I would like to write some code to test certain functions in a codebase that has gotten relatively large but has no tests. I recently found a bug caused by copying a line and pasting it five times (was supposed to change a parameter on each line but forgot to). Didn't notice the bug until I refactored that procedure to make the code parallelizable for use with the Grid package.
Hence, I am worried about such unknown calculation mistakes in algorithms that involve a sequence of intermediate steps/calculations.
I found there is an assert command
I would write procedures that would call the procedures to be tested with certain arguments and assert the output.
Are there any other tools available or best practices perhaps from experience?
Is it possible to indent list/bullet items easily?  In other programs, when you tab to indent a bullet item, the bullet moves with you.  In Maple the bullet and/or list item stays fixed to the left of the execution group.
with(geometry):
_EnvHorizontalName = 'x':
_EnvVerticalName = 'y':
EQ := proc(M, N)
local eq, sol;
eq := simplify(expand((y - M[2])/(x - M[1]) - (N[2] - M[2])/(N[1] - M[1])));
sol := solve(eq, y);
RETURN(y = sol); end proc:
_local(D);
point(A, [-2, 7]):
point(B, [-5, -2]):
point(C, [8, -7]):
point(E, [1, 4]):
EQ([-5, -2], [8, -7]):
point(D, [1, subs(x = 1, rhs(%))]):
dsegment(sgAD, [A, D]):
BD := distance(B, D):
DC := distance(C, D):
triangle(ABC, [A, B, C]):
area(ABC):
triangle(ABD, [A, B, D]):
area(ABD):
triangle(ADC, [A, D, C]):
area(ADC):
is(area(ABD)/area(ADC) = BD/DC):
triangle(EBD, [E, B, D]):
area(EBD):
triangle(EDC, [E, D, C]):
area(EDC):
triangle(AEC, [A, E, C]):
area(AEC):
triangle(ABE, [A, B, E]):
area(ABE):
is(area(ABE)/area(AEC) = BD/DC):
display*([draw*[A(color = black, symbol = solidcircle, symbolsize = 6),
B(color = black, symbol = solidcircle, symbolsize = 6),
C(color = black, symbol = solidcircle, symbolsize = 6),
ABC(color = blue)],
textplot*([[coordinates(A)[], "A"],
[coordinates(B)[], "B"],
[coordinates(C)[], "C3"]],
align = [above, right])],
axes = none,
title = "Lemme du Chevron");
The program simply reproduces display...Why; Thank you.
display*([draw*[A(color = black, symbol = solidcircle, symbolsize = 12), B(color = black, symbol = solidcircle, symbolsize = 12), C(color = black, symbol = solidcircle, symbolsize = 12), ABC(color = blue)], textplot*([[-2, 7, "A"], [-5, -2, "B"], [8, -7, "C3"]], align = [above, right])], axes = none, title = "Lemme du Chevron")
queryequal(expr1, expr2)
queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2)))
(This question has its origin here).
