Source of interest in this topic.  There is a problem with drawing a cylinder. I draw a cylinder using the arrow function as follows:
cylinder := seq(arrow(`<,>`((L[1][i]+L[4][i])*(1/2), (L[2][i]+L[5][i])*(1/2), (L[3][i]+L[6][i])*(1/2)), `<,>`(-(L[1][i]+L[4][i])*(1/2)+(L[7][i]+L[10][i])*(1/2), -(L[2][i]+L[5][i])*(1/2)+(L[8][i]+L[11][i])*(1/2), -(L[3][i]+L[6][i])*(1/2)+(L[9][i]+L[12][i])*(1/2)), width = 1, color = green, head_length = 0, head_width = 0, length = VectorNorm(`<,>`((L[1][i]+L[4][i])*(1/2)-(L[7][i]+L[10][i])*(1/2), (L[2][i]+L[5][i])*(1/2)-(L[8][i]+L[11][i])*(1/2), (L[3][i]+L[6][i])*(1/2)-(L[9][i]+L[12][i])*(1/2)), 2), transparency = 0.), i = 1 .. N+1):
(L [j], j = 1..12 - the coordinates of the red points on the cylinder).
But, as you can see, because of the faces, everything does not turn out very smoothly. Is there a way to display the cylinder smoothly, but so that without too much computing resources, ie no more resource than a "arrow"?
Hai
Help required to plot the graphs for system  difference schemes .
 I am attaching the codes and sample graphs and  maple query but still getting  error.
here is the codes
restart; Digits := 1;
Pr:=0.01:E:=1:a:=0:N:=10:
`&Delta;t`:=0.01:`&Delta;y`:=0.01:
#Discritization scheme
for i from 1 by 1 while i<=N do;
end:
for j from 0 by 1 while j<=N do;
end:
eq1[i, j] := (U[i, j+1]-U[i, j])/`&Delta;t` = (1/2)*Gr*(theta[i, j+1]+theta[i, j])+(1/2)*Gc*(C[i, j+1]+C[i, j])+(U[i-1, j+1]-2.*U[i, j+1]-2.*U[i, j]+U[i+1, j])/(2.*`&Delta;y`)^2-(1/2)*M*(U[i, j+1]+U[i, j]):
eq2[i, j] := (theta[i, j+1]-theta[i, j])/`&Delta;t` = (1/Pr)*(theta[i-1, j+1]-2*theta[i, j+1]+theta[i+1, j+1]+theta[i-1, j]-2*theta[i,j]+theta[i+1,j])/(2.*`&Delta;y`)^2-E*((1/`&Delta;y`)^2*(U[i+1, j]-U[i, j])^2):
eq3[i, j] := (C[i, j+1]-C[i, j])/`&Delta;t` = (1/Sc)*(C[i-1, j+1]-2*C[i, j+1]+C[i+1, j+1]+C[i-1, j]-2*C[i,j]+C[i+1,j])/(2*`&Delta;y`)^2-(K/2)*(C[i, j+1]-C[i, j]):
Error, reserved word `end` unexpected
# initial conditions
U[i, 0] := 0:
theta[i, 0]:= 0:
C[i, 0] := 0:
NULL;
U[0,j]:=exp(a*j*`&Delta;t`):
theta[0,j]:=(j*`&Delta;t`):
C[0,j]:=j*`&Delta;t`:
U[N,j]:=0:
theta[N,j]:=0:
C[N,j]:=0:
sys := ([seq])(seq(eq[i, j], j = 0 .. N), i = 1 .. N):
nops(sys);
vars:=indets(sys):
nn := Matrix(N+1, N+1,(i, j)-> U[i-1, j-1]):
p:=proc(kk) local U_res,A;
  U_res:=solve(eval(sys,k=kk),vars);
  A:=eval(nn,U_res);
  plots:-matrixplot(A)
plots:-(U,[M],Y=0..4);
https://www.mapleprimes.com/questions/225117-How-To-Solve-This-Error-In-Maple
I have just upgraded my laptop from Windows 7 to Windows 10.  On starting up Maple 2018,  I receive the attached message on screen.  This is after previously loading the worksheet successfully.   Today,  I am not able to do so.  I need to permanently register my firewall to allow Maple to run; can anyone help?
