I'm new to Mapple 2024, and probably miss something.
lie, e[i] i=1..4, and G are previously defined objects. Then whe I define:
cf:=(k,l,m,t,x,y,z)->seq(lie(p,e[k](t,x,y,z),e[l](t,x,y,z))*G(t,x,y,z)[p,m],p=1..4);
cf(2,4,2,t,x,y,z);
I get:
0, 0, 0, -6*(-6*z^3*(7*z - 4)*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^2*x - 6*z^4*(1 - z)^3*(-x^2 + 1)^2*(-y^2 + 1)^3*x*(-3*z^2*(7*z - 4)*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^3 - 7*z^3*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^3 - 2*z^3*(7*z - 4)*(z - 1)*(y^2 - 1)^3*(x^2 - 1)^3) - (1 - z^3*(7*z - 4)*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^3)*(-24*z^3*(1 - z)^3*(-x^2 + 1)^2*(-y^2 + 1)^3*x + 18*z^4*(1 - z)^2*(-x^2 + 1)^2*(-y^2 + 1)^3*x))*z^4*(1 - z)^3*(-x^2 + 1)^2*(-y^2 + 1)^3*x*(1 - z^3*(7*z - 4)*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^3)
The 4th item eval as:
cf(2, 4, 2, t, x, y, z)[4] = -36*z^10*x^2*(x^2 - 1)^7*(7*z^2 - 8*z + 4)*(z - 1)^7*(y^2 - 1)^9*(-1 + z^3*(7*z - 4)*(z - 1)^2*(y^2 - 1)^3*(x^2 - 1)^3)
But when I define another function by just changing the seq operator with a sum operator:
cf2:=(k,l,m,t,x,y,z)->sum(lie(p,e[k](t,x,y,z),e[l](t,x,y,z))*G(t,x,y,z)[p,m],p=1..4);
cf2(2,4,2,t,x,y,z);
I get 0.
What do I miss ?
I want to define an alias L_2 in terms of another alias L_1, the latter being a RootOf(). I noticed that doing the following does not work: alias_in_alias.mw. How to fix it? Should I define the two alias sequantially? That is, L_1 first and then (in a follow up alias()) L_2?
Sorry for the super complicated expressions. You could perhaps show me with a simpler example. Thanks!
This is my code
A := [0, 0, 0];
B := [a, 0, 0];
C := [a, a, 0];
DD := [0, a, 0];
S := [0, 0, h];
d1 := Line(A, C);
d2 := Line(S, DD);
(Distance(d1, d2) assuming (a::positive and h::positive));
I got
abs(a)^2*abs(h)/sqrt(2*abs(a*h)^2 + abs(a)^4)
How can I remove abs?
Using with(plots) and with(plottools), how do you change the color of the line enclosing a disk? I can change the line style of the line, but I can't figure out how to change the color of the line. I didn't find anything in plot options that would fit my purpose.
how_do_i_change_the_color_of_the_line_around_a_disk_while_using_plottools.mw
I am trying to verify a solution by checking whether eval() returns 0 but it's taking me forever. If I recall correctly it once returned [0,0] so I am quite confident that the first and only positive root of that polynomial solves my system. I am now running again the same calculation but somehow eval() is stuck in "Evaluating...". I am not sure if it matters here, but parameters gamma, sigma_v, and sigma_d are strictly positive while -1<rho<+1 (rho is a correlation coefficient).
How else can I verify such solution?
