Could you explain me where the third output comes from?
print~([a, b]);
   a
   b
How I can perform integration by parts, with respect to the x[0..1],y[0..1],t
PART.mw
U := (1/2)*(E*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)/(-upsilon^2+1)+E*upsilon*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)/(-upsilon^2+1))*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)+(1/2)*(E*upsilon*(diff(u(x, y), x)-z*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), x))^2)/(-upsilon^2+1)+E*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)/(-upsilon^2+1))*(diff(v(x, y), y)-z*(diff(w(x, y), y, y))+(1/2)*(diff(w(x, y), y))^2)+E*(1-upsilon)*((1/2)*(diff(v(x, y), x))-z*(diff(w(x, y), x, y))+(1/2)*(diff(u(x, y), y))+(1/2)*(diff(w(x, y), x))*(diff(w(x, y), y)))^2/(-upsilon^2+1)+2*E*l^2*(diff(w(x, y), x, y))^2/(2+2*upsilon)+2*E*l^2*(-(1/2)*(diff(w(x, y), x, x))+(1/2)*(diff(w(x, y), y, y)))^2/(2+2*upsilon)+2*E*l^2*((1/4)*(diff(v(x, y), x, x))-(1/4)*(diff(u(x, y), x, y)))^2/(2+2*upsilon)+2*E*l^2*((1/4)*(diff(v(x, y), x, y))-(1/4)*(diff(u(x, y), y, y)))^2/(2+2*upsilon)
with(IntegrationTools)
Download PART.mw
I cannot thank you enough for the help.
I figure that there is a way to write a bunch of lines on a DE plot using some sort of command? I figure that it has to do with the sequence feature of maple.  What I am trying to do is show a bunch of lines in a DE plot that does y(n)=-1 where n is an integer ranging from -5 to 5.  I'll link my worksheet. Differential_Equation_slope_field.mw
     I have a large module of procedures. A procedure thet I know takes a long time to execute the result. I would like to know at what stage of the procedure the calculation takes time.
 1)  Copy/paste problem .
 Looks like Maple is not able to copy/paste the output
 from a summation command . Look at my example .
 I have to use the  " lprint " command .
2)   Mysterious small box character .
 Suppose I want to edit a command . I want to replace a character with a left bracket
 (or right bracket or left accolade but strangely not the right accolade).
 I put the cursor on the character and type the left bracket (or right...) .
 The left bracket ( or right ...)  is inserted . Now when I try to delete the character,
 a small box appear . The  character I am trying to delete is shifting to the right .
  Like  I said , just a little annoying .
3)  Open file problem .
 The first file I open in Maple with the  ctrl-o command , the "open file window" appears in
  the center of the screen . All the others files I am opening , the "open file window"  show up
  in the bottom left corner , top center or top right corner ... randomly .
  Very annoying on a 27" screen . For this last one ,I am not shure  if it is a Maple 2018 problem
   or a Windows 10 64 bits problem . I have few programs in my computer .
  When I use Microsoft Paint or Wordpad ,I don't see this problem .
  I don't know if somebody else can confirm those annoying things . If I am not the only one
  then I am hoping the next updates or versions will fix that .
    Thanks !
Here is the code I've wrote for third order polynomial .
I want to extend it for 100th order polynomial without writing the somehow same things 100 times !
what should I do ?
( I've done same thing in PHP with sprintf , there we could define variables like x{i} = ... , and so we could make a lot of variable with a for loop )
Thanks in advance .
Here is the code in *.mw format :
Test1.mw
with(plottools):with(plots): display(seq(seq(display(polygon([[i,j],[i,j+1],[i+1,j+1],[i+1,j]], color=`if``((j)::odd,ColorTools:-Color=magenta))), textplot([1+.5,j+.5,fprintf("%d",i*j)])),i=1..10), j=1..10),axes=none);
Hello Maple experts:
Using Maple 2018.2.1 on windows, with Physics package version 301.
There is some strange issue in parsing somewhere.  This works
r:='r'; u:='u'; t:='t';theta:='theta';k:='k';
k:=1/25;
pde := diff(u(r,theta,t),t)=k*(diff(u(r,theta,t),r$2) + 1/r*diff(u(r,theta,t),r)+1/r^2*diff(u(r,theta,t),theta$2));
bc1:= eval(diff(u(r,theta,t),r),r=1)=0;
bc2:= u(r,0,t)=0, u(r,Pi,t)=0;
ic := u(r,theta,0)=(r-1/3*r^3)*sin(theta);
sol:=pdsolve([pde, bc1, bc2, ic], u(r, theta, t),HINT = boundedseries(r = [0]));
No problem with the above, pdsolve gives solution. Now if I change k from 1/25 to 1, it gives parsing error in map
k:=1;
sol := pdsolve([pde, bc1, bc2, ic], u(r, theta, t),HINT = boundedseries(r = [0]));
Error, (in assuming) invalid input: map expects 2 or more arguments, but received 1
any K value less than one works.
Now I change K from 1 to 2, the error goes away. But no solution. Which is OK.
