I am a little not clear why Maple's odeadvisor gives [_2nd_order, _reducible, _mu_xy] as an ode type for a second order ode which is already exact as is.
When the ode is exact, then no integrating factor mu is needed (or rather mu=1). But Maple says the ode is "reducible" using an integrating factor mu(x,y)
ode:=x*diff(diff(y(x),x),x)+(y(x)-1)*diff(y(x),x)=0;
DEtools:-intfactor(ode);
DEtools:-odeadvisor(ode)
THis ode is Kamke's 6.78, it is alslo mentioned in this paper in table 1 at page 18
I am just little confused, about the terminology. I thought reducible means the ode reguire an integrating factor of the form mu(x,y) or my(x,y') or mu(y,y') when it is not exact in order to make it to an exact ode so it can be now solved.
Why would odeavisor then says an ode which is already exact is also reducible using mu(x,y)?
 How to rectify the Error, (in MTM:-findsym) invalid input: a string/name list is expected for sort method `lexorder`   .Could you please help me to plot the curve.
TC1.mw
Are Maple settings responsible for this error:
My worksheet carries out some preliminary checks and if these fail I want to prevent or cancel any further executuon of the worksheet.  Something like (pseodo-code)
llContinue = DoThePreliminaryChecks()
If Not llContinue
    Cancel/Return/?
EndIf
I couldn't find anything in the docs or with Google.  Any suggestions?  Thanks.
Mathematica's Dimensions returns a list of the allowed levels, which has been implemented in Maple as . But
MmaTranslator:-Mma:-Dimensions(<<1 | 2>, <1 | 0>>);
returns [6], and
MmaTranslator:-Mma:-Dimensions([[1, 2], [1, 0]]);
returns [2, 2, 4]. What happened here?
It should be [2, 2].
MmaTranslator:-Mma:-Dimensions(linalg[matrix]([[1, 2], [1, 0]]));
[0]
MmaTranslator:-Mma:-Dimensions(< 1 , 2 ; 1 , 0 >);
[6]
MmaTranslator:-Mma:-Dimensions(convert(`{{1, 2}, {1, 0}}`, FromMma));
[2, 2, 4]
MmaTranslator:-FromMma(`Dimensions[{{1, 2}, {1, 0}}]`, evaluate);
[2, 2]
Download Mma[Dimensions].mws
I have a vector (matrix) that looks like this. I want to save it to txt text. But the Export function doesn't seem to do that.
M:=Vector[column](10, [{{a, b}, {b, c}}, {{d, e}, {e, f}},
{{d, f}, {e, f}}, {{a, h}, {h, i}}, {{a, i}, {h, i}},
{{d, e}, {d, f}}, {{a, h}, {a, i}},{{c, d}}, {{a, b}, {a, c}}, {{a, c}, {b, c}}]);
Export(M,"E:\\M.txt");
Error, (in Export) invalid input: Export expects its 1st argument, input, to be of type string when target=file, but received Vector(10, [{{a, b}, {b, c}},{{d, e}, {e, f}},{{d, f}, {e, f}},{{a, h}, {h, i}},{{a, i}, {h, i}},{{d, e}, {d, f}},{{a, h}, {a, i}},{{c, d}},{{a, b}, {a, c}},{{a, c}, {b, c}}])
I found that I can save it in xsl format.
with(ExcelTools): Export(M, "E:\\M.xls");
How to save M in txt format below?
Hi Everyone,
I intend to find the invariants of a 2nd-order Tensor using the representation of the rotational group as an Infinitesimal generator. However, maple does not seem to find the correct invariants $\tr \mathbf{a}$, $\tr \mathbf{a}^2$, $\tr \mathbf{a}^3$. Maple only returns an empty set. I can't seem to figure out why that is the case.
Here is my code
with(PDETools)
assume(r >= 0)
interface(showassumed = 0)
X_z2 := (-a__21-a__12)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__11))+(a__11-a__22)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))-a__23*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))+(a__11-a__22)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+(a__12+a__21)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__22))+a__13*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))-a__32*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+a__31*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32)) = 0
X_y2 := (-a__31-a__13)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__11))-a__32*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))+(a__11-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))-a__23*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+a__21*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))+(a__11-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+a__12*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32))+(a__13+a__31)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__33)) = 0
X_x2 := -a__13*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__12))+a__12*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__13))-a__31*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__21))+(-a__32-a__23)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__22))+(a__22-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__23))+a__21*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__31))+(a__22-a__33)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__32))+(a__23+a__32)*(diff(f_1(x, y, z, a__11, a__12, a__13, a__21, a__22, a__23, a__31, a__32, a__33), a__33)) = 0
sys := [X_z2, X_y2, X_x2]
sol := pdsolve(sys)
Download SO(3)_spherical_2.mw
Any input would be appreciated!
