I am trying to construct multiple math plots within one procedure, however, only one is displayed at a time, and it is always at the end of the outputs. I searched for that peculiar behaviour and eventually found on
https://de.maplesoft.com/support/help/Maple/view.aspx?path=DataFrame/Tabulate
the line
This command inserts the assembly of Tables and Embedded Components into the worksheet using the InsertContent facility. The inserted content is placed after any usual output of the Execution Group in which this command is called. Each Execution Group allows for only one inserted result to exist at any given time. Multiple calls to commands which utilize the InsertContent facility made within the same Execution Group will result in each successive inserted assembly replacing any assembly inserted earlier for that Execution Group.
Is there a workaround for this issue? I cannot find one, e.g. on
https://de.maplesoft.com/support/help/Maple/view.aspx?path=DocumentTools%2fInsertContent
Thank you in advance. :)
I have trouble using ArrayTools, specifically Extend, to create a DataFrame. DF1 and DF2 are, even though awkwardly, created correctly, DF 3 does not work. My code is this:
with(ArrayTools):
with(DocumentTools):
nOben:=10;
nUnten:=3;
InitialisierungDF:=Vector(nOben-nUnten+1); #Initialisierung des Dataframes für die Tabelle
InitialisierungSpalte:=Vector[row](nOben-nUnten+1);
for i from 1 to nOben-nUnten+1 do
 InitialisierungDF(i):=oE;
 InitialisierungSpalte(i):=n=i;
print(InitialisierungDF);
print(InitialisierungSpalte);
DF1:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
            columns = [ GK, PZP, PZM, PY],
            rows = InitialisierungSpalte);
DF2:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
Tabulate(DF1);
print(Extend(InitialisierungDF,[oE]));
print(Extend(InitialisierungSpalte,[RMSE]));
InitialisierungDF:=Extend(InitialisierungDF,[oE]);
InitialisierungSpalte:=Extend(InitialisierungSpalte,[RMSE]);
DF3:= DataFrame( < InitialisierungDF | InitialisierungDF | InitialisierungDF | InitialisierungDF>,
The result is supposed to be a math table of the form
           GK   PZP    PZM   PY
n=1     oE     oE       oE     oE
n=2     oE     oE       oE     oE
RMSE  oE    oE      oE       oE
I have run into multiple problems, potentially bugs. First, I have to initialize awkwardly with
because InitialisierungDF:=Vector(1..nOben-nUnten+1,oE) doesn't work and produces entries like oE(1) for whatever reason.
Then, creating the data frame DF3 does not work at all with the above mentioned code.
DF3:= DataFrame(<Extend(InitialisierungDF,[oE])|Extend(InitialisierungDF,[oE])|Extend(InitialisierungDF),[oE]|Extend(InitialisierungDF,[oE])>,
            rows = Extend(InitialisierungSpalte,[RMSE]));
doesn't work either, however, this time a different error occurs. Looking at the vectors the dimensions seem to be correct in each case, though. Any suggestions on how to fix these things?
Hello everyone
Please help me about IntegrationTools:-Change does not transform x to u
IntegrationTools:-Change(int(3*x*sqrt(x+8), x))
I want to convert that primitive to a primitive like this: (2/3)*(Int(u^2*(u^2-8), u)) and Error, (in IntegrationTools:-Change) invalid boolean expression: 1
Please help me
Help_integrationTools.mw
Hello there,
When I tried to solve an equation using the 'solve' command in Maple, I got an answer.
However, I could not understand how Maple got to the answer. Would you tell me what steps Maple might have gone through in order to come to the answer?
Here is my worksheet:
q20210130.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/q20210130.mw .
Download q20210130.mw
PS) Perhaps this editbox began to dislike Google Chrome.
Dear Maple Users,
I appreciate your help with the previous 1D PDE problem that I posted.
Now I have another 2D axisymmetric diffusion PDE, looking for u(r,z,t), no variation in the theta direction:
PDE: u't = alpha*(u"r + (1/r)*u'r + u"z); a < r < b, 0 < z < L, 0 < t < infinity
BC1: u| z = L = Psi_s
BC2: -alpha*u'zz = 0 = 0
BC3: -alpha*u'r| r = a = 0
BC4: -alpha*u'r| r = b = flux_b
IC: u(r,z,0) = (z/L)*Psi_s
a, b, L, alpha, Psi_s, flux_b are given.
My attempt at a solution is attached, following the solution path that you provided for the previous 1D PDE problem.
2D_CCS_PDE_Sol.mw
I have run into an error message that I am unable to resolve. I would greatly appreciate your taking a look at this.
Perhaps, there is no closed form solution to this problem and a numerical solution may have to be attempted.
Please advise. Thanks.
