using the Physics package version:
  The "Physics Updates" version in the MapleCloud is 899 and is the same as the version installed in this computer, created 2021, January 2, 19:51 hours Pacific Time.
I end up with:
Latex:-Settings(useimaginaryunit=i,
      usecolor = false,
      powersoftrigonometricfunctions= computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false
resluting in an error:
Error, module does not export `ModuleApply`
Maybe some changes in the interface in the latest version?
Hello there,
First of all, happy new year to you and those around you!
One question: would you teach me how to replace the 'Zs/Z_AB' expression in the last term of the expression 'eq_5_m5'?
In other words, I wanted to see the 'desired' expression, but the 'subs()' command repalced the first occurance of the 'Zs/Z_AB' expression.
(Perhaps, this applet behind of this edit box does not like the Microsoft Edge browser)
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Q20210103.mw .
Download Q20210103.mw
here is my try
for ploting points of data ( d(n(, sum(n))
new.mw
Hello. I have certain requirements for drawings. Please tell me, is it possible to implement them when plotting in Maple? Thanks.
Drawing width 15 cm
Be sure to frame and mesh. The thickness of the frame and serifs on the axes is 0.5 pt. Mesh thickness 0.25 pt. The length of the serifs is 1.2 mm.
The thickness of the graph itself is 1 pt
Axis names 10 pt
Is there a similar function as (cylinderplot) to plot convex or concave toroidal shell segments?
This type of shell is as follows.
Recently, I encountered warnings and errors when size of my list is big. Maple says use array instead of list because of ... . When the list is just a list of numbers or a list of lists of the same size, I can rewrite it as an array, but how about a list like the following?
[seq([[0,0],0],i=1..10)]
This is just an example. So the elements of this list are lists containing a vector (a point in the plane) and a number (a property of this point). One idea is to use two arrays, a two dimensional array for recording the vectors, and one 1-dimensional array for recording the numbers and keep in mind that the i-th number of the second array is related to the i-th vector (row) in the first array. But is there any possibility to have this data recorded similar to when we are using lists, i.e. similar to the above code?
How can I get the follow graph of paraboloidal surfaces (ξ=1,η=2) with the coordinate vectors ξ, η0 , φ0 as shown in the picture.
Realation between cartesian coordinates and paraboloidal :
x=1/2 (ξ2 - η2), y=ξ η cos(φ), z=ξ η sin(φ)
I wrote the following code:
Student:-VectorCalculus
S1 := PositionVector([1/2*(-eta^2 + 1), eta*cos(phi), eta*sin(phi)], cartesian[x, y, z]):
LH := PlotPositionVector(S1, eta = -2 .. 0, phi = 0 .. 2*Pi, coordcurve = [eta = -2, tangent = true, binormal = true, vectornum = 1], scaling = constrained)
S2 := PositionVector([1/2*(xi^2 - 4), 2*xi*cos(phi), 2*xi*sin(phi)], cartesian[x, y, z]):
LG := PlotPositionVector(S2, xi = -1 .. 1, phi = 0 .. 2*Pi, coordcurve = [xi = 1, tangent = true, vectornum = 1], scaling = constrained)
And I got the two paraboloidal surfaces with the vectors separently.How can I get only one graph with these two surfaces as shown in the picture (with ξ=1, η=2) ?
If I have a vector like u:=<-2+m,3+m> and then I put m:=5 (for exemple) when I repeat u it doesnot replace the value of m by 5,
instead repeats the initial expression. I would like to find a way to achieve this in order to automate calculations.
This website suggests that the viewer write equations containing differentials and use them to plot topographical lines.
https://mathcurve.com/courbes3d.gb/topographic/topographic.shtml
I am basically familiar with equations containing derivatives, but not with equations containing differentials.
How can one employ these to draw the lines shown in the website's various plots of surfaces?
S := proc (n) local i; for i to n do if i <= n and type(i, divisors(n)) and type(n/i, odd) then sum(i) end if end do end proc
I solved a simple PDE numerically and found that I couldn't implement a simple thing!
For example:
PDE := diff(u(x,t),t)=1/10*diff(u(x,t),x,x);
IBC := {u(x,0)=1, u(0,t)=0, D[1](u)(1,t)=0};
pds := pdsolve(PDE,IBC,numeric);
p1 := pds:-plot(t=0): p2 := pds:-plot(t=1/10):p3 := pds:-plot(t=1/2):p4 := pds:-plot(t=1):
plots[display]({p1,p2,p3,p4});
I got some spatial dependencies for different fixed t. But I want to get opposite! How to get time dependence for fixed x?
Replacing t with x results in an error.
Update.
