Dear friends,
Greetings.
How to get the second solution.
how to change the guess value in maple.
figure 1 plot in Matlab with two different initial guesses.
TWOSOLUTION.mw
I am writing a maths books using maple now. It is fantastic to use maple for writing books in maths.
 in the polynomial x^3-3*x^2-33*x+35 This line is not copying in full line!!
Step 1: Find the sum of all the coefficients in the polynomial x^3-3*x^2-33*x+35 This line is copying in full!!
"= 1-3-33+35 = 0"
                                                 r x-1is a factor  ; 1 is a root of the polynomial.
In the next row, I copy pasted the lines above
"= 1-3-33+35 = 0"
Can any one find the reason?
Download cannotCopyWhy.mw
I enclose a part of my document where in I made a particular line with text and maths formats combined.Then I made changes in the line. Now copy paste does work only for the later half (both text and maths formats). The corrected first part is not being copied.
How do I do the corrections properly so that copy paste is not a problem at laer stages.
Thanks for the answer.
Ramakrishnan V
The equation sin(9*x-(1/3)*Pi) = sin(7*x-(1/3)*Pi) can be solved easy by hand with solutions k*Pi and -Pi/48 + K*Pi/8. With Maple, I tried
solve({sin(9*x-(1/3)*Pi) = sin(7*x-(1/3)*Pi)}, x, explicit, allsolutions)
I don't get the above solutions. How can I get these solutions?
My problem is related to recovering orbits from invariant polynomials, and their ideal of relations.
The invariant polynomials I obtained are:
u = x2 - x y + y2,
v = 2 x6 - 6 x5 y + 15 x4 y2 - 20 x3 y3 + 15 x2 y4 - 6 x y5 +  2 y6 ,
w = x6 - 4 x5 y + 10 x4 y2 - 10 x3 y3 + 5 x2 y4 - 2 x y5 + y6 .
Using the logic from the Cox et al. book I got that the algebraic relation (ideal of relations) between the invariants, which is:
11 u6 - 10 u3 v + 3 (v2 - v w + w2) = 0
Then, using Reduce[] (exact symbolic solver which uses cylindrical algebraic decomposition) from Mathematica I solved for x and y under the assumption x > y > 0, u > 0, v > 0 and w > 0, but I got rather a complex solution.
My question is whether there is a way to try getting something more straightforward than the solution given by Mathematica.
I tried to use Maple's solve function, but it immediately stops without any result of an error message.
My input for Reduce is:
Reduce[{x2 - x y + y2 == u, 2 x6 - 6 x5 y + 15 x4 y2 - 20 x3 y3 + 15 x2 y4 - 6 x y5 + 2 y6 == v,  x6 - 4 x5 y + 10 x4 y2 - 10 x3 y3 + 5 x2 y4 - 2 x y5 + y6 == w, 11 u6 - 10 u3 v + 3 (v2 - v w + w2) == 0, x > y > 0, u > 0, v > 0, w > 0}, {x, y}, Complexes]
and my input for solve:
solve({u = x^2 - x*y + y^2, v = 2*x^6 - 6*x^5*y + 15*x^4*y^2 - 20*x^3*y^3 + 15*x^2*y^4 - 6*x*y^5 + 2*y^6, w = x^6 - 4*x^5*y + 10*x^4*y^2 - 10*x^3*y^3 + 5*x^2*y^4 - 2*x*y^5 + y^6, 11*u^6 - 10*u^3*v + 3*v^2 - 3*v*w + 3*w^2 = 0, 0 < u, 0 < v, 0 < w, 0 < x, 0 < y, y < x}, {x, y})
Do you know what I am doing wrong, or what else could I try?
I use patmatch to look for certain expression inside a larger expression.
I find sometimes I need to repeat the same code to check for  "... + ..."   and also ".... * .....", since I do not know to tell Maple to look for + or * in the same code. *Luckily, I do not have to check for "-" or "/" operators, since "+" match with "-" and "*" match with "/").
An example will make things more clear.
