After this code:
g1 := PermutationGroup({[[1, 2]], [[1, 2, 3], [4, 5]]})
g1:=<(1, 2), (1, 2, 3)(4, 5)>
I can get a string "<(1, 2), (1, 2, 3)(4, 5)>". Could I use the string to restore the PermutationGroup with an elegant method?
Here is a worksheet with a system of differential equations
Maple_DE_Example.mw
The system is
y'(x)=z(x)*g(x)
z'(x)=y(x)*g(x)
where g(x) is a random number generator seeded by x. That is, for the same x, g gives the same result.
Using the classical method as an option to dsolve, a solution is plotted. Using rkf45, however, there is pretty much always an error that says
Warning, cannot evaluate the solution further right of ...
Why does it work with classical but not rkf45?
Is there a command that will count the number of digits in a binary number or any number for that matter? For example: 10110  has 5  digits in binary representation.
I choose to define a number in base 10.
number := 22
22
Then I choose to convert that number into base 2.
number_binary := convert(number, binary)
10110
On visual inspection it is determined that number_binary has 5 digits in binary representation.
Is there a common command that can count the number of digits in a binary number? Such as, 10110 has 5 digits.
Download Count_digits_in_a_binary_number.mw
I am trying to reproduce this visualization of RGB:
Does any one have anything like this for Maple?
As you can see in the figure below,
it shows a very strange "font",
you can obviously see very weird spacing even inside one word...
Who knows what's wrong???
Thanks a lot.
B/R
Jankel
I approximate the root of a given polynomial using Newton method.
Whem I change the output option the number of iteration change as displayed,
Why changind only output from animation to plot, the number of iterations displayed with each figure is not the same.
NewtonQuestion.mw
thank you
How can we determine the highest (or peak) value for every hump and at what value of (x, t) in the plot?
peak.mw
Good day,
I am looking for some guidance with the Syrup toolbox
I have a netlist that was generated with the Altium designer Spice simulator (XSpice based), I was able to import it into LTSpice and verrify the results.
I want to move it into maple to make use of the modellica code generation.
I then began modifying the netlist in order to meet the netlist syntax of Syrup. One of the most prominant change I needed to make was the arbitrary input nodes for my Voltage dependant Voltage sources.
Therefore, for any line that implies arbitrary sources such as:
E_U8_E1 U8_N208620 LO
+ VALUE { IF(V(U8_N208706, 0) > 0.5, 5, -5) }
was changed to:
V1    16   17 1vdc
E_U8_E1 U8_N208620 LO 16 17
This, of course, is a non ideal workaround which brings me to question 1,
Is there a way to define a arbitrary source with the Spice parser in Syrup?
Once these changes were made, it seems the Solve function in Syrup can parse the netlist without issue, however when it gets to the Solve portion it throws the following error:
Solve("file://C:/Users/msavoy/Documents/Spice_cct/inverter_newfet_nonot.cir", 'tran');
Solve: Analyzing SPICE deck "The Apple" (ignoring this line)
Error, (in Syrup:-Solve) invalid input: rcopy uses a 1st argument, A (of type anything), which is missing
Attached is a copy of the netlist, inverter_newfet_nonot.txtI am honestly at a lost as to what could be throwing the rcopy error
Furthermore, I wanted to test out the Modellica code generation in Syurp, it appears that it does not like having subcircuits, as running the test:
V 1 0 1
L1 1 2 L
C1 2 0 C
L2 2 3 L
C2 3 0 C
L3 3 4 L
C3 4 0 C
Vshort 4 5 0
Rt 5 0 1
.SUBCKT TEST A B C Y
V1 14 15 1
EINT YINT 0 14 15
+ VALUE {IF(V(A) > 0.5 && V(B) > 0.5 && V(C) > 0.5, 1, 0)}
RINT YINT Y 1
CINT Y 0 1n
.ENDS TEST
.end
provides the error of:
test_c := ToModelica("file://C:/Users/msavoy/Documents/Spice_cct/test_cct_RCL.txt", 'probes' = ["Rt.v"], 'parameters' = {C = 2, L = 1});
Error, (in Syrup:-ToModelica) invalid input: nodeToModelica expects its 1st argument, node, to be of type nonnegint, but received Y
Is it possible to define a sub circuit in a netlist that is to be converted to Modellica, or do all subcircuits need to be defined in their own file?
Consider the function f:=x->sin(x)/x.
If we plot it we obtain
If we try to solve the equation f(x)=0 we get no result back from Maple.
Now consider the function g(x):=x->|sin(x)/x|
If we plot g we obtain
The weird thing here is that the graph isn't touching the x-axis. Why not?
