Linear combinations of random variables: why Maple does not "inherit" the distributional assumptions when adding up two random variables?
In the script I attach below, I first define a vector of two uncorrelated gaussian RVs [epsilon[1],epsilon[2]] and then a vector of two correlated gaussian RVs [nu[1],nu[2]]. Both epsilon[1] and epsilon[2] are also uncorrelated with nu[1] and nu[2].
Now I want to create a vector of two correlated gaussian RVs, S, where S[1]=nu[1]+epsilon[1] and S[2]=nu[2]+epsilon[2]. The means and the variances of [S[1],S[2]] are correct, but the covariance (off-diagonal element of the covariance matrix) is weird. How to do this in Maple?
Please check this script:
RVs_sum.mw
If I have a pde with multiple constants (for example a and b) in them such that some are fixed constants (say k) and some terms are undetermined constants , how do I put that in a PDE such that Maple knows to solve the equation not for arbritary k (in case no solution exists), but any k such that k is not a function of the differentiating variable.
hey guys...please watch my file and help me. when i call(Am)...it only shows last value. how can i get all (Am) value in like seq or table
i := [seq(2*i-1, i = 1 .. 10)];
[1, 3, 5, 7, 9, 11, 13, 15, 17, 19]
for i in i do A[m] := (x/a)^(i+1)*(1-x/a)^2 end do;
x^2*(1-x/a)^2/a^2
x^4*(1-x/a)^2/a^4
x^6*(1-x/a)^2/a^6
x^8*(1-x/a)^2/a^8
x^10*(1-x/a)^2/a^10
x^12*(1-x/a)^2/a^12
x^14*(1-x/a)^2/a^14
x^16*(1-x/a)^2/a^16
x^18*(1-x/a)^2/a^18
x^20*(1-x/a)^2/a^20
Download 3.mw
i want to solve..this what is happening..i used maple not a long time ago.help me
restart; with(LinearAlgebra)
i := 1;
w := c[i]*(x/a)^(i+1)*(1-x/a)^2*(y/b)^(i+1)*(1-y/b)^2;
c[1]*x^2*(1-x/a)^2*y^2*(1-y/b)^2/(a^2*b^2)
(1/2)*(int(int([D__11*(diff(w, x, x))^2+2*D__12*(diff(w, x, x))*(diff(w, y, y))+4*D[66]*(diff(w, x, y))^2+D[22]*(diff(w, y, y))^2-2*q*w], x = 0 .. b), y = 0 .. a))
Error, (in int) wrong number (or type) of arguments: for an operator integrand a range without a variable of integration is expected, got x = 0 .. b
Download 2.mw
Given a list of equations say: eq1 := [diff(kk(r), r) = 0, ff(r)*1/2 = 0], how would i extract just the left hand side of each element ?
[diff(kk(r), r) , ff(r)*1/2 ]
Is there a way to compute the Riemann tensor for two different metrics in the physics package without each time setting up the metric. For example you just put the metric as an argument to do so in the differential geometry package.
I obtain the adjacency matrix from a graph. We know that it is indexed according to the order of vertices in the Vertices. But what if I want to rearrange it in a different order? Here is a specific example.
with(GraphTheory):
g:=Graph({{2,3},{1,2}});
Vertices(g); #[1,2,3]
AdjacencyMatrix(g);
I would like to display this matrix in the order of [3, 1, 2].
I get the following error: "Error, (in dsolve) invalid input: 'PDEtols/sdsolve' expects its 1st argument, SYS, to be of type OR(set(..."
I don't know what's wrong. My equations look like a set to me.
My equations:
{0 = -F__Ay - F__By, 0 = 25*F__Oy + 25*F__Ay - 25*F__By, diff(theta__1(t), t)*t - theta__1(t) = 0, -x__1(t) + 25*cos(theta__1(t)) = 0, -y__1(t) + 25*sin(theta__1(t)) = 0, (2500*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 - 50*cos(theta__1(t))*diff(theta__2(t), t)*theta__2(t) = F__Ax + F__Ox + F__Bx, (2500*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 - 50*cos(theta__1(t))*diff(theta__2(t), t)*theta__2(t) = F__Ay + F__Oy + F__By, diff(theta__2(t), t)*t - Pi/4 - theta__2(t) = 0, x__1(t) + 25*cos(theta__1(t)) - x__2(t) - 50*cos(theta__2(t)) = 0, y__1(t) + 25*sin(theta__1(t)) - y__2(t) - 50*sin(theta__2(t)) = 0, (1250*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 = -F__Ax - F__Bx, (1250*cos(theta__1(t))*diff(theta__1(t), t)*pi)/3 = -50*F__Ay + 50*F__By}
My solve:
dsolve({eqs[1] = 0, eqs[2] = 0, eqs[3] = 0, eqs[4] = 0, eqs[5] = 0, eqs[6] = 0, eqs_Mq[1] = eqs_g[3], eqs_Mq[1] = eqs_g[6], eqs_Mq[2] = eqs_g[1], eqs_Mq[2] = eqs_g[2], eqs_Mq[3] = eqs_g[4], eqs_Mq[3] = eqs_g[5]}, numeric)
Anyone can tell me what I'm doing wrong?