Plotting the difference of rhs - lhs seems to indicate equality over the range [0..1)
difference := rhs(op(queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))))[1])-op(queryequal(Int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0) = 2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2)), 2^(1/2)*EllipticF((1-1/(1+x__0))^(1/2)*2^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))))[2]; plot(difference, x__0 = 0 .. 1, title = 'difference', color = RED)
Try simplify
`assuming`([simplify(difference)], [0 < x__0 and x__0 < 1])
(EllipticK((1/2)*(2+2*x__0)^(1/2))-EllipticF(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2))-EllipticF(1/(1+x__0)^(1/2), (1/2)*(1+x__0)^(1/2)*2^(1/2)))*2^(1/2)
Try combine
`assuming`([combine(difference)], [0 < x__0 and x__0 < 1])
-2^(1/2)*EllipticF((x__0/(1+x__0))^(1/2)*2^(1/2), (1/2)*(2+2*x__0)^(1/2))-2^(1/2)*EllipticF(1/(1+x__0)^(1/2), (1/2)*(2+2*x__0)^(1/2))+2^(1/2)*EllipticK((1/2)*(2+2*x__0)^(1/2))
Try conversion to integral form
convert(difference, Int)
2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. 1))-2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2)))-2^(1/2)*(Int(2/((-_alpha1^2+1)^(1/2)*(-2*_alpha1^2*x__0-2*_alpha1^2+4)^(1/2)), _alpha1 = 0 .. (1-1/(1+x__0))^(1/2)*2^(1/2)))
`assuming`([simplify(%)], [0 < x__0 and x__0 < 1])
-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1)))
plot(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = .999 .. 1, color = RED)
evalf(eval(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = 1), 40); evalf(eval(-2*2^(1/2)*(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = 0 .. 1/(1+x__0)^(1/2))-(Int(1/((-_alpha1^2+1)^(1/2)*(4+(-2*x__0-2)*_alpha1^2)^(1/2)), _alpha1 = x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2) .. 1))), x__0 = .9999999999), 40)
-0.8716953127866940896552122384831392143938e-30
There seems to be a finite difference at x__0 = 1
Try an addition theorem from DLMF
Since all elliptic expression have the same modulus k, the following addition theorem could be applied under the condition that the corresponding case is fulfilled https://dlmf.nist.gov/19.11#E7
Check if the following case applies (i.e. is ψ=π/2?)
theta = 1/sqrt(1+x__0), `&varphi;` = sqrt(1-1/(1+x__0))*sqrt(2)
theta = 1/(x__0+1)^(1/2), varphi = (1-1/(x__0+1))^(1/2)*2^(1/2)
k = (1/2)*sqrt(1+x__0)*sqrt(2)
k = (1/2)*(x__0+1)^(1/2)*2^(1/2)
tan((1/2)*psi) = (sin(theta)*Delta(`&varphi;`)+sin(`&varphi;`)*Delta(theta))/(cos(theta)+cos(`&varphi;`))
tan((1/2)*psi) = (sin(theta)*Delta(varphi)+sin(varphi)*Delta(theta))/(cos(theta)+cos(varphi))
Delta(theta) = sqrt(1-k^2*sin(theta)^2)
Delta(theta) = (1-k^2*sin(theta)^2)^(1/2)
subs(theta = `&varphi;`, Delta(theta) = (1-k^2*sin(theta)^2)^(1/2))
Delta(varphi) = (1-k^2*sin(varphi)^2)^(1/2)
subs(Delta(theta) = (1-k^2*sin(theta)^2)^(1/2), Delta(varphi) = (1-k^2*sin(varphi)^2)^(1/2), k = (1/2)*(1+x__0)^(1/2)*2^(1/2), theta = 1/(1+x__0)^(1/2), varphi = (1-1/(1+x__0))^(1/2)*2^(1/2), tan((1/2)*psi) = (sin(theta)*Delta(varphi)+sin(varphi)*Delta(theta))/(cos(theta)+cos(varphi)))
tan((1/2)*psi) = (sin(1/(x__0+1)^(1/2))*(1-(1/2)*(x__0+1)*sin((1-1/(x__0+1))^(1/2)*2^(1/2))^2)^(1/2)+sin((1-1/(x__0+1))^(1/2)*2^(1/2))*(1-(1/2)*(x__0+1)*sin(1/(x__0+1)^(1/2))^2)^(1/2))/(cos(1/(x__0+1)^(1/2))+cos((1-1/(x__0+1))^(1/2)*2^(1/2)))
`assuming`([simplify(subs(psi = (1/2)*Pi, tan((1/2)*psi) = (sin(1/(1+x__0)^(1/2))*(1-(1/2)*(1+x__0)*sin((1-1/(1+x__0))^(1/2)*2^(1/2))^2)^(1/2)+sin((1-1/(1+x__0))^(1/2)*2^(1/2))*(1-(1/2)*(1+x__0)*sin(1/(1+x__0)^(1/2))^2)^(1/2))/(cos(1/(1+x__0)^(1/2))+cos((1-1/(1+x__0))^(1/2)*2^(1/2)))))], [0 < x__0 and x__0 < 1])
1 = (sin(1/(x__0+1)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2))*((2+2*x__0)*cos(1/(x__0+1)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(x__0+1)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(x__0+1)^(1/2)))
(14)
plot([lhs(1 = (sin(1/(1+x__0)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))*((2+2*x__0)*cos(1/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(1+x__0)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2)))), rhs(1 = (sin(1/(1+x__0)^(1/2))*((2+2*x__0)*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2)+sin(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))*((2+2*x__0)*cos(1/(1+x__0)^(1/2))^2+2-2*x__0)^(1/2))/(2*cos(1/(1+x__0)^(1/2))+2*cos(x__0^(1/2)*2^(1/2)/(1+x__0)^(1/2))))], x__0 = 0 .. 1, legend = [lhs, rhs])
lhs and rhs are not equal -> Case psi = (1/2)*Pi does not apply (provided that the formulas have been applied correctly).
