[I split this off from here into a separate question. dharr]
@dharr Thanks. For the second one, an output is . Is it possible to compel Maple to attempt to simplify the second algebraic number to a less complicated expression automatically?
Its minimal polynomial can be computed. However, this is not so convenient for the specific purpose. Actually, I want something like this:
evalA(-4*RootOf(_Z^3 - 3*_Z^2 - 10*_Z - 1)^2 + 19*RootOf(_Z^3 - 3*_Z^2 - 10*_Z - 1) + 3);
                       /  3        2           \
               5 RootOf\_Z  + 10 _Z  + 3 _Z - 1/
Mathematica has an additional function RootReduce to do so directly, but I cannot find such functionality in Maple.
Remark. A fairly complicated one:
evalA(-45658*RootOf(37*_Z^6 - 382*_Z^5 + 1388*_Z^4 - 2188*_Z^3 + 1475*_Z^2 - 406*_Z + 37, index = 6)^5 + 417257*RootOf(37*_Z^6 - 382*_Z^5 + 1388*_Z^4 - 2188*_Z^3 + 1475*_Z^2 - 406*_Z + 37, index = 6)^4 - 1252087*RootOf(37*_Z^6 - 382*_Z^5 + 1388*_Z^4 - 2188*_Z^3 + 1475*_Z^2 - 406*_Z + 37, index = 6)^3 + 1463384*RootOf(37*_Z^6 - 382*_Z^5 + 1388*_Z^4 - 2188*_Z^3 + 1475*_Z^2 - 406*_Z + 37, index = 6)^2 - 558475*RootOf(37*_Z^6 - 382*_Z^5 + 1388*_Z^4 - 2188*_Z^3 + 1475*_Z^2 - 406*_Z + 37, index = 6) + 69230);
17991 RootOf\
       6         5          4          3          2
  37 _Z  - 406 _Z  + 1475 _Z  - 2188 _Z  + 1388 _Z  - 382 _Z + 37,
  index = 4/
Convert a table in a form
output≔table([(2,4)=["O-H",0.97234632],(1,2)=["O-O",1.44940000],(1,3)=["O-H",0.97232285]])
Table can have more elements in a similar form at (1,2) and (2,1) position
In the new matrix converted
We should get a square matrix
With at (2,4) and (4,2) position
0.97234632
Similarly at (1,2) and (2,1) position 1.44940000
And so on
Remember a square matrix and it is symmetric
(Deleted because not reproducible on a different PC)
With 1D
int(1/(sqrt(x__0 - x)*sqrt(-x^2 + 1)), x = 0 .. x__0)
Warning, unable to determine if -1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
Warning, unable to determine if 1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0)
With 2D
int(1/(sqrt(x__0-x)*sqrt(-x^2+1)), x = 0 .. x__0)
The root cause might be the same as for this open question.
int_warning_2D.mw
int_warning_1D.mw
Fix a plot output image size to a certain big size instead of going to each plot and then trying to maginify it where output runs through pages.
How to insert pagebreak using code itself where I want as i run code
As if I get more lines of output difficut to run through output give ctrl+Enter each place later
Kind help
Considered a list of this type
L:=[["O",3.85090000,0.45160000,0.00120000],
["O",−2.59990000,1.40410000,−0.00180000],
["N",−1.57050000,−0.71710000,0.00010000],
["C",−0.20660000,−0.42310000,−0.00020000],
["C",0.22050000,0.90470000,0.00040000],
["C",0.72980000,−1.45700000,−0.00070000],
["C",1.58410000,1.19860000,0.00020000],
["C",2.09330000,−1.16290000,−0.00070000],
["C",2.52040000,0.16480000,−0.00030000],
["C",−2.64850000,0.17820000,0.00090000],
["C",−3.97350000,−0.54200000,0.00100000],
["H",−0.44360000,1.75770000,0.00120000],
["H",0.41130000,−2.49630000,−0.00100000],
["H",−1.80100000,−1.70860000,0.00010000],
["H",1.90530000,2.23700000,0.00090000],
["H",2.81800000,−1.97260000,−0.00080000],
["H",−4.06550000,−1.14630000,−0.90580000],
["H",−4.79040000,0.18440000,0.02880000],
["H",−4.04450000,−1.18860000,0.88020000],
["H",3.96500000,1.41760000,0.00170000]];
Find out the indexs of the list within the list where "H" is their and to store is set S.
