I would like to have Maple give me sin(2nPi) = 0 assuming that n is a positive integer. Is there a way to do it?
mapleatha.
Dear there,
I have a code.mw
  • If I don't use command Digits in the code, I get the following result:
Question 1: The third column of matrix B includes 16 decimal, but the fourth column of matrix B includes 11 decimal. Why?
  • When I write the command Digits:=20, I get the following result:
Question 2: The last column of matrix B shows the absolute error of the method.
When asked what is the absolute error of the method, what is the right answer?  (Because the higher the digit is chosen, the lower the absolute error is.)
Question 3: Are the two results consistent? How can we explain to someone who asks why the difference comes from?
 12 yeas later, the probelm  is not still improved in following links
https://www.mapleprimes.com/posts/38473-Simplify-Ceil-And-Floor
simplify(ceil(x)+floor(-x));
                         floor(-x) + ceil(x)
I think extending simplify by Joe Riel 8221  is a little complicated.
`simplify/ceil` := proc(ex)
    evalindets(ex, 'specfunc(anything,ceil)', x -> -floor(-op(x)));
simplify(floor(-x) + ceil(x));
 It seems that maple know  ceil(x)=-floor(-x)
why does not maple2020 still handle that?
With each new release of Maple Player, there are more and more restrictions. Tell me, please (in the latest release 2020.1) the ability to copy data from the Maple Player window was removed? (Ctrl+C)? And how do I find out all the restrictions?
How to solve and plot DE?
eq1 := diff(f(x), `$`(x, 5))+2*(diff(f(x), `$`(x, 4)))+diff(f(x), `$`(x, 3))+diff(f(x), `$`(x, 2))+2*(diff(f(x), `$`(x, 1)))+3*f(x) = g(x)
Hello all,
When I enter the following expression:
eqaux_2 := l__bb = L__aa0 + L__aa2 * cos(2*theta - 4/3*Pi);
the cos function got converted an equivalent sin function automatically and the result was displayed like this:
l__bb = L__aa0 - L__aa2*sin(2*theta + Pi/6)
Is there any way to ask Maple not to do this automatic conversion?
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/q20210204.mw .
Download q20210204.mw
This worksheet contains images scanned from a book of problems.
Problem56.mw
Suppose I want to create a matrix of derivatives, like gradient, Hessian, or Jacobian, and then apply that matrix to a function.  How do I do this?
Hi there,
I'm currently trying to work with combinations where I need to be able to retrieve a list of possible combinations, although i do not actually need to see the output but use it for a later part of programming.
Unfortunately, I get an error message such as the one in the title of this question.
It seems to me that maple is unable to allocate enough memory to evaluate the problem. I'm not familiar with any way to refine the programming.
are there any possible workarounds for this issue?
I was trying to simplify an expression using assume. However, I ended up with very long evaluation time and got an error: "Error, (in type/complex) too many levels of recursion". Here is the case:
Consider the following code:
restart:with(Physics):
simplify(csgn(a-b),assume=[a::real,b::real, a>0,b>0,a>b])
this gives 1 as expected.
However, if I run the following code:
simplify(csgn(a-b[2]),assume=[a::real,b[2]::real, a>0,b[2]>0,a>b[2]])
I get an error ""Error, (in type/complex) too many levels of recursion" after along evaluation. The last condition a>b[2] is causing the along evaluation time. Without it I get, of course, signum(a-b[2]), which is fine.
If I do these tests without Physics package loaded, I get the result 1 immediately in both cases without any problem. So, something in Physics package is causing this problem.
What is the problem? and how can I resolve this issue?
Thank you in advance.
Hello everyone, I wondered if there is a way to plot the solution for a DE using the DEplot command but at the same time show the graph of another function (explicit or implicit) that is not a solution of the DE itself. Is that possible?
I have this two expresions
e1 := (1/2)*P[psi]^2/(cos(`ϑ`)^2*Ix)
e2 := (1/2)*P[psi]^2/(cos(`ϑ`)^2*Ix)
simplify(e1-e2)=-(1/2)*(-P[psi]^2+P[psi]^2)/(cos(`ϑ`)^2*Ix)
but
simplify(-P[psi]^2+P[psi]^2)
is zero
why i dont obtain zero if i use simplify(e1-e2) ??
Download MHD1.mw
System of equations with boundary conditions are moving?
Also, find the values of unknown variables?
I know that, tetrahedron with vertices (0, 0, 0), (3, 0, 0), (0, 5, 0), (0, 0, 14) has center of insphere is  (1, 1, 1) and radius R = 1. How to create a tetrahedron whose coordinates of all vertices are integers, the inscribed spherical center and the inscribed spherical radius are integers?
Dear maple users
Greetings.
In this code, I am solving the PDEs via perturbation method.
There is some mistake in the boundary condition and pdsolve.
Kindly help me that to get the solution for this PDE via perturbation method.
Wating for your replay.
BC:
Code: JVB.mw
First 474 475 476 477 478 479 480 Last Page 476 of 2458