Perhaps this is why Maple does not simply the difference to zero.  NULL
Anything else that could be tried in Maple (maybe with other formulas)?
Download Equality_of_Elliptic_expressions.mw
Digits:= trunc(evalhf(Digits)); #generally a very efficient setting
15
Setup of BVP system:
#ordinary differential equations:
ODEs:= [
   #Eq 1:
   A1*(diff(f(x), x, x, x))/(A2*phi)-(diff(f(x), x))^2-M^2*(f(x))+f(x)*(diff(f(x), x, x)),
   #Eq 2:
   A4*Pr*phi*(diff(Theta(x), x, x))/A3+f(x)*(diff(Theta(x), x))+Q*Theta(x)
   #All these ODEs are implicitly equated to 0.
<ODEs[]>; #Display the ODEs.
Vector(2, {(1) = A1*(diff(diff(diff(f(x), x), x), x))/(A2*phi)-(diff(f(x), x))^2-M^2*f(x)+f(x)*(diff(diff(f(x), x), x)), (2) = A4*Pr*phi*(diff(diff(Theta(x), x), x))/A3+f(x)*(diff(Theta(x), x))+Q*Theta(x)})
Params := Record(fw = .2, M = .5, Q = .5, Pr = 6.2, phi = 0.5e-1, rf = 997.1, kf = .613, cpf = 4179, btf = 0.3e-4, p1 = 0.1e-1, p2 = 0.5e-1, p3 = 0.5e-1, rs1 = 5100, ks1 = 3007.4, cps1 = 410, bs1 = 0.2e-3, rs2 = 2200, ks2 = 5000, cps2 = 790, bs2 = 0.5e-3, rs3 = 3970, ks3 = 40, cps3 = 765, bs3 = 0.4e-3, A1 = B1*p1+B2*p2+B3*p3, B1 = 1+2.5*phi+6.2*phi^2, B2 = 1+13.5*phi+904.4*phi^2, B3 = 1+37.1*phi+612.6*phi^2, B4 = (ks1+2*kf-2*phi*(kf-ks1))/(ks1+2*kf+phi*(kf-ks1)), B5 = (ks2+3.9*kf-3.9*phi*(kf-ks2))/(ks2+3.9*kf+phi*(kf-ks2)), B6 = (ks3+4.7*kf-4.7*phi*(kf-ks3))/(ks3+4.7*kf+phi*(kf-ks3)), A2 = 1-p1-p2-p3+p1*rs1/rf+p2*rs2/rf+p3*rs3/rf, A3 = B4*p1+B5*p2+B6*p3, A4 = 1-p1-p2-p3+p1*rs1*cps1/(rf*cpf)+p2*rs2*cps2/(rf*cpf)+p3*rs3*cps3/(rf*cpf))
LB, UB := 0, 1; BCs := [`~`[`=`](([f(x), diff(f(x), x), Theta])(LB), [fw, 1, 1])[], `~`[`=`](([diff(f(x), x), Theta])(UB), [0, 0])[]]
[(f(x))(0) = fw, (diff(f(x), x))(0) = 1, Theta(0) = 1, (diff(f(x), x))(1) = 0, Theta(1) = 0]
NBVs := [A1*(diff(f(x), x, x))(0) = C*`*f`, -A4*(diff(Theta(x), x))(0) = `Nu*`]; Nu := `Nu*`; Cf := `C*__f`; x0 := Array([LB])
Solve := module () local nbvs_rhs, Sol, Dsolve, ModuleApply, AccumData, ModuleLoad; export SavedData, Pos, Init;  nbvs_rhs := `~`[rhs](:-NBVs); Dsolve := proc (Sys, Params::(set(name = realcons))) option remember; Sol := dsolve(Sys, _rest, 'numeric'); AccumData(Params); eval(Sol) end proc; ModuleApply := subs(_Sys = {:-BCs[], :-NBVs[], :-ODEs[]}, proc ({ fw::realcons := Params:-fw, Pr::realcons := Params:-Pr, M::realcons := Params:-M, Q::realcons := Params:-Q, phi::realcons := Params:-phi }) Dsolve(_Sys, {_options}, {_rest}[]) end proc); AccumData := proc (params::(set(name = realcons))) local n, nbvs; if Sol::rtable then nbvs := seq(n = Sol[2, 1][1, Pos(n)], n = nbvs_rhs) else nbvs := `~`[`=`](nbvs_rhs, eval(nbvs_rhs, Sol(:-LB)))[] end if; SavedData[params] := Record[packed](params[], nbvs); return  end proc; ModuleLoad := eval(Init); Init := proc () Pos := proc (n::name) local p; option remember; member(n, Sol[1, 1], 'p'); p end proc; SavedData := table(); return  end proc; ModuleLoad() end module
