with(PDEtools):
with(plot):
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received plot
A1:=Matrix([[phi,(chi),conjugate(phi),conjugate(chi)],
          [chi,(phi),conjugate(chi),conjugate(phi)],
          [lambda*phi,-(lambda)*(chi),
           conjugate(lambda)*conjugate(phi),-conjugate(lambda)*conjugate(chi)],
          [lambda*chi,-(lambda)*(phi),
           conjugate(lambda)*conjugate(chi),-conjugate(lambda)*conjugate(phi)]]);
A1 := Matrix(4, 4, {(1, 1) = phi, (1, 2) = chi, (1, 3) = conjugate(phi), (1, 4) = conjugate(chi), (2, 1) = chi, (2, 2) = phi, (2, 3) = conjugate(chi), (2, 4) = conjugate(phi), (3, 1) = lambda*phi, (3, 2) = -lambda*chi, (3, 3) = conjugate(lambda)*conjugate(phi), (3, 4) = -conjugate(lambda)*conjugate(chi), (4, 1) = lambda*chi, (4, 2) = -lambda*phi, (4, 3) = conjugate(lambda)*conjugate(chi), (4, 4) = -conjugate(lambda)*conjugate(phi)})
d1 := LinearAlgebra:-Determinant(A1):
d1; length(%);
conjugate(lambda)^2*conjugate(phi)^2*chi^2-conjugate(lambda)^2*conjugate(phi)^2*phi^2-conjugate(lambda)^2*conjugate(chi)^2*chi^2+conjugate(lambda)^2*conjugate(chi)^2*phi^2+2*conjugate(lambda)*conjugate(phi)^2*chi^2*lambda+2*conjugate(lambda)*conjugate(phi)^2*lambda*phi^2-8*conjugate(lambda)*conjugate(phi)*conjugate(chi)*chi*lambda*phi+2*conjugate(lambda)*conjugate(chi)^2*chi^2*lambda+2*conjugate(lambda)*conjugate(chi)^2*lambda*phi^2+conjugate(phi)^2*chi^2*lambda^2-conjugate(phi)^2*lambda^2*phi^2-conjugate(chi)^2*chi^2*lambda^2+conjugate(chi)^2*lambda^2*phi^2
705
den:=simplify(d1,size); length(%);
-(-(conjugate(chi)-conjugate(phi))*(chi+phi)*conjugate(lambda)+lambda*(conjugate(chi)+conjugate(phi))*(chi-phi))*(-(conjugate(chi)+conjugate(phi))*(chi-phi)*conjugate(lambda)+lambda*(conjugate(chi)-conjugate(phi))*(chi+phi))
333
con1:=phi=exp(I*lambda*(x-t/(4*lambda^2)-w^2)):con2:=chi=exp(-I*lambda*(x-t/(4*lambda^2)-w^2)):
den1:=simplify(dsubs({con1,con2},den));
4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*conjugate(lambda)*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda+8*conjugate(lambda)*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda^2-4*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda^2-16*conjugate(lambda)*lambda
plot3d(subs(Re(lambda)=1, Im(lambda)=.2, w=1, rhs(den1)),x=-6..6, t=-6..6)
Warning, inserted missing semicolon at end of statement
Error, invalid input: rhs received 4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*conjugate(lambda)*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda+8*conjugate(lambda)*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*...
Download 23May(1).mw
Seems to make no difference with or without RETURN() for the procedure ?
vraag_op_forum_gesteld_over_boek_vb_binomium.mw
For to know what each graph is standing for in the plot legenda
Could not yet get it  in y , y' , y '' , to 5th derative
Better is perhaps to have vertical table with the names and function expression together , but that could be difficult betounes_ex_set_task_4def.mw
f := x -> exp(-x)*sin(x); intvx:= 0..3;
f := proc (x) options operator, arrow; exp(-x)*sin(x) end proc
intvx := 0 .. 3
And this one below ( i prefer this one ) , but got in worksheet now the one above
Probably a option issue ?
2 determinants equal, solve for the unknowns in one determinant/Linear Algebra
Hi guys, thank you for reading my question.
A is one determinant "Matrix(2, 3, [[1, 2, 3], [3, 1, 2]])".B is" Matrix(2, 3, [[1, x, 3], [y, 1, z]])"
I wrote 2 matrice in the maple
As I try to solve the unknowns,I wrote:
A:= B, solve(x, y, z) It doesn't work
I switch another phrase,
A = B;solve(B:x,y,z)    It doesn't work as well
Could you help me with it ?