EDIT: THIS IS NOT A DUPLICATE QUESTION AND SHOULDN'T BE TAGGED AS SUCH
local gamma:
Equations:
eq1 := (gamma*sigma__v^2*(-1 + rho__v) - 2*lambda__2)*(rho__v*sigma__v^2 + sigma__v^2)/((2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)*((gamma*sigma__v^2*(-1 + rho__v) - 2*lambda__2)^2*(2*rho__v*sigma__v^2 + 2*sigma__v^2)/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)^2 + (-lambda__1*(gamma*sigma__v^2*(-1 + rho__v) - 4*lambda__2)/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2) + 1)^2*sigma__d^2 + gamma^2*lambda__2^2*sigma__v^4*(-1 + rho__v)^2*sigma__d^2/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)^2)):
eq2 := (gamma*sigma__v^2*(-1 + rho__v) - 2*lambda__1)*(rho__v*sigma__v^2 + sigma__v^2)/((2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)*((gamma*sigma__v^2*(-1 + rho__v) - 2*lambda__1)^2*(2*rho__v*sigma__v^2 + 2*sigma__v^2)/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)^2 + (-(gamma*sigma__v^2*(-1 + rho__v) - 4*lambda__1)*lambda__2/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2) + 1)^2*sigma__d^2 + gamma^2*lambda__1^2*sigma__v^4*(-1 + rho__v)^2*sigma__d^2/(2*gamma*(lambda__1 + lambda__2)*(-1 + rho__v)*sigma__v^2 - 8*lambda__1*lambda__2)^2)):
Eq1, Eq2 := eq1 - lambda__1, eq2 - lambda__2:
Solution:
Gamma := gamma*sigma__v*sigma__d:
L__2 := RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2);
l__2 := L__2*sigma__v*(rho__v + 1)/sigma__d:
quartic_solution := lambda__2 = simplify(allvalues~([l__2]))[1]:
RootOf((8*rho^3+24*rho^2+24*rho+8)*_Z^4+(-12*gamma*rho^3*sigma__d*sigma__v-12*gamma*rho^2*sigma__d*sigma__v+12*gamma*rho*sigma__d*sigma__v+12*gamma*sigma__d*sigma__v)*_Z^3+(5*gamma^2*rho^3*sigma__d^2*sigma__v^2-5*gamma^2*rho^2*sigma__d^2*sigma__v^2-5*gamma^2*rho*sigma__d^2*sigma__v^2+5*gamma^2*sigma__d^2*sigma__v^2-4*rho^2-8*rho-4)*_Z^2+(4*gamma*rho^2*sigma__d*sigma__v-4*gamma*sigma__d*sigma__v)*_Z-gamma^2*sigma__v^2*sigma__d^2*rho^2+2*rho*gamma^2*sigma__v^2*sigma__d^2-gamma^2*sigma__v^2*sigma__d^2)
Check: TOO SLOW
simplify(eval([eval(Eq1, lambda__1 = lambda__2), eval(Eq2, lambda__1 = lambda__2)], quartic_solution));
Download solution_check.mw
I was just wondering if there is a init file for the Windows version of Maple, like there is one for the LInux version.
I'm not talking about the Maple.ini file located in the user's Application Data folder. In the Linux version, there is a file, .mapleinit, where you can place all of your initialization setups, like the packages you want to automatically load with the worksheet, defining constants, etc.
If someone has any ideas, I really appreciate it. Thanks very much in advance.
is there any package out there to calculate Wigner J symbols and Clebsch-Gordon coefficients in Maple
Good day to all of you nice people.
I'm currently attempting to plot a vector field where each component of the vector is defined by the equations S_x, S_y, and S_z, which are functions of the radial coordinate. Here is a depiction of how the vectors change with respect to r:
The next step, which I'm unsure how to do, is to plot the vectors around the z-direction, or I should say, in phi direction, to achieve something similar to this example:
Thank you a lot for your kind help.
Here is my code:
Maple_Question.mw
I am running Maple 2023 - yes I should update - and I found a weird "bug" if you could call it that. For different versions of the Physics package I am getting different answers on the same problem.