colseq := [red, green, blue, brown]
#parameter values that remain fixed for the entire set of plots:
Pc:= phi=0.05:
#parameter values that remain fixed with each of the four plots::
Ps:= [
   [fw=0.2, Pr=6.2, M=0.5],
   [fw=0.2, Q=0.3, M=0.5],
   [fw=0.2, Pr=6.2, Q=0.3],
   [Q=0.3, Pr=6.2, M=0.5]
#parameter value for each curve
Pv:= [
   Q=[0.2, 0.4, 0.6, 0.8],
   Pr=[0.7, 1.4, 2.1, 2.8],
   M=[0.6, 1.2, 1.8, 2.4],
   fw=[1, 2, 3, 4]
for i to nops(Ps) do
   plots:-display(
      [seq(
         plots:-odeplot(
            Solve(lhs(Pv[i])= rhs(Pv[i])[j], Ps[i][], Pc),
            [x, Theta(x)], 'color'= colseq[j], 'legend'= [lhs(Pv[i])= rhs(Pv[i])[j]]
         j= 1..nops(rhs(Pv[i]))
      'axes'= 'boxed', 'gridlines'= false,
      'labelfont'= ['TIMES', 'BOLDOBLIQUE', 16],
      'caption'= nprintf(
         cat("\n%a = %4.2f, "$nops(Ps[i])-1, "%a = %4.2f\n\n"), (lhs,rhs)~(Ps[i])[]
      'captionfont'= ['TIMES', 16]
od;
for i to nops(Ps) do plots:-display([seq(plots:-odeplot(Solve(lhs(Pv[i]) = rhs(Pv[i])[j], Ps[i][], Pc), [x, D(f(x))], 'color' = colseq[j], 'legend' = [lhs(Pv[i]) = rhs(Pv[i])[j]]), j = 1 .. nops(rhs(Pv[i])))], 'axes' = 'boxed', 'gridlines' = false, 'labelfont' = ['TIMES', 'BOLDOBLIQUE', 16], 'caption' = nprintf(cat(`$`("\n%a = %4.2f, ", nops(Ps[i])-1), "%a = %4.2f\n\n"), `~`[lhs, rhs](Ps[i])[]), 'captionfont' = ['TIMES', 16]) end do
ParamPlot2d := proc (Y::{`module`, procedure}, X::(name = range(realcons)), FP::(list(name = realcons)), { dsolveopts::(list({name, name = anything})) := [] }) plot(proc (x) options operator, arrow; Y(Solve(lhs(X) = x, FP[], 'abserr' = 0.5e-4, 'interpolant' = false, 'output' = x0, dsolveopts[])) end proc, rhs(X), 'numpoints' = 25, 'axes' = 'boxed', 'gridlines' = false, 'labelfont' = ['TIMES', 'BOLDOBLIQUE', 16], 'caption' = nprintf(cat(`$`("%a = %4.2f, ", nops(FP)-1), "%a = %4.2f"), `~`[lhs, rhs](FP)[]), 'captionfont' = ['TIMES', 16], _rest) end proc
#procedure that extracts Nusselt number from dsolve solution:
GetNu:= (Sol::Matrix)-> Sol[2,1][1, Solve:-Pos(:-Nu)]:
Q:= [0.2, 0.4, 0.6]:
plots:-display(
   [seq(
      ParamPlot2d(
         GetNu, fw= 1..4, [M= 0.5],
         'dsolveopts'= [Q= Q[k], Pr=6.2,  phi=0.05],