Here we can say 12th list have "H"
Similarly 13th list has "H" and so on
So it will output a set
{11,12,13,...}
A function which takes a list like above as input and outputs the set which give index positions of lists containing "H"
Is their anyway in by which given a molecule I can code to get the hydrogen depleted form of the molecule using Maplesoft quantum chemistry toolbox
After hydrogen depleted get the BondDistances table of that depleted molecule structure
I have a third order equations, I would like to know the sign of its roots, not necessary to find the roots since the equations contains some parameters. All parameters used are positives.
roots.mw
thank you
Here is the full code with output and errors.
restart; with(plots): with(plottools):
w:=-Ps/2*(Hk*cos(theta)^2+2*H*cos(theta-psi));
             1    /             2                        \
      w := - - Ps \Hk cos(theta)  + 2 H cos(-theta + psi)/
dw:=diff(w,theta);
dw := - - Ps (-2 Hk cos(theta) sin(theta) + 2 H sin(-theta + psi))
equ:=dw=0;
           equ := - - Ps (-2 Hk cos(theta) sin(theta)
              + 2 H sin(-theta + psi)) = 0
Hg:=(sin(psi)^(2/3)+cos(psi)^(2/3))^(-3/2);
           Hg := ------------------------------------
                                                (3/2)
                 /        (2/3)           (2/3)\
                 \sin(psi)      + cos(psi)     /
psi:=35.0*Pi/180;H:=0.1;Ps:=1.0;Hk:=1.0;
                      psi := 0.6108652383
                            H := 0.1
                           Ps := 1.0
                           Hk := 1.0
Hc:=evalf(Hk*Hg); theta:='theta';
                       Hc := 0.5103773339
                         theta := theta
theta_s:=evalf(Pi-arctan(tan(psi)^1/3));
                     theta_s := 2.912295114
H:='H';np:=100;H_max:=1.0;
                             H := H
                           np := 100
                          H_max := 1.0
h_p:=array(1..np):
h_n:=array(1..np):
m_p:=array(1..np):
m_n:=array(1..np):
h_p[1]:=0.0;m_p[1]:=cos(psi);
                          h_p[1] := 0.
                     m_p[1] := 0.8191520442
for i from 2 to np do
   h_p[i]:=(i-1)*H_max/(np-1):
   H:=h_p[i]:
   theta_plus:=fsolve(equ,theta,0..Pi/2):
   m_p[i]:=evalf(cos(theta_plus-psi)):
h_n[1]:=0.0; m_n[1]:=evalf(cos(Pi-psi));
                          h_n[1] := 0.
                    m_n[1] := -0.8191520446
for i from 2 to np-1 do
   h_n[i]:=(i-1)*Hc/(np-1):
   H:=h_n[i]:
   theta_minus:=fsolve(equ,theta,theta_s..Pi);
   m_n[i]:=evalf(cos(theta_minus-psi)):
h_n[np]:=Hc; m_n[np]:=evalf(cos(theta_minus-psi));
                    h_n[100] := 0.5103773339
    m_n[100] := cos(fsolve(1.000000000 cos(theta) sin(theta)
       + 0.5052220075 sin(theta - 0.6108652383) = 0, theta,
      2.912295114 .. Pi) - 0.6108652383)
pl_pp:=array(1..np):
pl_pn:=array(1..np):
pl_np:=array(1..np):
pl_nn:=array(1..np):
i:='i';
                             i := i
NULL;
NULL;
NULL;
NULL;
for i from 1 to np do
   pl_pp[i]:=point([h_p[i],m_p[i]],color=red):