clutch.mw
I have say a
1) n cross n matrix A
2)  n cross 1 matrix B
I want to elementwise divide that is /~ each column of  by B and store in A itself like this
If b_1 is in B and a_11 is in A i want   b_1/~a_11 in a_11
That is i divide
B /~ A first column
B /~ A second column
Like that for all its n columns
Kind help please
To illustrate, here is an HTML example that overlays a circle and a letter
<span style="position: relative; font-size: 2em;">&#x25CB;<span style="position: absolute; top: 1.0em; right: 0.4em; font-size: 0.4em;">Y</span></span>
than can be pasted here to visualize.
I am not sure if that is possible with Maples typesetting tags.
Hello everyone!
I have an expression for the resonant frequency in terms of some geometric paremeter, say "x", i.e. f(x). I want to plot it together with the resonant wavelength (lambda=c/f) in the same plot. The "dualaxisplot" produces two curves (f(x), lambda(x)) with two uniform axes to the left and to the right. I am wondering is there a reasonably simple way to make it look as one curve, but with the second (e.g. lambda) axes nonuniformely scaled to fit the curve f(x)?
Many thanks in advance for your suggestions!
How do I combine a number of functions into a composite one?
For example
x := T -> (A - 1/T)/C;
y := x -> sqrt(1/27*B^3/C^3 + 1/4*x^2);
Combined into a final composite function
R := T -> exp((y - 1/2*x)^(1/3) - (y + 1/2*x)^(1/3)); such that the function R evaluates x and y as functions themselves.
Many times this sort of function definition makes it easier for the human.
Frac_C := proc (expr, a, t, alpha) local ig, m, tau;
m := ceil(alpha);
ig := (t-tau)^(m-alpha-1)*(diff(eval(expr, t = tau), tau$m));
`assuming`([(int(ig, tau = a .. t))/GAMMA(m-alpha)], [a < t]);
r := .5;
k := .7;
eq1 := Frac_C(x, 0, t, r)-y(t) = 0;
eq2 := Frac_C(y, 0, t, k)-x(t)-2*t = 0;
eq3 := x(0)-y(1) = 0;
eq4 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x), x = 1)) = 0;
eq5 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x, x), x = 1)) = 0;
eq6 := eval(diff(y(x), x), x = 0)-x(1)-2 = 0;
eq7 := y(0) = 0;
N := 5;
x[c] := [seq(a[i], i = 0 .. N)];
y[c] := [seq(b[i], i = 0 .. N)];
for n to N do
subs([seq(x(i) = x[c][i], i = 0 .. n), seq(y(i) = y[c][i], i = 0 .. n)], {eq1, eq2, eq3, eq4, eq5, eq6, eq7});
soln := solve({eq3, eq4, eq5, eq6, eq7, seq(coeff(lhs(eq), t, j) = 0, eq in {eq1, eq2})}, {a[n+1], b[n+1]});
x[c][n+1] := eval(a[n+1], soln);
y[c][n+1] := eval(b[n+1], soln);
x[s] := add(x[c][i]*t^(i-1), i = 1 .. N+1);
y[s] := add(y[c][i]*t^(i-1), i = 1 .. N+1);
x[s];
y[s];
Hi, i want to calculate fourier transform of functions with fractional powers. how can i do this? for example what is fourier transform of sqrt(x) ? I want a function or an expression as output, not the inetgral itself. thnx in advance
restart:with(inttrans):
f := x -> x^(1/2);
int(f(x)*exp(-I*w*x), x = -infinity .. infinity);
proc (x) options operator, arrow; x^(1/2) end proc
int(x^(1/2)*exp(-I*w*x), x = -infinity .. infinity)
fourier(f(x),x,w)
fourier(x^(1/2), x, w)
Download fracfourier.mw
How can I export data from the plot? Following is my Maple code.