         'legend'= [Q= Q[k]], 'color'= colseq[k], 'labels'= [fw, Nu]
      k= 1..nops(Q)
Error, invalid input: ParamPlot2d expects value for keyword parameter dsolveopts to be of type list({name, name = anything}), but received [[.2, .4, .6] = .2, Pr = 6.2, phi = 0.5e-1]
Download surface_dinesh_paper.mw  please help me to solve the problem
Hi, I would appreciate some help in solving the following system of partial differential equations. The particularity of the system is that only the individual variables (i.e. a, c, and l) depend on two arguments (t: current time period and v: date of birth). The other variables are either rates or aggregates. The aggregate variables (i.e. K, L, and Y) depend only on time, t, because they are the integrals of the individual variables over v. Thanks for your help.
restart; with(PDEtools)
alpha := .3306341; delta := solve(1+0.4877489e-1 = exp(delta_a)); T := 1
l0 := 42.375*(33.16667/(52*(24-9.95)*7)); L0 := l0*T
x0 := 0
IOR := .2093723865
KOR := IOR/delta
r0 := alpha/KOR-delta; rho := r0; fsolve({K0 = Y0*KOR, w0 = (1-alpha)*Y0/L0, alpha*exp(x0)*K0^(alpha-1)*L0^(1-alpha) = r0+delta}); assign(%)
0.2758153402e-1
{K0 = 2.510740299, Y0 = .5710794198, w0 = 1.390997088}
C0 := -K0*delta+Y0; c0 := C0/T
.4515111588
.4515111588
sigma := w0*(1-l0)/c0
2.234133040
eq1 := diff(c(t, v), t) = (r(t)-rho)*c(t, v)
eq2 := sigma*c(t, v) = w(t)*(1-l(t, v))
eq3 := r(t)*a(t, v)+w(t)*l(t, v) = c(t, v)+diff(a(t, v), t)
eq4 := Y(t) = exp(x(t))*K(t)^alpha*L(t)^(1-alpha)
eq5 := r(t)-delta = alpha*Y(t)/K(t)
eq6 := w(t) = (1-alpha)*Y(t)/L(t)
eq7 := K(t) = int(a(t, v), v = t-T .. t)
eq8 := L(t) = int(l(t, v), v = t-T .. t)
eq9 := x(t) = piecewise(t = 0, 0, t > 0, 0.1e-1)
eq := {eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}
SV := {K(0) = K0, L(0) = L0, Y(0) = Y0, a(t, 0) = 0, c(0, 0) = c0, l(0, 0) = l0, r(0) = r0, w(0) = w0}
pdsolve(eq, SV, numeric, 'time' = t, 'range' = 0 .. T)
Error, (in pdsolve/numeric/process_PDEs) variable(s) {v} are in the PDE system but are not dependent or independent variables
sol := pdsolve(eq, SV, 'time' = t, 'range' = 0 .. T)
Download OLG.mw
This might sound like a simple question, but I have looked pretty hard in the documentation and can't find a solution.  I want to plot functions in spherical coordinates in such a way that they are actually spherical.  For example, r = 1 should be a sphere.  All I can do is get the "cube" with sides labelled as the traditional variables r, theta, and phi.  That's not really spherical coordinates, it's just relabelled Cartesian.