Dear All.
Please kindly help to correct the attached code on discretization of fourth order PDE using method of line.
Thank you and kind regards.
Discretization of parabolic equation with method of line
diff(u(x, t), t) = -2*(diff(diff(u(x, t), x), x))-(diff(diff(diff(diff(u(x, t), x), x), x), x))-u(x, t)*(diff(u(x, t), x))
u(x, t)
u(x, t)
u(x, 0) = 0.3e-1*sin(x)
8
Convert the BC to finite difference
(1/2)*(u[m+1](t)-u[m-1](t))/h
(u[m-1](t)-2*u[m](t)+u[m+1](t))/h^2
(u[m-2](t)-4*u[m-1](t)+6*u[m](t)-4*u[m+1](t)+u[m+2](t))/h^4
Convert the governing equation to finite difference form
Error, invalid input: diff received 2*h, which is not valid for its 2nd argument
Error, invalid input: LinearAlgebra:-GenerateMatrix expects its 1st argument, eqns, to be of type ({list, set})({`=`, algebraic}), but received eqs
A
Download Discretization_of_PDE_Order_4.mw
ii := 50;
seq(ii, ii = 0 .. 5);
evalf(int(ii, ii = 0 .. 5))
For sequence the syntax is correct i.e the output is 0,1,2,3,4,5. is ii inside sequence command takes the value 5 assigned it then changes when ii ranges from 0 to 5?
ii:=50:
seq(ii)
output: 50
ii:=50:
seq(seq(ii),ii=1..5)
expected answer: 50,50,50,50,50
obtained: 1,2,3,4,5
please explain how seq command works
Trebuchet, Phase I, 2020-05-27 Ki restart; with(RealDomain); with(SolveTools); assume(h < r1); additionally(h < r2); [Im, Re, ^, arccos, arccosh, arccot, arccoth, arccsc, arccsch, arcsec, arcsech, arcsin, arcsinh, arctan, arctanh, cos, cosh, cot, coth, csc, csch, eval, exp, expand, limit, ln, log, sec, sech, signum, simplify, sin, sinh, solve, sqrt, surd, tan, tanh ] [AbstractRootOfSolution, Basis, CancelInverses, Combine, Complexity, Engine, GreaterComplexity, Identity, Inequality, Linear, Parametric, Polynomial, PolynomialSystem, RationalCoefficients, SemiAlgebraic, SortByComplexity] hz1 := g*(r3*m3*cos(phi1(t))-r1*m2*sin(phi2(t))/sin(phi2(t)-phi1(t)))/theta3; whattype(phi1(t)); whattype(phi2(t)); / r1 m2 sin(phi2(t)) \ g |r3 m3 cos(phi1(t)) + -----------------------| \ sin(-phi2(t) + phi1(t))/ hz1 := ------------------------------------------------ theta3 function function hz2 := phi1(t)+arcsin((h+r1*sin(phi1(t)))/r2); /h + r1 sin(phi1(t))\ hz2 := phi1(t) + arcsin|-------------------| \ r2 / subs(phi2 = hz2, hz1); / / | | 1 | | ------ |g |r3 m3 cos(phi1(t)) theta3 | | | | \ \ // /h + r1 sin(phi1(t))\\ \ \\ r1 m2 sin||phi1(t) + arcsin|-------------------||(t)| || \\ \ r2 // / || + ----------------------------------------------------------|| / / /h + r1 sin(phi1(t))\\ \|| sin|-|phi1(t) + arcsin|-------------------||(t) + phi1(t)||| \ \ \ r2 // /// deq := diff(phi1(t), t, t)-% = 0; / / / 2 \ | | | d | 1 | | deq := |---- phi1(t)| - ------ |g |r3 m3 cos(phi1(t)) | 2 | theta3 | | \ dt / | | \ \ / /h + r1 sin(phi1(t))\ \ \ r1 m2 sin|phi1(t)(t) + arcsin|-------------------|(t)| | \ \ r2 / / | + -----------------------------------------------------------| / /h + r1 sin(phi1(t))\ \| sin|-phi1(t)(t) - arcsin|-------------------|(t) + phi1(t)|| \ \ r2 / // \ | | | = 0 | | / ics := phi1(0) = -arcsin(h/r1), (D(phi1))(0) = 0; /h \ ics := phi1(0) = -arcsin|--|, D(phi1)(0) = 