If
p_{x} = a*p + u*q;    (1)
q_{x} = -conjugate(u)*p - a*q;  (2)     # where a is complex parameter, p_{x} mean derivative of p w.r.t x
Define, u=p^2+conjugate(q)^2,  (3)
Now take the derivative of (3) w.r.t x and by using (1) and (2), we get
 u_{x}=2(a*p^2 - conjugate(a)*conjugate(q)^2) + 2*(p^2 + conjugate(q)^2)*(p*q - conjugate(p)*conjugate(q)).  (4)
How to calculate the results (4) on maple?
123.mw
Hollo evreyone,
Can you help me to plot the functions given by the pdf attached file.
N.B : One can take theta=pi.
Best regardsplot.pdf
I have a list and I would like to generate all the permutations of that list deterministically and sequential. All I have found is shuffle which may duplicate results(of course I could track this to avoid dups but it should be overkill and slow and consume lots of memory).
I’m starting a large project in education for which I can see great potential in the use of the “MapleCloud”.  For many of the students, the ability to see information on their phone is a game-changer. Hence while my students do have access to Maple on their computers, they are more willing to check out a worksheet if they can view it in a browser.
Unfortunately, in the little time that I have started using MapleCloud, and sharing my work with others, numerous issues have arisen. Some examples:
  * the file system is too simplistic and can be overwhelmed easily as I add content;
  * the group sharing system is too limited – one must log on, which is not true for worksheets;
  * the display of the mathematics is sufficiently quirky that it is not easy to read;
  * the hiding of input mathematics appears not to work;
  * plots, animations and the output of the Explore function fails too frequently.
So, my questions:
  1) are you using MapleCloud, and
  2) if so, for what?
  3) And if you are using MapleCloud, do you have similar problems?
  4) Have you developed solutions that you would be willing to share.
If there is no interest, I’ll look in another direction. But if there is sufficient interest, I would hope Maplesoft notices and works to correct and improve. Some of it may be my own failing to understand Maple, but instead of overwhelming MaplePrimes with questions, I would rather converse with similar interested folks.
Dear Users! I solved a PDE by using the following code.
restart;a := 1:b:= 2:l:= 1:alpha[1]:= 1:alpha[2]:= 3:
  syspde:= [diff(u(x, t), t)-a+u(x, t)-u(x, t)^2*v(x, t)-alpha[1]*(diff(u(x, t), x$2)) = 0, diff(v(x, t), t)-b+u(x, t)^2*v(x, t)-alpha[2]*(diff(v(x, t), x$2)) = 0];
Bcs:= [u(x,0)=1,v(x,0)=1,D[1](u)(-l, t) = 0,D[1](u)(l, t) = 0,D[1](v)(-l, t) = 0,D[1](v)(l, t) = 0];
  sol:=pdsolve(syspde, Bcs, numeric);
  p1:=sol:-plot3d( u(x,t), t=0..1, x=-1..1, color=red);
  p2:=sol:-plot3d( v(x,t), t=0..1, x=-1..1, color=blue);
Now I want to see the value of u(x, t)+diff(u(x, t), x)+diff(u(x, t), t) when x=0 and t=1. Please help me to fix the problem. Thanks in advance.
with(RegularChains):
with(ChainTools):
with(MatrixTools):
with(ConstructibleSetTools):
with(ParametricSystemTools):
with(SemiAlgebraicSetTools):
with(FastArithmeticTools):
R := PolynomialRing([x,y,z,a,b]):
sys := [x^2 + y^2 - x*y - 1 = 0, y^2 + z^2 - y*z - a^2 = 0, z^2 + x^2 - x*z - b^2 = 0,x > 0, y > 0, z > 0, a - 1 >= 0, b-a >= 0, a+1-b > 0]:
dec := RealTriangularize(sys,R): # very slow
Display(dec, R);
dec := LazyRealTriangularize(sys,R): # it is faster
dec2 := value(dec): # very slow
value(dec2);
find a , b to satisfy sys have real solution
expect  one of solution is below, but above function are very slow, load a very time still no result, where is wrong?