Melvin
The routines for finding nonclassical symmetries of PDE, mentioned in the research articles are not currently available. The routines like GENDEFNC may have been changed to other one. Please tell how to find nonclassical symmetries of a PDE or a system of PDE. I am using Maple 2016.
I've found the Taylor series expansions for two functions.  The two expansions are identical until the third term.  When I subtract one expansion from the other, I expected that the identical terms would cancel and disappear.  But I can't get Maple to do this.  If I copy and paste the output into a Maple command, the "big Oh" terms are not treated correctly.  The correct answer would be (x^3)/6 + O(x^4).  Here's my work:
taylor(ln(1+x), x = 0, 4)
series(x-(1/2)*x^2+(1/3)*x^3+O(x^4),x,4)
taylor(ln(1+sin(x)),x=0,4)
series(x-(1/2)*x^2+(1/6)*x^3+O(x^4),x,4)
(series(x-(1/2)*x^2+(1/3)*x^3+O(x^4),x,4))-(series(x-(1/2)*x^2+(1/6)*x^3+O(x^4),x,4))
collect((3),x)
x-(1/2)*x^2+(1/3)*x^3+O(x^4)-x+(1/2)*x^2-(1/6)*x^3-O(x^4)
(1/6)*x^3
(1/6)*x^3
How can I get Maple to give me the right answer?  I tried various commands (collect, combine, simplify, etc.) but nothing worked.  Also, why do the font and color of my first two commands differ?  Thanks
Download Taylor_question.mw
Would you help me to figure out how to solve this error?
totalsalesx := 60.1 + tax + profit
tax := 0.3*profit
profit := 0.1*totalsalesx
then, 'Error, recursive assignment'
What I want to do is to calculate the 'totalsalesx' from the cost (60.1).
= 2*1/10);
= -1;
                               -1
= 10;
                               10
= -25;
                              -25
C= 1;
= (1/12*sqrt6/sqrtbeta*lambda*mu);
                       1     (1/2)  (1/2)
                      --- I 6      2
                       24
= alpha/((10*sqrt-lambda*mu)*beta);
                             1  (1/2)
                           - - 5
                             4
A0]= (1/2*alpha/((10*sqrt-lambda*mu)*(1/12*beta*sqrt6/sqrtbeta*lambda*mu)));
                    1    (1/2)  (1/2)  (1/2)
                   -- I 5      6      2
                    4
A1]= -(1/10*alpha/((1/12*beta*mu*sqrt6/sqrtbeta*lambda*mu));
                        1    (1/2)  (1/2)
                       -- I 6      2
A[2] := -(12*((112)*sqrt(6)/sqrt(beta*lambda*mu)))*lambda^2*alpha/(10*sqrt(-lambda*mu));
                    1     (1/2)  (1/2)  (1/2)
                   --- I 6      2      5
                    20
H := ln(sqrt(lambda/(-mu))*tanh(sqrt(-lambda*mu)*(xi+C)));
              /1/2)     /1  (1/2         \\
              ln|- 5      tanh|- 5      ( 1)||
                \5            \5                //
xi := k*x-t*w;
                1     (1/2)  (1/2)     1    (1/2)
               --- I 6      2      x + t
        2               4
u[0] := A[0]+A[1]*exp(-H)+A[2]*exp(-H)*exp(-H);
  1    (1/2)  (1/2)  (1/2)
 -- I 5      6      2
  4
                     1    (1/2)  (1/2)  (1/2)
                     - I 6      2      5
         (1/2) / 1     (1/2)  (1/2)     1    (1/2)    \\
      tanh|- 5      |--- I 6      2      x + - t 5      + 1||
          \5        \ 24                     4             //
                      1    (1/2)  (1/2)  (1/2)
                      - I 6      2      5
                      4
               \ 24              4             //
plot3d(Im(u[0]), x = -10 .. 10, t = -10 .. 10);
I have a .mapleinit file that amongst other things sets libname so my own packages are accessible and can be loaded using with(). Imagine my surprise when I found that a maple program that ran half an hour ago on Maple2019 bombed when it did not find its package. Closer investigation indicates that maybe .mapleinit is only searched for in currentdir()??