   pl_np[i]:=point([h_n[i],m_n[i]],color=blue):
   pl_pn[i]:=point([-h_n[i],-m_n[i]],color=red):
   pl_nn[i]:=point([-h_p[i],-m_p[i]],color=blue):
Error, (in plottools:-point) incorrect arguments for creating points structure, try providing the dimension option
display([seq(pl_pp[i],i=1..np),seq(pl_np[i],i=1..np),seq(pl_pn[i],i=1..np),seq(pl_nn[i],i=1..np)]);
Error, (in plots:-display) expecting plot structures but received: [pl_pp[60], pl_pp[61], pl_pp[62], pl_pp[63], pl_pp[64], pl_pp[65], pl_pp[66], pl_pp[67], pl_pp[68], pl_pp[69], pl_pp[70], pl_pp[71], pl_pp[72], pl_pp[73], pl_pp[74], pl_pp[75], pl_pp[76], pl_pp[77], pl_pp[78], pl_pp[79], pl_pp[80], pl_pp[81], pl_pp[82], pl_pp[83], pl_pp[84], pl_pp[85], pl_pp[86], pl_pp[87], pl_pp[88], pl_pp[89], pl_pp[90], pl_pp[91], pl_pp[92], pl_pp[93], pl_pp[94], pl_pp[95], pl_pp[96], pl_pp[97], pl_pp[98], pl_pp[99], pl_pp[100], pl_np[59], pl_np[60], pl_np[61], pl_np[62], pl_np[63], pl_np[64], pl_np[65], pl_np[66], pl_np[67], pl_np[68], pl_np[69], pl_np[70], pl_np[71], pl_np[72], pl_np[73], pl_np[74], pl_np[75], pl_np[76], pl_np[77], pl_np[78], pl_np[79], pl_np[80], pl_np[81], pl_np[82], pl_np[83], pl_np[84], pl_np[85], pl_np[86], pl_np[87], pl_np[88], pl_np[89], pl_np[90], pl_np[91], pl_np[92], pl_np[93], pl_np[94], pl_np[95], pl_np[96], pl_np[97], pl_np[98], pl_np[99], pl_np[100], pl_pn[59], pl_pn[60], pl_pn[61], pl_pn[62], pl_pn[63], pl_pn[64], pl_pn[65], pl_pn[66], pl_pn[67], pl_pn[68], pl_pn[69], pl_pn[70], pl_pn[71], pl_pn[72], pl_pn[73], pl_pn[74], pl_pn[75], pl_pn[76], pl_pn[77], pl_pn[78], pl_pn[79], pl_pn[80], pl_pn[81], pl_pn[82], pl_pn[83], pl_pn[84], pl_pn[85], pl_pn[86], pl_pn[87], pl_pn[88], pl_pn[89], pl_pn[90], pl_pn[91], pl_pn[92], pl_pn[93], pl_pn[94], pl_pn[95], pl_pn[96], pl_pn[97], pl_pn[98], pl_pn[99], pl_pn[100], pl_nn[59], pl_nn[60], pl_nn[61], pl_nn[62], pl_nn[63], pl_nn[64], pl_nn[65], pl_nn[66], pl_nn[67], pl_nn[68], pl_nn[69], pl_nn[70], pl_nn[71], pl_nn[72], pl_nn[73], pl_nn[74], pl_nn[75], pl_nn[76], pl_nn[77], pl_nn[78], pl_nn[79], pl_nn[80], pl_nn[81], pl_nn[82], pl_nn[83], pl_nn[84], pl_nn[85], pl_nn[86], pl_nn[87], pl_nn[88], pl_nn[89], pl_nn[90], pl_nn[91], pl_nn[92], pl_nn[93], pl_nn[94], pl_nn[95], pl_nn[96], pl_nn[97], pl_nn[98], pl_nn[99], pl_nn[100]]
NULL;
NULL;
@David Mazziotti
I just purchased the quantum chemistry package
The plotmolecule is not giving the correct structure of the attached xyz file can you please confirm and help
I am attaching
A.xyz    as     A.txt
Please rename it .xyz as maple is not allowing to attach a xyz file.
XYZ  file :       A.txt     Rename as xyz
Image file of the molecule which is expected:
Image coming from maple code:
It can be observed that the bond between yellow (Sulfur ) and carbon missing
Code given below I typed
with(QuantumChemistry);
molecule := ReadXYZ("A.xyz");
print(PlotMolecule(molecule));
The help page solve/details claims that solve(x^2-1,{x}, useassumptions) assuming x>0; is equivalent to solve({x^2-1, x>0},{x});. But the following example perplexes me again.