R1 = a^2+a+1-b^2;
R1 = a^2-1+b-b^2;
[R1 > 0, R2 > 0]
When the Explore command results in a slider, for example like this:
Explore(plot(x^2 + a, x = 0 .. 10), a = 10.5000000000 .. 11.5000000000)
The value shown next to the slider has only one decimal place, despite the fact that the slider can be easly placed at values in between.  Is there a way to change the number of decimal places shown on the slider label for the Explore command?
    In this example, we have the KdV equation
         t] - 6 uux] + xxx] = 0
    I would like to find the Lax pair for the KdV equation, which are
               Lψ=λψ
               ψ[t] = Mψ
              Lt+ML-LM = 0  called a compatibility condition
    So, I will start from this purpose
    Then we will assume M in the form
              M := a3*Dx^3+a^2+a1*Dx+a0
    thenb using M and L in the for L[tL-LM = 0can find
      Dx^5+( ) Dx^4+( ) Dx^3+( ) Dx^2+( ) Dx+( )=0
    then wean find a_i =0,1,2,3
  In the following maple code to do that
  my question is
   .How I canoue the soluo get a_i2,3 usinmaple code
    any maple packge to find Lax pair for PDE -
restart; with(DEtools); with(PDEtools)
     in this exampile we have KdV equation
      u[t]-6*uu[x]+u[xxx] = 0
    I would likeind the Lax pair for the KdV equation, which are
       Lψ=λψ
    psi[t] = M*psi
   where``
    L[t]+ML-LM = 0    called  apatibility  condition
    So, I  will start this purpose
     L:=-Dx^2+u;
    then we will assume M the m
    Ma3*Dx^3+a2*Dx^2+Dx+a0
    then busing in the form L[t]+ML-LM = 0 can find
  ( ) Dx^5+( ) Dx^4+( ) Dx^3+( ) Dx^2+( ) Dx+( )=0
 then we can find a_i ;i=,2,3
the fllowile code to
 my queion is ;
  1) How I can continue the solution  to get a_i ;i=0,1,2,3 using maple code  ?
  2) isir any maple packge to find  Lax pair for PDE ?
alias(u = u(x, t)); declare(u(x, t)); alias(a3 = a3(x, t)); declare(a3(x, t)); alias(a2 = a2(x, t)); declare(a2(x, t)); alias(a1 = a1(x, t)); declare(a1(x, t)); alias(a0 = a0(x, t)); declare(a0(x, t))
u
` u`(x, t)*`will now be displayed as`*u
u, a3
` a3`(x, t)*`will now be displayed as`*a3
u, a3, a2
` a2`(x, t)*`will now be displayed as`*a2
u, a3, a2, a1
` a1`(x, t)*`will now be displayed as`*a1
u, a3, a2, a1, a0
` a0`(x, t)*`will now be displayed as`*a0
_Envdiffopdomain := [Dx, x]
[Dx, x]
L := -Dx^2+u
-Dx^2+u
M := Dx^3*a3+Dx^2*a2+Dx*a1+a0
a3*Dx^3+a2*Dx^2+a1*Dx+a0
LM := expand(mult(L, M))
-a3*Dx^5-2*Dx^4*(diff(a3, x))-a2*Dx^4+Dx^3*u*a3-Dx^3*(diff(diff(a3, x), x))-2*Dx^3*(diff(a2, x))-Dx^3*a1+Dx^2*u*a2-Dx^2*(diff(diff(a2, x), x))-2*Dx^2*(diff(a1, x))-Dx^2*a0+Dx*u*a1-Dx*(diff(diff(a1, x), x))-2*Dx*(diff(a0, x))+u*a0-(diff(diff(a0, x), x))
ML := expand(mult(M, L))