with(PDEtools);
v_0 := 1;
vstar := 10;
r_0 := 1;
k := 0.1;
m := 0.1;
PDE := diff(v(r, t), t) = k*(diff(v(r, t), r, r) + diff(v(r, t), r)/r);
                                                / d         \
                           /  2         \   0.1 |--- v(r, t)|
          d                | d          |       \ dr        /
  PDE := --- v(r, t) = 0.1 |---- v(r, t)| + -----------------
          dt               |   2        |           r
                           \ dr         /
ans := pdsolve(PDE, HINT = f(r)*g(t));
ans := Typesetting:-mcomplete|vApplyFunction(rt)equalsf__1
                                              ||DifferentialD
  ApplyFunction(r) f__2ApplyFunction(t) where ||--------------
                                              ||DifferentialDt
  f__2ApplyFunction(t)equals0.1 f__2ApplyFunction(t) _c[1]
  DifferentialD
  --------------- f__1ApplyFunction(r)equals1. f__1ApplyFunction(
  DifferentialDr
                /DifferentialD                      \//
             1. |-------------- f__1ApplyFunction(r)|||
                \DifferentialDr                     /||
  r) _c[1] - ----------------------------------------||,
                                r                    ||
  Typesetting:-_Hold|[PDESolStruc|v(r, t) = f__1(r) f__2(t), [<
   d
  --- f__2(t) = 0.1 f__2(t) _c[1],
   dt
                                       / d         \\ ]\]\\
    2                               1. |--- f__1(r)|| ]|]||
   d                                   \ dr        /| ]|]||
  ---- f__1(r) = 1. f__1(r) _c[1] - ---------------- >]|]||
     2                                     r        | ]|]||
   dr                                               | ]|]||
build(ans);
                  /1         \             /           (1/2)  \
v(r, t) = c__3 exp|-- _c[1] t| c__1 BesselJ\0, (-_c[1])      r/
                  \10        /
             /1         \             /           (1/2)  \
   + c__3 exp|-- _c[1] t| c__2 BesselY\0, (-_c[1])      r/
             \10        /
design;
BC1 := eval(v(r, t) - v_0 = 0, r = 20);
                    BC1 := v(20, t) - 1 = 0
BC2 := D[1](v)(0, t) = 0;
NULL;
IC := v(r, 0) = v_0 + (vstar - v_0)*exp(-0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
                                    (1/2)    /            2\
   IC := v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /
conds := {BC1, BC2, IC};
    conds := { v(20, t) - 1 = 0,
                                 (1/2)    /            2\
      v(r, 0) = 1 + 25.38853126 2      exp\-50. (r - 1) /,
      D[1](v)(0, t) = 0 }
answer:=pdsolve(PDE,conds,HINT=);
Error, invalid =
Typesetting:-mambiguous(answerAssignpdsolveApplyFunction(PDEcomma
  condscommaTypesetting:-mambiguous(HINTequalslowast,
  Typesetting:-merror("invalid =")))semi)
u := r -> v_0 + (vstar - v_0)*exp((-1)*0.5*(r - r_0)^2/m^2)/(m*sqrt(2*Pi));
u := proc (r) options operator, arrow, function_assign;
   v_0+(vstar-v_0)*exp(-.5*(r-r_0)^2/m^2)/(m*sqrt(2*Pi)) end proc
plot(u(r), r = 0 .. 10);
                                 (1/2)    /            2\
      D[1](v)(0, t) = 0 }
BCs := {BC1, BC2};
          BCs := {v(20, t) - 1 = 0, D[1](v)(0, t) = 0}
pde_solve = pdsolve(PDE, BCs, IC);
solution := pdsolve(PDE, conds, numeric);
                  solution := _m1440390954528
t1 = 0 .. 10;
r1 = 0 .. 10;
solution, t1, r1;
                        solution, t1, r1
sol := pdsolve(PDE, conds, numeric, time = t, range = 0 .. 20, spacestep = 0.1, timestep = 0.1);
                     sol := _m1440421519392
sol:-animate(t = 0 .. 20, frames = 100);
M := sol:-value();
sol:-plot3d(r = 0 .. 10, t = 0 .. 20);
First 242 243 244 245 246 247 248 Last Page 244 of 2458