Suppose I want to see if sin(x)*sqrt(x*y) has sqrt(x*y) anywhere in it. So I first try
expr:= sin(x)*sqrt(x*y);
if patmatch(expr,a::anything+(b::anything*x*y)^(c::anything),'la') then
    assign(la);
    if c =1/2 or c=-1/2 then
       print("found sqrt(x*y)");
       print("did not find sqrt(x*y)");
    fi;
 fi;
And this fails, since I used "+" inside the patmatch. Then I try '*" instead
if patmatch(expr,a::anything*(b::anything*x*y)^(c::anything),'la') then
And now it does match.
What I'd like to write, is something like this (which ofcourse does not work)
if patmatch(expr,a::anything (* or +) (b::anything*x*y)^(c::anything),'la') then
I looked at conditional in patmatch, but it does not seem to apply for the above.
Any suggestions?
Maple 2019.1 on windows 10
Dear Users!
Hope everyone should fine here. I want to know how to multiple the entries of a matrix with a matrix like If A is matrix as:
A:= Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 2})
I want nonzero entries should multiply with m*m identity matrix and zero entries multiply with null matrix of order m*m. for m=2 the desired results i calculated manually as:
Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 2, (3, 4) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 2});
I want to know the general way. Thanks in advance
most people who post here seem to use .mw written in 2D, which I do not like to use.
Is there a tool to convert such a file to 1D worksheet that one can use from the command line before opening the document itself in Maple?
The reason I ask, sometimes opening the original file and trying to do this from inside Maple by selecting the code using the mouse, then  Format->ConvertTo->1D   does not work, and gives an error.
Also, sometimes, when I try to first create an empty worksheet document, and then try to copy/paste the code from the other document over, it also does not work. This happens when there are syntax errors in the original document. The error that comes up is
        Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
As an example, please see the attached file in the following question
https://www.mapleprimes.com/questions/227506--I-Need-Help-Trying-To-Write-A-Code
It will good to have a tool that converts such documents to 1D worksheet or even plain Maple code (.mpl) but I did not see such option under SAVE AS either. Also, when I tried to export it as .mpl file, I get the same error as above in the file. So I gave up.
Hello Anybody can help me to write codes for PDE to solve by Galerkin finite element method or any other methods can be able to gain results? parameter omega is unknown and should be determined.
I attached a pdf file for more .
Thanks so much
fem2
"restart:  rho:=7850:  E:=0.193e12:  n:=1:  AD:=10:  upsilon:=0.291:   mu:=E/(2*(1+upsilon)):  l:=0:  lambda:=E*upsilon/((1+upsilon)*(1-2*upsilon)):  R:=2.5:  ii:=2:  J:=2:       m:=1:       `u__theta`(r,theta,phi):= ( V(r,theta))*cos(m*phi):  `u__r`(r,theta,phi):= ( U(r,theta))*cos(m*phi): `u__phi`(r,theta,phi):= ( W(r,theta))*sin(m*phi):  :        eq1:=(r (R+r cos(theta))^2 (mu+lambda) (((&PartialD;)^2)/(&PartialD;r&PartialD;theta) `u__theta`(r,theta,phi))+2 r^2 (mu+lambda/2) (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;r^2) `u__r`(r,theta,phi))+r^2 (mu+lambda) (R+r cos(theta)) (((&PartialD;)^2)/(&PartialD;phi&PartialD;r) `u__phi`(r,theta,phi))+mu (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;theta^2) `u__r`(r,theta,phi))+(((&PartialD;)^2)/(&PartialD;phi^2) `u__r`(r,theta,phi)) mu r^2-3 (R+r cos(theta))^2 (mu+lambda/3) ((&PartialD;)/(&PartialD;theta) `u__theta`(r,theta,phi))+2 r (mu+lambda/2) (R+2 r cos(theta)) (R+r cos(theta)) ((&PartialD;)/(&PartialD;r) `u__r`(r,theta,phi))-r^2 sin(theta) (mu+lambda) (R+r cos(theta)) ((&PartialD;)/(&PartialD;r) `u__theta`(r,theta,phi))-3 r^2 cos(theta) (mu+lambda/3) ((&PartialD;)/(&PartialD;phi) `u__phi`(r,theta,phi))-r mu sin(theta) (R+r cos(theta)) ((&PartialD;)/(&PartialD;theta) `u__r`(r,theta,phi))-2 (mu+lambda/2) (2 (cos(theta))^2 r^2+2 cos(theta) R r+R^2) `u__r`(r,theta,phi)+r `u__theta`(r,theta,phi) sin(theta) (3 r (mu+lambda/3) cos(theta)+R mu))/(r^2 (R+r cos(theta))^2):  eq2:=(2 (mu+lambda/2) (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;theta^2) `u__theta`(r,theta,phi))+r (R+r cos(theta))^2 (mu+lambda) (((&PartialD;)^2)/(&PartialD;r&PartialD;theta) `u__r`(r,theta,phi))+r (mu+lambda) (R+r cos(theta)) (((&PartialD;)^2)/(&PartialD;phi&PartialD;theta) `u__phi`(r,theta,phi))+r^2 mu (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;r^2) `u__theta`(r,theta,phi))+(((&PartialD;)^2)/(&PartialD;phi^2) `u__theta`(r,theta,phi)) mu r^2+3 (R+r cos(theta)) ((4 r (mu+lambda/2) cos(theta))/3+R (mu+lambda/3)) ((&PartialD;)/(&PartialD;theta) `u__r`(r,theta,phi))-2 r (mu+lambda/2) sin(theta) (R+r cos(theta)) ((&PartialD;)/(&PartialD;theta) `u__theta`(r,theta,phi))+r mu (R+2 r cos(theta)) (R+r cos(theta)) ((&PartialD;)/(&PartialD;r) `u__theta`(r,theta,phi))+3 r^2 sin(theta) (mu+lambda/3) ((&PartialD;)/(&PartialD;phi) `u__phi`(r,theta,phi))+(-3 r R (mu+lambda/3) cos(theta)+(-lambda-2 mu) r^2-R^2 mu) `u__theta`(r,theta,phi)-2 r (mu+lambda/2) sin(theta) R `u__r`(r,theta,phi))/(r^2 (R+r cos(theta))^2):  eq3:=(r (mu+lambda) (R+r cos(theta)) (((&PartialD;)^2)/(&PartialD;phi&PartialD;theta) `u__theta`(r,theta,phi))+r^2 (mu+lambda) (R+r cos(theta)) (((&PartialD;)^2)/(&PartialD;phi&PartialD;r) `u__r`(r,theta,phi))+mu (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;theta^2) `u__phi`(r,theta,phi))+r (r mu (R+r cos(theta))^2 (((&PartialD;)^2)/(&PartialD;r^2) `u__phi`(r,theta,phi))+2 r (mu+lambda/2) (((&PartialD;)^2)/(&PartialD;phi^2) `u__phi`(r,theta,phi))+(4 r (mu+lambda/2) cos(theta)+R (mu+lambda)) ((&PartialD;)/(&PartialD;phi) `u__r`(r,theta,phi))+mu (R+2 r cos(theta)) (R+r cos(theta)) ((&PartialD;)/(&PartialD;r) `u__phi`(r,theta,phi))-mu sin(theta) (R+r cos(theta)) ((&PartialD;)/(&PartialD;theta) `u__phi`(r,theta,phi))-r (3 sin(theta) (mu+lambda/3) ((&PartialD;)/(&PartialD;phi) `u__theta`(r,theta,phi))+`u__phi`(r,theta,phi) mu)))/(r^2 (R+r cos(theta))^2):  "
EQ1 := collect(eq1, cos(m*phi))/cos(m*phi)+rho*omega^2; EQ2 := collect(eq2, cos(m*phi))/cos(m*phi)+rho*omega^2; EQ3 := collect(eq3, sin(m*phi))/sin(m*phi)+rho*omega^2