-a3*Dx^5-a2*Dx^4+Dx^3*u*a3-Dx^3*a1+3*Dx^2*a3*(diff(u, x))+Dx^2*u*a2-Dx^2*a0+3*Dx*a3*(diff(diff(u, x), x))+2*Dx*a2*(diff(u, x))+Dx*u*a1+a3*(diff(diff(diff(u, x), x), x))+a2*(diff(diff(u, x), x))+a1*(diff(u, x))+u*a0
Commutator := simplify(ML-LM)
a3*(diff(diff(diff(u, x), x), x))+(3*Dx*a3+a2)*(diff(diff(u, x), x))+diff(diff(a0, x), x)+Dx*(diff(diff(a1, x), x))+Dx^2*(diff(diff(a2, x), x))+Dx^3*(diff(diff(a3, x), x))+(3*Dx^2*a3+2*Dx*a2+a1)*(diff(u, x))+2*Dx^4*(diff(a3, x))+2*Dx^3*(diff(a2, x))+2*Dx^2*(diff(a1, x))+2*Dx*(diff(a0, x))
sol := diff(L, t)-Commutator = 0
diff(u, t)-a3*(diff(diff(diff(u, x), x), x))-(3*Dx*a3+a2)*(diff(diff(u, x), x))-(diff(diff(a0, x), x))-Dx*(diff(diff(a1, x), x))-Dx^2*(diff(diff(a2, x), x))-Dx^3*(diff(diff(a3, x), x))-(3*Dx^2*a3+2*Dx*a2+a1)*(diff(u, x))-2*Dx^4*(diff(a3, x))-2*Dx^3*(diff(a2, x))-2*Dx^2*(diff(a1, x))-2*Dx*(diff(a0, x)) = 0
collect(sol, [Dx, x])
-2*Dx^4*(diff(a3, x))+(-(diff(diff(a3, x), x))-2*(diff(a2, x)))*Dx^3+(-3*a3*(diff(u, x))-(diff(diff(a2, x), x))-2*(diff(a1, x)))*Dx^2+(-2*a2*(diff(u, x))-3*a3*(diff(diff(u, x), x))-(diff(diff(a1, x), x))-2*(diff(a0, x)))*Dx-a1*(diff(u, x))-a2*(diff(diff(u, x), x))-a3*(diff(diff(diff(u, x), x), x))-(diff(diff(a0, x), x))+diff(u, t) = 0
Download find_lax_pair.mw
Is it possible to force Maple to simplify these Sum(s) ?
SimplifySum.mw
s := Sum(a*X[n]+b, n=1..N);
simplify(s);
value(s);  # part of the job done  but...
IWouldLikeToHave = a*Sum(X[n], n=1..N) + b*N; # or +N*b, it doesn't matter
Sum(a*X[n]+b, n = 1 .. N)
N*b+sum(a*X[n], n = 1 .. N)
IWouldLikeToHave = a*(Sum(X[n], n = 1 .. N))+N*b
s := Sum(X[n]+Y[n], n=1..N);
(expand@value)(s);
IWouldLikeToHave = Sum(X[n], n=1..N) + Sum(Y[n], n=1..N);
Sum(X[n]+Y[n], n = 1 .. N)
sum(X[n]+Y[n], n = 1 .. N)
IWouldLikeToHave = Sum(X[n], n = 1 .. N)+Sum(Y[n], n = 1 .. N)
I performed an iteration of over 300 using for loop, how can I label each of the output? Please help...
Hi ,
How to animate implicitplot?
plots:-animatecurve(1/x, x = 0 .. 5, thickness = 5, size = [150, 150], axes = none, color = red)
with(plots, implicitplot)
P1 := implicitplot(x^2+y^2 = 9, x = -3 .. 3, y = -9 .. 9, thickness = 5, size = [150, 150], axes = none, color = red)
plots:-animatecurve(2*abs(x), x = -.5 .. .5, thickness = 5, size = [150, 150], axes = none, color = red)
implicitplot(x = -3*abs(sin(y)), x = -3 .. 3, y = 0 .. 6, thickness = 5, size = [150, 150], axes = none, color = red)
with(plots)
P1 := plots:-animatecurve(sqrt(1-(abs(x)-1)^2), x = -2 .. 2, thickness = 5, axes = none)
P2 := plots:-animatecurve(arccos(1-abs(x))-Pi, x = -2 .. 2, thickness = 5, axes = none)
P := display(P1, P2, view = [-2 .. 2, -3 .. 1], size = [350, 350], axes = none)
Download LoveMaple1Anim.mws.mw
with(plots)
Hello everyone.
