I do not have any code to produce yet.  I want to have Maple animate a bouncing ball on some 3d surface.
I want to animate this code
plots[odeplot](Trajectoire, [[x1(t), y1(t), t], [x2(t), y2(t), t], [x3(t), y3(t), t], [x4(t), y4(t), t], [x5(t), y5(t), t], [x6(t), y6(t), t], [x7(t), y7(t),t], [x8(t), y8(t), t], [x9(t), y9(t), t], [xA(t), yA(t), t]], TempsInitial..TempsFinal, numpoints = 10000,axes=boxed, scaling = constrained);
However, Maple 16 is giving me an error message :
Error, (in plots/animate) the first argument must be a procedure
I don't know how I can do to animate this code.
and if the A are an inversable matrix
worksheet output doesnt display the eigenvalues of a 19X19 matrix. Just gives in the form Root of(...). when datatype is indicated as anything other than complex(sflot) it gives error "unable to store". solution is required in compact mathematical expression form (may involve square roots etc). Please help.
restart:with(plots):
h3:=((1+lambda*m*x/a0+phi*((4/Pi*sum((-1)^(n+1)/(2*n-1)*cos(2*Pi*(2*n-1)*x),n=1..infinity)))));
q:=Q-1:
f:=sin(alpha)/E;
DP3:=Int(f-((q*(k+1)*(k+2))/((1-tau)^(k+1)*((h3^(k+2)))*(k+1+tau)))^(1/k),x=0..1);
E:=0.2:phi:=0.2:alpha:=0.1:k:=1:lambda:=0.1:a0:=0.5:m:=0.1:tau:=0.1:
plot((DP3),Q=0..1,axes=box,linestyle=1,color=[red]);
I am unable to plot DP3 vs Q, not only it take very long time but didn't give any output.
Please have a look.
Cheers!
I am looking for a spreadsheet to compute the precession of Mercury fom the Schwarzchilg metric and the geodesic equations. Are you aware of such an example?
When I try "touch and drag" in Maple documents, the documentation for example, I end up selecting text instead of scrolling. Unfortunately the alternatives for scrolling are a) the scrollbar, b) page-up/down or c) moving the cursor. Each of those alternatives is about 2.5311 orders of magnitude more inconvenient than touch&drag.
Does anybody know if its possible to get Maple (18) to scroll instead of select text when I touch the screen?
I am using Maple 17 to solve some equations. I am solving these equations with the solve command. There are some bounds on the parameters so I am including these inequalities. I have 4 variables, so I solve for 3 to get them in terms of the last one.
It returns piecewise solutions as per the inequalties as I hoped.
However for two ranges of the inequalities I get [] which I assume means no solution.
For another range I get an expression for each of my paramters.
For the final range I get 0 . What does this 0 mean and what do the [] mean?
I wondered if 0 meant that all paremeters equalling zero was a solution, but this is false.
Hi there
There seems to be a bug when evaluating elliptic integrals using assuming. Here's an example:
INT:=Int(1/sqrt(a*x^3+1),x=0..X);
is our integral for some a. Now evaluate the integral using assuming on X in different ways:
INT2:=simplify(value(INT)) assuming X>0, a>0, a<1;
INT3:=simplify(value(INT)) assuming X<0, a>0, a<1;
These give analytic solutions which are different. Now plot them both and compare to the numeric solution
plot([subs(a=0.1,INT2),subs(a=0.1,INT3),subs(a=0.1,INT)],X=-1..1,colour=[red,green,blue]);
I'm finding that the red curve which should work for X>0 is wrong, while the green one which is for X<0 is ok for X either sign. [blue is the correct answer - numerically!]
Any ideas?
Good afternoon sir.
Please let me know how to upgrade mu current version Maple17 to Maple 18.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
Good afternoon sir.
I request your kind support to the above cited query.
M.Anand
Good afternoon sir.
I request your kind suggestion to the above cited query.
M.Anand
Hi everyone.
I'm trying to visualize some some field lines for a 3D magnetic field I have simulated, and I have read that the Student[VectorCalculus] package is the best package for this type of visualization. I tried implementing it as described online and in the manual, and I got an error:
Error, (in plots/fieldplot3d) no non-zero vectors found
Does anyone have any ideas as to what could be causing this issue?
Attached is the Maple document I am using. The section entitled "Problem Area" is where the issue is.
turtle-rec-bend.mw
I need your help.
I compute the exact solution u(x,y,t) os PDE.
My code : PDEs.mw
I would like to plot the exact solution of my PDE.
My method work well but  when I put a:=1; b:=1; In the next lines there is no change, always I have a and b in my equation.
If i fix the time, "t=1 or 2 " for example; In the last lines i plot( u(x,y,2)); but doesn't work also.
Then animation in "t" how....
Thanks for your help.
First 1477 1478 1479 1480 1481 1482 1483 Last Page 1479 of 2463