(0.1788235818e12*r*(2.5+r*cos(theta))^2*(diff(diff(V(r, theta), r), theta))+0.2535718390e12*r^2*(2.5+r*cos(theta))^2*(diff(diff(U(r, theta), r), r))+0.1788235818e12*r^2*(2.5+r*cos(theta))*(diff(W(r, theta), r))+0.7474825716e11*(2.5+r*cos(theta))^2*(diff(diff(U(r, theta), theta), theta))-0.7474825716e11*U(r, theta)*r^2-0.3283200960e12*(2.5+r*cos(theta))^2*(diff(V(r, theta), theta))+0.2535718390e12*r*(2.5+2.*r*cos(theta))*(2.5+r*cos(theta))*(diff(U(r, theta), r))-0.1788235818e12*r^2*sin(theta)*(2.5+r*cos(theta))*(diff(V(r, theta), r))-0.3283200960e12*r^2*cos(theta)*W(r, theta)-0.7474825716e11*r*sin(theta)*(2.5+r*cos(theta))*(diff(U(r, theta), theta))-0.2535718390e12*(2.*cos(theta)^2*r^2+5.0*r*cos(theta)+6.25)*U(r, theta)+r*V(r, theta)*sin(theta)*(0.3283200960e12*r*cos(theta)+0.1868706429e12))/(r^2*(2.5+r*cos(theta))^2)+7850*omega^2
(0.2535718390e12*(2.5+r*cos(theta))^2*(diff(diff(V(r, theta), theta), theta))+0.1788235818e12*r*(2.5+r*cos(theta))^2*(diff(diff(U(r, theta), r), theta))+0.1788235818e12*r*(2.5+r*cos(theta))*(diff(W(r, theta), theta))+0.7474825716e11*r^2*(2.5+r*cos(theta))^2*(diff(diff(V(r, theta), r), r))-0.7474825716e11*V(r, theta)*r^2+3.*(2.5+r*cos(theta))*(0.1690478927e12*r*cos(theta)+0.2736000800e12)*(diff(U(r, theta), theta))-0.2535718390e12*r*sin(theta)*(2.5+r*cos(theta))*(diff(V(r, theta), theta))+0.7474825716e11*r*(2.5+2.*r*cos(theta))*(2.5+r*cos(theta))*(diff(V(r, theta), r))+0.3283200960e12*r^2*sin(theta)*W(r, theta)+(-0.8208002400e12*r*cos(theta)-0.2535718389e12*r^2-0.4671766072e12)*V(r, theta)-0.6339295976e12*r*sin(theta)*U(r, theta))/(r^2*(2.5+r*cos(theta))^2)+7850*omega^2
(-0.1788235818e12*r*(2.5+r*cos(theta))*(diff(V(r, theta), theta))-0.1788235818e12*r^2*(2.5+r*cos(theta))*(diff(U(r, theta), r))+0.7474825716e11*(2.5+r*cos(theta))^2*(diff(diff(W(r, theta), theta), theta))+r*(0.7474825716e11*r*(2.5+r*cos(theta))^2*(diff(diff(W(r, theta), r), r))-0.2535718390e12*r*W(r, theta)-1.*(0.5071436780e12*r*cos(theta)+0.4470589545e12)*U(r, theta)+0.7474825716e11*(2.5+2.*r*cos(theta))*(2.5+r*cos(theta))*(diff(W(r, theta), r))-0.7474825716e11*sin(theta)*(2.5+r*cos(theta))*(diff(W(r, theta), theta))-1.*r*(-0.3283200960e12*sin(theta)*V(r, theta)+0.7474825716e11*W(r, theta))))/(r^2*(2.5+r*cos(theta))^2)+7850*omega^2
#BCs can be from following
U(0, theta) = 0, (D[1](U))(0, theta) = 0, U(1, theta) = 0, (D[1](U))(1, theta) = 0
V(0, theta) = 0, (D[1](V))(0, theta) = 0, V(1, theta) = 0, (D[1](V))(1, theta) = 0
W(0, theta) = 0, (D[1](W))(0, theta) = 0, W(1, theta) = 0, (D[1](W))(1, theta) = 0
Download fem2
buchanan2005.pdf
I found this strange result:
When the central moment of order 2 and the variance are assessed on a sample of a random variable, they don't return the same value.
Let S be the sample, N its size and M its empirical mean.  The difference comes from the fact that
  • Variance(S)               = add( (S[n]-M)^2, n=1..N) / (N-1)
  • CentralMoment(S, 2) = add( (S[n]-M)^2, n=1..N) / N
By definition the variance of a random variable X is its 2nd order central moment.
This definition should also apply when these statistics are calculated on a sample of X.
It seems to me this is a mistake.
with(Statistics):
N := 100:
# Example 1
U := RandomVariable(BetaDistribution(3, 2)):
CentralMoment(U, 2, numeric);
Variance(U, numeric);
print():
S := Sample(U, N):
CentralMoment(S, 2);
Variance(S);
0.4000000000e-1
0.4000000000e-1
HFloat(0.05053851854005207)
HFloat(0.05104900862631522)
# Example 2
V := RandomVariable(Normal(3, 2)):
CentralMoment(V, 2, numeric);
Variance(V, numeric);
print():
S := Sample(V, N):
Variance(S)
4.
