu*phi-N^2*alpha*chi*delta*mu*vartheta-N^2*beta*delta*eta*mu*phi-N^2*beta*delta*eta*mu*vartheta-N*Pi*k*mu^3*p*tau-N*Pi*k*mu^3*rho*tau+N*Pi*beta*k*mu^2*tau+N*Pi*chi*k*mu^2*tau+N*Pi*delta*k*mu^2*tau+N*Pi*k*mu^2*phi*tau-N^2*beta*mu^4-N^2*eta*mu^4-N^2*chi*mu^4-N^2*mu^4*vartheta-N^2*alpha*mu^4-N^2*mu^4*phi-N^2*delta*mu^4-N^2*chi*eta*mu^3*q-N^2*alpha*beta*delta*mu^2-N^2*alpha*beta*mu^2*phi-N^2*alpha*beta*mu^2*vartheta-N^2*alpha*chi*delta*mu^2-N^2*alpha*chi*mu^2*phi-N^2*alpha*chi*mu^2*vartheta-N^2*alpha*delta*mu^2*phi-N^2*alpha*delta*mu^2*vartheta-N^2*beta*delta*eta*mu^2-N^2*beta*delta*mu^2*phi-N^2*beta*delta*mu^2*vartheta-N^2*beta*eta*mu^2*phi-N^2*beta*eta*mu^2*vartheta-N^2*chi*delta*mu^2*phi-N^2*chi*delta*mu^2*vartheta-N^2*delta*eta*mu^2*phi-N^2*delta*eta*mu^2*vartheta+N*Pi*k*mu^3*tau+N*Pi*Upsilon*epsilon*k*mu^3*p*rho*tau-N*Pi*Upsilon*alpha*k*mu^2*p*rho*tau-N*Pi*Upsilon*delta*k*mu^2*p*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu^2*p*tau+N*Pi*Upsilon*epsilon*k*mu^2*rho*tau*vartheta+N*Pi*Upsilon*eta*k*mu^2*p*q*tau+N*Pi*Upsilon*eta*k*mu^2*q*rho*tau-N*Pi*beta*epsilon*k*mu^2*p*rho*tau-N*Pi*delta*epsilon*k*mu^2*p*rho*tau+N*Pi*Upsilon*alpha*delta*k*mu*rho*tau+N*Pi*Upsilon*alpha*delta*k*phi*rho*tau+N*Pi*Upsilon*alpha*k*mu*phi*rho*tau+N*Pi*Upsilon*delta*epsilon*eta*k*tau*vartheta-N*Pi*Upsilon*delta*eta*k*mu*p*tau-N*Pi*Upsilon*delta*eta*k*mu*q*tau-N*Pi*Upsilon*delta*eta*k*phi*q*tau+N*Pi*Upsilon*delta*k*mu*phi*rho*tau+N*Pi*Upsilon*epsilon*eta*k*mu*tau*vartheta-N*Pi*Upsilon*eta*k*mu*phi*q*tau)))}, {C = 0, I = 0, R = 0, S = -Pi*(mu*p-mu-phi)/((mu+phi+vartheta)*mu), V = (mu*p+vartheta)*Pi/((mu+phi+vartheta)*mu)}
Download Coding_Equilibria.m
Greeting
can u help me how to solve this problem using the galerkin finite element method with graphs.  I attachment below.
IBC
Please seethe attachment. Every thing is on it. Its about implicit pde.
Dear Sir
I apologize, because I do not usually make manipulations in the System (Mac OsX)
While typing  cat( kernelopts( mapledir ), "/lib" ), I found the path to my Maple system library folder.
And by using the Unix terminal on my eMac, I see that this folder does not include a (old) file Physics2017.mla, but the following ".mla" files: MTM.mla, MathematicalFunctions.mla, maple.mla, update.mla.
For the moment, I do not dare copy the new Physics2017.mla in the library folder.
Is there not a possibility of conflicting some ".mla" files, e.g.  "update.mla" ?
I am trying to implement an example from page 106 in the book Essential Maple 7 in hope that I can understand a problem related to the "solve" function. The example is:
f[1] := c*x[1]^2*x[2]+9*x[1]^2+2*x[1]*x[2]+5*x[1]+x[2]-3;
f[2] := 2*x[1]^3*x[2]+6*x[1]^3-2*x[1]^2-x[1]*x[2]-3*x[1]-x[2]+3;
f[3] := x[1]^3*x[2]+3*x[1]^3+x[1]^2*x[2]+2*x[1]^2;
with(Groebner)
infolevel[primpart]:=5
gb:=gbasis([f[1],f[2],f[3]],tdeg(x[1],x[2])):
According to the book, I should receive an output that tell me what "content" has been removed. This will tell me what values of the parameter c have special solutions.
If I enter this in my version of Maple 2015 with no changes, I receive no output. This is not so surprising since the example was written for Maple 7. So I changed infolevel[primpart] to infolevel[all]. With this change, I receive some information, but it is rather general and not what I want.
Does anyone know if there is some other way to do this example in Maple 2015?
Thanks for your help.
I have an equation which i want solve it with DTM, but there are two problems:
1- How do I write a Dirak Delta function in maple for this equation?
2- I used pade approximation due to initial condition. Then how many sentenceses should be used to achieve the correct answer?
in this equation there are some constant parameter.
M:=0;A:=1;Phi:=0;r:=0.5;lambda:=0;phi[1] := 1.;  beta := .67;   phi[1] := 1.
then:
F[0]:=0;F[1]:=lambda;F[2]:=a/2;
That's my pleasure If there is somebody help me to code and solve this problem.
Thanks for every one very very much.
using the package geom3d
if I define two planes and attempt to find angle between them.
p1: 12-6*x-6*y-4*z = 0
p2: 3*x+3*y+2*z-6=0
and use the command FindAngle(p1,p2) then it returns arccos(2/11) any way to force maple to return a result in degree?
Hello ,
I need your helps to solve this integrale
int((x-a)^m/x, x)
int((x-a)^m/x, x)
Download Intégrale.mw
Good day, I have an assignment in which I'm required to plot the solid that results from the cone (x^2+y^2-z^2=0), limited by the planes z=0 and x+2z=3. So far I've been trying to use plot3d and implicitplot3d, to no avail: the parametric expression from plot3d returns something quite different from the intented, and implicitplot3d won't allow the use of variable parameters.
Any ideas on how to solve this?
Hi everyone, I've just learnt some basic tools and I need your help.
First 926 927 928 929 930 931 932 Last Page 928 of 2434
