I am trying to plot some movement equations, but the following error keeps happening:
when I tryed to rewrite the equation the error became:
Error, (in DEtools/convertsys) invalid specification of initial conditions
Can someone help me with those errors?
Here is the code:
with(LinearAlgebra);
with(linalg);
with(DifferentialGeometry);
with(VariationalCalculus);
with(Tensor);
with(tensor);
with(Tools);
DGsetup([t, x, y, z], M)
g1 := evalDG(N(t)^2*`&t`(dt, dt)-a(t)^2*(`&t`(dx, dx)+`&t`(dy, dy)+`&t`(dz, dz)))
g1inv := InverseMetric(g1)
C1 := Christoffel(g1)
RM1 := CurvatureTensor(C1)
RM1g := CurvatureTensor(g1)
ContractIndices(RM1, [[1, 3]])
ContractIndices(RM1g, [[1, 3]])
RT := RicciTensor(g1, RM1)
ContractIndices(RT, g1inv, [[1, 1], [2, 2]])
S1 := RicciScalar(g1, RM1)
RM1contra := RaiseLowerIndices(g1inv, RM1, [2, 3, 4])
RM1cov := RaiseLowerIndices(g1, RM1, [1])
Kret1 := ContractIndices(RM1contra, RM1cov, [[1, 1], [2, 2], [3, 3], [4, 4]])
eval(simplify(subs(N(t) = 1, Kret1)))
Lag := a(t)^3*N(t)*Kret1
phi = phi(t)
Lam := -(1/2)*a(t)^3*N(t)*((diff(phi, t))^2/N(t)^2+m^2*phi)
Ltot := Lag+Lam
EqELN := EulerLagrange(Ltot, t, N(t))
EqN := eval(simplify(subs(N(t) = 1, EqELN)))
Eqa := subs(N(t) = 1, Ltot)
EqELa := EulerLagrange(EqaD, t, a(t))
tini := 0
with(DEtools)
with(plots)
tfin = 10
(D(a))(tini) = 0
((D@@2)(a))(tini) = 0
((D@@3)(a))(tini) = 0
phi := a^-3
Dphi := 0
(D(N))(tini) = 0
((D@@2)(N))(tini) = 0
((D@@3)(N))(tini) = 0
sys1 := {EqN, a(tini) = 0.1e-2, (D(a))(tini) = 0.1e-2, ((D@@2)(a))(tini) = 0.1e-2, ((D@@3)(a))(tini) = 1}
tfin = 2
p1 := dsolve(sys1, type = numeric, abserr = 1.*10^(-8), relerr = 1.*10^(-8), range = tini .. tfin)
figN := odeplot(p1, [t, a(t)])
sys2 := {EqELa, a(tini) = 0.1e-6, (D(a))(tini) = 0.1e-4, ((D@@2)(a))(tini) = 0.1e-5, ((D@@3)(a))(tini) = 1, ((D@@4)(a))(tini) = 0.1e-5}
p2 := dsolve(sys2, type = numeric, abserr = 1.*10^(-8), relerr = 1.*10^(-8), range = tini .. tfin)
figa := odeplot(p2, [t, a(t)])
How do I plot the following with Maple 2015?
For my differential equations class we have to input the following problem into Maple, I've never used maple before and I was wondering if someone who is experienced with maple could help me out with the code to put into Maple. Thanks I appreciate it!
Using the Maple program, Write the procedure RungeKutta(f, a, b, aplpha, n) which use the improved Euler's method to approximate the solution of the initial-value problem y'=f(t,y), a\leqt\leqb, y(a)= alpha at (n+1) equally spaced numbers in the interval [a,b]
The input parameters are as follow:
f is the name of the function f(t,y);
a and b are the end points of the interval of integration;
alpha is the initial condition.
The output: array w is the approximation of y at the (n+1) values of t.
I'm really not sure what else to say that isnt already obvious from the worksheet i uploaded, it's pretty obvious what i am trying to do i just dont understand what neutral operator even is, and couldn't find anything on the help page i was directed to by the error.
with(StringTools):
Join([convert(A, 'string'), "=", convert(B, 'string'), "(mod", convert(Set2[1], 'string'), ")"])
"A = B (mod Set2[1] )"
"convert(≡,'string')"
Error, invalid neutral operator
Download INVALID_NEUTRAL_OPERATOR.mw
I employed the sort command to sort through 10 solutions to a series of order 10.  However, I do not follow the logic of the output.  So I attempted to sort by ascending order by the magnitude, but I am getting errors which I am having trouble circumnavigating.  Can show me how to sort my solutions properly?
