Maple function code:
GetAngle := proc(opp, hyp)
local theta;
theta = arcsin(opp/hyp);
evalf(180/Pi*theta);
GetAngle(4,5)
                       57.29577950 theta
Matlab code:
function [outputArg1,outputArg2] = GetAngle(opp,hyp)
    theta = asin(opp/hyp);
    outputArg1 = 180/pi*theta;
end
> GetAngle(4,5)
ans =
   53.1301
Ditto same code from Maple programming guide 2017:
Why is there a difference in the answer, am I coding it wrong? I mean any syntax errors that I am not following?
I need find CPU time for a set of mathematical calculations,  what is the best method in maple 18?
Dear all!
I am facing problem to find the solution of system of linear equations as attached for different values of alpha, please the see the attachment and fix my problem
Equations.mw
Hi there,
I know for a given 2x2 system of differential equations, it is possible for maple to plot a phase portrait on x-y plane (or a graph with directions and arrows).And this is also possible in a 3x3 system by choosing 2 variables / the plane of projection by including the code scene=[x(t),y(t)] (on x-y plane) .
My question is:
given a system of 3x3 differential equations,like
dx/dt = f(x(t),y(t),z(t))
dy/dt = g(x(t),y(t),z(t))
dz/dt = h(x(t),y(t),z(t)),
how could I produce a 3D vector field of the system? (with arrows)
Good day!
I am working to solve a double series (LP  minimization) problem of the form
z = add(add(x[i,j]*y[i,j]*z[j], j=1..6), i=1..3).
However, this returns a set [ ].
Since LPSolve does not operate on a set (removing the brackets manually will enable LPSolve to obtain the solution), can anyone suggest what is wrong with the structure of this z-equation? x, y are matrices and z is a column vector.
If I insert a hyperlink to a website, it works fine when I'm in Maple, but when I export my Maple to pdf, the hyperlink is not clickable anymore.
I've tried using both Windows' "Microsoft Print to PDF", Maple's own "Export to PDF", "cutepdf" as well as MacOS "Save to PDF". Is there a way of doing this?
Best wishes
Hey any one can help? I calculated the characteristical Polynom of my Matrix M:
-(lambda-2)^2*(544-lambda^9-328*lambda^7-16*cos(x-y)+6*cos(x-y)*lambda+6*cos(x+y)*lambda-408*cos(y)*lambda^2-408*cos(x)*lambda^2+540*cos(y)*lambda+540*cos(x)*lambda-28*cos(y)*lambda^4-28*cos(x)*lambda^4+152*cos(y)*lambda^3+152*cos(x)*lambda^3+2*cos(y)*lambda^5+2*cos(x)*lambda^5-256*cos(y)+17232*lambda^2-256*cos(x)-7852*lambda^5+17768*lambda^4+2088*lambda^6+28*lambda^8-16*cos(x+y)-23632*lambda^3-5844*lambda)
now I want to solve the second part of the polynomial with lambda^9 but maple gives me the RootOf-function
_Z^9-28*_Z^8+328*_Z^7-2088*_Z^6+(-2*cos(y)-2*cos(x)+7852)*_Z^5+(28*cos(y)+28*cos(x)-17768)*_Z^4+(-152*cos(y)-152*cos(x)+23632)*_Z^3+(408*cos(y)+408*cos(x)-17232)*_Z^2+(-12*cos(x)*cos(y)-540*cos(y)-540*cos(x)+5844)*_Z+32*cos(x)*cos(y)+256*cos(y)+256*cos(x)-544
How can I simplify this expression to solve over lambda.
purpose is to plot all the eigenvalues.
Thank you in advance.
Why does the following work as expected...
f__c := proc (x__0, y__0) options operator, arrow; piecewise(x__0^2+y__0^2 <= 1 and (x__0-1)^2+y__0^2 <= 1 and x__0^2+(y__0-1)^2 <= 1 and (x__0-1)^2+(y__0-1)^2 <= 1, 1, not (x__0^2+y__0^2 <= 1 and (x__0-1)^2+y__0^2 <= 1 and x__0^2+(y__0-1)^2 <= 1 and (x__0-1)^2+(y__0-1)^2 <= 1), 0) end proc
But the following does not?
cnd := x__0^2+y__0^2 <= 1 and (x__0-1)^2+y__0^2 <= 1 and x__0^2+(y__0-1)^2 <= 1 and (x__0-1)^2+(y__0-1)^2 <= 1
f__c := proc (x__0, y__0) options operator, arrow; piecewise(cnd, 1, not cnd, 0) end proc
(Sorry about the lack of formatting, the forum insists my Maple syntax is invalid)
The first one produces the expected result, x__0 and y__0 are treated as variables in the condition (i.e. f__c(a, b) returns the same piecewise function with x__0 replaced with a and y__0 replaced with b); the second one does not (i.e. f__c(a, b) returns the piecewise function, still with x__0 and y__0 in the condition, and never gets evaluated).
I have a system of PDes, the code i think it's well writte but when I use pdesolve i have no solution obtained.
Maybe I must add something else
Many thinks
sysPDes.mw
I am defining,
f(x):= x-> diff(g(x),x)/(1+g(x))
Here g(x)<<1 and I am looking for series expansion, 1/(1+g(x)) = 1- g(x) + g(x)^2 etc.
But I cannot get this by using series(f(x),g(x)=0) or other options.
Rahul
Is there a way to remove the parentheses around y'(t)?
mapleatha
proc() local a := 0, b := 1;
  print(proc(x::uneval) x := 1 end proc(a));
  print(proc(x::uneval) x := b end proc(a))
end proc();
Error, (in unknown) illegal use of a formal parameter
Why doesn't the second nested procedure keep a unevaluated?
With Typesetting level set to Maple Standard, x->(f@g)(x) is displayed as x->f@g(x), which is wrong because composition has lower precedence than function application.
sum((-1)^k/k^(1/2), k = 2 .. infinity);
Error, (in polylog) numeric exception: division by zero
how can filter data im maple 18 befor used in draw plot? i need simple example
First 937 938 939 940 941 942 943 Last Page 939 of 2463
