I have a non-linear deq of 2nd order which I want to solve numerically. The integration should stop if the integrated variable exceeds a certain value, i.e. phi(t)>phi_ end or equivalently phi(t)-phi_end>0. Maple doesn't accept this type of event and the test phi(t)=phi_end doesn't catch (obviously). How to work around?
just downloaded maple on my windows computer with AMD processor but I can't get it to work!!!!
The program opens up but as soon as I start to write, the program freezes. When the program is frozen there is nothing I can do I can't even close it.
I have tried just about everything ( antivirus, deleting the program, updating the computer) u name it.
if anyone has any suggestions, please write to me!!!
Hi everyone, I have copied soem code from a paper. I hope to try and manupiluate some of the varables. However it seems while I am coping the code I get this error Error, (in dsolve/numeric/process_input) system must be entered as a set/list of expressions/equations .I have checked online but it seems that there is nothing I can find to fix this problem. My code is posted below
Thanks for your time and help!
with(VariationalCalculus)
with(ODEtools)
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received ODEtools
with(DEtools)
with(plots); with(plottools); PDEtools[declare]((theta, phi, psi)(t), prime = t)
`derivatives with respect to`*t*`of functions of one variable will now be displayed with '`
with(linalg)
We will now declare our first equations
x[1] := l[1]*sin(theta(t))
y[1] := -l[1]*cos(theta(t))``
x[2] := -l[2]*sin(theta(t)); y[2] := l[2]*cos(theta(t))
x[4] := x[1]-l[4]*sin(theta(t)+phi(t)); y[4] := y[1]+l[4]*cos(theta(t)+phi(t)); x[3] := x[2]+l[3]*sin(theta(t)-psi(t)); y[3] := y[2]-l[3]*cos(theta(t)-psi(t))
R[1] := vector(2, [x[1], y[1]]); R[2] := vector(2, [x[2], y[2]]); R[4] := vector(2, [x[4], y[4]]); R[3] := vector(2, [x[3], y[3]])
`\`R`[1]*` ≔ map`(diff, R[1], t); `\`R`[2]*` ≔ map`(diff, R[2], t); `\`R`[4]*` ≔ map`(diff, R[4], t); `\`R`[3]*`≔map`(diff, R[3], t)
T := combine(simplify(collect((1/2)*m[1]*innerprod(`\`R`[4]*`,`*R[4]*`)+m[2]/2*
innerprod(\`R[3]\`,\`R[3]`), [l[1], l[2], l[3], l[4], m[1], m[2], diff(theta(t), t), diff(phi(t), t), diff(psi(t), t), cos(psi(t)), sin(psi(t))])), trig)
U := collect(simplify(expand(g*m[1]*y[4]+g*m[2]*y[3])), [l[1], l[2], l[3], l[4], m[1], m[2], diff(theta(t), t), diff(phi(t), t), diff(psi(t), t), cos(psi(t)), sin(psi(t)), g])
L := simplify(collect(T-U, [l[1], l[2], l[3], l[4], m[1], m[2], diff(theta(t), t), diff(phi(t), t), diff(psi(t), t), cos(psi(t)), sin(psi(t))]))
Eul := remove(has, EulerLagrange(L, t, [theta(t), phi(t), psi(t)]), K[1]); eq1 := op(select(has, Eul, (diff(psi(t), t))^2)); eq2 := op(select(has, remove(has, Eul, (diff(psi(t), t))^2), sin(psi(t)))); eq3 := op(remove(has, remove(has, Eul, (diff(psi(t), t))^2), sin(psi(t))))
INITS := {phi(0) = (1/4)*Pi, psi(0) = (1/4)*Pi, theta(0) = 3*Pi*(1/4), (D(phi))(0) = 0, (D(psi))(0) = 0, (D(theta))(0) = 0}
PARAM := [g = 9.8, l[1] = 10, l[2] = 100, l[3] = 100, l[4] = 21, m[1] = 1000, m[2] = 1]
sys := eval([eq1, eq2, eq3], PARAM)
sol := dsolve([op(sys), op(INITS)], numeric, output = listprocedure)
NULL``
Download Test_1.mw
Is there any method to handle the huge expression of A where it is given that sigma+x=a, sigma*x=b
It is huge. I tryed with
B := mtaylor(A, [sigma, x], 8)
Unable to handle. I know that the expression can be written in powers in sigma^ix^j and thereafter sigma+x=a, sigma*x=b could be substituted..
Any help.
