Sorry if it's a dumb question, i'm new with Sage.
I'm doing the multiplication of two matrix and I obtain the expression
[142√(2x−2√)+122√y]
I want to represent this on 3d, but I realized that the expression has to be written with operators '*'
How can I add the operators to my expression?
Let A=[V1, V2 ,..., Vn ] be a list of binary vectors such that the length of Vi for i=1...n is the positive integer number m. For instance, in the following example we have n=6 and m=5.
A := [[1, 1, 1, 0, 0], [0, 1, 0, 1, 1], [1, 0, 1, 1, 1], [0, 1, 1, 1, 0], [1, 1, 0, 1, 0], [0, 1, 1, 1, 1]]
Suppose that ej with j=1...m are vectors of size m such that all entries of ej 's are zero except the jth entry where is equal to 1. Now set S=[e1,e2,...,em]. For example by m=5 we get
S:=[[1, 0, 0, 0, 0], [0, 1, 0, 0, 0], [0, 0, 1, 0, 0], [0, 0, 0, 1, 0], [0, 0, 0, 0, 1]]
First, we choose i,j in [1...m] such that i<>j and then we update S as follows S=[e1,e2,...,em,ei+ej mod 2]. For example, it follows from i=1 and j=2 that
S:=[[1, 0, 0, 0, 0], [0, 1, 0, 0, 0], [0, 0, 1, 0, 0], [0, 0, 0, 1, 0], [0, 0, 0, 0, 1], [1, 1, 0, 0, 0]]
Now consider the kth entry of A which is called Ak. Then we check that what is the minimum number of entries of S so that the summation of these entries mod 2 is equal to Ak. For example, for  S=[e1,e2,...,em,e1+e2 mod 2] we get [2, 3, 4, 3, 2, 4] which means the minimum number of entries of the S that are required to be added in order to obtain A1 is 2 and so on. Therefore, for the given example we get
E:=[[1, 2, [2, 3, 4, 3, 2, 4], 18, 7.615773106],
[1, 3, [2, 3, 3, 3, 3, 4], 18, 7.483314774],
[1, 4, [3, 3, 3, 3, 2, 4], 18, 7.483314774],
[1, 5, [3, 3, 3, 3, 3, 4], 19, 7.810249676],
[2, 3, [2, 3, 4, 2, 3, 3], 17, 7.141428429],
[2, 4, [3, 2, 4, 2, 2, 3], 16, 6.782329983],
[2, 5, [3, 2, 4, 3, 3, 3], 18, 7.483314774],
[3, 4, [3, 3, 3, 2, 3, 3], 17, 7.],
[3, 5, [3, 3, 3, 3, 3, 3], 18, 7.348469229],
[4, 5, [3, 2, 3, 3, 3, 3], 17, 7.]];
For instance, the interpretation of [3, 5, [3, 3, 3, 3, 3, 3], 18, 7.348469229] is that if S be [e1,e2,e3,e4,e5,e3+e5 mod 2] then we get [3, 3, 3, 3, 3, 3] where 18 is the summation of [3, 3, 3, 3, 3, 3] and also the number 7.348469229 is obtained from the following command:
MatrixNorm(convert([3, 3, 3, 3, 3, 3], Matrix), Frobenius);
Now we choose Ek for k in [1..nops(E)] such that Ek[4] be minimum over all Ek[4]'s. For example we choose [2, 4, [3, 2, 4, 2, 2, 3], 16, 6.782329983] since 16 is minimum between Ek[4]'s.
There are two points: First one is that if we have Ei and Ej such that Ei[4]=Ej[4] then we choose Ei if  Ei[5]>Ej[5] . The second point is that if Ei[4]=Ej[4] and also Ei[5]=Ej[5] then we choose one of them such as the first one. Finally we update the set S from the first two entries of Ek that we have obtained. For instance, the updated S in our example is:
S=[e[1],e[2],e[3],e[4],e[5],S[E[6][1]]+S[E[6][2]] mod 2]=[e[1],e[2],e[3],e[4],e[5],e[2]+e[4] mod 2]
Now we repeat this procedure for the updated S until that in one of the entries of E such as Ek we get Ek[3]=[1,1,..,1].