I didn't make a worksheet for this topic.
I have been bothered lately by the number format for axis labels in Maple. My problem existed before, but it apparently didn't bother me before. I have spent many hours trying to find an answer in the program help, in MaplePrimes, and in general online searches. I am not having any luck at all (good luck, that is).
I want to change the format of the axis numbering. Maple seems to default to 2 decimal places in my graph, and I really need more. Oddly, when I export the graph to PDF, I get another decimal place (even though I didn't explicitly ask for one).
How do I change the axis-label format? Any idea what I might get when I export the graph?
Thanks for your help,
Jno.
How can I change the order of variables in a polynomial as I want? For example, I want to assign a polynomial G of 3 variables a,b,c. Then I want to compute G(a,b,c) (exchange the variable a to b, exchange variable b to a)?
Hello everybody
I would like to check, with Spacetime Tensors computation , if  a transfomation is a Lorentz transformation , i.e that leavs Minkosky metric invariant
For esample a boost  or axis rotation transformation
Some could help me ? ( Maple 2016)
Thank's a lot
I've probably asked about this long time ago but I do not remember now. But it is still a problem any way in 2022.2
Compare these two results
code is
alias(seq(c[k] = _C||k, k = 0..10));
c[1]*h(x);
Int(c[1]*h(x),x);
c[1]*h(x);
Int(c[1]*h(x),x);
I tried with typesetting level as extended and standard and same result.
Is this a know issue? It is not a big deal as it only affects display but it will be nice to find why it happens when using alias.
This a more a math question than  a maple programming question. But interesting.
I have a point P=[x,y] on a line y= 2+3x. The point maps to Pn=[f(x, y), g(x, y)]. That represents a conic.
I want to find the equation of the conic. I did it by calculating 5 points and that works fine but only because I know I'm looking for a conic.
Can the problem by solved without having to get the five points?
I copied and pasted the equations for the lines because they were generated by commands in a pagkage I have.
