Dear All
Please help me for using fsolve
the fsolve command doesnt work!
> restart;
> with(LinearAlgebra); Digits := 20;
> Z := Matrix(2); N := 3; y11 := sum(a[n]*x^n, n = 0 .. N); y12 := sum(b[n]*x^n, n = 0 .. N); y21 := sum(c[n]*x^n, n = 0 .. N); y22 := sum(d[n]*x^n, n = 0 .. N); y11 := unapply(y11, x); y12 := unapply(y12, x); y21 := unapply(y21, x); y22 := unapply(y22, x);
> A := linalg[matrix](2, 2, [1, -1, 1, exp(x)]); B := linalg[matrix](2, 2, [-3*exp(-x)-1, 2-2*exp(-x), -3*exp(-x)-2, 1-2*cosh(x)]);
> C := eval(B, [x = 1]);
> Y := linalg[matrix](2, 2, [y11(x), y12(x), y21(x), y22(x)]);
> yy11 := diff(y11(x), x); yy12 := diff(y12(x), x); yy21 := diff(y21(x), x); yy22 := diff(y22(x), x); yy11 := unapply(yy11, x); yy12 := unapply(yy12, x); yy21 := unapply(yy21, x); yy22 := unapply(yy22, x);
> YY := linalg[matrix](2, 2, [yy11(x), yy12(x), yy21(x), yy22(x)]);
> S := {seq(eval(YY, [x = n/N])-(eval(A, [x = n/N]))*(eval(Y, [x = n/N]))-(eval(B, [x = n/N])) = Matrix(2), n = 1 .. N)};
> S1 := {eval(Y, [x = 0]) = linalg[matrix](2, 2, [3, 0, 1, 1])};
print(??); # input placeholder
> SS := `union`(S, S1);
> sol := fsolve(SS);
I am new user of Maple. I have an expression like f(x,y)/g(x,y) and I want to have Maple name f(x,y) as something simple like "h" so that later equations write h/g(x,y) instead of the complete f(x,y)/g(x,y), and also to be able to simplify other equations in terms of h.
For example, a=(x+1)(y-5)^2/(x+y-3). Can I get Maple to let h=(x+1)(y-5)^2, so that I get h/(x+y-3) when I ask for a?
Sorry if this question is basic (and my math terminology incorrect), but I have been trying for a while.
firstly apologies in advance for stuff in this question such as "triangle symbol",  my computer is pretty old.
ok so i was confused a bit here, what i'm trying to do is write a maple procedure that computes Af for a given f contained in V . except we only need to correct the bug in the script below. This script demonstrates such a procedure in the case that omega is a square. The domain is given here as the negative set of a function F contained in V .  I have left in notes where/what i think we need to do but i dunno how to...
N:=10 ; # Global Var
F:=(x,y)->sgn(abs(x-N/2)+abs(y-N/2)-N/4);
Average := proc(F, f0) local f, i, j;
f := f0; # !!!!!!!!!!!!!! something is bad here...
for i to N do for j to N do
if F(i, j) < 0 then
f[i, j] := (f0[i - 1, j] + f0[i + 1, j] + f0[i, j + 1] + f0[i, j - 1])/4 ;
end do;end do;
return f;
f0:=Matrix(N,F); # just to have something to test the procedure
Average(F,f0); # does not return the expected average, modifies f0
the necessary information we were given to produce this so far was..
Let N be a positive integer and [N] = {i contained in N | 1<= i <=N }  Let "Omega" C {(i,j) contained in [N] x [N] | 2<=i,j<=N-1} be a subset. Let V = R^([N]x[N]) be the vector space of real valued functions [N]x[N] -> R
and A, "triangle symbol":V->V (average) and "triangle symbole" (Laplacian) be the linear maps such that
[Af](i; j) = f(i; j)      if (i; j) not contained in "Omega"   OR
                             [f(i, j + 1) + f(i, j - 1) + f(i + 1, j) + f(i - 1, j)]/4 if (i,j) is contained in "Omega"
["traingle symbol"f](i,j) =  0 if (i,j) isnt contained in "Omega"   OR
                            ( f(i,j) - [f(i, j + 1) + f(i, j - 1) + f(i + 1, j) + f(i - 1, j)]/4 )    if (i,j) is contained in "Omega"
 Please and thank you for any help in advance <3
Maple needs 827 characters to write a equation of a straight line.
