D[1,2](1/x);
what does this mean?
How do I find where 𝑓(𝑥) = (2*𝑥 ^2) tan(2*𝑥), is discontinuous in the interval [0,2𝜋], and find the discontinuities. I know you need ot use the commands: discount(f(x),x), iscont(f(x),x=a..b,’open’), iscont(f(x),x=a..b,’close’) and fdiscont(f(x),x=a..b, resolution) which will help me find the list of ranges, each of width resolution, in which there appears to be a discontinuity in the function or its first derivative.However, what is next ?
Solve the following ODE for given initial conditions both analytically and numerically. Use the odeadvisor in DEtools package to classify the equations. Plot the explicit and numerical solutions in the range [0,20] using plot and odeplot commands. 𝑦 ′′(𝑡) + 16𝑦(𝑡) = 3 sin(𝜔 𝑡), for 𝜔 ∈ {1,4,5,8}, 𝑦(0) = 𝑦 ′ (0) = 0
I started by:
ode := diff(y(t), t, t) + 16*y(t) = 3*sin(w*t);
                  /  2      \
                  | d       |
           ode := |---- y(t)| + 16 y(t) = 3 sin(w t)
                  |   2     |
                  \ dt      /
odeadvisor(ode, y(t));
            [[_2nd_order, _linear, _nonhomogeneous]]
I undertsnad how to plot
but how do I odeplot and how do I contribute 𝜔 ∈ {1,4,5,8
. Let 𝑔(𝑥) = cos2 (𝑥 2+1) (sin𝑥+1) 2 and 𝑓(𝑥) = (2𝑥 2 − 1) 3√𝑥 + 2.
Write a procedure to return the tangent line of the function 𝑓(𝑥) at the given point 𝑥 ∈ 𝐷𝑓.
I started by writing a regular Proc template
such as
tangent line:=proc(y);
however i am unsure if I shpuld go forwrad with using an if loop or not?
What is the correct way to specify region where solution of a PDE is needed? For example, I am trying to verify my hand solution to this HW problem: Solve Poisson PDE in 2D
The above is the only information given in the textbook. So it is only in the upper half plane. If I type this
interface(showassumed=0);
pde := VectorCalculus:-Laplacian(u(x,y),[x,y])=-1/(1+y);
bc:=u(x,0)=0;
pdsolve([pde,bc],u(x,y)) assuming y>0
Maple gives
But I get by hand using method of images is
So not exactly the same. I think I made mistake in my solution. But I am also not sure that just saying "assuming y>0" is doing what I think it is supposed to do. For example, suppose we want to solve the same PDE say in the first quadrant. Typing
pdsolve([pde,bc],u(x,y)) assuming y>0,x>0
Gives same solution. But the solution should be different. And typing
Gives same answer as well.
So I think I need another way to tell Maple the region of the solution. i.e. I need to tell Maple to use the Laplacian for the upper half plane only and not the Laplacian in the whole 2D space.
Any suggestions what to do and how to handle such problems?
TangentLine(l, point(A, 0, 1), circle(c, [point(C, 0, 1), 1]))
Under geometry package if I use the command Tangentline, and if I want to change either the point of the circle, then
Error, (in geometry:-line) the first argument is expected of type name
How I make it overwrite l each time? So I don't have to rename the tangents each time?
When composing multiple plots, plots:-display's normal behavior is to set the overall plotting region to what is necessary to accommodate the union of the individual plots.  That works correctly most of the time but not in the case shown below.  This may indicate a bug in one of plots:-shadebetween,  plots:-display,  plottools:-extrude.  I have not been able to pinpoint the problem.  Any ideas?
Make a 3D plot:
plots:-shadebetween(x^2, 2-x^2, x=-1..1, color=red, transparency=0):
p1 := plottools:-extrude(%, 0..0.3);
Make another 3D plot:
plottools:-sphere([1.5,0,0], 1, color="Green"):
p2 := plots:-display(%);
Combine the plots:
plots:-display([p1,p2], scaling=constrained, style=surface);
We see that most of the green sphere has been cut off.  One way to fix things is
to add a view option (see below), but that wouldn't have been necessary if things
were working properly.
plots:-display([p1,p2], scaling=constrained, style=surface,
  view=[-1..3, DEFAULT, DEFAULT]);
This was done in Maple 2019.
Maple 2017 behaves the same way.  I don't know whether this ever worked properly in earlier Maples.
Download bug-in-3D-view.mw
Dear, I would like to kindly request your help with the following problem I have:
L:= [0, 3,0,7];
for i from 1 to 4 do
if L[i] > 0 then
x[i]:= [L[i]/2]
I need to write the elements x[i] as a list, however if I type x[i];  Maple just returns the last value of L[i]/2, namely 7/2. I do not know how to obtain the full list [3/2, 7/2]. What am I doing wrongly?
Many thanks in advance for your kind help.
