Maple 2017.3 has these problems which hamper my work with it. I shown three examples.
Example 1: Maple cannot recognize automatically that two complex numbers are equal:
[>eq1:=9*exp((1/9)*(5*I)*Pi)-9*exp((1/9)*(2*I)*Pi) = -8*exp((1/9)*(2*I)*Pi)+7*exp((1/9)*(5*I)*Pi)+exp((1/18)*(13*I)*Pi)*sqrt(3);
Here, lhs(eq1) and rhs(eq1) are in fact equal. Yes, evela(simplify(lhs(eq1)-rhs(eq1)) reduces to zero but not when solving equations (see Example 2).
Example 2:
[>sys1:=[_xx[1]+lhs(eq1),_xx[1]+rhs(eq1)];
[>solve(sys1,[_xx[1],_xx[2]]);
yields no answer.
Example 3:
[>alias(omega=RootOf(_Z^2+_Z+1));
[>rt:=(-1+I*sqrt(3))/2;
Maple fails to substitute the alias and recognize that rt=omega.
Any suggestion on a work-around problems 2 and 3 would be helpful.
Rafal Ablamowicz
www.math.tntech.edu/rafal/
I have load the new Physics-Version 678, but it is not active. How can I do this?
Here the output:
                           version()
 User Interface: 1455132
         Kernel: 1455132
        Library: 1455132
       MapleIDE: 928330
                            1455132
                      interface(version)
Standard Worksheet Interface, Maple 2020.0, Windows 10, March 4
   2020 Build ID 1455132
                      kernelopts(version)
   Maple 2020.0, X86 64 WINDOWS, Mar 4 2020, Build ID 1455132
                       Physics:-Version()
The "Physics Updates" version in the MapleCloud is 678 and is
   the same as the version installed in this computer, created
   2020, May 20, 10:21 hours, found in the directory
   C:\Users\wgellien\maple\toolbox\Physics Updates\lib\
                     Physics:-Version(678)
Warning, this package updates content shipped in a standard Maple install.  Use the 'restart' command to clear your session before using these commands.
Kernel(The "Physics Updates" version "678" is installed but is
   not active. The active version of Physics is within the
   library C:\Users\wgellien\maple\toolbox/Physics Updates/lib\P\
  hysics Updates.maple, created 2020, May 20, 14:46 hours),
  [The "Physics Updates" version "678" is installed but is not
   active. The active version of Physics is within the library
   C:\Users\wgellien\maple\toolbox/Physics Updates/lib\Physics
   Updates.maple, created 2020, May 20, 14:46 hours]
With kind regards
Wolfgang Gellien
Can a second plot be added to a plot generated by a plots[odeplot] command for the case below?
> dsn := dsolve(eval(ddesys, {beta = 4, gamma = 0.0478, sigma = 0.10,tau__1 = 1.1,tau__2 = 8.7}), numeric):
> plots[odeplot](dsn, [[t, S(t), color = green], [t, Ex(t), color = black], [t, Ix(t), color = blue],[t, R(t), color = red]],  0 .. 100, legend = [ S(t), Ex(t), Ix(t), R(t)], labels = [t,""] );
Beware!
In Maple 2019 we get the strange value
cos((Pi/2) -1e-12);
                                                  -10
                       -2.051033808 10
In Maple 2020 we get the correct answer
cos(Pi/2-1e-12);
        -13
                9.999999999996916397514419 10
That error in Maple 2019 certainly messed up quite a few of my calcualtions!
I'm trying to create a graph using a matrix that has numbers and text values, how can I specify that some values of the matrix are strings and others are numbers? I'd like to create something like this
Mainly just symantics, Maple often shifts -'ve terms to the front, how to re-orient terms so the positive terms are always first?
a:= (a2b1-a1b2)*j1+(a4b4-a3b5)*j2
                           ( - a1b2 + a2b1) * j1 + ( - a3b5 + a4b4) * j2
Here is the simplest example of the problem. If I type
assume(j, integer, j>0); assume(k, integer, k > 0);
followed by
int(cos(j*t)*cos(k*t), t = -Pi..Pi);
Maple gives the answer 0, not, as I would have expected, Pi*KroneckerDelta[j,k].