Considering a multi-variable polynomial:
expr := 36*a^3*b^3+8*a^2*b^2*(9*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)+((a-b)^2-2*(a+b)+1)^2*(a+b+1)^5+a*b*((a-b)^2-2*(a+b)+1)*(17*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)^2: # assuming nonnegative
I intend to find the nonnegative real roots of it.
solve({expr = 0, (a, b) >= ~ 0}, [a, b], allsolutions);
solve(expr = 0., [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
solve({expr = 0., (a, b) >= ~ 0}, [a, b], allsolutions);
all return six solutions, but curiously,
solve(expr = 0, [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
only returns four solutions. Why???
In addition, as you can see, the first output (i.e., sol1) is thoroughly less meaningful. Can't it be more readable??
sol1 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b], allsolutions) =
[[a = 0, b = 1], [a = 3^(1/2)-1, b = RootOf((-741235976922591048947725497133370413109846163676281959390560108171291511786260537194814187602376638467882392432305864*3^(1/2)+1283858372427879519277780718816094877088966867890478064541174875107114975191197490158346515516574907111238006510832897)*_Z^8+(542622395505288470330055221682724463979120704214196105150614766935823463404936952963532327914198268643355614078527033*3^(1/2)-939849558339893627565395772584016362240571623138367813630505449406759560167584121426096047290555008292409170786084695)*_Z^7+(27663303262730616171732317130828357033086591952430419833222950914496979987637185645479748907213281840470027913754446250*3^(1/2)-47914246756235321853987379290323009935074722268098020072540300747281044857411765919011355938402797296261231903185833860)*_Z^6+(-36848925451143075385294452437991667121840085487125852139251120381482252862356891660819456375517484560073220737684055360*3^(1/2)+63824211085697719773601999676355867125229886950052051470652732444578522019946850568834704346278726602905590979989005206)*_Z^5+(-361541600067355242269699717707379679953498397064818094940691654358197984962782803819129269994590941790029033835785321091*3^(1/2)+626208420366406708672813369852190896907780666621957659007533759258885959287096424079349105562785060297582745252447270847)*_Z^4+(469917886838763314544262854134623783463102170709338866937842556434901449696233730989733509809486602395675273592523379039*3^(1/2)-813921655390140293483357785790922432834508040979560342164969934794994487106266639300148834412459020073129881509269947685)*_Z^3+(2419091701164731099042357448446421888413075728672522494523180828886450053865285232431099171783692236478370266582727759022*3^(1/2)-4189989734585541679787610388006771626857619186946433018568920261866881451820006582050966407487366628715776067639375659568)*_Z^2+(-276526595929812923186277260098945143564039808175960075417091066631428638512893788855336862569832144723039829695578843580*3^(1/2)+478958113794505090444730274771005660986137994458744274847200001817421835204311147220572248669252963586284164359082018778)*_Z-2241557156236496486338463519192106892320755475146925672942972549523504139162741341146795559700763371271548957041603585449*3^(1/2)+3882490882671219790342097523842232566093205006918585285230133334462570311857306952032638288791685675699575851624588398080, index = real[4])], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1], [a = 1/2+(1/2)*3^(1/2), b = RootOf((3265859930834838622581170032695923790177759993209560990735389424723672715638564736*3^(1/2)+5656635330609319983539361351500545583607599001912359529744925502462343818424446992)*_Z^8+(12188355192278997228701701416892393163963118988331481511215704351909689249701576464*3^(1/2)+21110850453723155834822232801088862537748477983453402031696019279095705783764588192)*_Z^7+(-16329299654174193112905850163479618950888799966047804953676947123618363578192823680*3^(1/2)-28283176653046599917696806757502727918037995009561797648724627512311719092122234960)*_Z^6+(-47558033069228748234327710008167261759137556448974526775358049368769421447413364728*3^(1/2)-82372929583945025397186856831061837257531071444955446405553455730528485970812729160)*_Z^5+(71016746435016238932635448066739883738739336153617153345258159361269798232579788444*3^(1/2)+123004613013684064253