A "while" ago this was possible by commands. E.g.:
(from https://www.youtube.com/watch?v=uaQh_bXcIGA)
I consulted the help pages for Export and CodeGeneration options, but could not find anything suitable to generate a C code file.
Did I overlook something or searched for the wrong help pages?
If such options no longer exist, what is the preferred way to transfer C code from Maple to MapleSim?
Am I supposed to copy, paste & save with a third party editor? If I do so for a C code generated from a Maple procedure (generated with makeproc), I get
A complete example that works in 2022 versions would be helpfull. The tutorial "6.6 Tutorial 6: Using the External C Code/DLL Custom Component App" unfortuneately does not include code generated by Maple that can be imported, compiled, simulated and verified against a MapleSim model as in the example from youtube (which is still very instructive by the way).
After loading the Physics package, I have define the langragian L this way:
L:=sqrt((1+(y')^2)/y)
After some algebra, I get the following integral:
((1+(y'(x))^2)^(-1)*1/y(x) = C
At that stage, I would like to isolate the term y'(x) and do the change of variable. But since I am under the Physics package, I try to isolate it with no succes and worst if I try to change the variable first. A little help would be appreciate.
Thank you in advance
Mario
Maple 2022 under Windows
I have a nonlinear system of 12 SYMBOLIC equations in 6 variables. I am using solve() but it's taking me ages and will probably return the "Kernel connection has been lost" error after a half-day/ a day.
How do I solve it? Is it even possible to solve it? Is there a way to solve it approximately?
Where is the problem within this procedure which I can not get the numerical values of V[1] , V[2], ...
A := Matrix([[2*t, 2, 3], [4, 5*t, 6], [7, 8*t, 9]])
A := Matrix(3, 3, {(1, 1) = 2*t, (1, 2) = 2, (1, 3) = 3, (2, 1) = 4, (2, 2) = 5*t, (2, 3) = 6, (3, 1) = 7, (3, 2) = 8*t, (3, 3) = 9})
B := LinearAlgebra:-Transpose(Matrix([t, 2*t, 3*t]))
B := Matrix(3, 1, {(1, 1) = t, (2, 1) = 2*t, (3, 1) = 3*t})
test:=proc(n)
  local s,t,M,V;
  s:=1:
  for t from 1 to n do
    M:=A+A^(-1);
    V[s]:=(M.B):
    s:=s+1:
  V;
test(4)
V
V[1]
V[1]
Download ProcPropl.mw
fig([L1(color = blue), L2(color = blue), L3(color = green), C1(color = black), C2(color = black), C3(color = orange), C4(color = orange)]);
point(oo, [0, 0]);
                               oo
rotation(fig1, fig, oo, Pi/2, 'counterclockwise');
Error, (in geometry:-rotation) wrong type of arguments why thos error ? Thank you;
q := (f)->local ff := `if`(type(f,procedure),f,`x`->f); ff(z + (ff(k))):
Trying to create something so that I can do q(x) or q(x->x^2) or whatever.
Trying to understand the difference between an expression and a function as represented by maple. I thought I could just turn whatever is passed to q, such as x*cos(x) in to a function by x->x*cos(x) as one would do normally but this does not work.
How_to_collect_Coefficent.mw
Kindly help me to find the coefficients from the equation. I have attached the MAPLE file here.
Thank You
Is there any easy way to do subs([a,b,c]=x, [2,4,5,1,a,4,5,a,b,434,a,b,c,5,5,5,1]) = [2,4,5,1,a,4,5,a,b,434,x,5,5,5,1]
and another way to get [2,4,5,1,a,4,5,a,b,434,x,b,c,5,5,5,1]
The first subsitutes the entire match and the second substitutes when matches but only for first element.
I know I can write routines to do this and will after posting this but is there a native way that is simple?
I try to enrich the layout of my documents by tables like that of trigonometric numbers. Is there a way to make it simpler? without going through the encoding of all values.Thanks
TableauTest.mw
The worksheet below displays a sphere with a surface patch defined by the arcs of three intersecting circles on the sphere's surface.
How can the patch be colored differently from the non-patch sphere's surface?
Patch_on_a_Sphere.mw
I am looping over a list of functions to calculate various properties of the said functions. some of these calculations take too long. I was wondering if there was a way to skip to the next element of the loop if a calculation takes more than a specific time.
 I looking to contact a maple sales representative. I am from india I am not getting any contact number. Can anyone help.
Kind help anyone if possible. I do research in mathematics  field but at a personal level. I need help on which product to buy and a sales represitive number or someone to contact me so that i can first understand certain doubts from my personal end then I can opt for.
I may have asked this before, but if so lost answer.
I'm trying to put a relatively elaborate peace of code in a loop, but can't figure out how to have multiple lines. Each command separated by ';' is awkward and seems to cause me to make even more typos then normal and it's hard to read the code.
Is there a way to have command on separate lines with in a loop?
-Arthur
I used Maple to factor (using ifactor) the number 10^128 + 1.  Maple produced the factors in a matter of seconds.
One of the factors had 116 digits.  I then restarted Maple and executed the command ifactor(X) where X was the
factor with 116 digits.  Maple found the number was prime instantly.  I do not understand how one can determine
that a number  with 116 digits is prime in less than a second.  My guess is that Maple has stored some large primes.
Also I used  Maple to factor (10^128+3) and I turned the program off because it was taking forever.
First 282 283 284 285 286 287 288 Last Page 284 of 2428