This is what I was getting when I run Version 1410:
with(Physics):
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1744. The version installed in this computer is 1410 created 2023, March 11, 12:59 hours Pacific Time, found in the directory /Users/b2hull/maple/toolbox/2023/Physics Updates/lib/`
Setup(mathematicalnotation=true):
g_[arbitrary]:
`Systems of spacetime coordinates are:`*{X = (x1, x2, x3, x4)}
`Default differentiation variables for d_, D_ and dAlembertian are:`*{X = (x1, x2, x3, x4)}
`Setting `*lowercaselatin_is*` letters to represent `*space*` indices`
`The arbitrary metric in coordinates `*[x1, x2, x3, x4]
`Signature: `(`- - - +`)
LG :=(g_[~mu,~nu]*Ricci[mu,nu])*sqrt(-%g_[determinant]);
Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2)
SG:=Intc(LG,X)
Int(Int(Int(Int(Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2), x1 = -infinity .. infinity), x2 = -infinity .. infinity), x3 = -infinity .. infinity), x4 = -infinity .. infinity)
EQ:=Fundiff(SG,%g_[~delta,~gamma])/sqrt(-%g_[determinant])
((1/2)*%g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*%g_[delta, gamma]*%g_[determinant]/(-%g_[determinant])^(1/2)+Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2)*%g_[delta, `~mu`]*%g_[gamma, `~nu`])/(-%g_[determinant])^(1/2)
Simplify(subs(%g_=g_,EQ))
-(1/2)*Physics:-g_[delta, gamma]*Physics:-Ricci[nu, `~nu`]+Physics:-Ricci[delta, gamma]
And this is what I get if I used the latet update for 2023, Version 1683:
with(Physics):
`The "Physics Updates" version in the MapleCloud is 1744. The version installed in this computer is 1683 created 2024, March 6, 17:43 hours Pacific Time, found in the directory /Users/b2hull/maple/toolbox/2023/Physics Updates/lib/`
g_[arbitrary]:
SG:=Intc(LG,X)
-(1/2)*%g_[delta, gamma]*Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]
Strange right? I bring this up because it makes me wonder about potential errors in other computations...
The answer - equation 6 - in 1410 is the correct answer. This is simply a derivation of the Einstein Tensor.
Or some other type of calculation in indexed set. I tried the maple android app with no luck. How is done in maple?
Hey there guys, was wondering if I could get some help with this - I'm pretty new to maple.
I'm trying to take a collection of coupled ODEs I have and get maple put them in state-space form for me. I've tried a few different approaches and messed around with a few different commands but havent managed to quite make it work. At the moment I'm trying to make a DiffEquation object and then use StateSpace to get the state space representation, but I keep getting this "diff-eq is not a polynomial" line as a warning when I run the DiffEquation command and as an error when I try to conver to state space.
Could anyone tell me why I'm getting this and what the best/correct way to go about this is?
Cheers
Triple Cart derivation
