This may be a bug.  In Maple 2019.0
plot3d(x^2+y^2)
Now grab the graphing window and drag to adjust it's size.  It doesn't adjust it's size until you let go of the mouse button.
Any with an idea on how to determine the Inflexition points on a discrete data set in Maple? I can only find stuff online on how to in Matlab, but not in Maple.
Any suggestions on how to do it in Maple?
You can graph Maple in 4 dimensions ... help...
Examples
If maple can auto discover derived equations,
then most variable are unknown name which may or may not be physics variable.
so, how to guess which physics data suitable for these look like meaningless variable?
or these tools only visualize the relationship of existing known equations?
Please, I would really appreciate if anyone can help me to find the step by step solution for this equation:
I got the right answer by choosing Solve for X, but it did not come with step by step :/
8*x*e^(-3*x^2) - 24*x^3*e^(-3*x^2)
kind regards
I have a problem using the NonlinearFit function from the Statistics package in Maple 2018.
I want to fit an exponential function which is non-linear in the parameters. The function in itself is working fine but i want to implement an extra condition on the parameters that are fitted. I already implemented the range of each parameter which is from 0 to 1, but I also want to implement the following condition:
a + b + c = 1.0
This is the code that i am using:
with(Statistics);
X := Vector([0, 100, 200, 300, 400, 500], datatype = float);
Y := Vector([0.2e-2, 0.5e-2, 0.7e-2, 0.75e-2, 0.77e-2, 0.8e-2], datatype = float);
nlfit := NonlinearFit(epsfunc, X, Y, t, parameterranges = [a = 0 .. 1, b = 0 .. 1, c = 0 .. 1], initialvalues = [a = .2, b = .2, c = .2], output = [parametervalues, leastsquaresfunction]);
It there a way to implement the additional condition that a+b+c=1.0?
Joa
Edit:
Epsfunc is the result of solving an ODE using dsolve:
the following code is used:
eq1 := x(t)+(t1+t2)*(diff(x(t), t))+t1*t2*(diff(x(t), t, t)) = (n1+n2)*(diff(eps(t), t))+(n1*t2+n2*t1)*(diff(eps(t), t, t));
tr := n1*n2*(E1+E2)/((n1+n2)*E1*E2);
x := proc (t) options operator, arrow, function_assign; x0 end proc;
solution := dsolve({eq1, eps(0) = x0/(E1+E2), (D(eps))(0) = x0*((n1/E1+n2/E2)/(n1+n2)-1/(E1+E2))/tr}, eps(t)); assign(solution);
E := 500;
E1 := a*E; E2 := b*E; t1 := 100; t2 := c*t1; n1 := E1*t1; n2 := E2*t2; x0 := 2;
epsfunc := eval(eps(t));
How to solve this DE with IC by using DTM.
D^m u(x,t)=u''(x,t)-u^2 (x,t), where n-1< m < n
IC: u(x,0)=1+sin(x), and u'(x,0)=0
I have a problem for school that I need help with.
Solve: by variation of parameters.