P := [X, Y]
[X, Y]
Pn := [(5*X+12*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y), (2*(12*X-5*Y))*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y)]
[(5*X+12*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y), 2*(12*X-5*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y)]
Y := 2+3*Xn
2+3*X
for i to 5 do P || i := eval(Pn, X = i) end do
[181139/51416, -19775/25708]
l12 := 153621*x*(1/68840)+169429*y*(1/27536)-15067/17210
(153621/68840)*x+(169429/27536)*y-15067/17210
l34 := -5733*x*(1/473062)+258973*y*(1/946124)+244205/946124
-(5733/473062)*x+(258973/946124)*y+244205/946124
c1 := l12*l34
((153621/68840)*x+(169429/27536)*y-15067/17210)*(-(5733/473062)*x+(258973/946124)*y+244205/946124)
l13 := 5499*x*(1/2360)+6539*y*(1/944)-793/472
(5499/2360)*x+(6539/944)*y-793/472
l24 := 596115*x*(1/6899489)+7228091*y*(1/6899489)+195364/363131
(596115/6899489)*x+(7228091/6899489)*y+195364/363131
plots:-implicitplot([l12, l34, l13, l24])
c2 := l13*l24
((5499/2360)*x+(6539/944)*y-793/472)*((596115/6899489)*x+(7228091/6899489)*y+195364/363131)
c := simplify(c2*lambda+c1)
(655607277/3256558808)*(x+(2515/846)*y-305/423)*(x+(556007/45855)*y+285532/45855)*lambda-(880709193/32565588080)*(x-(19921/882)*y-18785/882)*(x+(65165/23634)*y-4636/11817)
lambda := solve(eval(c, [x = P5[1], y = P5[2]]), lambda)
-1/4
simplify(c)
-(5039454771/65131176160)*x^2+(1/130262352320)*(-29130506847*y+40315638168)*x-(423368829/3256558808)*y^2+(111619143207/130262352320)*y
plt1 := plot(Y, X = -10 .. 10)
plt2 := plots:-implicitplot([c])
plots:-display(plt1, plt2, colour = ["Red", "Green"])
for i in [-7, 13/3, 42*(1/7)] do x := eval(Pn[1], X = i); y := eval(Pn[2], X = i); simplify(c) end do
Download Q_23-03-04_how_to_find_conic_from_mapping.mw
Dears,
I have a problem whem try to solve a optimization probolem.
The equations are "complex" (G1 equation), and this error is showed "Error, (in Optimization:-NLPSolve) could not store 0.1749271137e-1*(588.000000000000+72.0000000000000*(-3.03333333+.333333333333333*MM)*(MM-17.80)+72.0000000000000*(.333333333333333*NN-3.5666666666667)*(17.00-1.*NN)+24.50000000*(2.90+4.666666667*tan(1.000000000*arctan(.166666666666667*MM-2.96666666666667)))*(18.00+5.627472876000*sin(-1.570796327+1.000000000*arctan(.166666666666667*MM-2.96666666666667))/sin(-1.745329252+1.000000000*arctan(.166666666666667*MM-2.96666666666667)))*cos(-.5235987756000+1.000000000*arctan(.166666666666667*MM-2.96666666666667))^2*sin(.3490658504000+1.000000000*arctan(.166666666666667*MM-2.9666 ... 756000+1.000000000*arctan(.166666666666667*MM-2.96666666666667))^2)-1. in a floating-point rtable".
Someone can help me?
ATS := proc(NN::float, MM::float)
L[7]*H[4] + L[4]*H[2] + L[1]*(H[1] - H[2]) + 1/2*(P[X1] - NN)*(H[1] - H[2]) + 1/2*(MM - P[XF])*(H[1] - H[2]);
bounds := 14.90 .. 16.90, 17.90 .. 19.90;
cstr8 := proc(NN::float, MM::float)
G1 - FS;
NLPSolve(ATS, {cstr8}, bounds, initialpoint = [15.90, 18.90], assume = nonnegative)
Hi MaplePrimes,
I am interested in obtaining some gravitational field equations from an action using the FunDiff command. I have been able to write what I think is a pretty short and quick worksheet(with an arbitrary metric) and I am easily able to obtain the Einstein Field Equations. However, when I introduce some new more complicated terms into the action and apply the Simplify command maple does not appear to be able to evaluate and I end up halting the computation. When I specify a metric Maple, for example Schwarzschild, Maple will easily be able to Simplify my expression but it will use metric components during the process. Where what I am interested in is just the Tensor expression with respective indices.
I was wondering if anyone had any thoughts on how I could resolve this.
I have attached the worksheet that I am working with. I look forward to your thoughts/comments.
ActionFieldEquations.mw
If we use, for example, pointplot3d with an mx3 matrix we get a 3d plot. I can click on the plot and choose the lighting. But how do we do that with code?
First 241 242 243 244 245 246 247 Last Page 243 of 2434