with(DynamicSystems)
cart1eom := `m__1 `*(diff(v__1(t), t, t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = F
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = F
cart2eom := m__2*(diff(v__2(t), t, t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t))
m__2*(diff(diff(v__2(t), t), t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t))
cart3eom := m__3*(diff(v__3(t), t, t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))
m__3*(diff(diff(v__3(t), t), t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))
F := alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2)``
expand(cart1eom)
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t) = alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2)
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t)-alpha*k__m*k__g*V(t)/(R*r)+k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2) = 0
collect(`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t)-alpha*k__m*k__g*V(t)/(R*r)+k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2) = 0, [v__1(t), v__2, diff(v__1(t), t, t), diff(v__1(t), t)])
k*v__1(t)-k*v__2(t)+`m__1 `*(diff(diff(v__1(t), t), t))+(c__1+k__m^2*k__g^2/(R*r^2))*(diff(v__1(t), t))-alpha*k__m*k__g*V(t)/(R*r) = 0
cart1eom``
eoms := [cart1eom, cart2eom, cart3eom]
[`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2), m__2*(diff(diff(v__2(t), t), t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t)), m__3*(diff(diff(v__3(t), t), t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))]
sys_1 := DiffEquation(eoms, [V], [v__3], statevariable = [v__1, v__2, v__3])
_m2358947700544
StateSpace(sys_1)
_m2358947252000
Download 403TripleCart.mw
I`m trying execute the example of Deeplearnig:
with(DeepLearning);
v1 := Vector(8, i -> i, datatype = float[8]);
v2 := Vector(8, [-1.0, 1.0, 5.0, 11.0, 19.0, 29.0, 41.0, 55.0], datatype = float[8]);
model := Sequential([DenseLayer(1, inputshape = [1])]);
model := Vector(2, {(1) = Typesetting:-mi("`DeepLearning
   Model`"), (2) = Typesetting:-mi("`<keras.engine.sequential.Se\
  quential object at 0x000001C5B6520700>`")})
model:-Compile(optimizer = "sgd", loss = "mean_squared_error");
model:-Fit(v1, v2, epochs = 500);
"<Python object: <keras.callbacks.History object at 0x000001C5CC\
  EE9DE0>>"
convert("<Python object: <keras.callbacks.History object at 0x000001C5CCEE9DE0>>", 'symbol');
<Python object: <keras.callbacks.History object at 0x000001C5CCE\
  E9DE0>>
model:-Predict([10]);
But, finally, there is this error:
Error, (in Predict) AttributeError: 'CatchOutErr' object has no attribute 'flush'
['Traceback (most recent call last):\n', '  File "C:\\Program Files\\Maple 2023\\Python.X86_64_WINDOWS\\lib\\site-packages\\keras\\utils\\traceback_utils.py", line 70, in error_handler\n    raise e.with_traceback(filtered_tb) from None\n', '  File "C:\\Program Files\\Maple 2023\\Python.X86_64_WINDOWS\\lib\\site-packages\\keras\\utils\\io_utils.py", line 80, in print_msg\n    sys.stdout.flush()\n', "AttributeError: 'CatchOutErr' object has no attribute 'flush'\n"]