A := -sigma*(sigma^2+2*sigma*(alpha-1)+alpha*beta+1-alpha)*(alpha+sigma-1)^2*(sigma*theta+delta)*(gamma1*(alpha+sigma-1)+(1-sigma)*(beta+sigma))*alpha*(1-x)^2*(beta+x)^3*((theta*x+delta-gamma1)*(alpha+x-1)-(1-x)*(beta+x))+alpha*(1-sigma)^2*(beta+sigma)^3*((sigma*theta+delta-gamma1)*(alpha+sigma-1)-(1-sigma)*(beta+sigma))*x*(x^2+2*x*(alpha-1)+alpha*beta+1-alpha)*(alpha+x-1)^2*(theta*x+delta)*(gamma1*(alpha+x-1)+(1-x)*(beta+x))
NULL``
Download 1.mw1.mw
Hi, everyone! I am a new user to maple and I need to import some code I have found from a paper, just so I can manupluate some of the variables. However when I have copied and pasted my code, I keep getting the error Error, mismatched or missing bracket/operator.  I did check online and it seems to be a bracket missing but I have copied without errors from the source.
I have attached a picture and did a copy paste of the code that is giving me an error below.
Thanks for your help
x[1] := l[1]*sin(theta(t));
y[1] := -l[1]*cos(theta(t));
y[2] := l[2]*cos(theta(t));
'R[1]'':=map(diff,R[1],t):
polysols(diff(u(x), x) = u(x)^2 - 1) produces no results, while it can be verified by direct observation that u(x) = 1 is a polynomial solution.
Can someone help me write the program for this equation?
I really need this program.
With respect
I was experimenting on and found coeff and degrees  do not work with algebraic type powers. So I set aboud dismanteling  a example polynomial. I certainly went around the houses doing this. I wanted to put the powers and coefficinets of x in an array.
I sure there must be a simpler way.
NULLNULL
r := proc (x) options operator, arrow; a[0]+a[1]*x-a[2]*x^2+a[8]*x^(8/5)-a[h]*x^h+k*x^(-b/a) end proc
mnmls := [op(r(x))]
[a[0], a[1]*x, -a[2]*x^2, a[8]*x^(8/5), -a[h]*x^h, k*x^(-b/a)]
A := Array(1 .. 2, 1 .. nops(mnmls))
Array(%id = 36893489621187187044)
mnmls, x0 := selectremove(has, mnmls, x)
[a[1]*x, -a[2]*x^2, a[8]*x^(8/5), -a[h]*x^h, k*x^(-b/a)], [a[0]]
A[2, 1] := op(x0)
a[0]
coeff(r(x), x, 2)
Error, unable to compute coeff
coeffs(r(x), x)
Error, invalid arguments to coeffs
degree(mnmls[1], x)
degree(mnmls[4], x)
FAIL
degree(mnmls[5], x)
FAIL
indets(r(x))
{a, b, h, k, x, a[0], a[1], a[2], a[8], a[h], x^h, x^(-b/a), x^(8/5)}
bits := [seq([op(mnmls[i])], i = 1 .. nops(mnmls))]
[[a[1], x], [-1, a[2], x^2], [a[8], x^(8/5)], [-1, a[h], x^h], [k, x^(-b/a)]]
deeperbits := [seq(op(op(bits)[i]), i = 1 .. nops(bits))]
[a[1], x, -1, a[2], x^2, a[8], x^(8/5), -1, a[h], x^h, k, x^(-b/a)]
varpwrs, cofsl := selectremove(has, deeperbits, x)
[x, x^2, x^(8/5), x^h, x^(-b/a)], [a[1], -1, a[2], a[8], -1, a[h], k]
is(nops(vars) = nops(cofsl))
cofs := convert(cofsl, Array)
Array(%id = 36893489621220545228)
for i to numelems(cofs)-1 do if cofs[i] = -1 then cofs[i] := 0; cofs[i+1] := -cofs[i+1]; i = i+2 end if end do; cofs; cofs := remove[flatten](has, cofs, 0)
Array(%id = 36893489621220530764)
cofs
is(nops(vars) = numelems(cofs))
pwrs := `assuming`([simplify(`~`[log[x]](varpwrs))], [x > 0, a::'real', b::'real', h::'real'])
[1, 2, 8/5, h, -b/a]
A
for i to nops(mnmls) do A[1, i+1] := pwrs[i]; A[2, i+1] := cofs[i] end do; A
Download Q_11-9-22_monomial_powers_and_coeffs.mw
pde := diff(u(x,t),t) + u(x,t)*diff(u(x,t),x) = 0;
diff(u(x, t), t)+u(x, t)*(diff(u(x, t), x)) = 0
These are all wrong:
pdsolve({pde,u(x,0)=f(x)});
pdsolve({pde,u(x,0)=sin(x)});
pdsolve({pde,u(x,0)=erf(x)});
u(x, t) = 0
u(x, t) = 0
u(x, t) = 0
But these ones are correct:
pdsolve({pde,u(x,0)=exp(x)});
pdsolve({pde,u(x,0)=x});
u(x, t) = LambertW(t*exp(x))/t
u(x, t) = x/(t+1)
Download mw.mw
in a worksheet, typing
r:=(x^2 - 2*x - 1)/4;
Maple returns
But when typing
r:=(x^2 - 2*x - 1)/(4*x);
Now it does not expand terms and gives what is expected
Is there a way to make the first example remain unexpanded? Same with Mathematica:
I know this only affects the display only. But it is annoying, as I want to see the numerator and denominator on the screen as I put them there and not have them change.