Is that true or what am I doing wrong?
Can anybody help me or give a direction to handle with such problems?
Putting
  assume(2<alpha , alpha<=4);about (alpha);
before it does not help either.
f:=-(6*(3*alpha^2*(alpha-1+sqrt(alpha^2-3*alpha+2))^4/(alpha-1)^4-12*alpha^2*(alpha-1+sqrt(alpha^2-3*alpha+2))^3/(alpha-1)^3-6*alpha*(alpha-1+sqrt(alpha^2-3*alpha+2))^4/(alpha-1)^4+16*alpha^2*(alpha-1+sqrt(alpha^2-3*alpha+2))^2/(alpha-1)^2+24*alpha*(alpha-1+sqrt(alpha^2-3*alpha+2))^3/(alpha-1)^3+3*(alpha-1+sqrt(alpha^2-3*alpha+2))^4/(alpha-1)^4-8*alpha^2*(alpha-1+sqrt(alpha^2-3*alpha+2))/(alpha-1)-24*alpha*(alpha-1+sqrt(alpha^2-3*alpha+2))^2/(alpha-1)^2-12*(alpha-1+sqrt(alpha^2-3*alpha+2))^3/(alpha-1)^3+8*(alpha-1+sqrt(alpha^2-3*alpha+2))^2/(alpha-1)^2+8*alpha+(8*(alpha-1+sqrt(alpha^2-3*alpha+2)))/(alpha-1)-7))/(alpha*(alpha-1+sqrt(alpha^2-3*alpha+2))^2/(alpha-1)^2-2*alpha*(alpha-1+sqrt(alpha^2-3*alpha+2))/(alpha-1)-(alpha-1+sqrt(alpha^2-3*alpha+2))^2/(alpha-1)^2+(2*(alpha-1+sqrt(alpha^2-3*alpha+2)))/(alpha-1)-1)^4;
• Is there a simple way to find the domain for the real solutions of f(x)?
• And is there a way to let maple get the part of f(x) with the sqrt?
   (not by typing it by hand as I dit below)
• Is there a way to write the summary of the found domains in one line?
Thanks for your help.
# How to find the Domain for real solutions for x?
f(x):=(x-1+sqrt(x^2-3*x+2))/(x-1);
discont_for_x=discont(f(x),x);
# x<>+1 (because the de denom=0 is not allowed)
denom(f(x))=0;
x={solve(denom(f(x))=0,x)};
# x<=1 union  2<=x (because the part under the sqrt must be >=0 to give Real solutions)
sqrt(x^2-3*x+2);
0<=x^2-3*x+2;
x=solve(0<=x^2-3*x+2,x);
Hi all
Please, I'd like to clarify some basic points about performing computations in Maple 18. Up to now I have been doing some numeric calcs using matrices normally composed of 10 to 15 columns and 200 to 600 rows.
When doing the calcs with a matrix of ~200 rows, it is just ok but as the number of rows increase the calculation speed reduces significantly.
The data contained in each row is calculated within a loop cycle (i.e.: for i from 1 to 200 do ......).
The number of rows is controlled by a slider so when I drag the slider the calcs are automatically updated and the results shown graphically.
As I said it is too slow so I don't know if I should be looking into the option of doing calcs symbolically first? However you can't use symbolic notation when working with matrices. I still got a lot of calcs to do but prefer not to continue as it will only get slower so better to see if I can optimise speed.
Any comment is trully appreciated.