What`s is happening?
I have a complicated bivariate function f(Gamma,rho) that is a RootOf of a quartic. I know that it is strictly positive (one of the four roots at least) for Gamma=0..10 and rho in (-1,+1), with bounds excluded.
I need to find the signs of its first and second derivatives (wrt to Gamma and wrt to rho: 4 derivatives in total).
I encounter numerical issues when I plot3d the derivatives using D[]() vs. fdiff() (numerical function evaluations of the RootOf). I was hoping for the two commands to produce the same output, but they don't it seems. What's going on?
Script:
_quartic := RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2);
convert(_quartic,radical):
f(Gamma,rho) := simplify(%):
RootOf((8*rho^3+24*rho^2+24*rho+8)*_Z^4+(-12*Gamma*rho^3-12*Gamma*rho^2+12*Gamma*rho+12*Gamma)*_Z^3+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*_Z^2+(4*Gamma*rho^2-4*Gamma)*_Z-Gamma^2*rho^2+2*rho*Gamma^2-Gamma^2)
Synthetic representation of derivatives
der1_Gamma := diff(_quartic, Gamma):
der1_rho := diff(_quartic, rho):
Diff('f(Gamma,rho)', Gamma) = collect~(normal(eval(der1_Gamma, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff('f(Gamma,rho)', rho) = collect~(normal(eval(der1_rho, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
der2_Gamma := diff(der1_Gamma, Gamma):
der2_rho := diff(der1_rho, rho):
Diff('f(Gamma,rho)', Gamma$2) = collect~(normal(eval(der2_Gamma, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff('f(Gamma,rho)', rho$2) = collect~(normal(eval(der2_rho, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff(f(Gamma, rho), Gamma) = -((-6*rho^3-6*rho^2+6*rho+6)*f(Gamma, rho)^3+(5*Gamma*rho^3-5*Gamma*rho^2-5*Gamma*rho+5*Gamma)*f(Gamma, rho)^2+(2*rho^2-2)*f(Gamma, rho)-Gamma*rho^2+2*Gamma*rho-Gamma)/((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)
Diff(f(Gamma, rho), rho) = -(1/2)*((24*rho^2+48*rho+24)*f(Gamma, rho)^4+(-36*Gamma*rho^2-24*Gamma*rho+12*Gamma)*f(Gamma, rho)^3+(15*Gamma^2*rho^2-10*Gamma^2*rho-5*Gamma^2-8*rho-8)*f(Gamma, rho)^2+8*Gamma*rho*f(Gamma, rho)-2*rho*Gamma^2+2*Gamma^2)/((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)
Diff(f(Gamma, rho), Gamma, Gamma) = ((448*rho^8+1792*rho^7+1792*rho^6-1792*rho^5-4480*rho^4-1792*rho^3+1792*rho^2+1792*rho+448)*f(Gamma, rho)^8+(-1632*Gamma*rho^8-3264*Gamma*rho^7+3264*Gamma*rho^6+9792*Gamma*rho^5-9792*Gamma*rho^3-3264*Gamma*rho^2+3264*Gamma*rho+1632*Gamma)*f(Gamma, rho)^7+(2120*Gamma^2*rho^8-8480*Gamma^2*rho^6-208*rho^7+12720*Gamma^2*rho^4-624*rho^6-208*rho^5-8480*Gamma^2*rho^2+1040*rho^4+1040*rho^3+2120*Gamma^2-208*rho^2-624*rho-208)*f(Gamma, rho)^6+(-1200*Gamma^3*rho^8+2400*Gamma^3*rho^7+2400*Gamma^3*rho^6-7200*Gamma^3*rho^5+640*Gamma*rho^7+640*Gamma*rho^6+7200*Gamma^3*rho^3-1920*Gamma*