The updated Maple is `Maple 2019.2, APPLE UNIVERSAL OSX, Oct 30 2019, Build ID 1430966`
The old one is gone :-(. It was Maple2019.0. I should add that on this system, Maple is installed on an administrator account that is not my user account (luckily I have access to that). I am running macOS 10.14.6 Mojave.
I verified my older Maples still work as before.
Has anyone else seen this behaviour?
Mac Dude.
Edit: I need to be more specific here: When I double-click a worksheet (.mw file) then currentdir() will be set to the directory the .mw file is in. This has been long-standing Maple behaviour. But then currentdir() does not cover the home directory where .mapleinit sits. As a result, a blank sheet finds my .mapleinit whereas my files (that habitually I open with double-click or drag-drop) do no longer run the .mapleinit file.
I need to animate the following function in two dimensions
,u:=  (x, y) -->x^2+y^2+3
((gradplot(u(x, y), x = -10 .. 10, y = -2 .. 2, grid = [8, 8], thickness = 3, arrows = SLIM, color = u(x, y
Amr
How to use Fourier transform to extract the part of data which higher than near flat data no matter of scale such as very small decimal value?
would like to extract part when very small decimal small start to increasing or a noise start to appear in time series data.
and then highlight with rectangle in plot for that part of data.
if Fourier transform can not detect this noise or an increasing data or spike then return 0, if detected then return 1
find the moduli of the 5 roots of the polynomial
p(z)= z^5 -3*z^4 -2*z^3 +5
and enter a decimal approximation to the largest modulus in the box below.  Your approximation should be correct to 10 significant figures.
how will we answer to this using maple.
I am trying to animate on maple. I have two solutions 𝑢1(𝑥, 𝑎) = 𝑐𝑜𝑠(𝑥 − 2𝑎) and 𝑢2(𝑥, 𝑎) = 𝑐𝑜𝑠(𝑥 + 2𝑎), for 𝑎 ∈ [1,10], how do I animate them?
S := Sum(1/i(i + 1)(i + 2)(i + 3), i = 1 .. infinity);
evalf(S);
                        -Float(infinity)
S1 := applyop(convert, [1, 2], S, parfrac, x);
                    infinity
                       )              1
              S1 :=   /     ----------------------
                     -----  i(i + 1)(i + 2)(i + 3)
                     i = 1
S2 := applyop(expand, 1, S1);
                    infinity
                       )              1
              S2 :=   /     ----------------------
                     i = 1
S3 := map(op(0, S2), op(S2));
                                            /infinity    \
                                            |  /     (-1)|
                                            \ i = 1      /
            /infinity                      \
      S3 := |  /     i(i + 1)(i + 2)(i + 3)|
            \ i = 1                        /
I am trying to find the limit approaching inf of the sum of 1/( 𝑖(𝑖 + 1)(𝑖 + 2)(𝑖 + 3)). I dont know what to do after this.
lim 𝑛→+∞∑ 1 /(𝑖(𝑖 + 1)(𝑖 + 2)(𝑖 + 3))
Let 𝑦 and 𝑧 and be variables, let 𝑦 =( 𝑎+𝑏𝑧+𝑐𝑧^2)/( 𝑑+𝑒𝑧+𝑓𝑧 ^2) . Use the function solve in Maple to solve for 𝑧 in terms of 𝑦, that is, find a function 𝑧 = 𝑓(𝑦) (in fact, you should be able to find two). Let 𝑔(𝑧) = 𝑎+𝑏𝑧+𝑐𝑧^2)/( 𝑑+𝑒𝑧+𝑓𝑧 ^2)  and compute 𝑔(𝑓(𝑦)) for both of these functions and show that if you simplify the expressions you get a predictable answer.
I ave already solved the values, however I am unable to simplify these expressions.
I am working with the Physics package in maple. I have a rank 6 tensor, I want to assign the elements of a set (with equal number of components as the tensor) as the corresponding components of a tensor. Entering manually all the components using 'RedefineTensorComponents' is not an option, as it has 4096 components. How can I do this?
First 619 620 621 622 623 624 625 Last Page 621 of 2428
