I was working through some example problems and came across this statement.  Actually comparing Sympy results to Maple. (I prefer Maple).
"Calculate the volume integral of f(...) over the sphere of radius r"
I can solve the problem, but, got hung up on the exact meaning of the problem statement.
Tom Dean
with(VectorCalculus):
## http://www.acme.byu.edu/wp-content/uploads/2017/08/Sympy.pdf
## Problem 7
f := proc(x, y, z)
    (x^2 + y^2 + z^2)^2
(M, d) := Jacobian([rho*sin(phi)*cos(theta),
                    rho*sin(phi)*sin(theta),
                    rho*cos(phi)],
                   [rho, phi, theta],
                   'determinant' );
abs(d);
simplify(%);
eqn := f(rho*sin(phi)*cos(theta), rho*sin(phi)*sin(theta), rho*cos(phi));
eqn := eqn * abs(simplify(d));
soln := int(eqn,[rho=0..r,theta=0..2*Pi,phi=0..Pi]);
subs(r=3, soln);
How I can convert Root Of to conventional form?
root_of.mw
Q1 := x*(x-delta)*(1-x)*(x+y)-alpha*x*y; Q2 := beta*x*y-Zeta*y*(x+y); SOLL := solve({Q1, Q2}, {x, y})
{x = 0, y = 0}, {x = 1, y = 0}, {x = delta, y = 0}, {x = RootOf(beta*_Z^2+(-beta*delta-beta)*_Z-alpha*Zeta+alpha*beta+delta*beta), y = -RootOf(beta*_Z^2+(-beta*delta-beta)*_Z-alpha*Zeta+alpha*beta+delta*beta)*(Zeta-beta)/Zeta}
Download root_of.mw
update_standings_ELO_draw.mw
This latest question involves ELO, which is used to rate chess players (and other sports).
The difference between the previous (win-loss) system and ELO is the allowance for a third option, a draw. Carl coded the previous rating system, and I have tried to alter it.
See code for ELO procedure.
Adding a D to the third field, gets the result I want.
ELO(Record(rating= 2400),Record(rating= 2000),D)
Adding anything other than D to the third field means the first player defeats the second.
My preference would be to leave nothing in this third field to signify this (but I don't know if this is possible).
The main problem is getting the bulk processing to work (for a series of matches...)
See Update procedure.
I have this flawed notation:
Games:= [[Tom_C, David_J, D],[David_J, Tom_C]]: #Tom_C drew David_J then David_J defeats Tom_C.
Hope someone can help.
I am a newbie. I m having some problems in solving generalised eigenvalue problem for symbolic matrices. Help me to discover the problems with this code.
Here is my code:-
> M := Matrix(2, 2, [4*(I*E/L^3), 6*(I*E/L^3), 6*(I*E/L^3), 24*(I*E/L^3)])
> G :=Matrix(2,2,[2/(15)(-1/(L)),1/(10)(-1/(L)),1/(10)(-1/(L)),12/(5)(-1/(L))])
> Eigenvalues(M, G, output = 'Vector[row]')
Error:-
Error, (in LinearAlgebra:-Eigenvalues) invalid input: LinearAlgebra:-Eigenvalues expects its 2nd argument, C, to be of type Matrix(square) but received G
If decimal place is 1 such as 123.1 as input matrix and output matrix is eigenvector
is there a easy way to see changes of eigenvector in graph ?
because 3 x 3 matrix has 9 elements
and eigenvector each vector may not fix in place,
how do mathematician observe the perturbation in this case?
would like to find which changes can cause different in eigenvectors
 Dear Sir,
I trying to merge two which are one is an actual plotted graph and another one zoomed from the same graph. I want to copy zoomed graph into an actual graph, can anyone help in this regard?
My actual graph is like as follows
and after zooming this graph I got as follows
Now I want to change (Insert the zoomed graph inside the actual graph where the text is inserted) by using these two graphs as below
Please help me to plot like this...
I am currently facing an issue as regards stability analysis and I will be glad if anyone can offer me some suggestions.  My aim is to have a Theorem in my research stating that the Disease free equilibrium is locally asymptotically stable if R0 (Basic reproduction number) < 1 and unstable if R0 > 1. The same applies to the endemic equilibrium.  I am trying to carry out a stability analysis using Linearization. However, due to the nature of my model, not all my eigenvalues are negative. Below is my Jacobian Matrix:
ROW 1                           ROW 2                       ROW 3                         ROW 4
Column 1:=              -psi-gamma-mu                       varphi                              omega                                   betaS
Column 2:=                 -psi                 - varphi - varpi - mu                    0                                  epsilon * beta  M
Column 3:=                   gamma                         varphi                             - omega - mu                                  xi * beta * V
Column 4:=                 0                                0                                0                       betaS + epsilon * beta  M + xi * beta * V -tau - kappa - mu
By using the Routhz Hurwitz criterion, I reduced the matrix block from 4 by 4 to 3 by 3 by using column 4 as co-factor, however, after this matrix reduction, I was still unable to get all terms relating to my basic reproduction number for me to compare and see if the conditions in Routh Criterion is satisfied using the condition R0 < 1 holds.