This equation is example, really I solve this:
PDE := diff(u(x,t),t)+v*(1+k*sin(2*Pi*f*t))*diff(u(x,t),x)=a*diff(u(x,t),x,x);
IBC := {u(x,0)=T__0,u(0,t)=sin(2*Pi*f*t),u(L,t)=T__0};
So sin makes this equation nonlinear, so I need numerical procedure.
I have the following function:
f:=t->862.979774+1825.011621/([1+1.54943476*e^(-677.0138344*t)]^(131537/203808))
Is there any way Maple can calculate the indefinite integral of f(t)? I have tried integrating f(t) in a range t=tmin..tmax numerically using dsolve/numeric and plotting the numeric integral and I am satisfied with the result, but I would much prefer an analytic integration so that I obtain some function y(t) that I can later use which will be the indefinite integral of f(t).
So far, I have tried unsuccessfully to obtain an indefinite integral of f(t) using int and dsolve. Thanks in advance.
when trying to solve equation using fsolve, it returns just what i wrote and didn't solve. Can anyone help? I tried all i know. File is attached below.
Thanks a lot.
II.01.mw
f:=(x,y)-> x*y^3-x^2/y^3;
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y));
lis:=[]:
for tmp in op(eq) do
    if has(tmp,alpha) then
       lis:=[op(lis),op(2,simplify(select(has,tmp,alpha)))];
    fi;
od;
lis;
PDEtools:-Solve(lis[1]=lis[2],p)
This method happend to work for this example, but it does not work in general. This is because the function can be anything. Here is a second example
f:=(x,y)-> -2/3*x+1/3*(x^2+3*y)^(1/2);
We see by inspection if p=2 then we can write the above as, by setting p=2 as
But the Maple code I had above does not work on this
lis:=[]:
       lis:=[op(lis),simplify(select(has,tmp,alpha))];
    fi;
od;
lis;
The problem is finding all powers of alpha in each term and setting up an equation to find p such that all terms have same numerical value.
So I abandoned this method as too messy to program (it works well for hand solution, this is an example where solving something by hand is easier than on the computer) and then tried solve directly, like this (on the first example)
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y))- alpha^r*f(x,y)=0;
And here is where I am stuck. I need to ask Maple if it can find alpha, r that are rational numbers, such that the above equation is solved.
PDEtools:-Solve(eq,[p,r])
But we know from above that p=1/6 and r=3/2 is solution
simplify(subs([p=1/6,r=3/2],eq))
             0=0
The question is: Can Maple solve such an equation for  p,r? I remember now reading something about parameteric solver in Maple. I need to look that up to see if it helps. I tried SolveTools:-SemiAlgebraic on this, but it did not help.
Are there better methods to determine in Maple if function is isobaric and to find the index p and r?
Reference: book
Notice, some places define isobaric function as one in which we can find p such that
But this is not correct. I've seen it on 2 pages on the net. The correct definition is
Also note: When p=1 isobaric function becomes a homogeneous function which is special case of isobaric and r is now called the degree of homogeneity
But for isobaric, p do not have to be 1. This is the main difference.
f(x,y) will always be a function of x,y.  I will add more examples of isobaric functions to test against.
edit. Simplified question is restated below
After looking more into this. I found I actually wanted to solve the simpler problem, which is
So please ignore the general case of isobaric where r<>p-1 which is harder.
I only need to look at this case where r=p-1 which is actually simpler. It turned out this is what I need for my solver and not the general case.
I will now give my solution to this and show where the problem I am having.
I am using Maple solve to find p. So no r any more. Only solving for one variable. But Maple solve fails sometimes. And this is the problem.
The problem is that solve can find p for many cases, but fails on some, where there is clearly a solution. I will show 5 examples below.
#example 1. WORKS
f:=(x,y)-> 3*sqrt(x*y);
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y))- alpha^(p-1)*f(x,y)=0;
PDEtools:-Solve(eq,p) assuming alpha>0;
#example 2. WORKS
f:=(x,y)-> 4*(x*y)^(1/3);
#example 3. WORKS
f:=(x,y)-> (-3*x^2*y-y^2)/(2*x^3+3*x*y);
#example 4 WORKS
f:=(x,y)-> (-(x*y)/2+sqrt(x^2*y^2-4*y)/2)*y;
And here is the one that does not work
#Example 5. Does not work. How to make it work?
f:=(x,y)-> -2*x/3+sqrt(x^2+3*y)/3;
There is a solution for this. p=2 works. Why solve did not find it? I mean, it gives RootOf, which does not help me decide if this is isobaric or not. Why it did not find the solution p=2?
simplify(subs(p=2,eq)) assuming alpha>0
                 0=0
Using Mathemtica, it found p=2 solution. How to make Maple find this solution is my question.
Sorry for the long question. I first thought I needed the general isobaric case, but found later i needed the simpler one.
First 455 456 457 458 459 460 461 Last Page 457 of 2427