Joseph Thodiyil
How do I print the body of a procedure.  In older versions, verboseproc controlled this.
interface(verboseproc = 3)
interface(prettyprint = 1)
print(int)
                  _m140116321288416, [_m140116321288416]
print(type);
                 proc () option builtin = type; end proc,
                   [proc () option builtin = type; end proc]
Can I make something like it using codegen (dinamically set parameters and default arguments freely)?
proc( a , b::integer , c:=0 , d::integer:=1 , { e:=2 , f::integer:=3 } ) return a, b, c, d, e, f end proc
eq1 := diff(h(t), [`$`(t, nu)])+(1/4)*h(t) = 8/3*(1/(sqrt(Pi)*t^(1/2))-(3/32)*t^2+(3/16)*exp(-t)-1);
with ics h^k (0)=0 for k=0..n
Dear Maple Users,
This particular question is example problem 8.4.1 in the textbook: "PDE & BVP with MAPLE", 2nd Edition by George A. Articolo.
I shall paraphrase the problem here and attach the Maple Worksheet solution as detailed in the textbook.
We seek the temperature distribution u(x,t) in a thin rod whose lateral surface is insulated over the interval I = {x | 0 <x<1}. The left end of the rod is held at a fixed temperature of 10, and the right end is held at the fixed temperature of 20. There is no internal heat source. The thermal diffusivity of the rod is k = 1/20, and the rod has an intitial temperature distribution u(x,0) = f(x) given as follows.
The nonhomogeneous diffusion equation is:
ut'(x,t) = k*ux"(x,t) +h(x,t)
The BCs are nonhomogeneous:
u(0,t) = 10
u(1,t) = 20
The IC is:
u(x,0) = 60x -50x2+10
The internal heat source term is:
h(x,t) = 0
I have typed in the MAPLE commands exactly as in the textbook (attached), but it does not execute in my Student 2020 version of MAPLE.
Could you please take a look at the attached MAPLE worksheet and let me know if something can be done to make it work.
Thank you for your help.
Joe Thodiyil
George_A_Articolo_2ndEdition_Ex_8.4.1_PDE.mw
I solve a given pde with some conditions given, but I get
unable to handle PDE problem subject to boundary conditions
solution_pdes.mw
many thanks for your help
I am trying to find one option so that  a sphere is tangent with every edge of a tetrahedron. Suppose tetrahedron OABC, here O(0,0,0), A(x1, y1, z1), B(x2, y2, z2), and C(x3, y3, z3).  How to find a sphere is tangent with every edge of a tetrahedron?
I know how to contruct an isoscele ABCD trapeze knowing the 2L length of AB and BC=CD=CD=a. But I don't know answer to that question : L being fixed together with points A and B , show that the place of C when a varies is a branch of hyberbola. Here is my code.
restart; unprotect(O, D);
Vdot := proc (U, V) add(U[i]*V[i], i = 1 .. 2) end:
dist := proc (M, N) sqrt(Vdot(expand(M-N), expand(M-N))) end:
_EnvHorizontalName := x: _EnvVerticalName := y:
O:=[0,0]:A:=[-L,0]:alpha:=arccos((2*L-a)^2/(2*a*(2*L-a))):h:=tan(alpha)*(2*L-a)/2:
B:=[L,0]:C:=[L-(2*L-a)/2,h]:D:=[-L+(2*L-a)/2,h]:
L := 6; a := 7;
poly := [A, B, C, D, A];tp := textplot([[A[], "A"], [B[], "B"], [C[], "C"], [D[], "D"]], color = black, 'align' = {'above', 'right'});
trapeze := polygonplot(poly, axes = normal, color = "DarkGreen", transparency = .9);
display([tp, trapeze], scaling = constrained); Thank you foryour help.
Hi everyone:
I want to write the below serie in Maple, how can I do it?
where: k = 0,.....,n
n is a Natural number.
tnx...
Dear Users!
I want to find the solution of the solution of PDEs as given bellow:
PDE1 := diff(u(y, t), t)+diff(u(y, t), t, t) = diff(u(y, t), y, y)-u(y, t);
PDE2 := v(y, t)+diff(tau(y, t), t) = diff(u(y, t), y);
ICandBC := {tau(y, 0) = 0, u(0, t) = 0, u(3, t) = 0, u(y, 0) = 0, (D[2](u))(y, 0) = 0};
pds := pdsolve({PDE1, PDE2}, ICandBC, numeric);
But got the following error
Error, (in pdsolve/numeric/process_PDEs) number of dependent variables and number of PDE must be the same
Kindly help me to fix this error. I shall be very thankful.
Special request to:
@acer @Carl Love @Kitonum @Preben Alsholm
I have created a set of help files using the example templates. After I create the .help file and install it with my package, I can view the help pages in the help viewer. However, when I click on any link within a help page, the target page opens as a worksheet in Maple. I understand this is because I created the hyperlink with a worksheet as the target. However, I don't know where to obtain the help topic name for a help page before it has been created.  I have searched help, but can't find any applicable guidance.  Can anyone tell me how to determine the help topic name when first creating the help pages.
I have attached one of my help file worksheets.     Hlpdiracmatrices.mw
First 476 477 478 479 480 481 482 Last Page 478 of 2458