My Basic Reproduction Number is as follows:
(varphi+mu+varpi)*(mu+omega-mu*rho)-(mu+varphi+omega)*mu*sigma+ epsilon ((omega+mu+gamma)*sigma*mu+(mu+omega-mu*rho)*psi) + xi*((varphi+varpi+mu+psi)*mu*rho+(mu*sigma+gamma+psi)*varphi+(mu-mu*sigma+varpi)*gamma)/((varphi+mu)*(psi+gamma+omega+mu)+(omega+mu+gamma)*varpi+psi*omega)
Are there any other methods to  carry out local stability analysis? and Can local stability analysis be done using maple?
Thank you in advance
Hi everybody!
I want to make the substitution  Int(x^n u(x),x=-Infinity..Infinity) by m_n (m index n), the subs command doesn't seems to work...
I can calculate real number eigenvector with QR algorithm from rotation matrix
but this real number is just magnitude of complex number
what is the rotation matrix for calculating complex number?
what algorithm do maple use to calculate fraction eigenvector?
are complex decimal and complex fraction eigenvectors are two different algorithm?
Hello everyone!
how to solve system of 5 equations like as in attachment, but much more faster?
I tried to do this on my computer (CPU 8 Core 3,4 GHz, RAM DDR3 2x8 GB, SSD) but after 12 hour my computer doesn't respond.
What I can do if I don't have a supercomputer?
Forum.mw
A := Matrix([[1,2,3],[4,5,6],[7,8,9]]);
v, e := Eigenvectors(A):
evalf(e);
A := Matrix([[1,2,3+0*0.1],[4,5,6+0*0.1],[7,8,9+0*0.1]]);
evalf(e);
Hoped everything is fine. I want to integrate the following expression under the different conditions of discriments Delta.
int(1/(a[3]*(u(eta)^3+d[2]*u(eta)^2+d[1]*u(eta)+d[0])), eta);
when Delta = 0;Delta > 0 and Delta < 0.
where discriments Delta = -27*(2*(d[2])^3/27+d[0]-d[1]*d[2]/3)^2-4*(d[1]-(d[2])^2/3)^3;
I am waiting your positive respone.
@acer @Carl Love @Kitonum @Preben Alsholm
Hello, I have a problem which might be very basic but I can't get over it.
I need to compute Christoffel symbols with the "Christoffel" command of the "Tensor" package. However, I noticed that whenever I give maple a metric with a vanishing diagonal element, I get the following error:
Error, (in DifferentialGeometry:-Tensor:-InverseMetric) expected 1st argument to be a metric tensor. Received: _DG([["tensor", M, [["cov_bas", "cov_bas"], []]], [`...`]])
For example, I tried with a very simple 2D case, giving coordinates (t,x) and a metric ds2=f(x)dtdx+h(x)dx2
for which I can compute by hand Christoffel symbols without any problem. The problem really seems to be about the missing diagonal element since if I add it, everything works fine.
By the way, I also noticed that if I apply the "InverseMetric" command I get exactly the same error, even though the matrix is invertible (except possibly at zeros of the functions f and h).
I will be grateful for any suggestion.
Consider the following expression (omega being the socalled minimal spin connection in the vierbein formalism of general relativity):
with(Physics):
with(Tetrads):
omegaDef := omega[mu,c,d] = 1/2*(
   +e_[~rho,c]*(d_[mu](e_[rho,d]) - d_[rho](e_[mu,d]))
   -e_[~rho,d]*(d_[mu](e_[rho,c]) - d_[rho](e_[mu,c]))
-1/2*e_[~a,mu]*e_[~rho,c]*e_[~sigma,d]*(d_[rho](e_[sigma,a]) - d_[sigma](e_[rho,a]));
Define(omegaDef):
The Define command raises "Error, (in Physics:-Define) numeric exception: division by zero" in Schwarschild spacetime (loaded with g_[sc]), but not, say, in Tolman spacetime (loaded with g_[tolman]). Furthermore, if either the first two terms, or the last term, are/is removed in omega, then no error is raised in Schwarzschild spacetime. What is going on?
I need to evaluate a variable inside the function definition in the moment it is defined and not every time it is called. Is there a way around?
a:=3;
f := x-> a*x;
f(t);
a:=4;
f(t);
I want the function "f" to be 3*x even if "a" is modified after the declaration. In Mathematica I am used to the so called immediate assignmet(=) and delayed assignment(:=) for which I cannot find an equivalent command in Maple.
Any help is appreciated!
First 835 836 837 838 839 840 841 Last Page 837 of 2459