The worksheet is in my reply below.
with(PDEtools);
assume(k::real, x::real, omega::real, t::real, theta::real, c::real);
tr0 := c*(t*upsilon+x) = xi;
tr1 := I*(k*x+omega*t+theta);
tr2 := phi(lhs(tr0))*exp(tr1);
PDE := proc (u) options operator, arrow; I*(diff(u, t))+diff(u, x, x)-I*sigma*u*(conjugate(u)*(diff(u, x))-u*(diff(conjugate(u), x))) end proc;
Eq1 := PDE(tr2);
Eq2 := simplify(convert(expand(subs(tr0, Eq1)), diff));
for_maple_prime.mw
Hi, I'm currently studying the dynamics of a system of ODEs and I would like to plot a bifurcation diagram using Maple.
The system is:
diff(x(t), t) = -y(t)-z(t)
 diff(y(t), t) = x(t)+a*y(t)
diff(z(t), t) = b+x(t)*z(t)-c*z(t).
Can anyone help me with a procedure to output a bifurcation diagram for the system?
Dear Users,
Recently, I started using Maple2017. In Maple 18, I have used the following commands for import/export and it worked fine.
Digits := 50;
Rhs:= ImportVector("/home/15_degree_3izto1_fixed/Vec.txt", source = delimited);
MatA:=ImportMatrix("/home/15_degree_3izto1_fixed/Mat.txt", source = delimited) ;
Note : Vec.txt contains float with 50 digits, and Mat.txt contains algebraic equation eg. 123456716798271394816*y+173974937*10^(-16)
While maple 18 used to import all the informations with 50 digits of accuracy, Maple2017 only import float[8] ?It only imports first 20 digits and so on..? What has changed in 2017?
Thanks and regards,
1.
with(Groebner):
K := {r-x^4,u-(x^3)*y,v-x*y^3,w-y^4};
G := Basis(K, 'tord', degrevlex(r,u,v,w));
R1 := eliminate(G, {r,u,v,w}); # eliminate is the reverse of Basis
Ga := Basis({a*G[1],a*G[2],a*G[3],a*G[4],a*G[5],a*G[6],a*G[7],a*G[8],a*G[9],a*G[10],a*G[11],a*G[12],a*G[13],a*G[14], (1-a)*K[1], (1-a)*K[2], (1-a)*K[3], (1-a)*K[4]}, 'tord', deglex(a,r,u,v,w));
Ga := remove(has, Ga, [x,y,a]);
eliminate(Ga, [r,u,v,w]);
how to eliminate Ga to find back K ?
2.
A1A2 and A3A4 parallel
A(0,0), B(u1,0), D(u2,u3), C(x1,x2), E(x3,x4)
#BC = A1A2
xx1 := u1:
xx2 := x1:
yy1 := 0:
yy2 := x2:
#AD = A3A4
xx3 := 0:
xx4 := u2:
yy3 := 0:
yy4 := u3:
eq1 := (xx2 - xx1)*(yy4 - yy3) - (yy2 - yy1)*(xx4 - xx3);
(x1-u1)*u3-x2*u2;
#CD = A1A2
xx1 := x1:
xx2 := u2:
yy1 := x2:
yy2 := u3:
#AB = A3A4
xx3 := 0:
xx4 := u1:
yy3 := 0:
yy4 := 0:
eq2 := (xx2 - xx1)*(yy4 - yy3) - (yy2 - yy1)*(xx4 - xx3);
-(u3-x2)*u1;
#E is on the same line of AC
xx1 := x3:
yy1 := x4:
xx2 := 0:
yy2 := 0:
xx3 := x1:
yy3 := x2:
eq3 := Determinant(Matrix([[xx1,yy1,1],[xx2,yy2,1],[xx3,yy3,1]]));
-x3*x2+x1*x4;
#E is on the same line of BD
xx1 := x3:
yy1 := x4:
xx2 := u1:
yy2 := 0:
xx3 := u2:
yy3 := u3:
eq4 := Determinant(Matrix([[xx1,yy1,1],[xx2,yy2,1],[xx3,yy3,1]]));
-x3*u3+u1*u3-u1*x4+u2*x4;
sol := eliminate({eq1,eq2,eq3,eq4},[x1,x2,x3,x4]);
with(Groebner):
K := {(rhs(sol[1][1])-lhs(sol[1][1])),(rhs(sol[1][2])-lhs(sol[1][2])),(rhs(sol[1][3])-lhs(sol[1][3])),(rhs(sol[1][4])-lhs(sol[1][4]))};
G := Basis(K, 'tord', degrevlex(x1,x2,x3,x4));
R1 := eliminate(G, {x1,x2,x3,x4}); # eliminate is the reverse of Basis
Ga := Basis({a*G[1],a*G[2],a*G[3],a*G[4], (1-a)*K[1], (1-a)*K[2], (1-a)*K[3], (1-a)*K[4]}, 'tord', deglex(a,x1,x2,x3,x4));
Ga := remove(has, Ga, [u1,u2,u3,u4,a]);
From Question1, is it possible to find from sol to eq1, eq2, eq3 and eq4 ?