I have a very simple question.  When I use maple to solve the following equations,  everything works as expected
solve({
a + b + c + d = 0,
d * (480-471.1) + b * (484.3-471.1) + c * (547.2-471.1) + m4 = 0,
a * (471.1-484.3) + d * (480-484.3) + c * (547.2-484.3)  + m4 = 0,
a * (471.1-547.2) + d * (480-547.2) + b * (484.3-547.2) + m4 = 0,
a * (471.1-477) + d * (480-477) + b * (484.3-477) + c * (547.2-477) + m4 = 0,
a * (471.1-494) + d * (480-494) + b * (484.3 - 494) + c * (547.2 - 494) + m4 = 0,
a * (471.1-540) + d * (480-540) + b * (484.3 - 540) + c * (547.2-540) + m4 = 0,
a * (471.1-477) + m1 = 0,
a * (471.1-494) + d * (480-494) + b * (484.3 - 494) + m2 = 0,
a * (471.1-540) + d * (480-540) + b * (484.3 - 540) + m3 = 0},{a,b,c,d,m4})
Now if I add one more equation to it then maple won't solve
solve({
a + b + c + d = 0,
a * (471.1-481) + d * (480-481) + mx = 0},{a,b,c,d,m4,mx})
Obviously,  using the first solve command,  I can solve for a and d.  I can substitude that into the last equation and solve for mx.  But for some reason, maple just won't do that for me directly from the second solve command.
Can someone help?  thanks
When I tried to copy any of the expression among (1) and (4), the only MathML string appearing at the target application is this:
<math xmlns='http://www.w3.org/1998/Math/MathML'></math>
n:= 2:
X:= Vector(n, symbol= x);
Vector(2, {(1) = x[1], (2) = x[2]})
W:= Matrix(3,2, symbol= w);
Matrix(3, 2, {(1, 1) = w[1, 1], (1, 2) = w[1, 2], (2, 1) = w[2, 1], (2, 2) = w[2, 2], (3, 1) = w[3, 1], (3, 2) = w[3, 2]})
V:= W.X;
Vector(3, {(1) = w[1, 1]*x[1]+w[1, 2]*x[2], (2) = w[2, 1]*x[1]+w[2, 2]*x[2], (3) = w[3, 1]*x[1]+w[3, 2]*x[2]})
answer:=seq(diff~(v,W), v= V);
answer := Matrix(3, 2, {(1, 1) = x[1], (1, 2) = x[2], (2, 1) = 0, (2, 2) = 0, (3, 1) = 0, (3, 2) = 0}), Matrix(3, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = x[1], (2, 2) = x[2], (3, 1) = 0, (3, 2) = 0}), Matrix(3, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0, (3, 1) = x[1], (3, 2) = x[2]})
Can you tel me how to fix this error?
Download question1a.mw
Refers to yMaple 2019.1
The command alias(X(s)=laplace(x(t),s,t)) will not be executed in the  code following it. It seems that the 'funny font' L used instead of the word 'laplace' ist not recognized. Maple 2018.2.1 works fine, since it doesn't use the 'L" but works with 'laplace'. Is there a fix ?
Consider the following problem.
I'm looking for an implementation of the following approximation-method. Thanks to @Carl Love I already have a code for the exact solution. (It might be that my example using the given A,b,c does not have a solution but then I would just have to use different A, b, c.)
num211.pdf
I uploaded the question as a pdf so that it is nicer to read.
I know there are probably better ways which are already part of some packages but I want to use this method.
Edit:
A procedure that does the following is all I need:
num211_2.pdf
First 603 604 605 606 607 608 609 Last Page 605 of 2434