x3y’’’ – x2y’’ − 2xy’ + 6y = x2
Use any software, e.g. Maple, as an aid in computing roots of the auxiliary equation and the Wronskian-based determinants W, W1, W2, W3
I was able to hand calculate the roots as [m1 = 3, m2 = 2, m3 = -1]
with(VectorCalculus); Wronskian([x^3, x^2, 1/x], x, 'determinant')
Matrix(%id = 18446744078324919462), -12*x
with(VectorCalculus); Wronskian([0, x^2, 1/x], x, 'determinant')
Matrix(%id = 18446744078349556782), 0
with(VectorCalculus); Wronskian([x^3, 0, 1/x], x, 'determinant')
Matrix(%id = 18446744078266878782), 0
with(VectorCalculus); Wronskian([x^3, x^2, 0], x, 'determinant')
Matrix(%id = 18446744078331625094), 0
m3 := Matrix(3, 3, [0, x^2, 1/x, 0, 2*x, 1/x^2, x^2, 2, 2/x^3])
Matrix(%id = 18446744078385724822)
Determinant(m3, method = multivar)
Determinant(Matrix(%id = 18446744078385724822), method = multivar)``
roots(x^3-x^2-2*x+6, alpha, beta)
solve(x^3-x^2-2*x+6 = 0, x)
-(1/3)*(71+9*58^(1/2))^(1/3)-(7/3)/(71+9*58^(1/2))^(1/3)+1/3, (1/6)*(71+9*58^(1/2))^(1/3)+(7/6)/(71+9*58^(1/2))^(1/3)+1/3+((1/2)*I)*3^(1/2)*(-(1/3)*(71+9*58^(1/2))^(1/3)+(7/3)/(71+9*58^(1/2))^(1/3)), (1/6)*(71+9*58^(1/2))^(1/3)+(7/6)/(71+9*58^(1/2))^(1/3)+1/3-((1/2)*I)*3^(1/2)*(-(1/3)*(71+9*58^(1/2))^(1/3)+(7/3)/(71+9*58^(1/2))^(1/3))
m3 := Matrix(3, 3, [0, x^2, 1/x, 0, 2*x, 1/x^2, 1/x, 2, 2/x^3])
Matrix(%id = 18446744078348970214)
Determinant(Matrix(%id = 18446744078348970214), method = multivar)
Download project_27.mw
Lets say I have a circle with the eqn
x^2 + y^2 - 10*x - 75 = 0
Is there a command which would allow me to convert the above to (x-5)^2+y^2=100 ?
I have tried to both collect, factor but neither of these work for obvious reason.
So any idea/surgestion on which command one could use?
Many thanks in advance.
i have try to solve these eq by maple
and i got these errors
new2fornet.maple
simplify(series(sin(g(x)),x=0,4));
sin(g(0)) + cos(g(0))*D(g)(0)*x + (-1/2*sin(g(0))*D(g)(0)^2 + 1/2*cos(g(0))*(D@@2)(g)(0))*x^2 + (1/6*(-D(g)(0)^3 + (D@@3)(g)(0))*cos(g(0)) - 1/2*sin(g(0))*(D@@2)(g)(0)*D(g)(0))*x^3 + :-O(1)*x^4
and I'd like to give the various values for g to evaluate the series. That is, I know g and it's derivatives at 0.
Maple 2019.2.
These two expressions are mathematically equivalent:
But simplify(expr1-expr2) does not give zero where simplify(convert(expr1,trig)-expr2) does.
Is this normal behavior or can be expected sometimes? As a user I would have expected Maple internally to figure all of this itself. Compare to Mathematica:
Is there a different command in Maple that will show mathematical equivalence of two expressions to try other than simplify?
expr1:=(-exp(n*Pi*(2*b - y)/a) + exp(n*Pi*y/a))/((exp(2*n*Pi*b/a) - 1)):
expr2:= sinh(n*Pi/a*y)/tanh(n*Pi/a*b)-cosh(n*Pi/a*y):
simplify(expr1-expr2);
(-sinh(n*Pi*b/a)*exp(n*Pi*(2*b-y)/a)+(-sinh(n*Pi*y/a)*cosh(n*Pi*b/a)+cosh(n*Pi*y/a)*sinh(n*Pi*b/a))*exp(2*n*Pi*b/a)+(exp(n*Pi*y/a)-cosh(n*Pi*y/a))*sinh(n*Pi*b/a)+sinh(n*Pi*y/a)*cosh(n*Pi*b/a))/((exp(2*n*Pi*b/a)-1)*sinh(n*Pi*b/a))
simplify(convert(expr1,trig)-expr2);
Download q.mw
How to change default directory for Maple 2019?
Solving_ODE.mw
Here is an example.  How would I solve this non-homogeneous system of ODEs
Is there a guide for programming in maple?  I mean like using it like a normal programming language using the code editor (external one not the whole worksheet thing maple has by default) debugging writing functions and the lot.
First 618 619 620 621 622 623 624 Last Page 620 of 2428
