I am working with a package that is not entirely stable and which can sometimes corrupt Maple's state. I would like to "sandbox" the risky operations, executing each of them in another kernel thread that I can destroy (or somehow reset), getting back just the return result of each operation (each return result involves only global names, numbers, and strings). What would be a good way to achieve this?
I see the Task model, but it is not clear to me that each kernel used is effectively restart()'d for each Task Start(). At the moment I would have a bit more confidence in manually using Thread Create(), except that I do not see any information on how to destroy a thread (just to destroy Mutex and Condition Variable resources.)
This is, I suppose, a kind of security, but it is not covered by EngineSecurity. (Not unless I need to process[popen] to achieve this.)
Hy all its my first post, thankyou for having me.
I'm not sure why this happens but say I got a list
X := [0, 1, 2, 3];
and perform this expression
sum(sum(a[k]*X[i]^k, k = 0 .. n), i = 1 .. nops(X))
I get output 4*a[0]+6*a[1]+14*a[2] which is correct and what I want, but if I swap the summations
to
sum(sum(a[k]*X[i]^k, i = 1 .. nops(X)), k = 0 .. n)
I get 3*a[0]+6*a[1]+14*a[2] which is incorrect I believe, unless I'm being silly and missing something.
this happens because its a 0 in my list, if I replace a zero with a non zero number then it works fine and if I replace my set with
X := [seq(x[i], i = 0 .. 3)];
both summations give me
a[2]*x[0]^2+a[2]*x[1]^2+a[2]*x[2]^2+a[2]*x[3]^2+a[1]*x[0]+a[1]*x[1]+a[1]*x[2]+a[1]*x[3]+4*a[0]
and at the end there is 4*a[0]
nothing that is really depending on any element in the list. so why when I replace an element with 0 using the second expression (which should be equivalent to first) gives me less a[0]I really would like to understand why this is happening
any insight or assistance would be gratefully appreciated.(I'm still a noob)
I Need eliminate u(t) in Matrix U
How can I do it directly from dsolve without using string tools?
I am trying to take a list of prime numbers that I already generated with the following:
L4:=NULL:
for i from 2 to 50 do
if nops(ifactor(i))=1 then L4:=L4,i end if:
[L4]
This gives me the primes bewteen 2-50, [2,3,5,7,11,13,17,23,29,31,37,43,47].  I want to write something that takes the products of my list like this
2*3=6
2*3*5=30
2*3*5*7=210
and so on through the whole list.  Any ideas?  I figured out how to take the product of 2*3, 2*5, 2*7 and so on, but I cant figure how to make it do 2*3, 2*3*7 and so on.
I am doing a presentation on Euclids infinite prime proof and thought it would be cool to write a maple program that will show his proof for a certain amount of prime numbers.
Thanks,  Matt
I have a Maple file which contains many proc loops and functions.
I need a linkage between some files to read the requested functions from source file and export calculations to another file.
Is it possible?
When I show the context menu on maple 18 (CTRL click on mac or right click with a mouse) on an equation the system doesn't show the tutor or series options as written in the example I use.   (after having loaded the multivariate calculus as asked)
Is that an issue in my installation ?  Where do I have to place the cursor ?  Is the multivariate calculus module well loaded ?
Thanks for your help
Stéphane
Dear friends,
I would like to know the agorithm of isovle for solving 2 order equations for more than 3 variables.
I see that not all the solutions are shown for example for:
x^2+y^2=z^2+t^2
 Could you please help me with this?
hi,
I have bought maple18 student edition. I want to learn GPU programming through Maple. Please suggest how to do this. I have a notebook with i7 processor and NVIDIA geforce 750m graphics. I want to solve system of algebraic equations, integral equations etc in parallel using GPUs.
I am trying to simplify sums of a few LaguerreL polinomials of different n using the identities in the function advisor such as recurrsion relations. How does one go about in using the FunctionAdvisor identities when trying to simplify expressions containing orthogonal polynomials?
Hello guys.
I have a system of differential equations , which I want to solve the perturbation method , but the following problem :
I got zero approximation
SYS0 := dsolve({Sys, isc}, {delta0(x), u0(x)}, type = numeric, output = listprocedure)
SYS0:=[x=proc(x) ... end proc,delta0(x)=proc(x) ... end proc,u0(x)=proc(x) ... end proc]
How can I use the zero-order approximation for the future is being computed ?