0 \r1/ dsolve({deq, ics}, phi1(t)); dsolve(deq); deq_numeric := subs(r1 = 8, r2 = 8, r3 = 1, h = 5, m2 = 1, m3 = 20, theta3 = 20, deq); / | / d / d \\ 1 | |--- |--- phi1(t)|| - -- g |20 cos(phi1(t)) \ dt \ dt // 20 | | \ / /5 \ \ \ 8 sin|phi1(t)(t) + arcsin|- + sin(phi1(t))|(t)| | \ \8 / / | + --------------------------------------------------------| = 0 / /5 \ \| sin|-phi1(t)(t) - arcsin|- + sin(phi1(t))|(t) + phi1(t)|| \ \8 / // ics_numeric := phi1(0) = 0, (D(phi1))(0) = -.63; ics_numeric := phi1(0) = 0, D(phi1)(0) = -0.63 hz1 := dsolve({ics, deq_numeric}, phi1(t), numeric); Error, (in dsolve/numeric/process_input) unknown arcsin(5/8+sin(phi1(t))) present in ODE system is not a specified dependent variable or evaluatable procedure sin(-phi1(t)-arcsin((h+r1*sin(phi1(t)))/r2)); / /h + r1 sin(phi1(t))\\ -sin|phi1(t) + arcsin|-------------------|| \ \ r2 //
How to convert expression below to LaTex:  $\lim _{x \rightarrow 2} \frac{2}{x+3}$
And How to convert expression below to LaTex:  $\int_{2}^{3} \frac{1}{x^{2}+2} d x$
file test: newLaTex.mw
ode3 := diff(P(t), t) = 0.2*P(t) - 300;
                        d
ICs := [[0, 1300], [0, 1800]];
DEplot(ode3, p(t), p = -50 .. 2000, t = 0 .. 2000, ICs, arrows = LINE, color = RED, linecolor = BLUE, title = "Solution Curves ode3");
Error, (in DEtools/DEplot) invalid variable in specification of independent variable range
I want to plot y=sec(x) and x=-pi/4, x= pi/4. I also want the bounded region shaded. I have been able to graph sec(x) but I can't figure out how to get the two vertical lines and the bounded region shaded.
Hi there!
Essentially, sum(sqrt(-2),x=2..1) is, as it should be, 0. My issue is, that e.g. sum(sqrt(-2),x=2..0) or sum(sqrt(-2),x=2..-1)  are declared by Maple as -I*sqrt(2) and -(2*I)*sqrt(2), which, to my knowledge, is not true, and should be 0 as well. I need those results for a rather complicated algorithm to be 0, otherwise it doesn't work.
NEUZMinus:= proc(Unten, Oben, f,G,Liste,n)::real;
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; g:= zu integrierende Funktion;
  #G:= Gewicht; n:= Hinzuzufügende Knoten;
  Basenwechsel:=proc(Dividend, m);
  print(Anfang,Dividend,p[m]);
  Koeffizient:=quo(Dividend, p[m],x);
  Rest:=rem(Dividend, p[m],x);
  if m=0 then
    Basenwechsel:=[Koeffizient];
    Basenwechsel:=[Koeffizient,op(Basenwechsel(Rest,m-1))];
p[-1]:=0;
p[0]:=1;
for i from 1 to max(n,numelems(Liste)) do
  p[i]:=x^i-add(int(x^i*p[j]*diff(G,x),x=Unten..Oben)*p[j]/int(p[j]^2*diff(G,x),x=Unten..Oben),j=0..i-1);
  print(p[i]);
c[i-1]:=lcoeff(p[i],x)/lcoeff(p[i-1],x);
d[i-1]:=coeff(p[i],x,(i-1))/coeff(p[i-1],x,(i-1));
if i <> 1 then
  e[i-1]:=coeff(p[i]-(c[i-1]*x+d[i-1])*p[i-1],x,i-2)/coeff(p[i-2],x,i-2);
  e[i-1]:=1;
print(Liste[1],numelems(Liste));
Hn:=mul(x-Liste[i],i=1..numelems(Liste));
print(Hn);
 Koeffizienten:=Basenwechsel(Hn,numelems(Liste));
print(Koeffizienten);
for j from 0 to numelems(Liste)-1 do
  a[s][j][j]:=1;
for s from 1 to numelems(Liste)-1 do
  a[s][0]:=[1];
  a[s][1]:=[-e[s]*c[0]/c[s],d[0]-d[s]*c[0]/c[s],c[0]/c[s]];
  for j from 2 to numelems(Liste)-1 do
    print(1);
