I have a function. It's calculating coefficients of a polynomial.
So when it's done, I have the variables a0, a1, a2,a3 ... aN
where N is an input value and could be any positive integer.
Now, I just want to show them on the screen. So if I have, say , a0=1.3 and a1=5.76, I want this to appear:
1.3x + 5.76x2
That's all. I just want a loop that does this:
for term from 1 to N do:
    print( a0 ); print (x^N); print ("+");
so all the terms come out on the same line, as in my example above. I've tried so many ways, but each time it ignores the numerical values of a0 and just writes "a0" on the screen, or breaks it up into a set, or puts || marks everywhere, or does it on sequential lines, or something or something or something.
I have Maple 16 for Windows 64-bit. How to get a printable Maple 16 Quick Reference Card? Also, how to save the Maple 16 Quick Reference Card as a separate file? (When I try to copy the Card I get en error message "selection too large").
How can I use separation of variable to solve heat equation ut=uxx on a rod of length pi/4 with u(0,t)=0, u(pi/4)=0 and u(x,0)=x(pi/4-x)
then solve heat equation by laplace transform
Dear Maple experts,
I would like to generate population data that is the best possible approximation of a multivariate normal distribution with a specified covariance matrix and vector of means. I do not want to draw a sample from a multivariate distribution, but I want the population values itself which are approximately multivariate normal distributed. The size of the datamatrix should be limited, otherwise I could draw a huge sample from a multivariate normal distribution. For instance, I would like to generate a 200 by 6 data matrix that is the best (or at least good enough) approximation of a MVN distribution. For a bivariate normal distribution one could calculate the probalities of a grid by integrating the density, but for six variables that seems undoable.
Before trying the invent the wheel again, I think I will ask this question to experts, because it is unlikely that there is no already existing algorithm that does the job pretty well.
Thanks in advance,
Harry Garst
i have a list of data, i can plot them with point plot,but i can not plot it in line style not point, could anyone help ? tnx for your help.
okay so we have to, In the Notation of this question http://www.mapleprimes.com/questions/201278-Fix-A-Syntax-Error-In-My-Simple-Function-please-Help , let f0 be contained in V be any given function and de ne
a sequence (fn) with n contained in (N subscript 0) of functions fn contained in V by
(f subscript 0) := f0  and   fn+1=Afn  for all n contained in (N subscript 0).
prove that this sequence converges pointwise, i.e. that for all   i,j contained in [N]X[N],
(f subscript infinity)(i, j) := (lim n-> infinity  fn(i, j)) exists and that "triangle"(f subscript infintiy) =0
and that
f1 = 0 :
any help would be much appreciated guys <3
I am using the following commands to create an animation of a simple cardioid being traced out. I would like to add to this an animation of the filling of the region bounded by the curve and the coordinate axes as the curve is being traced out. How might one achieve this?
animatecurve([2-2*sin(theta),theta,theta=0.. 2*Pi],coords=polar,axiscoordinates=polar,frames=250, numpoints=300, scaling=constrained)
I have a plot of a sinusoidal function(cos_phi) which changes with incrementing values of variable k. When this function goes above 1 or below -1 I would like to have the range of k for which it occurs outputed somehow. Would anybody know how to do this?
I am having trouble printing out a limit cylce on maple 16.  I have the attached file and if anybody could look at it and perhaps help me out it would be greatly appreciated.  The first limit cycle is supposed to look somewhat like the second one.  I'v tried many different things but nothing seems to be working.  an explenation would also be nice too.  if the file does not open correctly also let me know. thank you very much.
 Math_4710_Hilbert_16.mw
Say I have this list,
tmp:=[[0, 1, 2], [1, 0, 2], [1, 1, 2], [1, 2, 0]];
and the sums of each element (list),
map(x->convert(x,`+`),tmp);
How do I quickly pickup the elements, where they sum to 3? Like this:
wanttohave:=[[0, 1, 2], [1, 0, 2],  [1, 2, 0]];
Given the lengths of the three sides of a triangle, write a procedure, triType, to produce an output which shows whether the triangle is acute, right or obtuse with the three sides given??
Hi all
I have the following segment of maple program which belongs to time delay systems dynamic. here C=X-X0-G.Z-X.Dtau.P+X.Dtau.Z-U.P, is a matrix(vector) which comes from reordering the system terms and my goal is to minimizing J:=X.E.Transpose(X)+U.E.Transpose(U), subject to constraint C=0, but i don't know how to do so.