rho^5-2400*Gamma^3*rho^2-1920*Gamma*rho^4-2400*Gamma^3*rho+1920*Gamma*rho^3+1200*Gamma^3+1920*Gamma*rho^2-640*Gamma*rho-640*Gamma)*f(Gamma, rho)^5+(250*Gamma^4*rho^8-1000*Gamma^4*rho^7+1000*Gamma^4*rho^6+1000*Gamma^4*rho^5-632*Gamma^2*rho^7-2500*Gamma^4*rho^4+632*Gamma^2*rho^6+1000*Gamma^4*rho^3+1896*Gamma^2*rho^5+1000*Gamma^4*rho^2-1896*Gamma^2*rho^4+16*rho^6-1000*Gamma^4*rho-1896*Gamma^2*rho^3+32*rho^5+250*Gamma^4+1896*Gamma^2*rho^2-16*rho^4+632*Gamma^2*rho-64*rho^3-632*Gamma^2-16*rho^2+32*rho+16)*f(Gamma, rho)^4+(240*Gamma^3*rho^7-720*Gamma^3*rho^6+240*Gamma^3*rho^5+1200*Gamma^3*rho^4-32*Gamma*rho^6-1200*Gamma^3*rho^3-240*Gamma^3*rho^2+96*Gamma*rho^4+720*Gamma^3*rho-240*Gamma^3-96*Gamma*rho^2+32*Gamma)*f(Gamma, rho)^3+(-25*Gamma^4*rho^7+125*Gamma^4*rho^6-225*Gamma^4*rho^5+125*Gamma^4*rho^4+125*Gamma^4*rho^3-225*Gamma^4*rho^2+125*Gamma^4*rho-25*Gamma^4)*f(Gamma, rho)^2+(16*Gamma^3*rho^6-64*Gamma^3*rho^5+80*Gamma^3*rho^4-80*Gamma^3*rho^2+64*Gamma^3*rho-16*Gamma^3)*f(Gamma, rho)-5*Gamma^4*rho^6+30*Gamma^4*rho^5-75*Gamma^4*rho^4+100*Gamma^4*rho^3-75*Gamma^4*rho^2+30*Gamma^4*rho-5*Gamma^4)/(((16*rho^2+32*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^2+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^2-10*Gamma^2*rho+5*Gamma^2-4*rho-4)*f(Gamma, rho)+2*Gamma*rho-2*Gamma)*((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)^2)
Diff(f(Gamma, rho), rho, rho) = (1/4)*((21504*rho^6+129024*rho^5+322560*rho^4+430080*rho^3+322560*rho^2+129024*rho+21504)*f(Gamma, rho)^10+(-80640*Gamma*rho^6-347136*Gamma*rho^5-526080*Gamma*rho^4-245760*Gamma*rho^3+157440*Gamma*rho^2+199680*Gamma*rho+56064*Gamma)*f(Gamma, rho)^9+(127680*Gamma^2*rho^6+336512*Gamma^2*rho^5+122944*Gamma^2*rho^4-319744*Gamma^2*rho^3-18176*rho^5-246976*Gamma^2*rho^2-90880*rho^4+40576*Gamma^2*rho-181760*rho^3+53696*Gamma^2-181760*rho^2-90880*rho-18176)*f(Gamma, rho)^8+(-110016*Gamma^3*rho^6-112128*Gamma^3*rho^5+191808*Gamma^3*rho^4+172032*Gamma^3*rho^3+57344*Gamma*rho^5-105792*Gamma^3*rho^2+191488*Gamma*rho^4-59904*Gamma^3*rho+192512*Gamma*rho^3+24000*Gamma^3+2048*Gamma*rho^2-94208*Gamma*rho-37888*Gamma)*f(Gamma, rho)^7+(54960*Gamma^4*rho^6-28480*Gamma^4*rho^5-102480*Gamma^4*rho^4+56960*Gamma^4*rho^3-74176*Gamma^2*rho^5+40080*Gamma^4*rho^2-126144*Gamma^2*rho^4-28480*Gamma^4*rho+41088*Gamma^2*rho^3+7440*Gamma^4+138368*Gamma^2*rho^2+5120*rho^4+19776*Gamma^2*rho+20480*rho^3-25536*Gamma^2+30720*rho^2+20480*rho+5120)*f(Gamma, rho)^6+(-15300*Gamma^5*rho^6+30000*Gamma^5*rho^5-2100*Gamma^5*rho^4-24000*Gamma^5*rho^3+50048*Gamma^3*rho^5+14100*Gamma^5*rho^2+5632*Gamma^3*rho^4-6000*Gamma^5*rho-89856*Gamma^3*rho^3+3300*Gamma^5-1024*Gamma^3*rho^2-13056*Gamma*rho^4+39808*Gamma^3*rho-31232*Gamma*rho^3-4608*Gamma^3-15360*Gamma*rho^2+10752*Gamma*rho+7936*Gamma)*f(Gamma, rho)^5+(1875*Gamma^6*rho^6-6250*Gamma^6*rho^5+7125*Gamma^6*rho^4-3500*Gamma^6*rho^3-18316*Gamma^4*rho^5+2125*Gamma^6*rho