Matlab seems to be pretty strong at doing color plots with separate color bars, e.g.
Is this also possible in Maple and somehow in combination with `plots[surfdata](...,color=zhue,...)`?
In a 3d coordinate system I have a circular spacecurve with z-minimum -4 and z-maximum +4. In the same 3d coordinate system I have a 3d surface plot with z-minimum -0.5 and z-maximum +1.3 . When I choose the color option "Z(Hue)" in order to color-code the z-values on the 3d surface and make the topography more clear, I mostly get a totally green 3d surface. It seems that the color scaling is coupled with the spacecurve with z-values of +-4 . How can I uncouple the color scaling from the spacecurve and couple it with the z-range of the surface, while the color-limits shall be at +-1.3 ?
I have a nice family of functions of the form:
W:=(p,n,mu,w)->sum(w[k] * (n-k)* mu(n-k),k=1..n)
which can be evaluated for different p's using the operator mu*diff(...,mu)
The recursion begins with p=0 and proceeds using mu*diff(W(p,n,mu,w),mu) = W(p+1,n,mu,w).
Can anybody implement this procedure in Maple
How can I make transformations like:
sum(a*u[k]+b*v[k],k=1..n) into a*sum(u[k],k=1..n)+b*sum(v[k],k=1..n)
and in the opposite direction?
Dear,
I paste below a simple code illustrating what I want to do: interpolate a function from two lists . I wonder it is a very simple task but I the function and the graph I get don't match with the correct ones in the end (both are plotted below).
> y_data:=[0.5266426348e-1, 0.7090942099e-1, 0.9392192453e-1, .1228458380, .1598545751, .2107200296, .3127241088, .4144428927, .5679723063, .6817484378, .7973388763, .9326799232, 1.393259472, 1.493936979, 1.566845149, 1.624353545, 1.670898228, 1.708874880, 1.739919717, 1.765298377, 1.786042765, 1.803007037, 1.816897481, 1.828294327, 1.837670808, 1.845410531, 1.851823072, 1.857157571, 1.861614283, 1.865354162, 1.868506707, 1.871176289, 1.873447229, 1.875387839, 1.877053637, 1.878489894, 1.879733654, 1.880815343, 1.881760039, 1.882588494, 1.883317935, 1.883962726, 1.884534877, 1.885044474, 1.885500010, 1.885908668, 1.886276537, 1.886608800, 1.886909882, 1.887183573, 1.887433127, 1.887661351, 1.887870669, 1.888063180, 1.888240711, 1.888404854, 1.888557000, 1.888698365, 1.888830022, 1.888952911, 1.889067865];
> x_data:=[10, 53/5, 56/5, 59/5, 62/5, 13, 68/5, 68/5, 13, 62/5, 59/5, 56/5, 56/5, 59/5, 62/5, 13, 68/5, 71/5, 74/5, 77/5, 16, 83/5, 86/5, 89/5, 92/5, 19, 98/5, 101/5, 104/5, 107/5, 22, 113/5, 116/5, 119/5, 122/5, 25, 128/5, 131/5, 134/5, 137/5, 28, 143/5, 146/5, 149/5, 152/5, 31, 158/5, 161/5, 164/5, 167/5, 34, 173/5, 176/5, 179/5, 182/5, 37, 188/5, 191/5, 194/5, 197/5, 40];
inverted_pairs:=[seq([y_[i], x_[i]], i = 1 .. nops(y_))];
interp := LeastSquares(y_data, x_data, k_, curve = a*k_^3+b*k_^2+c*k_+d);
I've tried different kinds of interpolation methods. In this code I use LeastSquares() function. I'm sure it has a quick solution but I'm really stuck and would appreciate any help/advice.
Thanks in advance!
PS: I didn't mention in above, but it is really important for me to get the associated function of the curve (e.g. ak_^3+bk_^2+ck_+d). I can get it using LeastSquares() function but with your code (where you use ArrayInterpolation()) the function is not generated in the end. Could you please indicate some way to do that? Thanks!
I need to find the local maxima and minima of f(x,y)=x(x+y)*e^(y-x). I have tried to look for an appropriate method that I could use to achieve this, but got stuck. I also don't quite understand the math behind tying to obtain the local maxima and  minima for a function of this type.
I'm trying to evaluate the multidimensional limit:
(1+y)^(x-1)-1/(1-cos((x-1)^2+y^2)^(1/4)) as (x,y)->(1,0) using the limit command :
limit((1+y)^(x-1)/(1-cos((x-1)^2+y^2)^(1/4)),{x=1,y=0});
but don't seem to get any output. Also, I think the limit for this function doesn't exist or is indeterminate on R2. Where am I wrong?
I am considering options to access Maple features from within a Fortran program using the OpenMaple API. I do not find any examples illustrating this (or even precise statements if this is possible in principle). (Quite surprising to me considering the presence of Fortran in scientific computing).
Is the only way to go to write a C wrapper for the API? If yes, is there an example for such a wrapper which performs common conversions between Fortran and C data types.
Greetings, seeking an expert to animate a plot.
see worksheet.posterior_graphs_(encapsulted)_1D.mw
before they play each other, each have a law (a normal distribution) plot-output 6.
after DD defeats CC, and a numerical integration is performed the new laws are given by plot-output 18.
as you can see, the laws of DD and CC are closer together.
if the calc was repeated (DD defeats CC again), the laws would be closer again.
so what i require is an animation of the new laws from game 1 to (say) game 6 (DD defeats CC every time). seeing the red and blue distributions merging would be ideal.
as an aside I heard maples FFT could simplify the complicated integration. any suggestions?
cheers
(http://imgur.com/SDBP0sw)
Hello, everyone!
I was given this week's Maple assignment in my class and I've come across a problem. I'll say this now so I don't get sent away, I am NOT asking for the answer. For this question there is a part A and part B, but also a preliminary check to make sure our code is wokring (as seen in the picture link). The issue I'm here for is that I can't figure out the code for the preliminary check... I've been here for hours and I'm stumped.
This is my attemp so far;
f := x^(6*ln(x))
Digits:=15;
T2 := convert(%, polynom)
f_value := evalf(subs(x = 5, T2))
I'm very confused what to do next in order to get that preliminary test amount of 5121425.461.
Thanks in advance! :)
I have been Maple  18 with no problem. Then, today, the  "=" symbol and  "+" symbol don't work.  Does anyone know what to do about this?
There a lot of symbols that don't work in Maple.
The symbols that dont work are shown as an "A".
Almost half of the symbols in the pallets are shown as an "A".
I am trying to discretize a kernel of the form $K(x,y,t,s)$. I want to evaluate a four dimensional integral of the form
\int\int\int\int K(x,y,t,s)*h_m(x)*h_n(y)*h_p(t)*h_q(s) dsdtdxdy, where limits of integration are from 0 to 1.
$h_m()$ are function of one variable.
please suggest how to evaluate this.
First 1348 1349 1350 1351 1352 1353 1354 Last Page 1350 of 2463