I have written a procedure in Maple for the mentioned question. But my procedure takes long time to compute when I run it over a list such as A with parameters n=m=64.
I want to kindly request you please modify the following code or suggest another fast procedure for this question.
 with(ListTools):
 with(combinat):
 BP := proc (A::list)
    local n, m, r, S, U, tt, P, E, t, Q, Z, R, k, T, j, PP, i, QQ;
    n := nops(A);
    m := nops(A[1]);
    r := [seq(0, i = 1 .. m)];
    r[1] := 1;
    S := [seq(Rotate(r, m-i+1), i = 1 .. m)];
    unassign('r');
    U := [];
    tt := 1;
 while 0 < tt do
     P := choose(nops(S), 2);
     E := [];
     for t to nops(P) do
          Q := P[t];
          Z := [];
          R := [S[], `mod`(S[Q[1]]+S[Q[2]], 2)];
          for k to n do
               T := A[k];
               for j to nops(R) do
                    PP := choose(nops(R), j);
                    for i to nops(PP) do
                         QQ := PP[i]; r := `mod`(add(R[QQ[i]], i = 1 .. nops(QQ)), 2);
                         if Occurrences(0, r-T) = m then
                            Z := [op(Z), j];
                            i := nops(PP)+1;
                            j := nops(R)+1
                      unassign('i, QQ, r, PP'):
              E := [op(E), [Q[], Z, add(Z[i], i = 1 .. nops(Z)), evalf(MatrixNorm(convert(Z, Matrix), Frobenius))]];
              unassign('k, Z, Q, R'):
          r := FindMinimalElement([seq(E[i][4], i = 1 .. nops(E))]);
          R := [];
         for i to nops(E) do
             if E[i][4] = r then R := [op(R), E[i]] end if
         T := [FindMaximalElement([seq(R[i][5], i = 1 .. nops(R))], position)];
         S := [S[], `mod`(S[R[T[2]][1]]+S[R[T[2]][2]], 2)];
         U := [op(U), [R[T[2]][1], R[T[2]][2]]];
         if Occurrences(1, R[T[2]][3]) = n then tt := 0 end if;
         unassign('r, i, R, T, E')
     return U;
 A := [[1, 1, 1, 0, 0], [0, 1, 0, 1, 1], [1, 0, 1, 1, 1], [0, 1, 1, 1, 0], [1, 1, 0, 1, 0], [0, 1, 1, 1, 1]];
 BP(A);
      [[2, 4], [3, 6], [5, 7], [1, 2], [1, 6], [3, 8], [3, 9], [8, 9]]
For more information please see Section 2.1 of the following paper: https://eprint.iacr.org/2019/856.pdf
Thanks in advance for your consideration of this request.
Dear friends,
Lets say I have this procedure here.
graph := proc(fn::anything, t::{integer, name}) if type(t, integer) then return fn; else return plot(fn, gridlines); end if; end proc
Currently it returns a function from input if I provide an addtional argument in integer form. And it provides the graph for the function if I include an extra argument of type name.
However I would like to do (if possible) is to using the same proc to make the parameter t optional instead. Meaning if type
graph(x^2)  then it only returns the input and if I type graph(x^2,g) then instead it returns the graph of the input function.
Is this possible to do? I have this paragraph in the help files https://www.maplesoft.com/support/help/Maple/view.aspx?path=parameter_classes#optional But I am not sure if thats the way to go?
Hope somebody has a hint/idea? Best regards
Hello everybody,
I am new to MaplePrimes, so I am sorry for possible bad formatting.
I am solving some physical problem in cylindrical coordinates, so the EDIT independent variables are r,phi,Z. The equations I obtain contain constants _C from dsolve and constant parameters aplha[i,j], for example
sin(phi)*_C1*alpha[3, 5] + cos(phi)*_C1*alpha[3, 4] = sin(phi)*_C11*alpha[1, 3] - cos(phi)*_C11*alpha[2, 3]
I would like to solve this type of equations for all values of the variables, namely phi in the example above.
