Hello everbody!
Ive got a question about my dutch math book, and why it thinks its answer is better than mine.
It is question c. the integral that is covers the x value from 4 to 6 for f(x).
I would think that means the integral of 1 to 6 - the integral of 1-4, and thus 4-7=-3. Now i dont know how they thought about getting a smaller area under the function with a larger domain of x, so i am not sure what is going on. Im not even sure if what they ask is possible. The book gave 3 as an answer. My answer was -3. Looking at it, and thinking about it. It may not even be possible.
Any way, that is the question.
Picture 2 shows the rules, picture 3 shows the answers of the book.
Greetings,
The function
Opdracht 2
a.
b.
-7
c.
4-7
-3
d.
8*5
40
e.
int(5, x = 1 .. 6)+4
29
f.
3*4-6*5
-18
Download Question_for_maple_primes_5.mw
Let f(x) = x3+9x2-9x-1/x4+1
Find the equations of the 4 lines having slope 0.5 that are tangent to the graph of 𝑓(𝑥) (first find the values of 𝑥 where 𝑓 ′(𝑥) = 0.5).
Hello there,
I'm currently working on a school-related assignment, where I have to put two functions equal each other to find their crossing point. My issue is, that these two functions are waves, and continiue into infinite.
If I put them equal as this, my document crashes:
f(x) = g(x)
My question is then, if I can put some requirement to Maple, so it only calculates from significant X-intervals
elctroWav.mw have the equation 1 :
eq1 := 2*m*(E + e0^2/(rb*rho))*g(rho, t)*(-rb*rho + R)/(h^2*R) + R*(diff(g(rho, t), rho, rho)*(-rb*rho + R)/R - 2*diff(g(rho, t), rho)*rb/R)/(rb^3*rho) - diff(g(rho, t), t, t)*(-rb*rho + R)/(a^2*c^2*R) = 0;
with iv1:
iv1 := D[1](g)(0, 0) - g(0, 0)*rb/R = rb*R, g(1, 0)*(R - rb)/R = 0, D[2](g)(rb, 0) = a*c;
As in maple document electroWav.mw
The issue is that there is an unsolved part with RootOf how can I rezolve it?
-R*h^2*RootOf(AiryBi(-(R*_Z^3*h^2 + 2*e0^2*m*rb^2)/(_Z^2*R*h^2)))^3
Please advice...
restart;In this code "add" is a trouble.
A := Matrix([[1, 2, 1, 3], [1, 1, 2, 1], [1, -2, 5, -11]]);
cs := LinearAlgebra:-ColumnSpace(A);
cnames := [seq(c || j, j = 1 .. numelems(cs))];
cvals := seq(solve([entries(A[() .. (), k] -~ add(`*`~(cnames, cs)), 'nolist')], cnames)[], k = 1 .. op([1, 2], A));
seq(add*rhs~(cvals[k]) *~ cs, k = 1 .. op([1, 2], A));
add does not play its role. Why. Thank you.
Is there an easy command to generate the edge sets of of all connected graphs for a given number of vertices? Ideally, I'd like to output to be of the form (e.g.)
G={{1,2},{2,3},{1,3},{1,4}};
text text text text;
text1 text1;
so that I can easily copy it into another program to be read. Or, is there a way that I can produce an output like the following (e.g. for n=3)
G={{1,2},{2,3}};
text1 text1;
G={{1,2},{2,3},{1,3}};
text1 text1;
and have it export to a text file?
The timelimit command of Maple can be used to do a computation if it uses less than a given amount of time, otherwise generating an error message that can be cought by try ... catch. Now my question is that there exists any similar command, but with a limitation on memory usage, not the time usage. I don't mean what datalimit in kernelopts can does, because I am not going to limit the memory usage of the whole Maple session, but just a command which may be used inside a larger procedure etc.
Hello.
I wrote some codes for solving equations in a special way. My codes work very fine when my differential system has only one equation.
But when I extend it to a system that has two or more equations, sometimes does not work and I face with error. However, in one system (2 eq) it also works. But it is only a special case. If you want, I can upload it here as well.
I am attaching the maple file containing the error. You can observe it.
By examining many cases, I think that maybe the root of the problem is that I must change my codes in a way that they are for a "system". Indeed, instead of writing codes for each differential equation, I must define a system and write these codes for a system containing some differential equations.
However, I think that the boundary conditions sometimes also may be the root of the error.
I change the attached codes for this purpose, but I failed. I prefer to not present my wrong codes for this purpose.