I am first time using the Flexble Beam block, and I tried simple cantilever beam with mass at the free end. Deflection is not as I expected (comparing to my hand calculations). I have tried also to use Force instead of mass (with a same load quantity), but nothing changed. Is there something that I might be missing? Expected deflection of a free end is 15 mm (I have obtained 2,8 mm in Maplesim).
Hello there,
Is the price of 295 USD for unlimited use in time?
Kind regards,
Eduardo
Hello guys,
Can anyone recommend good books on advanced programming and other Maple topics? The books I have only have the basics.
Oliveira
Maple standard Output
int(f(x), x)
int(f(x), x)
Desired output with an italic d (here formated manualy with the  in the menu bar)
int(f(x), x)
int(f(x), x)
which reverts to roman layout either after re-execution of the worksheet or re-evaluation.
  int(f(x), x)
int(f(x), x)
Background:
I would like to achieve textbook style formatting of integrals in Maple output. I am aware that interpreting a dx in an integral as a "differential" is controversial. The way Maple displays the integration variable in italic and the d in roman makes sense and avoids confusion with interpretations that are no longer needed.
However, what I want to avoid is mixing
dx and dx in the same document.
Can Maple be set by default that the d in the dx of an integral becomes italic?
If this is not possible and because this question comes from habits in physics: Would a display option in the physics package be possible?
Download Differential_format_in_integrals.mw
Execute the following codes in Maple input (1-D math) in the Standard interface.
(cat("A".."C"),cat("d".."f"))||'$"G".."I",$"j".."l"';
Then an error occurred. But if one copy them into 2-D math (instead of Convert To>2-D Math Input) and execute them directly, everything goes without any error messages.
It says that mixed 1-D and 2-D math inside one command is not supported and not recommended stylistically. However, I just want to understand the reason why an error is raised here.
kernelopts(version);
`Maple 2022.2, X86 64 WINDOWS, Oct 23 2022, Build ID 1657361`
Error, `||` unexpected
cat("A" .. "C"), cat("d" .. "f") || '`$`("G" .. "I"), `$`("j" .. "l")'
"AG", "AH", "AI", "Aj", "Ak", "Al", "BG", "BH", "BI", "Bj", "Bk", "Bl", "CG", "CH", "CI", "Cj", "Ck", "Cl", "dG", "dH", "dI", "dj", "dk", "dl", "eG", "eH", "eI", "ej", "ek", "el", "fG", "fH", "fI", "fj", "fk", "fl"
Download unexpectedConcatenation.mws
I am having trouble with this a system of 12 differential equations with the respective 12 initial conditions. I try to usen dsolve with the "numeric" parameter but it stays "evaluating" forever. I tried a system of 10 equation and I got the correct answer, although the program stayed calculating for several minutes (more or less 5 minutes). Is the size of this system too much to handle for the program?
This is the system of differential equations (sys) and the initial conditions (ics) that I am trying to solve:
maple_primes_question.mw
sys := {diff(a[0](t), t)-(diff(a[1](t), t))+diff(a[2](t), t)-(diff(a[3](t), t))+diff(a[4](t), t)-(diff(a[5](t), t)) = 0, diff(b[0](t), t)+diff(b[1](t), t)+diff(b[2](t), t)+diff(b[3](t), t)+diff(b[4](t), t)+diff(b[5](t), t) = 0, diff(a[0](t), t)-.8090169943*(diff(a[1](t), t))+.309016994*(diff(a[2](t), t))-16*a[2](t)+.3090169950*(diff(a[3](t), t))+77.66563145*a[3](t)-.809016994*(diff(a[4](t), t))-187.3312629*a[4](t)+1.000000002*(diff(a[5](t), t))+289.4427191*a[5](t) = 0, diff(a[0](t), t)-.3090169938*(diff(a[1](t), t))-.8090169951*(diff(a[2](t), t))-16*a[2](t)+.8090169933*(diff(a[3](t), t))+29.66563140*a[3](t)+.3090169967*(diff(a[4](t), t))+27.33126306*a[4](t)-1.000000000*(diff(a[5](t), t))-110.5572808*a[5](t) = 