I would like to create a table that contains my ouput : iteration, eigenvalues, eigenvectors,
My code work well, but unfortunatelly I can't display a table with the wanted output.
cccc.mw
How to draw 3D plot from given data as follows
x:=[0.1, 0.2, 0.3, 0.4, 0.5, 0.1, 0.2, 0.3, 0.4, 0.5,0.1, 0.2, 0.3, 0.4, 0.5,0.1, 0.2, 0.3, 0.4, 0.5,0.1, 0.2, 0.3, 0.4, 0.5]
y:=[0.1, 0.1, 0.1, 0.1, 0.1, 0.2, 0.2, 0.2, 0.2, 0.2, 0.3, 0.3, 0.3, 0.3, 0.3, 0.4, 0.4, 0.4, 0.4, 0.4,0.5,0.5,0.5,0.5,0.5]
z:=[1.971284960, 1.642401616, 1.372353338,1.153620572,0.9762759982,
    1.675502483, 1.411976881, 1.190627373,1.007730234,0.8570007139,
    1.397140245, 1.184230644, 1.003688984,0.852696223,0.7268039317,
    1.144791107, 0.9725020383,0.8257592921,0.7020549659,0.5979974836,        0.9208492326, 0.7816302394, 0.6627749172,0.5620029444,0.4766238930]
Like:
Product Name: Maple 17
I have to take my equations for velocity, acceleration, and height and evaluate them in 4 second intervals and combine them into one table or columns.
Deal all
I would like to approximate the largest eigenvalue of a given maxtrix and its corresponding eigenvector.
I have a problem in step 7, how obtain the index where the maximum is located, then How I return at the end of while loop
a table contains eigenvalues, eigenvectors and err
PWM.mw
The procedures "getCP" which uses "cpsub" (not exported) acts differently inside the package as opposed to them outside it.
In the package it returns a column matrix which is incorrect. Should return a 2 row matrix. They dismantle a polynomial into it's powers and coefficients. I know one cant run the package here. Included are the two procedures and the text of the notepad file to make the package.
with(AlgCalc)
[`&oplus;`, FundThrm, SignedArea, diag, diftab, faulD, faulS, getCP]
f := sort(2+x^7+5*x^2-7*x^a+k*x^2, [x], ascending)
2-7*x^a+5*x^2+k*x^2+x^7
getCP(f, x)
Matrix(%id = 36893490212391698668)
g := sort(5*x^8+k*x^2-7*x^3+x+2, [x], ascending)
2+x+k*x^2-7*x^3+5*x^8
CP := getCP(g, x)
Matrix(%id = 36893490212391688180)
with(AlgCalc)
getCP(f, x)
Matrix(%id = 36893490212390043884)
getCP(g, x)
Matrix(%id = 36893490212390032796)
Dismantlimg a polynomial  uses the following 2 procedures
" cpsub:= proc(t, var:=alpha)  description "used by getCP";       local i,cf,varpwr;                   if   not has(t, var)                  then return < 0,t>:               elif whattype(t)=`^` then return <op(t)[2],1>;                  else varpwr,cf:= selectremove(has,[op(t)],var);                       if op(varpwr)=var then                        return <1, `*`(op(cf))> ;                   end if;                     for i from 1 to nops(varpwr) do                    if numer(varpwr[i])=1  then if op((1)/(varpwr[i]))=alpha then varpwr[i]:=-1 else  varpwr[i] :=-op((1)/(varpwr[i]))[2] end if else  varpwr[i]:=op(varpwr[i])[2]end if                        end do;                   return <`+`(op(varpwr)),`*`(op(cf))>;                   #print(op(t));                                   end if ;            end proc:"
getCP := proc (f, var := alpha) local t; description "Dissmantles a polynomial into powers and coefficients"; if not has(f, var) then return `<,>`(0, f) elif whattype(f) = `^` then return `<,>`(op(f)[2], 1) elif whattype(f) = `*` then return `<|>`(`~`[cpsub]([f], var)[]) else `<|>`(`~`[cpsub]([op(f)], var)[]) end if end proc
cp := getCP(f, x)
Matrix(%id = 36893490212391322676)
whattype(cp)
Matrix
Notepad file to Create AlgCalc.
AlgCalc := module ()
export SignedArea,
           `&oplus;`,
             getCP,
             diag,
             diftab,
             faulD,
             faulS,
             FundThrm;
 option package;
$include "SignedArea.mm"
$include "`&oplus;`.mm"
$include "cpsub.mm"
$include "getCP.mm"
$include "diag.mm"
$include "diftab.mm"
$include "faulD.mm"
$include "faulS.mm"
$include "FundThrm.mm"
end module;
Download 6-11-22_Procedures_acting_differently_in_Package.mw
There is a document on the Maple website entitled "Writing Packages". It contains the following snippet when talking about libname
Note: Maple automatically adds lib subdirectories of directories in HOMEDIR/maple/toolbox as well as your current directory to the predefined variable libname. Therefore, modifying the .mapleinit or maple.ini file is only necessary if you want to designate a directory as the default location in which the savelib command will save your library files.
Is this snippet accurate?
If we create a directory called test and create a directory inside called lib and in it a repository called myRepo.mla, and in Maple the current working directory is test, will test/lib/myRepo.mla be found by libname?
It doesn't seem to be the case.
First 270 271 272 273 274 275 276 Last Page 272 of 2434