I will be so grateful if anyone can guide me
best wishes
Mahmood   Dadkhah
Ph.D Candidate
with(Optimization):
macro(LA= LinearAlgebra):
L:=1:  r:=2:  tau:= 1:
interface(rtablesize= 2*r+1):
Z:= Matrix(
     2*r+1, 2*r+1,
     [tau,
      seq(evalf((L/(2*(iz-1)*Pi))*sin(2*(iz-1)*Pi*tau/L)), iz= 2..r+1),
      seq(evalf((L/(2*(iz-1-r)*Pi))*(1-cos(2*(iz-1-r)*Pi*tau/L))), iz= r+2..2*r+1)
     scan= columns,
     datatype= float[8]
Dtau00:= < 1 >:
Dtau01:= Vector[row](r):
Dtau02:= Vector[row](r):
Dtau10:= Vector(r):
Dtau20:= Vector(r):
Dtau1:= LA:-DiagonalMatrix([seq(evalf(cos(2*i*Pi*tau/L)), i= 1..r)]):
Dtau2:= LA:-DiagonalMatrix([seq(evalf(sin(2*i*Pi*tau/L)), i= 1..r)]):
Dtau3:= -Dtau2:
Dtau4:= copy(Dtau1):
Dtau:= < < Dtau00 | Dtau01 | Dtau02 >,
         < Dtau10 | Dtau1  | Dtau2  >,
         < Dtau20 | Dtau3  | Dtau4  > >;
P00:= < L/2 >:
P01:= Vector[row](r):
P02:= Vector[row](r, j-> evalf(-L/j/Pi), datatype= float[8]):
P10:= Vector(r):
P20:= Vector(r, i-> evalf(L/2/i/Pi)):
P1:= Matrix(r,r):
P2:= LA:-DiagonalMatrix(P20):
P3:= LA:-DiagonalMatrix(-P20):
P4:= Matrix(r,r):
P:= < < P00 | P01 | P02 >,
      < P10 | P1  | P2  >,
      < P20 | P3  | P4  > >;
interface(rtablesize=2*r+1):    # optionally
J:=Vector([L, L/2 $ 2*r]):      # Matrix([[...]]) would also work here
E:=DiagonalMatrix(J);
X:=  Vector[row](2*r+1,symbol=a);
U:=Vector[row](2*r+1,symbol=b);
X0:= Vector[row](2*r+1,[1]);
G:=Vector[row](2*r+1,[1]);
C:=simplify(X-X0-G.Z-X.Dtau.P+X.Dtau.Z-U.P);
Z := Matrix(5, 5, {(1, 1) = 1., (1, 2) = 0., (1, 3) = 0., (1, 4) = 0., (1, 5) = 0., (2, 1) = 0., (2, 2) = 0., (2, 3) = 0., (2, 4) = 0., (2, 5) = 0., (3, 1) = 0., (3, 2) = 0., (3, 3) = 0., (3, 4) = 0., (3, 5) = 0., (4, 1) = 0., (4, 2) = 0., (4, 3) = 0., (4, 4) = 0., (4, 5) = 0., (5, 1) = 0., (5, 2) = 0., (5, 3) = 0., (5, 4) = 0., (5, 5) = 0.})
Dtau := Matrix(5, 5, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (2, 1) = 0, (2, 2) = 1., (2, 3) = 0, (2, 4) = 0., (2, 5) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 1., (3, 4) = 0, (3, 5) = 0., (4, 1) = 0, (4, 2) = -0., (4, 3) = -0., (4, 4) = 1., (4, 5) = 0, (5, 1) = 0, (5, 2) = -0., (5, 3) = -0., (5, 4) = 0, (5, 5) = 1.})
P := Matrix(5, 5, {(1, 1) = 1/2, (1, 2) = 0, (1, 3) = 0, (1, 4) = -.318309886100000, (1, 5) = -.159154943000000, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = .1591549430, (2, 5) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0.7957747152e-1, (4, 1) = .1591549430, (4, 2) = -.159154943000000, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (5, 1) = 0.7957747152e-1, (5, 2) = 0, (5, 3) = -0.795774715200000e-1, (5, 4) = 0, (5, 5) = 0})
E := Matrix(5, 5, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (2, 1) = 0, (2, 2) = 1/2, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 1/2, (3, 4) = 0, (3, 5) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 1/2, (4, 5) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 1/2})
X := Vector[row](5, {(1) = a[1], (2) = a[2], (3) = a[3], (4) = a[4], (5) = a[5]})
U := Vector[row](5, {(1) = b[1], (2) = b[2], (3) = b[3], (4) = b[4], (5) = b[5]})
X0 := Vector[row](5, {(1) = 1, (2) = 0, (3) = 0, (4) = 0, (5) = 0})
G := Vector[row](5, {(1) = 1, (2) = 0, (3) = 0, (4) = 0, (5) = 0})
C := Vector[row](5, {(1) = 1.500000000*a[1]-2.-.1591549430*a[4]-0.7957747152e-1*a[5]-.5000000000*b[1]-.1591549430*b[4]-0.7957747152e-1*b[5], (2) = a[2]+.1591549430*a[4]+.1591549430*b[4], (3) = a[3]+0.7957747152e-1*a[5]+0.7957747152e-1*b[5], (4) = a[4]+.3183098861*a[1]-.1591549430*a[2]+.3183098861*b[1]-.1591549430*b[2], (5) = a[5]+.1591549430*a[1]-0.7957747152e-1*a[3]+.1591549430*b[1]-0.7957747152e-1*b[3]})
