with(Student:-Basics); simplify((b - 1)/(b + 2 - (b^2 + 2)/(b - (b - 2)/(b + 1)))); b - 1 This is correct, but I want to see the step-by-step solution. P.D. I try the ExpandSteps command already but the result doesn't give me the solution. Please, help me. Thanks in advance
Is there an option or a tool to know if maple is trying to finish the calculation or if it is in a bucle?
Is there a Maple function that given a group gives its name?
In a calculation I am encountering expressions of the following kind:
-.27059805007310*sin(.12+epsilon)+.27059805007310*sqrt(1.-cos(.12+epsilon)^2)
As is known, for epsilon < Pi-0.12, the two terms are equal but opposite in sign and the result should be zero (ok, maybe a few 1E-15 for round-off). But for the heck of it I cannot get Maple to simplify this with the assumption e.g. epsilon < 0.1.
This can probably be simplified by squaring the two terms and then subtracting them, but that can possibly lead to other "interesting" effects and besides is a bit cumbersome.
Has anybody found a good way of  doing this?
M.D.
How to build a library (package) containing my own procedures ? Could you give me an example. Thank you.
I've written a Mapleflow document that is supposed to use a microphone array to find the intersection of three equations to locate the source of a gunshot.  But the calculation is "Evaluating," and has been for half an hour.  How do I interrupt the calculation?
I'd up load the file, but
So:
Not_evaluating_theta.mw
When I tried to explain to a student how to set it up, it stopped working.  I tried changing the order, but got the same result. I tried using "t" instead of theta, but got the same result. Please help.
I am trying to simplify a large expression using simplify(), but it takes too long and I eventually run out of processing power after a few days. Is there any way I could get similar results with an alternative function?
Any help is appreciated.
I am doing some work on differential equations, and I am checking the solutions.  Whether the solution is correct or not depends on whether or not a real number plus zero*i is a real number or an imaginary number.  I want to test how maple handles this by plotting sin(x)i.
This is intended to be a complex plot.  I am expecting a series of points along the real axis where sin(x) is zero.  Can anyone help me with this?
Hi.
I have to make a picture Polynomiograph from metrics such as
m:= Matrix([[1, 2, 3], [4, 5, 6]])
By assigning each number a color as follows.
1 = aquamarine
2 = blue
3 = brown
4 = coral
5 = cyan
6 = black
How should I write the code?
i m looking for procedure ( or command) in Maple language to calculate the principal measure of my angle Ra ?
Thanks a lot for ideas
PrincipalMeasure.mw
Maple 2021.1 screen shot: property box too small to select properties
how it should look like
How do I get it back to normal?
I am using the RandomGraph() command from the GraphTheory[RandomGraphs] package to generate many random graphs of certain order (n) and size. The default labeling for vertices is based on the set {1,2,3,4,...n}. Is there a way to change the default labeling so that the vertices are labeled {v1, v2,...,vn}? I know how define the vertex labels for a predetermined graph, but I'm looking for a way to automatically apply these labels to a randomly generated graph. Thanks!
i have two equations;i.g eq1 and eq2. i want to factor psi(x,t) in eq2 using linear differential operators and substitute it in equation 1. could anyone help?
restart:with(DEtools):
eq1:=E*D(II)(x)*D[1](psi)(x,t)+E*II(x)*(D[1]@@2)(psi)(x,t)-G*A(x)*psi(x,t)+G*A(x)*D[1](v)(x,t)
E*(D(II))(x)*(D[1](psi))(x, t)+E*II(x)*(D[1, 1](psi))(x, t)-G*A(x)*psi(x, t)+G*A(x)*(D[1](v))(x, t)
convert(eq1,diff)
E*(diff(II(x), x))*(diff(psi(x, t), x))+E*II(x)*(diff(diff(psi(x, t), x), x))-G*A(x)*psi(x, t)+G*A(x)*(diff(v(x, t), x))
eq2:=-(G*D[1](A)(x)*psi(x,t)+G*A(x)*D[1](psi)(x,t))+(G*D[1](A)(x)*v(x,t))+G*A(x)*(D[1]@@2)(v)(x,t)-m(x)/G*D[2](v)(x,t)
-G*(D(A))(x)*psi(x, t)-G*A(x)*(D[1](psi))(x, t)+G*(D(A))(x)*v(x, t)+G*A(x)*(D[1, 1](v))(x, t)-m(x)*(D[2](v))(x, t)/G
convert(%,diff)
-G*(diff(A(x), x))*psi(x, t)-G*A(x)*(diff(psi(x, t), x))+G*(diff(A(x), x))*v(x, t)+G*A(x)*(diff(diff(v(x, t), x), x))-m(x)*(diff(v(x, t), t))/G
isolate(convert(eq2,diff),psi)
psi = (proc (x, t) options operator, arrow; -(G^2*A(x)*(diff(psi(x, t), x))-G^2*(diff(A(x), x))*v(x, t)-G^2*A(x)*(diff(diff(v(x, t), x), x))+m(x)*(diff(v(x, t), t)))/(G^2*(diff(A(x), x))) end proc)
eval(eq1,psi(x,t)=rhs((isolate(eq2,psi))(x,t))):convert(%,diff)
E*(diff(II(x), x))*(diff(psi(x, t), x))+E*II(x)*(diff(diff(psi(x, t), x), x))+A(x)*(G^2*A(x)*(diff(_XX(x, t), x))-G^2*A(x)*(diff(diff(v(x, t), x), x))-G^2*(diff(A(x), x))*v(x, t)+m(x)*(diff(v(x, t), t)))/(G*(diff(A(x), x)))+G*A(x)*(diff(v(x, t), x))
Download Dd.mw
I m looking for a simple way to generate random integers ( with step excuding 0) instead of through Maple TA package ( see my file) ?
Ideas? Thanks
RandomIntegerSteps.mw
First 410 411 412 413 414 415 416 Last Page 412 of 2458
