Plot the wedge cut from the cylinder x²+y²=1 by the planes z=-y and z=0.
Plot the solid that lies between the cylinder z= y^2 and the xy -plane that is bounded by the planes x = 0, x =1, y = −1, y =1.
I want to solve a simple newsvendor problem for general Demand Probability Distribution with maple code.
let,
Underage cost
                              c[u]
Overage cost
                              c[o]
Demand (
D;
) follows pdf
f(.);
 and CDF
F;
Decision varible is quantity
q;
So cost function is
TC := piecewise(q-D >= 0, c[o]*(q-D), q-D < 0, c[u]*(-q+D));
 piecewise(0 <= q - D, c[o] (q - D), q - D < 0, c[u] (-q + D))
After taking expectation of TC and derivating it w.r.t q we will get
q;
* as critical fractile i.e.
q*= F^(-1) (
                             c[u]
                          c[u] + c[o]
)      i.e. F inverse (
c[u]/(c[u]+c[o]);
Can someone please help me how to find q* in MAPLE using solve() or any other function?
Thanks in Advance!
This might be something basic. But looking at help I do not see it now.
why has(expr,sqrt) do not give true?  is something special about sqrt function?
mysol :=sin(x);
has(mysol,sin); #works
mysol :=ln(x);
has(mysol,ln);  #works
mysol :=sqrt(x);
has(mysol,sqrt);  #does not work
hasfun(mysol,sqrt);  #does not work
Just wondering why, that is all. Only this worked
hastype(mysol,sqrt)
I am sure there is a good reason for this. sqrt seems to be special function.
Maple 2020.2
I'm trying to solve the following ode system:
odes := diff(a0(t), t) - diff(a1(t), t) + diff(a2(t), t) = 0, diff(a0(t), t) - diff(a2(t), t) - 16*a2(t) = 0, diff(b0(t), t) + diff(b1(t), t) + diff(b2(t), t) = 0, diff(b0(t), t) - diff(b2(t), t) - 48*b2(t) = 0, diff(a1(t), t) + 4*diff(a2(t), t) - 3*diff(b1(t), t) + 12*diff(b2(t), t) = 0, diff(a0(t), t) + diff(a1(t), t) + diff(a2(t), t) - diff(b0(t), t) + diff(b1(t), t) - diff(b2(t), t) = 0;
ics := a0(0) - a2(0) = 0, b0(0) - b2(0) = 1, a0(0) - a1(0) + a2(0) = 0, b0(0) + b1(0) + b2(0) = 1, a1(0) + 4*a2(0) - 3*b1(0) + 12*b2(0) = 0, a0(0) + a1(0) + a2(0) - b0(0) + b1(0) - b2(0) = 0;
dsdef := dsolve({ics, odes}, numeric);
There are 6 ordinary differential equations with 6 initial conditions. The functions are named a0(t), a1(t), a2(t), b0(t), b1(t), b2(t).
The question is that Maple solve the system analliticaly (exact dsolve) but when I run the "numerical dsolve" it returns: "Error, (in DEtools/convertsys) invalid specification of initial conditions", and I can't recognize the error/s.
How to show that the function z0(t)=t²+exp(-t)  is solution of z"(t)+2z'(t)+z(t)=2exp(-t); Thank you.
I tried to draw a normal boxplot for the a simple data using Maple. My attempt is in below.
X := [13, 15, 16, 16, 19, 20, 21, 21, 22, 22, 25, 25, 25, 25, 30, 33, 33, 35, 35, 35, 35, 36, 40, 45, 46, 52, 70]:
P1 := Statistics[BoxPlot](X, offset = 1, distance = 1, width = 1, orientation = horizontal, outliers = true);
plots[display](P1, view = [1 .. 80, 0.5 .. 2.5]);
But I am not happy from the result.
  1. It seems the box-plot range doesn't include the max, 70, instead it puts a circle there!
      2. What are the small rectangles and circles? I just need a simple box-plot with the line-range starting from min and ending at max, then a box starting from the first quartile and ending at the third quartile and a vertical line at the median. No extra feature and not ignoring any data.
      3. I don't want the vertical axis which is for the index of the data, I just have one data and that vertical axis is just distracting the audience.
How to resolve these three issues?
all in real domain, sqrt(A)*sqrt(B) can be combined to sqrt(A*B) when both A,B are non-negative.
Is there a way in Maple to  find the conditions when sqrt(A)*sqrt(B)=sqrt(A*B) ? i.e. the conditions on A,B where this is true?