J:=X.E.Transpose(X)+U.E.Transpose(U);
J := a[1]^2+(1/2)*(a[2]^2)+(1/2)*(a[3]^2)+(1/2)*(a[4]^2)+(1/2)*(a[5]^2)+b[1]^2+(1/2)*(b[2]^2)+(1/2)*(b[3]^2)+(1/2)*(b[4]^2)+(1/2)*(b[5]^2)
Minimize(J,{C=0});
Error, (in Optimization:-NLPSolve) invalid arguments
#XP:=-.015+X[1]+add(X[l+1]*f1(l)+X[r+l+1]*f2(l), l= 1..r):
#plot([XP,T1], t= 0..1);#,legend= "Solution Of x(t) with r=50"):
Download work1.mwswork1.mws
Hi , i need to write some maple functions for the equations below and i am not sure if this should be arrays or not. please see the question below;
Consider a factory which manufactures only one product. Raw material is bought from external supplier and stored until required.
Finished items are held in a warehouse. The operation of factory and its warehouse
can be modelled as a set of equations as folllows.
 Let us define at time t :
R(t) = Raw material stored (units)
F(t) = finished goods stock (units)
B(t) = order backlog (units)
T(t) = target stock level for finished goods (units)
All variables defined above give quantities at the start of week t.
X( t, t+1 )= weekly orders received from customers
M( t, t+1 )= raw material supplied per week.
P( t, t+1 )= production per week.
D(t, t+1 )= amount dispatched to customers per week.
All variables defined above give quantities over week t to t+1
(i.e over the week t). The operation of the factory and its warehouse can be expressed
as a set of equations given as follows:
Backlog and Stock Position
(1) B(t+1) = B(t)+X (t,t+1)–D(t,t+1)
(2) T(t+1) =(m +1)/m(X(t,t+1)+X(t–1,t)+…+X (t–m+1,t–m+2))
(assuming that the company wishes to maintain m (suppose m=5)) weeks stock of
finish items and hence the target level is m times the average of the last m–1 weeks)
(3) R (t+1)=R(t)+M(t,t+1)–P(t,t+1)
(4) F (t+1)=F (t) +P(t,t+1)–D(t,t+1)
Rates
(5) D (t,t+1) = B(t) if B(t)<F(t)
F (t) otherwise
(6) M (t,t+1) = P(t–1,t)
(7) P (t,t+1) = T(t) – F(t) + D(t,t+1)
= R(t) if result exceeds R(t)
= 0 if the result is negative
Given the initial values for the variables, it is possible to simulate this system to study
how the system will respond to the order rate. Suppose that all is calm, and the factory
has operated as follows for the last five weeks.
Target warehouse stock = 250
Finished goods stock = 250
Raw material stock = 150
Production rate = 50/week
Material supply rate = 50/week
Order rate = 50/week
Order backlog = 50
Suppose the behaviour continues for the first week of the simulation but that during
next week orders double due to the sales promotion. During the third week orders
drops to zero as all demand returns of the previous week was satisfied. For the fourth
week and the succeeding weeks, demand returns to an order rate of 50/week. What
happens elsewhere in the system? A deterministic simulation will provide the answer
to the above mentioned question.
 For this compute the following.
i) The values of the equations (1)–(4) at the start of week t.
ii) The values of the equations (5)–(7) i.e. the new values of the rates during
the following week.
iii) Move simulation time to the start of the next week.
Next simulation should be presented in tabular form and plot production and demand
rate to examine the performance of the system.
All help will be much appreciated.
Best Regards,
How can I solve x^2 on -Pi..Pi and to evaluate this at x= Pi to prove that Sum(1/n^2, n= 1..infinity) = Pi^2/6.
I do not have any code to produce yet.  I want to have Maple animate a bouncing ball on some 3d surface.
First 1476 1477 1478 1479 1480 1481 1482 Last Page 1478 of 2463