Is there a way to force Maple to alllow for both the possibilities that j = k and j <> k, and thereby to give the general result using the Kronecker delta (or equivalent)?
Bought this book way back in 2000 to learn programming in Maple for procedures.
Problem was that i could not test myself with the exercises, because there were no answers included
Has someone answers in Maple from these exercises ?
That is the only way to learn from this book and check my knowledge about programming.
Jan
The following spreadsheet contains an integral to be done
in the framework of the Maxwell–Jüttner distribution and therefore date back to 1911
integrale_juttner_primes.mw
with(IntegrationTools):
the following integrand represents the scaling of the Maxwell–Jüttner distribution (1911) in 3D
where x is the Lorentz factor which is equal or greater than 1
integrandx:= x*sqrt(x^2 - 1)*exp(-x);
x*(x^2-1)^(1/2)*exp(-x)
C:=1/int(integrandx,x=1..infinity);
1/(BesselK(0, 1)+2*BesselK(1, 1))
pdf:=C*integrandx;
x*(x^2-1)^(1/2)*exp(-x)/(BesselK(0, 1)+2*BesselK(1, 1))
the above pdf represents the probability density function of the Maxwell–Jüttner distribution
DF:=int(C*integrandx,x=1..xx) assuming xx>1;
int(x*(x^2-1)^(1/2)*exp(-x)/(BesselK(0, 1)+2*BesselK(1, 1)), x = 1 .. xx)
the above DF represents the inert form of the distribution function but the integral at the moment
does not exists
Download integrale_juttner_primes.mw
I am using Maple to do a parameter estimation on systems of ODEs using linear least-squares.
Though I have solved the problem, I would like to arrive into better symbolic expressions for the parameters, as they are obtained as the solution of systems of linear equations where the coefficient matrix and the RHS vector have sums as their elements.
The difficulty I have now is that the expressions I arrive at are, for instance:
and what I would like to do, now, would be to express this as
(2*h^2*sum(x[i]^2,i=1..4))*alpha+(2*h^2*sum(x[i]^2*y[i],i=1..4))*beta+2*h*sum(x[i]^2,i=1..4)-2*h*sum(x[i]*x[i+1],i=1..4)
x and y are already defined as vectors.
Is there any way I can do it?
Rudnei
Is it possible to solve a differential equation, where the solution is a 8x8 matrix u(t)?
The equation to solve for, "vgl", is this one:
The values for u(0) are known:
The functions QL(t) and RL(t) are also 8x8 matrix functions. They are actually Fourier series.
Can anyone point me in a direction how to tackle this in Maple?
For completness, I add the entire Maple worksheet (Toon.mw), but my last line obviously doesn't work ;-)
Also all the matrices for the Fourier series are added, just for completeness: RL0.txtRL1.txtRL_1.txtstrQL0.txtstrQL1.txtstrQL2.txtstrQL_1.txtstrQL_2.txtustart.txt
Any hints appreciated a lot!
Stef
Before Maple 2020, it was possible to start up Maple from the Linux commandline with multiple files, as  in
maple   -x   worksheet-1.mw   worksheet-2.mw   ...   worksheet-n.mw
That started up Maple's Java interface and loaded the n worksheets in separate tabs.
That no longer seems to work in Maple 2020 — now the command exits silently when invoked with multuple files.  Why?
Aside: Loading a single file works as expected, but not multiple files.
I'm still trying to get used to the commands. How do you find the height of a cylinder and plot to a graph?
Thanks in Advance.
Example: Using a Formula
Height of a Cylinder:
ex6v := 600
ex6r := 4
ex6h := ex6v/Pi(ex6r)^2
600/Pi(4)^2
(1.1)
Download heightofcylinder.mw
I wanted to create a group of interactive components that, when given an eqaution in a math container of an ellepses (in the form of ((x/A)^2)+((y/B)^2)=1) would pick A and B and give back two formulas of the type
x(t)=A*cos(t)
y(t)=b*sin(t)
So, is there a way to extract A and B from the initial formula?
Probably a dumb question, but I don't manage to read complex numbers from a text file, not even when the text file is created by Maple itself. I've been looking around, but didn't find an answer (which must be rather a simple one, I suppose).
Why is A not a matrix with complex numbers, as is B?
First 553 554 555 556 557 558 559 Last Page 555 of 2428