^2+25540*Gamma^4*rho^4-2250*Gamma^6*rho+12072*Gamma^4*rho^3+875*Gamma^6-26520*Gamma^4*rho^2+12992*Gamma^2*rho^4+6244*Gamma^4*rho+10240*Gamma^2*rho^3+980*Gamma^4-15488*Gamma^2*rho^2-9728*Gamma^2*rho-512*rho^3+3008*Gamma^2-1536*rho^2-1536*rho-512)*f(Gamma, rho)^4+(3320*Gamma^5*rho^5-9240*Gamma^5*rho^4+7600*Gamma^5*rho^3-560*Gamma^5*rho^2-6144*Gamma^3*rho^4-1320*Gamma^5*rho+4992*Gamma^3*rho^3+200*Gamma^5+6784*Gamma^3*rho^2-4992*Gamma^3*rho+1024*Gamma*rho^3-640*Gamma^3+1536*Gamma*rho^2-512*Gamma)*f(Gamma, rho)^3+(-200*Gamma^6*rho^5+800*Gamma^6*rho^4-1200*Gamma^6*rho^3+800*Gamma^6*rho^2+1248*Gamma^4*rho^4-200*Gamma^6*rho-3136*Gamma^4*rho^3+1920*Gamma^4*rho^2+576*Gamma^4*rho-768*Gamma^2*rho^3-608*Gamma^4+768*Gamma^2*rho)*f(Gamma, rho)^2+(-16*Gamma^5*rho^4+192*Gamma^5*rho^3-480*Gamma^5*rho^2+448*Gamma^5*rho+256*Gamma^3*rho^3-144*Gamma^5-384*Gamma^3*rho^2+128*Gamma^3)*f(Gamma, rho)-20*Gamma^6*rho^4+80*Gamma^6*rho^3-120*Gamma^6*rho^2+80*Gamma^6*rho-32*Gamma^4*rho^3-20*Gamma^6+96*Gamma^4*rho^2-96*Gamma^4*rho+32*Gamma^4)/(((16*rho^2+32*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^2+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^2-10*Gamma^2*rho+5*Gamma^2-4*rho-4)*f(Gamma, rho)+2*Gamma*rho-2*Gamma)*((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)^2)
Signs of derivatives: fdiff (numerical function evaluations of the RootOf) vs. D[]()
_quartic := RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2):
plot3d(_quartic, Gamma=0..10, rho=-1..+1, labels=[Gamma,rho,Lambda(Gamma,rho)],axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30]);
Define it as a f and test it for Gamma=1 and rho=0.5
f := (Gamma,rho) -> RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2):
evalf(f(1.0,0.5));
HFloat(0.5110796212870378)
Value at zero:
f(0,0):
allvalues(%):
fl := select(is, [allvalues(f(0,0))], positive)[];evalf(%);
(1/2)*2^(1/2)
.7071067810
Value at infinity (commented out because too slow)
#limit(f(x,y), {x = infinity, y = 0}):
#fh := select(is, [allvalues(%)], positive)[];evalf(%);
Derivative at zero:
allvalues([D[1](f)(0,0)]):
Dfl := %[1][];
-1/4
Derivative at a point, evaluated, vs numerical derivative at a point:
D[1](f)(1,0.5):
evalf(%);
fdiff(f(x,y), x, {x = 1.0, y = 0.5});
fdiff(f, [1], [1.0,0.5]);
D[2](f)(1,0.5):
evalf(%);
fdiff(f(x,y), y, {x = 1.0, y = 0.5});
fdiff(f, [2], [1.0,0.5]);
HFloat(-0.05086932918910799)
-0.5086932919e-1
-0.5086932919e-1
HFloat(-0.05166477232109392)
-0.5166477232e-1
-0.5166477232e-1
Can make a function out of fdiff
fDfG := (Gamma,rho) -> fdiff(f, [1], [Gamma,rho]);
fDfr := (Gamma,rho) -> fdiff(f, [2], [Gamma,rho]);
proc (Gamma, rho) options operator, arrow; fdiff(f, [1], [Gamma, rho]) end proc
proc (Gamma, rho) options operator, arrow; fdiff(f, [2], [Gamma, rho]) end proc
Check for numerical values close to thresholds:
Digits := 15:
evalf('D[1]'(f)(0.1e-8,0.5));fdiff(f, [1], [0.1e-8,0.5]);