Cesar
m 18 cubacuhre integration fail, intergrand unknown
restartprintlevel = 3binomial(7, 2); with(StringTools); FormatTime(%c)with(LinearAlgebra); with(IntegrationTools)with(numapprox); with(OrthogonalSeries); LinearAlgebra:-HermitianTranspose(3-I*7)infolevel[`evalf/int`] := 4; pie = evalf(Pi)n = 1l = 0m = 0n1 = 1l1 = 0m1 = 0alpha = 5.8alpha1 = 4.2R = .5Theta = (1/6)*PiPhi = 3*Pi*(1/4)region := [r = 0 .. infinity, theta = 0 .. Pi, phi = 0 .. 2*Pi]r1 := proc (r, theta, phi, R, Theta, Phi) options operator, arrow; (r^2+R^2-2*r*R*(sin(theta)*sin(Theta)*cos(phi-Phi)+cos(theta)*cos(Theta)))^(1/2) end proc"coef:=(l1,l2,m1,m2)->(-1)^(l1-l2) (((4 *pie *(2 l1+1)!)/((2 l1-2 l2+1)!*(2 l2+1)!))*("
"(binomial(l1+m1,l2+m2)*binomial(l1-m1,l2m2))/(binomial(2* l1,2* l2)))())^(1/(2));NN:=(n,alpha)->((2 alpha)^(n+(1)/(2)))/(((2 n)!)^((1)/(2)));  "
integrand := sum(sum(R^(l1-l2)*SphericalY(l1-l2, m1-m2, Theta, Phi)*coef(l1, l2, m1, m2)*r^(2+l+l2)*SphericalY(l2, m2, theta, phi)*LinearAlgebra:-HermitianTranspose(SphericalY(l, m, theta, phi))*NN(n, alpha)*r^(n-l-1)*exp(-alpha.r)*NN(n1, alpha1)*r1(r, theta, phi, R, Theta, Phi)^(n1-l1-1)*exp(-alpha1*r1(r, theta, phi, R, Theta, Phi))*sin(theta), m2 = -l2 .. l2), l2 = 0 .. l1)
evalf(Int(integrand, region, 'epsilon' = 0.1e-3, 'method = _CubaCuhre'));
``NULL
binomial(7, 3)region4 := [x = 0 .. 10*Pi, y = 0 .. 10*Pi]
integrand4 := (cos(x)+(1/3)*sin(y))^6*(sin(y)-(1/3)*cos(x))^2
evalf(Int(integrand4, region4, 'epsilon' = 0.1e-3, 'method = _CubaCuhre'))
Download stovrlp2.mw
Hi, as the title says I am animating an implicitplot and want a different color for each curve left by the trace. I realize it may be easier to build plot structures using seq and display(..,insequence=false) but I thought I should learn more Maple ha ha. Plus  it seems easier to implement.
 Forgot to say I use Maple 15
For equation sol[2][1]=constant A,
> animate(implicitplot, [sol[2][1] = A, x = -6 .. 15, y = -15 .. 15, numpoints = 10^5], A = -10 .. 10, trace = 2, frames = 20);
Hi all
In matlab software we have a command namely fmincon which minimizes any linear/nonlinear algebric equations subject to linear/nonlinear constraints.
Now my question is that: what is the same command in maple?or how can we minimize linear/nonlinear function subject to linear/nonlinear constraints in maple?
thanks a lot
Mahmood   Dadkhah
Ph.D Candidate
I need to find mina(w) then a=-1,0,1 and
w := piecewise((x-a)/t <= -10, 202*a-200*x-(202001/101)*t, (x-a)/t <= -910/101, 3*a-x-(1011/101)*t, (x-a)/t <= 910/101, 2*a-t, (x-a)/t <= 10, a+x-(1011/101)*t, 10 < (x-a)/t, -198*a+200*x-(202001/101)*t)
Also need to plot it, i think it should look like this
I am getting a complex solution for a physical quantity, how can I plot it. Should I plot the real part or modulus?
solution is,
C1*sqrt(4*tau^2*M^2*lambda^2+Q^2)*LegendreP((1/2*I)*sqrt(7)-1/2, I*sqrt(7), (2*I)*lambda*M*tau/Q)+C2*sqrt(4*tau^2*M^2*lambda^2+Q^2)*LegendreQ((1/2*I)*sqrt(7)-1/2, I*sqrt(7), (2*I)*lambda*M*tau/Q)
where C1 and C2 are integration constants.
Perhaps I am being daft, but to me the Physics package seems, quite surprisingly, to have trouble multiplying by a nonzero, non-square matrix. The test code
with(Physics):
Matrix(2,2,fill = 0) . Vector(2),
Matrix(2,2,fill = 1) . Vector(2),
Matrix(2,3,fill = 0) . Vector(3);
Matrix(2,3,fill = 1) . Vector(3);
produces the following output:
Error, (in Vector[column]) Matrix index out of range
i.e., the last expression cannot be evaluated; while the test code (where no loading of the Physics package is performed)
#with(Physics):
Matrix(2,3,fill = 0) . Vector(3),
produces the following expected output:
PS: To be sure, I have from http://www.maplesoft.com/products/maple/features/physicsresearch.aspx downloaded the latest version (2014, March 19, 4:0 hours) of the Physics package for Maple 17 (the version I am running).