If I do not choose the variables for which to solve, I get phi=phi as one of the equations in the solution. If i choose all the variables except phi, i get an the expression for the constants containing the variable phi.
Is there a way to solve these equations automatically or do I have to separate them manually using collect and coeffs?
Or could the solution be the comand Parameters from Physics package?
EDIT: I did not explain the problem properly. I am solving some complicated set of determining equations to obtain integrals of motion. They are rce in the attached file. I substitute some ansatz for the magnetic field and I solve them for
W(r), h_Z(r, phi, Z), h_phi(r, phi, Z), h_r(r, phi, Z), m(r, phi, Z), n_Z(r, phi, Z), n_phi(r, phi, Z), n_r(r, phi, Z), s_Z(r, phi, Z), s_phi(r, phi, Z), s_r(r, phi, Z), rho(r), sigma(r)
The first set of equation, called third in the file are solved by HOconds_polar_solved. This is where the  konstants alpha[i,j] appear. I substitute HOconds_polar_solved into the equations rce and try to solve them for the remaining functions.
Because it is an overdetermined system, I get some equations of the type in the original question or (for example)
8*r^5*_C1*((alpha[4, 4] - alpha[5, 5])*cos(2*phi) + sin(2*phi)*alpha[4, 5])=0
Because r and phi are the independent veriables of the system, the solution to the equation above should be
_C1=0 or (alpha[4,4]=alpha[5,5] and alpha[4,5]=0)
But I get the following.
solve(8*r^5*_C1*((alpha[4, 4] - alpha[5, 5])*cos(2*phi) + sin(2*phi)*alpha[4, 5]));
 {_C1 = 0, phi = phi, r = r, alpha[4, 4] = alpha[4, 4], alpha[4, 5] = alpha[4, 5], alpha[5, 5] = alpha[5,5]},
{_C1 = _C1, phi = phi, r = 0, alpha[4, 4] = alpha[4, 4],  alpha[4, 5] = alpha[4, 5], alpha[5, 5] = alpha[5, 5]},
 {_C1 = _C1, phi = phi, r = r, alpha[4, 4] = -tan(2 phi) alpha[4, 5] + alpha[5, 5], alpha[4, 5] = alpha[4, 5], alpha[5, 5] = alpha[5, 5]}
The file (part of the original file, which is very long): question.mw
EDIT 2: I changed the title to contain independent variables, which makes the answer more clear. The second Answer from Carl Love works fine, at least in the presented case.
   1 1 1 2 2 3 3
(  1 3 3 2 2 1 2 )
how to input this permutation into permgroup ?
Hi again friends. I simply can't get the command to work. My task is to dsolve the differential equation numerically, by using dsolve which has an option called numeric. I need to use the numeric and odeplot command to plot the numerical solution for f(t) for the timeinterval from 0 to 600 s.
So I searched and found this link: http://www.maplesoft.com/support/help/Maple/view.aspx?path=plots/odeplot
The example in the page was useful, I followed the steps, but I keep get this error-repport:
with(DiscreteTransforms);
Digits := 600;
ss := 1:
windowlength := 50:
ma := []:
me := []:
counter1 := 1:
Z := Vector(windowlength, datatype = complex[8]);
Z5 := []:
for i from windowlength+ss to 1+ss by -1 do
eq2 := x:
eq2a := x*2:
god := solve(eq2a=y, t);
ma := [op(ma), evalf(subs(t=100, eq2a))]:
me := [op(me), 100]:
Z[counter1] := [Complex(evalf(subs(t=100, eq2a)),0)];
counter1 := counter1 + 1:
Z2 := FourierTransform(Z);
Z5 := []:
for i from 1 to counter1 do
Z5 := [op(Z5),Re(Z2[i])]:
p := dualaxisplot(listplot(Z, color = red), listplot(me, color = blue), style = line, gridlines = false):
p3 := dualaxisplot(listplot(ma, color = red), listplot(me, color = blue), style = line, gridlines = false):
> Z[counter1] := [Complex(evalf(subs(t = 100, eq2a)), 0)];
Error, unable to evaluate expression to hardware floats: [0.1395407376854069872222364799062994087470140319577366200576294159849633469734297167456440703192248821030980068084453175485138428545865904609881858312543669285411895851509107873579430804484462212873775830538595858575740816705029437533106045686220745333574567547827085763824574616984653193169818770743931611305635956093618789559193701301264280264321394773730076308141252308187470580964653518965117431518571850910086488220847415724949651796448259541027929735646487459091205173804995401770417274097230705447077344465381061736283732438996738107330437055827420813951050981604075837450139995544638...