4.
HFloat(3.7514118336684517)
HFloat(3.7893048824933824)
# Examples revisited
S := Sample(U, N):
Variance(S)*(N-1)/N;
print():
S := Sample(V, N):
Variance(S)*(N-1)/N
HFloat(0.03346262243902275)
HFloat(0.03346262243902278)
HFloat(4.159851396769612)
Download StrangerThings.mw
Hello. Let's say I have a set A1 in which there are nested sets {5,6},{8,9}. How can I get A2 from A1? Expand nested sets so that all elements are in the same set
The eval command doesn't work on random variables.
For instance:
with(Statistics):
X := RandomVariable(Normal(mu, sigma)):
Y := eval(X, mu=1);
Mean(Y); # returns mu
I once found a Maple command whose syntax is the same as eval's and acts as eval
Y := COMMAND(X, mu=1)
Mean(Y); # returns 1
Could someone remind me of its name?
How can i plot a probability function such as cos(x-y)*cos(y-z)*cos^3(x-2z)=0.6 where
x=0..5, y=0..x, z=0..y.
please guide me.
When you declare a random variable X  by writting X := Statistics:-RandomVariable(...) Maple associates to the name X an "object" dubbed _R.
My question is very simple: is it possible to recover the definition of X from the "object" _R?
To illustrate, suppose I've written
> X := Statistics:-RandomVariable(Normal(0, 1)) ;
       _R
I would like to extract the information "_R represents a random variable Normal(0, 1)" from _R
Dear Maple users,
I am progressing, but one last hitch, see below. A want the invariants of the PDE below. However, the final expression is too general to be useful. I would like to insert specific values for F1(R), F2(R), F3(R), and F4(R):
F3=F4=0; and F2=1, and F3(R)=aR, where a is a constant. R is one of my independent variables (the Reynolds number).
I would like to do this at the step where the Infinitiesimals are generated by
infinies := Infinitesimals(PDE)
For example, the first entry would then be, infinies:=[ _xi[y](y, R, l, u) = y, ... ]. Then Invariants should give me much simplified expressions which I need.  How can i do this?
Nadeem
with(PDEtools)
declare(u(y, R))
` u`(y, R)*`will now be displayed as`*u
declare(l(y, R))
` l`(y, R)*`will now be displayed as`*l
L := diff_table(l(y, R))
table( [(  ) = l(y, R) ] )
NULL``
U := diff_table(u(y, R))
table( [(  ) = u(y, R) ] )
DepVars := ([l, u])(y, R)
[l(y, R), u(y, R)]
PDE := U[y, y]+2*l(y, R)^2*U[y]*U[y, y]+2*l(y, R)*L[y]*U[y]^2+1/R = 0
diff(diff(u(y, R), y), y)+2*l(y, R)^2*(diff(u(y, R), y))*(diff(diff(u(y, R), y), y))+2*l(y, R)*(diff(l(y, R), y))*(diff(u(y, R), y))^2+1/R = 0
[_xi[y](y, R, l, u) = _F2(R)*y+_F3(R), _xi[R](y, R, l, u) = _F1(R), _eta[l](y, R, l, u) = (1/2)*l*(-R*_F2(R)+_F1(R))/R, _eta[u](y, R, l, u) = (2*R*_F2(R)-_F1(R))*u/R+_F4(R)]
InfinitesimalGenerator(infinies, DepVars, prolongation = 1)