I tried to do so:
F := eval(delta0(x), SYS0);
F1 := eval(u0(x), SYS0);
Fdiff := eval(diff(delta0(x), x), SYS0);
F1diff := eval(diff(u0(x), x), SYS0);
Error, (in eval/diff) non-algebraic expressions cannot be differentiated
Sysq := ((9/10)*F1(x)*F(x)*F1diff-(3/10)*Fdiff*F1(x)*F1(x)+(3/2)*F1(x))*F(x) = (1/5)*F(x)*delta1(x)-(3/10)*u1(x);
Sysqq := u1(x)*Fdiff+F1(x)*(diff(delta1(x), x))+delta1(x)*F1diff+F(x)*(diff(u1(x), x)) = 0;
SystemSec := Sysq, Sysqq;
SYS22 := dsolve({SystemSec, delta1(0) = 10^(-8), u1(0) = 10^(-8)}, {delta1(x), u1(x)}, type = numeric);
but I can not differentiate u0 (x), delta0 (x) to find u1 (x), delta1 (x) in my system
123.mw
Sorry for my english
Thank
I want to generate all 4x4 matrices of rank-1 over the field with two elements, F_2. I don't want to use actual arrays though, I just want to use symbols representing the unit matrices. So for example Eij represents the 4x4 matrix with a 1 in row i & column j, and 0's elsewhere.
We have 16 unit matrices: E11, E12, ..., E14, ... E41, E42, E43, E44. Then we have to look at all possible linear combinations that result in a rank-1 matrix. So for example: E11+E12,  E11+E21,  E11+E12+E13,  E33+E43, etc. The total number of rank-1 4x4 matrices over F_2 is 225. How can I find all of these quickly?
Hi number of officials,
As I enter the command defined 'int' I get an error message.
What can I do. Can you help me.
Commands Entered:
int(x^2+3*x, x);
ansvers:
Error, (in int) wrong number (or type) of arguments: invalid option value passed to indefinite integration: {}
I'm wondering why the fit routine gives weird results, when telling him to fit
with(Statistics):
X:=Vector[column](3, {1 = 616.3096, 2 = 616.3248, 3 = 616.3342}, datatype = sfloat, storage = rectangular, order = Fortran_order, shape = []);
Y:=Vector[column](3, {1 = 99590., 2 = 127564., 3 = 144223.}, datatype = sfloat, storage = rectangular, order = Fortran_order, shape = []);
g:=Fit(a+b*x+c*x^2,X,Y,x)
It's telling me: Warning, model is not of full rank
If I calculate the coefficients the direct way (well the fit should be exact,because we only have 3 values and 3 parameters) I get:
M:=Matrix(3, 3, {(1, 1) = 1, (1, 2) = 616.3096, (1, 3) = 379837.52305216, (2, 1) = 1, (2, 2) = 616.3248, (2, 3) = 379856.25909504, (3, 1) = 1, (3, 2) = 616.3342, (3, 3) = 379867.84608964}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []);
V:=Vector[column](3, {1 = 99590, 2 = 127564, 3 = 144223}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []);
C:=MatrixVectorMultiply(M^-1,V)
Hi there
I'm trying to isolate (y1-3)2+(x1-1)in the equation 25(y1-3)2+200+100(x1-1)2=0.
I have tried isolate and solve, but solve coplains about solving for expressions (but when inputting i:=(x1,y1)->(y1-3)2+(x1-1)2 it still doesn't work), and isolate can only isolate either (y1-3)2 or (x1-1). Not both.
How can I do this with as few lines as possible?
- Alex
Use the Maple command DEplot to draw a direction field for the equation
make sure it at least covers the area −1 ≤ x ≤ 1,
−1 ≤ y ≤ 1
the equation is dy/dx+4y^3 −3y = 0.
then I have :
y(x):=dy/(dx)+4*y^(3)-3*y=0
with(DEtools); DEplot(y(x), x = -1 .. .1, y = -1 .. .1);
Error, (in DEtools/DEplot) vars must be declared as a list, e.g. [x(t),y(t),...]
so how can I change the command to make it work..
First 1346 1347 1348 1349 1350 1351 1352 Last Page 1348 of 2463