evalf('D[1]'(f)(0.1e-7,0.5));fdiff(f, [1], [0.1e-7,0.5]);
evalf('D[1]'(f)(0.1e-5,0.5));fdiff(f, [1], [0.1e-5,0.5]);
evalf('D[1]'(f)(0.00001,0.5));fdiff(f, [1], [0.00001,0.5]);
evalf('D[1]'(f)(0.001,0.5));fdiff(f, [1], [0.001,0.5]);
evalf('D[2]'(f)(1,-0.99));fdiff(f, [2], [1,-0.99]);
evalf('D[2]'(f)(1,-0.97));fdiff(f, [2], [1,-0.97]);
evalf('D[2]'(f)(1,-0.1));fdiff(f, [2], [1,-0.1]);
evalf('D[2]'(f)(1,0.98));fdiff(f, [2], [1,0.98]);
57735026.8022959
57735026.8022959
-0.833333329724894e-1
-0.833332972489415e-1
-0.833329724894151e-1
-0.832972489466445e-1
-223.615892086941
-223.615892086941
-43.0236130145893
-43.0236130145893
-.212392503268663
-.212392503268663
-0.127828146340716e-2
-223.615892086941
-223.615892086941
Compare with D (vertical range here to prevent effect of large values from fdiff near zero):
d1G := plot3d([D[1](f), fDfG], 0..10, -0.95..+0.95, view=-0.3..0, color = [red, blue]);
d1r := plot3d([D[2](f), fDfr], 0..10, -0.95..+0.95, color = [red, blue]);
Second derivatives:
evalf('D[1,1]'(f)(1.0,0.5));
fdiff(f, [1, 1], [1.0,0.5]);
evalf('D[2,2]'(f)(1.0,0.5));
fdiff(f, [2, 2], [1.0,0.5]);
fD2fG := (Gamma,rho) -> fdiff(f, [1, 1], [Gamma]);
fD2fr := (Gamma,rho) -> fdiff(f, [2, 2], [Gamma]);
0.266607527050519e-1
.151600577769391
.151600577769391
proc (Gamma, rho) options operator, arrow; fdiff(f, [1, 1], [Gamma]) end proc
proc (Gamma, rho) options operator, arrow; fdiff(f, [2, 2], [Gamma]) end proc
d2G:= plot3d([D[1,1](f), fD2fG], 0..10, -0.9..+0.9, color = [red, blue]);
d2r:= plot3d([D[2,2](f), fD2fr], 0..10, -0.9..+0.9, color = [red, blue]);
d1d2G := plot3d([fDfG, fD2fG], 0.1e-6 .. 10, -0.98 .. +0.98, axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30], size=[1000,1000]);
d1d2r := plot3d([fDfr, fD2fr], 0.1e-6 .. 10, -0.98 .. +0.98, axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30], size=[1000,1000]);
Download signs_derivatves_bivariate.mw
Why does no substitution work on functions with s(n+1,t) (see eqns (2-8))? Also (&PartialD;)/(&PartialD; (sigma2*t))=1/(sigma2)(&PartialD;)/(&PartialD; t), how can I do it on Maple?shift.mw
I am trying to load the third-party package 'CPC Program Library (qub.ac.uk)' by following the instructions as in 'how to install wkptest? - MaplePrimes'. But encounter with Errors: '
Error, `:` unexpected
with(wkptest);
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received wkptest
sourcefolder:=cat(kernelopts('C:\Users\ahmed\Downloads\adty_v1_0'),"/wkptest");
installfolder:=cat(kernelopts('homedir'),"/maple/toolbox/wkptest/lib");
FileTools:-MakeDirectory(installfolder, 'recurse'=true);
libraryfile:=cat(installfolder,"/wkptest.mla");
try
  FileTools:-Remove(libraryfile);
catch:
end try:
LibraryTools:-Create(libraryfile);
libname:=libraryfile,libname;
read cat(sourcefolder,"/wkptest_cpc");
with(wkptest);
Download exam_wkptest1.mws
First 139 140 141 142 143 144 145 Last Page 141 of 2458