proc (f) options operator, arrow; add(xi[x[j]]*(diff(f, x[j])), j = 1 .. 2)+add(eta[u[m]]*(diff(f, u[m]))+eta[u[m], [y]]*(diff(f, u[m][y]))+eta[u[m], [R]]*(diff(f, u[m][R])), m = 1 .. 2) end proc
Phi := Invariants(infinies, DepVars)
l*exp(-(1/2)*(Int((-R*_F2(R)+_F1(R))/(R*_F1(R)), R))), -(Int(_F3(R)*exp(-(Int(_F2(R)/_F1(R), R)))/_F1(R), R))+y*exp(-(Int(_F2(R)/_F1(R), R))), u*exp(Int((-2*R*_F2(R)+_F1(R))/(R*_F1(R)), R))-(Int(_F4(R)*exp(Int((-2*R*_F2(R)+_F1(R))/(R*_F1(R)), R))/_F1(R), R)), u[y]*exp(Int((-R*_F2(R)+_F1(R))/(R*_F1(R)), R)), l[y]*exp(-(1/2)*(Int((-3*R*_F2(R)+_F1(R))/(R*_F1(R)), R))), (1/2)*Intat(-exp((1/2)*(Int((2*(diff(_F1(_j), _j))*_j+_j*_F2(_j)-_F1(_j))/(_j*_F1(_j)), _j)))*(-2*(diff(_F2(_j), _j))*_j^2*l[y]*(y*exp(-(Int(_F2(R)/_F1(R), R)))-(Int(_F3(R)*exp(-(Int(_F2(R)/_F1(R), R)))/_F1(R), R))+Int(_F3(_j)*exp(-(Int(_F2(_j)/_F1(_j), _j)))/_F1(_j), _j))*exp(Int(_F2(_j)/_F1(_j), _j)+(1/2)*(Int((-3*_j*_F2(_j)+_F1(_j))/(_j*_F1(_j)), _j))-(1/2)*(Int((-3*R*_F2(R)+_F1(R))/(R*_F1(R)), R)))+l*(-(diff(_F2(_j), _j))*_j^2+(diff(_F1(_j), _j))*_j-_F1(_j))*exp((1/2)*(Int((-_j*_F2(_j)+_F1(_j))/(_j*_F1(_j)), _j))-(1/2)*(Int((-R*_F2(R)+_F1(R))/(R*_F1(R)), R)))-2*(diff(_F3(_j), _j))*l[y]*_j^2*exp((1/2)*(Int((-3*_j*_F2(_j)+_F1(_j))/(_j*_F1(_j)), _j))-(1/2)*(Int((-3*R*_F2(R)+_F1(R))/(R*_F1(R)), R))))/(_j^2*_F1(_j)), _j = R)+l[R]*exp((1/2)*(Int((2*(diff(_F1(R), R))*R+R*_F2(R)-_F1(R))/(R*_F1(R)), R))), u[R]*exp(Int(((diff(_F1(R), R))*R-2*R*_F2(R)+_F1(R))/(R*_F1(R)), R))+Intat(-exp(Int(((diff(_F1(_k), _k))*_k-2*_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k)-(Int((-_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k))-(Int((-2*_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k)))*(-(diff(_F2(_k), _k))*_k^2*u[y]*(y*exp(-(Int(_F2(R)/_F1(R), R)))-(Int(_F3(R)*exp(-(Int(_F2(R)/_F1(R), R)))/_F1(R), R))+Int(_F3(_k)*exp(-(Int(_F2(_k)/_F1(_k), _k)))/_F1(_k), _k))*exp(Int(_F2(_k)/_F1(_k), _k)+Int((-2*_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k)+Int((-R*_F2(R)+_F1(R))/(R*_F1(R)), R))+(diff(_F4(_k), _k))*exp(Int((-_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k)+Int((-2*_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k))*_k^2-_k^2*u[y]*(diff(_F3(_k), _k))*exp(Int((-2*_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k)+Int((-R*_F2(R)+_F1(R))/(R*_F1(R)), R))+exp(Int((-_k*_F2(_k)+_F1(_k))/(_k*_F1(_k)), _k))*(u*exp(Int((-2*R*_F2(R)+_F1(R))/(R*_F1(R)), R))-(Int(_F4(R)*exp(Int((-2*R*_F2(R)+_F1(R))/(R*_F1(R)), R))/_F1(R), R))+Int(_F4(_k)*exp(-(Int((2*_k*_F2(_k)-_F1(_k))/(_k*_F1(_k)), _k)))/_F1(_k), _k))*(2*(diff(_F2(_k), _k))*_k^2-(diff(_F1(_k), _k))*_k+_F1(_k)))/(_k^2*_F1(_k)), _k = R)
First 696 697 698 699 700 701 702 Last Page 698 of 2459