013423478212462789515684702771043974383244940692061281906669908)*_Z^4+(-539074301591972734261861623983834399153978765971327430710378028630584341753429268*3^(1/2)-933704079412004867600664919608623045951401970711134655767859337789085046795723776)*_Z^3+(-8660811640968922793242100644402781523021841461481655906743406226105766029465794376*3^(1/2)-15000965796942156111966381948246207258139974790596863072851606476670777826354805396)*_Z^2+(-30769734905669303241874027457081560634086527346916553595415452889491557012102176442*3^(1/2)-53294744192044789072581100596045559567736905080848045509547703544202848750472876382)*_Z-3181857373467742490740890760219056890779274438575702235481520595135068397863751433*3^(1/2)-5511138633283790175605724430174371395924969988541134171865969654221197707640077992, index = real[4])]]
sol2 := `assuming`([solve(expr = 0., [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) =
[[a = 0., b = 1.], [a = .7320508076, b = 1.000000000], [a = 1., b = 0.], [a = 1., b = .7320508076], [a = 1., b = 1.], [a = 1.366025404, b = 1.366025404]]
sol3 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0.}, [a, b], allsolutions) =
sol4 := `assuming`([solve(expr = 0, [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) = [[a = 0, b = 1], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1]]NULL
_SolutionsMayBeLost;
_SolutionsMayBeLost
numelems(sol1), numelems(sol2), numelems(sol3), numelems(sol4) = 6, 6, 6, 4NULL
sol5 := [[a = 0, b = 1], [a = sqrt(3)-1, b = 1], [a = 1, b = 0], [a = 1, b = sqrt(3)-1], [a = 1, b = 1], [a = (sqrt(3)+1)*(1/2), b = (sqrt(3)+1)*(1/2)]]
Why did't solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b]) return sol5?
map2(evala@eval, expr, sol5);
[0, 0, 0, 0, 0, 0]
Error, (in type/algext) too many levels of recursion
Download solve_details.mw
 Can you tell me how I can create the variation tab of a function with Maple 2022?
Thanking you,
,DAVID CRESPIL
I have only seen big O show up in series solutions, as in
series(sin(x),x)
I've never seen it before show up in result of solve
eq:=x=p*(a*ln(p+sqrt(p^2-2))+2*_C1)/(2*sqrt(p^2-2));
sol:=solve(eq,p);
What does it actually mean when the solution has  O(RootOf(....))?
Should not result of solve be exact? isn't having big O means an approximation?
Maple 2022.2 on windows 10
Q1: Is it possible to find out where a warning was generated (i.e. which procedure issued the warning)?
Q2: Is a command specific warning suppression possible? Something like that for example: infolevel[int] := 0
Q3: Can warnings be removed form a document before printing it?
Typical warnings I want to suppress are attached
Download warnings_to_suppress.mw
Update: for the attached warnings Typesetting:-Settings(parserwarnings = false) is effective, which does not work for warnings discussed bellow.
So for my project, I need to be able to do this integral for different values of "l". Here is the integral I need to evaluate:
Where "R", "Xi", and "l" are all constant. When I try to do it, it gives back an imaginary number. The absolute value of this imaginary number seems to be correct but I'm not sure why it's imaginary. This is a plot of what it should give for various values of "l":
Here is my maple code copy-pasted from the application (I'm new to Maple and this forum and cannot figure out how to attach the file version of my code sorry):
Digits := 30;
E := 3.83*10^14;
                                            14
                  E := 3.8300000000000000 10
R := 0.1*E;
                                            13
                  R := 3.8300000000000000 10
l := 0.01*R;
                                            11
                  l := 3.8300000000000000 10
A := int((-4*E^2 + r^2)^(1/2)*(R^2 - l^2 + r^2)/((R^2 - (l - r)^2)^(1/2)*((l + r)^2 - R^2)^(1/2)), r = abs(l - R) .. l + R)/(Pi*R^2);
             A := 19.9744824651978825998722703010 I
Max := (1 + 4*(E/R)^2)^(1/2);
             Max := 20.0249843945007857276972121483
NULL;
Here is the code when I exported as maple input:
NULL;
Digits := 30;
E := 3.83*10^14;
R := 0.1*E;
l := 0.01*R;
NULL;
Thank you in advance!
First 229 230 231 232 233 234 235 Last Page 231 of 2427