with(PDEtools);
u := phi(c*(t*upsilon+x))*exp(I*(k*x+omega*t+theta));
PDE := proc (u) options operator, arrow; I*(diff(u, t))+diff(u, x, x)-I*sigma*u*(conjugate(u)*(diff(u, x))-u*conjugate(diff(u, x))) end proc;
Eq1 := PDE(u)
For example
if x*y*z+ x*y^2
after filter
x*y*z
I have resolved the roots of a series both numerically & analytically.  Let me qualify numerical  versus analytical.  Analytically I evaluate the series without substituting values for the various parameters of the series.  I then differentiate the series, then substitute in the appropriate parametric values, & then solve.  By this method I obtained 5 complex roots.
The numerical approach has values already assigned to the parameters of the series.  I then differentiate & solve.  I obtain only REAL roots in this instance.  I then restricted these results to obtain the solution I believe to be correct given by result (7).
I cannot seem to steer the solver in the analytic case to obtain the correct REAL result that I am expecting.  Can anyone help on this?
Before any website moderator thinks this is the same question as Error-in-Isinternal-Too-Many-Levels, it is not.  I have resolved that question.  This is a different question, but on the same problem!
reconcile_solns.mw
hi, i have an expression "f" and i want to substitute the expression with Square root with another namee like phi, how should i do that? i should not use solve commands since the expression is more complicated and i have just pick part of it. tnx in advance.
f:=(3*beta[11]^2-4*beta[11]*sigma[11]+6*beta[12]^2-12*beta[12]*sigma[12]+2*sigma[11]^2+6*sigma[12]^2)*(1/sqrt(6*beta[11]^2-8*beta[11]*sigma[11]+12*beta[12]^2-24*beta[12]*sigma[12]+4*sigma[11]^2+12*sigma[12]^2))*(1/omega^2);
(3*beta[11]^2-4*beta[11]*sigma[11]+6*beta[12]^2-12*beta[12]*sigma[12]+2*sigma[11]^2+6*sigma[12]^2)/((6*beta[11]^2-8*beta[11]*sigma[11]+12*beta[12]^2-24*beta[12]*sigma[12]+4*sigma[11]^2+12*sigma[12]^2)^(1/2)*omega^2)
subs(sqrt(6*beta[11]^2-8*beta[11]*sigma[11]+12*beta[12]^2-24*beta[12]*sigma[12]+4*sigma[11]^2+12*sigma[12]^2)=phi,f);
factor(simplify(f,{sqrt(6*beta[11]^2-8*beta[11]*sigma[11]+12*beta[12]^2-24*beta[12]*sigma[12]+4*sigma[11]^2+12*sigma[12]^2) = phi}));
Error, (in simplify/siderels:-simplify/siderels) side relations must be polynomials in (name or function) variables
simplify(algsubs(sqrt(6*beta[11]^2-8*beta[11]*sigma[11]+12*beta[12]^2-24*beta[12]*sigma[12]+4*sigma[11]^2+12*sigma[12]^2)=phi,  f))
Error, (in algsubs) no variables appearing rationally in pattern
# i want sth like this :
(3*beta[11]^2-4*beta[11]*sigma[11]+6*beta[12]^2-12*beta[12]*sigma[12]+2*sigma[11]^2+6*sigma[12]^2)/(phi*omega^2)
Download problem.mw
I tried a Animation with 10 randoms HeatMaps:
with(Statistics): with(LinearAlgebra); randomize(): with(plots):
f:= rand( 1..2 ):
for n to 10 do :
RM := Matrix(10, 10, proc (i, j) options operator, arrow; (-1)^f() end proc);
G[n] := HeatMap(RM, axis = [gridlines = [10, color = blue], thickness = 2]) ;
end do
display(seq(G[n], n = 1 .. 10), insequence = true);
But this is nor work as well. How do i this?
Regards.
I want numerical randoms whose out are 1 or -1 only, how do i it?
I tried this:
with(Statistics):
RM := LinearAlgebra:-RandomMatrix(10, generator = -1 .. 1)
But this is not work as well.
Regards.
First 845 846 847 848 849 850 851 Last Page 847 of 2427