If it is possible, help me to change my codes.
Thanks a lot.
ERROR.mw
Solve equation :x4-x3-3x2-x+12=0
I am running Maple 2021 and have this plot in Differential Equation. However, It will not display the Graph.
The  general solution : y = 1.42
                  "exp(-0.125*t)*sin(1.41*t)"
NULL;
soln := y(t) = 1.42*exp(-0.125*t)*sin(1.41*t);
         soln := y(t) = 1.42 exp(-0.125 t) sin(1.41 t)
(b) Plot y vs. t  and y' vs. t on the same axes.
Let y and dy be the right side and derivative , respectively, of soln. Graph y and dy together
So i have defined some variables example:
xb=1000
yb=2500
db=5321
eb=521
and i want to solve the following symbolically without maple taking into account the variables:
eb=ab*yb*db*x
How do I force Maple to show the equation for the expression symbolically without unassigning the variables? I was thinking about local variables, but that would make the worksheet messy as the variables are used in other calculations.
how to use semilogplot here
plots[odeplot](res1, [[t, N(t)]], 0.1e-2 .. 1000, axes = boxed, tickmarks = [3, 2], color = red, thickness = 1, linestyle = solid, titlefont = [Helvetica, roman, 18], labeldirections = [horizontal, vertical], labelfont = [Helvetica, roman, 24])
I try to find kernel and image of a application whose i know the matrix.
with(LinearAlgebra);
A := Matrix([[1, 1, 1, -1], [-1, 1, -1, -1], [1, -1, -1, -1], [-1, -1, 1, 3]]);
k := op(NullSpace(A));#kernel
MatrixVectorMultiply(A, k);#check
C := op(ColumnSpace(A));
X := <x, y, z, t>;
F := MatrixVectorMultiply(A, X) - a*C[1] - b*C[2] - c*C[2];
G := op(convert(F, list));
solve({seq(G[i] = 0, i = 1 .. 4)}, {a, b, c}); why there is no solution ? Thank you.
How to fprintf say a plot into a docx file in maplesoft
kind help
I'm solving a set of non-linear equations:
eqn1 := W__1 + W__2 + W__3 + W__4 = 4;
eqn2 := W__1*zeta__1 + W__2*zeta__2 + W__3*zeta__3 + W__4*zeta__4 = 0;
eqn2 := W__1 zeta__1 + W__2 zeta__2 + W__3 zeta__3 + W__4 zeta__4 =
eqn3 := W__1*zeta__1^2 + W__2*zeta__2^2 + W__3*zeta__3^2 + W__4*zeta__4^2 = 2/3;
                         2               2               2
     eqn3 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
                      2   2
        + W__4 zeta__4  = -
eqn4 := W__1*zeta__1^3 + W__2*zeta__2^3 + W__3*zeta__3^3 + W__4*zeta__4^3 = 0;
                         3               3               3
     eqn4 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
        + W__4 zeta__4  = 0
eqn5 := W__1*zeta__1^4 + W__2*zeta__2^4 + W__3*zeta__3^4 + W__4*zeta__4^4 = 2/5;
                         4               4               4
     eqn5 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
                      4   2
        + W__4 zeta__4  = -
                          5
eqn6 := W__1*zeta__1^5 + W__2*zeta__2^5 + W__3*zeta__3^5 + W__4*zeta__4^5 = 0;
                         5               5               5
     eqn6 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
                      5
        + W__4 zeta__4  = 0
eqn7 := W__1*zeta__1^6 + W__2*zeta__2^6 + W__3*zeta__3^6 + W__4*zeta__4^6 = 2/7;
                         6               6               6
     eqn7 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
                      6   2
        + W__4 zeta__4  = -
                          7
eqn8 := W__1*zeta__1^7 + W__2*zeta__2^7 + W__3*zeta__3^7 + W__4*zeta__4^7 = 0;
                         7               7               7
     eqn8 := W__1 zeta__1  + W__2 zeta__2  + W__3 zeta__3
                      7
        + W__4 zeta__4  = 0
solve({eqn1, eqn2, eqn3, eqn4, eqn5, eqn6, eqn7}, {W__1, W__2, W__3, W__4, zeta__1, zeta__2, zeta__3, zeta__4});
However, the result looks like this:
How should I obtain numerical values for W1,W2,W3,W4,zeta1,zeta2,zeta3,zeta4 ?
First 369 370 371 372 373 374 375 Last Page 371 of 2429