Why does the map error shows up when k=1 only? Same error shows up if K is missing all togother, as in
pde := diff(u(r,theta,t),t)=diff(u(r,theta,t),r$2) + 1/r*diff(u(r,theta,t),r)+1/r^2*diff(u(r,theta,t),theta$2);
I want to create a Heaviside function called MyStep() which will behave exactly like the built in Heaviside with one exception: for MyStep(0) it will return 1 instead of undefined.
MyStep(t) = 0, 0<t
MyStep(t) = 1, else
I got an square matrix (70×70) from MATLAB (please download attached text file 1.txt). Following codes are used in MAPLE, but an unknown error is occurred. It seems that matrix is divided in two submatrices. Please hint me or run the codes to obtain fiirst three minimum real positive roots of the determinant.
Thank you for taking your time
Maple codes
Digits:=150:
M:=parse(FileTools[Text][ReadFile]("1.txt")):
LinearAlgebra:-Determinant(M):
fsolve(%,P=0..0.5)*100;
Good morning everyone
I'm sorry if I'm asking a simple question, but I would like to create a maplet from a maple code I written.
My first problem is I would like to now how to create a table like in excel, to be fill up by the user of the maplet.
Basically, the maplet will consist of enter two parameters who define the number of colums and row needed for the table,
Then fill up this table, which gonna be plot, and then a button to fit this curve using an equation. And the starting value in order to fit the curve will also be set up by the user.
Thanks you in advance if you can help me to set up this table in the maplet.
cheers!
in Maple 2017 (could not try 2018) the following is a bug;
with(LinearAlgebra);
U:= Matrix(4,4, shape=triangular[upper, unit], symbol =u);
-U;
It returns the wrong matrix, with +1 on the diagonal and -u_{ij} on the upper part. That is, it changes the sign only of the entries in the upper part. The bug is for any size, and also for lower triangular.
I have been trying to use fsolve to iteratively solve a free convection heat transfer problem for a heated vertical plate using units and the ThermoPhysicalData library.  I have received some help and have managed to get rid of the eror messages but I still can't seem to get it to solve.
Here is the code
with(Units:-Standard); with(ThermophysicalData);
conv_VerticalPlate_proc := proc (T__side, T__amb, Area, L, varepsilon, q__i)
  local sigma, g, T__s, `T__&infin;`, T__f, k, rho, Cp, Pr, mu, nu, alpha, beta, Ra__L, Nus__L, h, q__h, q__r, q__total;
  g := 9.81*Unit('m'/'s'^2); sigma := 5.6703*Unit('W'/('m'^2*'K'^4))/10^8;
  if type(T__side, with_unit) then
    T__s := convert(T__side, temperature, kelvin)
  elif T__side = 0 then
    T__s := 273.15*Unit('K')
    T__s := T__side*Unit('K')
  if type(T__amb, with_unit) then
    'T__&infin;` := convert(T__amb, temperature, kelvin)
  elif T__amb = 0 then
    'T__&infin;` := 273.15*Unit('K')
    `T__&infin;` := T__amb*Unit('K')
  T__f := (1/2)*T__s+(1/2)*`T__&infin;`;
  k := Property(thermal_conductivity, temperature = T__f, pressure = Unit('atm'), air);
  rho := Property(density, temperature = T__f, pressure = Unit('atm'), air);
  Cp := Property(Cpmass, temperature = T__f, pressure = Unit('atm'), air);
  Pr := Property(prandtl, temperature = T__f, pressure = Unit('atm'), air);
  mu := Property(viscosity, temperature = T__f, pressure = Unit('atm'), air);
  if type(k, with_unit) and type(rho, with_unit) and type(Cp, with_unit) and type(mu, has_unit) then
    nu := mu/rho;
    alpha := k/(rho*Cp);
    beta := 1.0/T__f;
    Ra__L := g*beta*abs(T__s-`T__&infin;`)*L^3/(alpha*nu);
    Nus__L := (.825+.387*(Ra__L^(1/6))/(((1+(.492/Pr)^(9/16))^(8/27))))^2;
    h := Nus__L*k/L; q__h := h*(T__s-`T__&infin;`)*Area;
    q__r := varepsilon*sigma*(T__s^4-`T__&infin;`^4)*Area;
    q__total := q__h+q__r
    0.1e-6*Unit('W')
  end if
conv_VerticalPlate_proc(31.5*Unit('degC'), 20*Unit('degC'), Unit('m'^2), Unit('m'), .9);
                      100.8567010 Unit(W)
conv_VerticalPlate_proc(x*Unit('degC'), 20*Unit('degC'), Unit('m'^2), Unit('m'), .9);
                         0.001 Unit(W)
fsolve(100*Unit('W')-conv_VerticalPlate_proc(x, 20*Unit('degC'), Unit('m'^2), Unit('m'), .9), x = Unit('degC') .. 100*Unit('degC'));
I would appreciate help wih this.
For example if a:=[3,3,1,5,7,8,5,4,4,4,4,3,9]
What is the simplest way, or alternate ways, to remove only one 4 for example from the dataset.
model.mw
after loop how to pick equations automatically solve system of equations???
First 718 719 720 721 722 723 724 Last Page 720 of 2428