I tried changing the typesetting level, but this had no effect.
I used to like Maple becuase it does not change anything unless asked to, and everything is explicit, which is better.
Now I am starting to change my mind on this aspect of Maple.
Hello. Is there any way to plot 2+ oscillators as shown in the image below?
Thanks for any help.
Newbie here....
I'm struggling to see with the default font size, I'm also struggling with readability of the text/charactors in the left hand paletetes/workbook pull down menus.  I can see that there are style choice options in format>styles but it seems that I need to set every single permutation separately to acheive readability nirvana which seems unlikely to be the best route.
Is there a global setting for font size?  Alternatively are there style files somewhere that the nearly blind can download?
I am really struggling with this.
Cheers
Please, how do I use surface or contour to plot discontinous function?
z = f(x,y) := x-.8193318913*sin(x)*cos(x)/(cos(x)^2+sinh(y)^2)-(0.2931044702e-2*(0.7500000000e-3*x^2-0.7500000000e-3*y^2+0.1622336517e-1))*sin(x)*cos(x)/(((0.7500000000e-3*x^2-0.7500000000e-3*y^2+0.1622336517e-1)^2+0.2250000000e-5*x^2*y^2)*(cos(x)^2+sinh(y)^2))-0.4396567053e-5*x*y*sinh(y)*cosh(y)/(((0.7500000000e-3*x^2-0.7500000000e-3*y^2+0.1622336517e-1)^2+0.2250000000e-5*x^2*y^2)*(cos(x)^2+sinh(y)^2)):
How should I handle the limit in the integration answe?. I don't see why it is necessary.
_local(gamma)
p := `assuming`([proc (alpha) options operator, arrow; alpha^m end proc], [m]); LinearAlgebra:-Transpose(integer)
integer
q := `assuming`([proc (alpha) options operator, arrow; alpha^n end proc], [n]); LinearAlgebra:-Transpose(integer)
integer
Sa := eval((1/2)*(int(simplify(p(alpha)*(D(q))(alpha)), alpha = 0 .. 1)))
-(1/2)*(limit(alpha^(m+n), alpha = 0, right)-1)*n/(m+n)
s1 := eval((1/2)*(int(simplify(p(alpha)*(D(q))(alpha)), alpha)))
(1/2)*alpha^(m+n)*n/(m+n)
eval(s1, alpha = 1)-(eval(s1, alpha = 0))
(1/2)*n/(m+n)
Download Q_9-9-22_limit_in_integral.mw
What is the best and accurate way to export a large symbolic matrix (200*300) from Maple to Matlab? The Marix have a lot of variables, symbols and operators such as diiff, int, ....
Here is a simple example:
A := Matrix(2, 6, {(1, 1) = x*y*z, (1, 2) = (1/2)*tau[2], (1, 3) = sin(x*y*z), (1, 4) = ln(x*y*z), (1, 5) = tau[1]*exp(x*y*z), (1, 6) = sin(x+y)+cos(x+y), (2, 1) = x^2+1, (2, 2) = x^2+1/sin(x*y*z), (2, 3) = 2*exp(y), (2, 4) = tau[1], (2, 5) = diff(f(x, y, z), x), (2, 6) = int(f(x, y, z), x)})
A := 1/sin(protected)
CodeGeneration[Matlab](codegen[makeproc](A, [x, y, tau[1], tau[2]]))
Error, (in codegen/makeproc) optional arguments must be equations [x, y, tau[1], tau[2]]
Download export.mw
First 280 281 282 283 284 285 286 Last Page 282 of 2428