Please i don't want to convert from list to set then apply set minus and convert back because it loses its order and repititions.
so i want something that can for example do the following:
list_minus([1,2,4,6,2,1,3,6,2],[7,4,2,5,2]) = [1,6,1,3,6,2]
so it removes repititions from left and order is retained.
Hi all
I dont know why some Z1 appears on the screen and the code does not converge.
please help me
thanks alooooot
n:=3;
nn:=3;
m:=1;
BB:=1;
BINF:=5:
pr:=7;
digits:=10;
eq1:=diff(f(tau),tau$3)+((3/5)*f(tau)*diff(f(tau),tau$2))-(1/5)*(diff(f(tau),tau$1))^2+((2/5)*tau*diff(h(tau),tau$1))-((2/5)*h(tau))-BB*diff(f(tau),tau$1)=0;
eq11:=(1/pr)*diff(h(tau),tau$3)+(3/5)*f(tau)*diff(h(tau),tau$2)=0;
h(tau):=sum(p^i*h[i](tau),i=0..nn);
f(tau):=sum(p^i*f[i](tau),i=0..n);
H1:= p*(diff(f(tau),tau$3)+((3/5)*f(tau)*diff(f(tau),tau$2))-(1/5)*(diff(f(tau),tau$1))^2+((2/5)*tau*diff(h(tau),tau$1))-((2/5)*h(tau))-BB*diff(f(tau),tau$1))+(1-p)*(diff(f(tau),tau$3)):
H11:= p*((1/pr)*diff(h(tau),tau$3)+(3/5)*f(tau)*diff(h(tau),tau$2))+(1-p)*(diff(h(tau),tau$3)):
eq2:=simplify(H1):
eq22:=simplify(H11):
eq3:=collect(expand(eq2),p):
eq33:=collect(expand(eq22),p):
eq4:=
convert(series(collect(expand(eq2), p), p, n+1), 'polynom');
eq44:=
convert(series(collect(expand(eq22), p), p, n+1), 'polynom');
for i to n do
s[i] := coeff(eq4, p^i) ;
print (i);
for i to nn do
ss[i] := coeff(eq44, p^i) ;
print (i);
s[0]:=diff(f[0](tau), tau$3);
ss[0]:=diff(h[0](tau), tau$3);
ics[0]:=f[0](0)=0, D(f[0])(0)=0, D(f[0])(BINF)=0;
icss[0]:=h[0](BINF)=0, D(h[0])(0)=1, D(h[0])(BINF)=0;
dsolve({s[0], ics[0]});
f[0](tau):= rhs(%);
#dsolve({ss[0], icss[0]});
h[0](tau):= -exp(-tau); #;rhs(%);
for i to n do
f[ii-1](tau):=convert(series(f[ii-1](tau), tau, nn+1), 'polynom');
h[ii-1](tau):=convert(series(h[ii-1](tau), tau, nn+1), 'polynom');
s[i]:=simplify((s[i]));
ics[i]:=f[i](0)=0, D(f[i])(0)=0, D(f[i])(BINF)=0;
dsolve({s[i], ics[i]});
f[i](tau):=rhs(%);
ss[i]:=(ss[i]);
icss[i]:=h[i](BINF)=0, D(h[i])(0)=0, D(h[i])(BINF)=0;
dsolve({ss[i], icss[i]});
h[i](tau):=rhs(%);
f(tau):=sum((f[j])(tau),j=0..n);
with(numapprox):
plot(diff(f(tau),tau),tau=0..5,color=blue,style=point,symbol=circle,symbolsize=7,labels=["tau","velocity"]);
plot(pade(diff(f(tau),tau), tau, [7, 7]),tau=0..5,color=blue,style=point,symbol=circle,symbolsize=7,labels=["tau","velocity"]);
x*(y+z)/x
convert any polynomial to Divide(Mult(x, Plus(y+z)), x)
First 1478 1479 1480 1481 1482 1483 1484 Last Page 1480 of 2463