A,B will only be functions of x,y.
An example will make things clear.
expr1:=sqrt(x^2*y - 4)*sqrt(x^2*y);
expr2:=sqrt(  (x^2*y - 4)*(x^2*y));
By looking at the above, we see that expr1 = expr2 when  x^2*y-4>=0 and x>0 or x^2*y-4>=0 and x<0. Actually I think only x^2*y-4>=0 is needed, since x is being squared anyway.
How to make Maple show this? I can't get Maple to show this
solve(expr1=expr2,[x,y]) assuming real;
But this is wrong. it says it is true for all x and all y?.   Mathematica can do it using Reduce command
I know I can force the combination by using the command
combine(expr1,sqrt,symbolic);
ps. Maple took the x outside the sqrt. So x>0 is assumed here.
pps. I do not understand why simplify(expr1,symbolic) did not work here, and neither  simplify(expr1,symbolic,size=false) worked. Only combine worked.
But I wanted to see if Maple could tell the condition when this is allowed, so I can write these down.
It would be nice if the command above would also tell the conditions under which it combined the sqrts. But this information is not given.
This is all done non-interactive in a program without being able to look at the screen and decide what to do. Only thing I know is that if an expression has sqrts and functions of x,y.
Is there a way in Maple to have tell conditions when expr1=expr2?
Maple 2020.2
 I installed maple calculator on iphone. I have problem with function x=y^2.
the arms of the chart should point to the right, not up
Other calculators like Graph Calculator showing in proper way generated chart/plot. But on maple I have problem - what I’m doing wrong.. I spent a lot of time to find answer but without success.
The result below surprises me.
Why does  rgf_findrecur return a result instead of saying that there is no homogeneous linear recurrence of order 1?
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
genfunc:-rgf_findrecur(1, [1, 2, 3, 4], t, n);
                       t(n) = 2 t(n - 1)
PS: maybe this was a problem in Maple 2015, if it has been corrected since just let me know
By using equation x^2+y^2=4 for cylinder and plane z=0 and the plane z=3-x, plot the solid.
I would like to split the expression 1 / (x²+i)² into partial fractions, but Maple (2020) doesn't seem to know:
convert(1/(z^2+I)^2, parfrac, z);
How do i fix this?
I wanna shade/fill different areas in a single graph and provide a legend for the graph. Areas are defined as follows where 0<=x<=1 and 0<=z<=1.
(label = c1) \quad if 0<x<1/13*(5-2sqrt(3)),0<z<1/2(2x+x^2)+1/2sqrt(4x^3+x^4)
(label = c2) \quad if 0<x<1/13*(5-2sqrt(3)),1/2(2x+x^2)+1/2sqrt(4x^3+x^4)<z<2x
I am trying solve on the outout of odetest, in order to determine range of which x makes this output zero.
It works sometimes and  does not work another times. I mean, it gives correct domain something, and other times, it overlooks some domain.
Here is an example
ode:=x*diff(y(x),x)*y(x) = (y(x)^2-9)^(1/2):
ic:=y(exp(4)) = 5:
sol:=dsolve([ode,ic],y(x)):
res:=odetest(sol,ode);
solve(simplify(res),x,allsolutions = true) assuming real;
It is true than when x=1, then is zero.  But so all values x>1 as well.
How to get solve to find those values as well and not just x=1?
I tried PDEtools:-Solve as well. It did not better
PDEtools:-Solve(simplify(res),x,allsolutions = true) assuming real;
Compare to Mathematica
Are there other commands in Maple which could obtain all the solutions like in the above?
Maple 2020.2 on windows 10
My problem is a hickup in the Maple 2020 version as compared to earlier versions :
In the Maple 2020 listtorec from package gfun asks for unknown value u(0) in recognition of series.
Example from the Maple help page:
with(gfun);
l := [1, 1, 2, 5, 14, 42, 132, 429, 1430, 4862, 16796, 58786];
rec := listtorec(l, u(n));
Error, (in gfun:-listtorec) invalid unknown function, u(0)
This error also happens with the second example in the Maple help page:
rec2 := seriestorec(series(add(l[i]*x^(i - 1)*(i - 1)!, i = 1 .. nops(l)), x, 12), u(n), ['egf']);
Error, (in gfun:-seriestorec) invalid unknown function, u(0)
How to feed this unknown value in the  call?
First 456 457 458 459 460 461 462 Last Page 458 of 2427