    a[s][j][abs(s-j)]:=sum(-c[j-1]*e[i+1]*a[s][j-1][i+1]/c[i+1],i=abs(s-j)..min(abs(s-j),s+j-2));
    print(2);
    a[s][j][abs(s-j)+1]:=sum(d[j-1]-c[j-1]*d[i]/c[i])*a[s][j-1][i],i=abs(s-j)+1..min(abs(s-j)+1,s+j-1)+sum(-c[j-1]*e[i+1]*a[s][j-1][i+1]/c[i+1],         i=abs(s-j)+1..min(abs(s-j)+1,s+j-2));
    print(3);
    for i from abs(s-j)+2 to s+j-2 do
      a[s][j][i]:=c[j-1]*a[s][j-1][i-1]/c[i-1]+(d[j-1]-c[j-1]*d[i]/c[i])*a[s][j-1][i]-c[j-1]*e[i+1]*a[s][j-1][i+1]/c[i+1]+e[j-1]*a[s][j-2][i];
      print(4);
    a[s][j][s+j-1]:=sum(c[j-1]*a[s][j-1][i-1]/c[i-1],i=max(s-j+2,s+j-1)..s+j-1)+sum((d[j-1]-c[j-1]*d[i]/c[i])*a[s][j-1][i],i=max(s-j+1,s+j-1));
    print(5);
    a[s][j][s+j]:=sum(c[j-1]*a[s][j-1][i-1]/c[i-1],i=max(s-j+2,s+j)..s+j);
    print(6);
end do
end proc
In the case of
for example, the
i=abs(s-j)+1..min(abs(s-j)+1,s+j-2) clause in the end checks, wether the term should be added or not. I basically just need a way to tell Maple wether to add a term or not, depending on wether abs(s-j)+1 is not greater than s+j-2 in this case, without using if-clauses if possible. The problem here is, that min(abs(s-j)+1,s+j-2) can become 0, Maple then tries to calculate something instead of returning 0, and then complains when something inside the term is not properly defined (c[j-1] can become c[-1] for example when j=0) and aborts the entire procedure. How can I tell it to just assign 0?
I'm having problems with Multiplying Complex Numbers in Maple 2019.
Thanks in Advance.
Example 2: Multiplying Complex Numbers
(2-i)(4+3*i)
(3+2*i)(3-2*i)
4*i(-1+5*i)
(3+2*i)^2
2-i(4+3*i)
3+2*i(3-2*i)
4*i(-1+5*i)
(3+2*i)^2
(1.1)
Download Multiplying_Complex_num.mw
How I can plot the answers obtained from solving two differential equations?
SAL.mw
e := 0.62e-2
0.62e-2
r := 0.15e-1
0.15e-1
DDo2 := .17*3600
612.00
DDco2 := .12*3600
432.00
N := 20
20
P1o2 := 3600*(1000*(27*10^(-13)*24.45)*100)/(10000*0.986923267e-2)
0.2408029155e-3
P1co2 := 3600*(1000*(99*10^(-13)*24.45)*100)/(10000*0.986923267e-2)
0.8829440235e-3
P2o2 := Pi*r^2*DDo2*N/(e+r)
408.1106684
P2co2 := Pi*r^2*DDco2*N/(e+r)
288.0781188
diff(y[o2](t), t) = ((P1o2+P2o2)*(21-y[o2](t))-100*(167*y[o2](t)/(1.6+y[o2](t))*.25))*(1/1300)
diff(y[o2](t), t) = 6.592560841-.3139314686*y[o2](t)-3.211538462*y[o2](t)/(1.6+y[o2](t))
diff(y[co2](t), t) = ((P1co2+P2co2)*(0.4e-1-y*y[co2](t))+.25*(.8*(167*y*y[co2](t)/(1.6+y*y[co2](t))))*100)*(1/1300)
diff(y[co2](t), t) = 0.8863969285e-2-.2215992321*y*y[co2](t)+2.569230769*y*y[co2](t)/(1.6+y*y[co2](t))
                 initial*conditional     @t=0     yO2=21 , yco2=0.04
Download SAL.mw
I am writing a question in Mobius that requires students to enter the union and infinity symbols. I am using a Maple graded answer, and I am able to get it to grade infinity properly by typing the word "infinity" in the answer and using Maple syntax with symbolic entry, so that they have access to the infinity symbol in the equation editor. There is a union symbol in the equation editor, but I am not sure how to code the answer to make it accept the union symbol as correct.
First 549 550 551 552 553 554 555 Last Page 551 of 2428