Dear Friends,
Please help to generate the following matrix.
I get this warning when ever I create a function that uses a sum or sequence:
g := x->sum(...,j=1..5);
I'm pretty sure I used to not get it at all in previous versions, I just upgraded recently and started seeing it. Is there any way to disable it? It is polluting the worksheet. Sometimes I might have several local's and I want them to be implicitly local but I do not want 10 warning messages.
Hello;
What trick if any is needed to obtain zero for this sum in Maple?
sum(sin(Pi*n/2)*sin(n*Pi*(x + 1)/2)*cos(n*Pi*t/2),n=1..infinity)
The above sum, according to Mathematica is zero. I am trying to see if same result can be obtained by Maple in order to verify this result. It is possible ofcourse that Mathematica result is not correct. I am also trying to verify the sum is zero by hand, but no success so far.
mySum:=sum(sin(Pi*n/2)*sin(n*Pi*(x + 1)/2)*cos(n*Pi*t/2),n=1..infinity)
sum(sin((1/2)*Pi*n)*sin((1/2)*n*Pi*(x+1))*cos((1/2)*n*Pi*t), n = 1 .. infinity)
value(mySum)
simplify(mySum)
Here is Mathematica result
Using Maple 2019.2 on windows 10.
Download q2.mw
It is easy to draw all the types of arcs in plots. Hence a multiple plot may help under such situations. I attempted to draw for a few problems, but found it difficult. Can any one help in drawing the same to get neat and clean output drawings for me to explain the answer to students.
Find the area of the shaded portion (b) . (portion b not shaded)
Find the area of the shaded portion.
 Area b = Area (a+b) - Area a =    -     =
Find the radius of the circle.
 Mistake : It shd be 0.25 and not 4 times (x+...)
Find the height of the cone.
A circle with radius 1 is tangent to 2 points of the parabola y = x2   What is the area between the circle ana parabola?
Maple drawing shows all outer portions of circles.I used snipping tool to get cropped picture for first problem.
I already got a similar problem and got a response that i should use being forward and backward, but that seems to be not worth it many a times since figures become bigger in maple drawing with outer rectangles used for eliminating portions. (Ex: problem 1, not shown here)
Download GeometryProblems_Sketches_Problems.mw
a follow up question.
I am solving some overdetermined system of ODEs in cylindrical coordinates r,phi,Z. I obtain some equations of the following type:
(diff(_F1(phi, Z), phi)*r + diff(diff(s_r(phi, Z), phi), phi))/r = -s_r(phi, Z)/r
As can be seen, the differentiated functions do not depend on r, which is an independent variable. Thus, the correct solution is to separate the equation and have
_F1(phi,Z)=_F1(Z), s_r(phi,Z)=s_r(Z).
By using dsolve, I always obtain a solution containing r.
A similar problem that does no contain derivatives is solved by solve/identity.
Is there something similar for dsolve?
EDIT: I again put here more info and file. I solve some overdetermined system of differential equations.
[diff(s_r(r, phi, Z), r) = 0, diff(s_r(r, phi, Z), phi) = -diff(s_phi(r, phi, Z), r)*r^2,
diff(s_Z(r, phi, Z), r) = -diff(s_r(r, phi, Z), Z), diff(s_phi(r, phi, Z), phi) = -s_r(r, phi, Z)/r,
diff(s_Z(r, phi, Z), phi) = -diff(s_phi(r, phi, Z), Z)*r^2, diff(s_Z(r, phi, Z), Z) = 0,
diff(m(r, phi, Z), r) = s_Z(r, phi, Z)*B_phi(r, phi, Z) - s_phi(r, phi, Z)*B_Z(r, phi, Z),
 diff(m(r, phi, Z), phi) = s_r(r, phi, Z)*B_Z(r, phi, Z) - s_Z(r, phi, Z)*B_r(r, phi, Z),
 diff(m(r, phi, Z), Z) = s_phi(r, phi, Z)*B_r(r, phi, Z) - s_r(r, phi, Z)*B_phi(r, phi, Z),
s_r(r, phi, Z)*diff(W(r, phi, Z), r) + s_phi(r, phi, Z)*diff(W(r, phi, Z), phi) +
s_Z(r, phi, Z)*diff(W(r, phi, Z), Z) = 0]
After some time, I arrive at the equation in the original question. So the independance of the other functions on r is the consequence of the other equations.
Here is the file (shortened): mwquestion2.mw
Why is constants not an envvar or differently, why is there no envvar to declare constants?
We can see the context of  Matlab code in the Windows preview pane as follows, but we can' t see the context of Maple codes.
I wonder whether it is possible for Maple, too or not. Is there any method to achieve this? Because it really offers a great advantage for the fast browsing context of code in a folder that includes a lot of maple files.
(I use Maple 2019 and Windows 10)
First 616 617 618 619 620 621 622 Last Page 618 of 2428