> Complex(evalf(subs(t=100, eq2a));
Error, unable to match delimiters
Typesetting:-mambiguous(Complexlparevalf(subs(tequals100comma eq2a)),
  Typesetting:-merror("unable to match delimiters"))
> Complex(evalf(subs(t = 100, eq2a)), 0);
1.395407376854069872222364799062994087470140319577366200576294159849633469734\
  297167456440703192248821030980068084453175485138428545865904609881858312543\
  669285411895851509107873579430804484462212873775830538595858575740816705029\
  437533106045686220745333574567547827085763824574616984653193169818770743931\
  611305635956093618789559193701301264280264321394773730076308141252308187470\
  580964653518965117431518571850910086488220847415724949651796448259541027929\
  735646487459091205173804995401770417274097230705447077344465381061736283732\
        -571
  43899673810733043705582742081395105098160407583745013999554463814123790354 10
   + 0. I
Who deleted www.mapleprimes.com/questions/228364-Graphics-Problem
and www.mapleprimes.com/posts/211539-Buggy-Lights
I thought I had alzheimers or something.  Who's deleting these posts and questions.  I realize they are similar but there is different information in there that was useful.  Why don't we delete all similar questions .. of course this would be horrible since some have slight differences - granted some don't have answers tagged on the end and are exact copies those are of course waranted and I would agree to be deleted becuase they were duplicates.
Please undelete those questions - there were referenses and extensive conversations in there that are not present in the saving question.
Hi everyone, I'm having a bit of trouble using the dsolve () command in maple, it keeps coming up with error messages.
My assignment is to find the first order differential equation of Tovn(t), and then I know that you have to define it and then dsolve the definition.
The problem is, that what am I doing wrong?
For example
input 3 lists
[1,2,3,4,5]
[0,5,2,3,7]
[7,5,2,3,2]
return [2,3],[5,2,3]
If I have a line on the form a*x+by+c = 0 which command do I use to rearrange it to y = m*x+b ?
Other than isolate
Many thanks in advance.
testing2.mw
P := 10; -1; r := .5; -1; c := 1; -1; Rb := proc (alpha) options operator, arrow; (1/2)*P+(1/2)*c+(1/2)*alpha*cos(alpha) end proc; -1; plot(Rb, 0 .. (1/2)*Pi); -1; sys1 := {beta > 0, beta = cot(beta), beta < (1/2)*Pi}; -1; p := solve({beta > 0, beta = cot(beta), beta < (1/2)*Pi}, {beta})
"p:="
sys := {x^2 = 9, x+y < 10}; -1; m := solve({x^2 = 9, x+y < 10}, {x, y})
{x = 3, y < 7}, {x = -3, y < 13}
Greetings!
I'm triying to solve this system in Maple:
  beta = cot(beta),
  0 < beta < (1/2)*Pi
But when I execute this statement
  p := solve({beta = cot(beta), beta>0, beta<(1/2)*Pi}, {beta})
the value of p in NULL.  Maple doesn't show any errors.
Edit: Example from the "solve" help article works as shown, that was my typo.
Could you please tell me, what am I doing wrong?
This is another problem I just found in Maple 2019.2 on windows 10. professional.
I wanted to close Maple, so did  File->Exit
But Maple did nothing. It did not close.  Also Alt-F4 did not close Maple. I had to click on the little X on top right corner of the open window to close Maple.
In earlier version this used to work to close Maple.
Do others see this as well?  To reproduce, simply start Maple, and do File->Exit.
Here is a movie also
I want to separate  the derivative and non-derivative (the part other than  derivative) terms from the following (shown in figure) equations by using maple commands or code. Kindly help me. Thanks in advance.
First 617 618 619 620 621 622 623 Last Page 619 of 2428