0, diff(a[0](t), t)+.3090169938*(diff(a[1](t), t))-.8090169951*(diff(a[2](t), t))-16*a[2](t)-.8090169933*(diff(a[3](t), t))-29.66563140*a[3](t)+.3090169967*(diff(a[4](t), t))+27.33126306*a[4](t)+1.000000000*(diff(a[5](t), t))+110.5572808*a[5](t) = 0, diff(a[0](t), t)+.8090169943*(diff(a[1](t), t))+.309016994*(diff(a[2](t), t))-16*a[2](t)-.3090169950*(diff(a[3](t), t))-77.66563145*a[3](t)-.809016994*(diff(a[4](t), t))-187.3312629*a[4](t)-1.000000002*(diff(a[5](t), t))-289.4427191*a[5](t) = 0, diff(a[1](t), t)+4*(diff(a[2](t), t))+9*(diff(a[3](t), t))+16*(diff(a[4](t), t))+25*(diff(a[5](t), t))-3*(diff(b[1](t), t))+12*(diff(b[2](t), t))-27*(diff(b[3](t), t))+48*(diff(b[4](t), t))-75*(diff(b[5](t), t)) = 0, diff(b[0](t), t)-.8090169943*(diff(b[1](t), t))+.309016994*(diff(b[2](t), t))-48*b[2](t)+.3090169950*(diff(b[3](t), t))+232.9968944*b[3](t)-.809016994*(diff(b[4](t), t))-561.9937886*b[4](t)+1.000000002*(diff(b[5](t), t))+868.3281572*b[5](t) = 0, diff(b[0](t), t)-.3090169938*(diff(b[1](t), t))-.8090169951*(diff(b[2](t), t))-48*b[2](t)+.8090169933*(diff(b[3](t), t))+88.99689421*b[3](t)+.3090169967*(diff(b[4](t), t))+81.99378917*b[4](t)-1.000000000*(diff(b[5](t), t))-331.6718425*b[5](t) = 0, diff(b[0](t), t)+.3090169938*(diff(b[1](t), t))-.8090169951*(diff(b[2](t), t))-48*b[2](t)-.8090169933*(diff(b[3](t), t))-88.99689421*b[3](t)+.3090169967*(diff(b[4](t), t))+81.99378917*b[4](t)+1.000000000*(diff(b[5](t), t))+331.6718425*b[5](t) = 0, diff(b[0](t), t)+.8090169943*(diff(b[1](t), t))+.309016994*(diff(b[2](t), t))-48*b[2](t)-.3090169950*(diff(b[3](t), t))-232.9968944*b[3](t)-.809016994*(diff(b[4](t), t))-561.9937886*b[4](t)-1.000000002*(diff(b[5](t), t))-868.3281572*b[5](t) = 0, diff(a[0](t), t)+diff(a[1](t), t)+diff(a[2](t), t)+diff(a[3](t), t)+diff(a[4](t), t)+diff(a[5](t), t)-(diff(b[0](t), t))+diff(b[1](t), t)-(diff(b[2](t), t))+diff(b[3](t), t)-(diff(b[4](t), t))+diff(b[5](t), t) = 0}
ics := {a[0](0) = 0.7499999990e-1, a[1](0) = .1500000001, a[2](0) = .1500000002, a[3](0) = .1500000000, a[4](0) = .1499999999, a[5](0) = 0.7499999987e-1, b[0](0) = .9750000000, b[1](0) = 0.5000000005e-1, b[2](0) = -0.5000000005e-1, b[3](0) = 0.5000000000e-1, b[4](0) = -0.4999999998e-1, b[5](0) = 0.2499999996e-1}
sols := dsolve(`union`(sys, ics), numeric)
Download maple_primes_question.mw
What am I doing wrong? or is it that the program cannot handle such a large system? In that case, that would be dissappointing since I have to solve a similar system but with up to 22 differential equations and initial conditions so I am stuck...
Anyway, thank you very much for any guidance, and happy new year.
 A:= <x1,y1,z1>:  B:= <x2,y2,z2>:  P :=<x3, y3, z3>:  H:=A+t*(B-A):  solve( (P-H)^+ . (B-A), t ):  'H'=eval(H, t=`%` );
Error, invalid powe, rhow to overcome this mistake ? Thank you.
Typesetting:-mambiguous( AAssign (x1commay1commaz1)colon  BAssign
  (x2commay2commaz2)colon  P Assign(x3comma y3comma z3)colon  H
  AssignA + tast(Buminus0A)colon  solveApplyFunction(
  Typesetting:-mambiguous((Puminus0H)circ + ,
  Typesetting:-merror("invalid power")) period (Buminus0A)comma t
   )colon  (H)equalsevalApplyFunction(Hcomma tequals% )semi)
Simple question I cannot remember the solution of.
When I import "executable maple input" from a file, the content is imported as a string and therefore have quotation marks around the code if saved in a variable. It therefore wont execute.
How do you defeat quotation marks around  executable maple code with a command in order to execute the code ?
First 244 245 246 247 248 249 250 Last Page 246 of 2427
