When asking dsolve to use specific ode type to solve an ode, in particular, dAlembert type, which typically generate complicated solutions, sometimes dsolve solution shows up using parameter T.
But odetest gets confused by this expression it seems. I am not able to figure if I am doing something wrong in using odetest, or may be odetest does not know how to handle such form of a solution.
Here is an example. This ode
is of these types:
ode:=diff(y(x), x) = (y(x)^3 + 2*x*y(x)^2 + x^2*y(x) + x^3)/(x*(y(x) + x)^2);
DEtools:-odeadvisor(ode);
By default, dsolve was smart to use homogeneous type to solve the ODE, as this gives the simplest solution.
One can force dsolve to use the other types. When using dAlembert, odetest gives an error trying to verify any one of the solutions returned from dsolve due to the way the solution is returned. Here is the result
sol:=[dsolve(ode,y(x),[homogeneous])];
No problem here for odetest. it can verify any of the above 3 solutions with no error generated.
odetest(sol[1],ode)
Lets compare using dAlembert type
sol:=[dsolve(ode,y(x),[dAlembert])]: #solution too complicated to show here
odetest(sol[1],ode)
It looks like odetest does not know how to handle the form of the solution as returned by dsolve for this case. The problem is that each solution is actually made up of two parts, not just y(x) as normally is the case. One part defines something called X(T_) and the next part which is the solution y(x) uses this X(T) in it.
Did I do something wrong, or is there a way around this, or is this by design?
Maple 2020.2
a^(5/2)*s^2*(D(f))(eta)^2*sqrt(nu)/(R*sqrt(a)*sqrt(nu)+eta*nu) = a^(5/2)*s^2*(D(P(s, eta*sqrt(nu)/sqrt(a))))(eta)/sqrt(nu)
Is it possible to rearrange the above equation for D(P)(eta)
Hi, i'm new on this site. I want to know how to set an output un-scientific number but we can set the number of digit "after comma" as we want?
The best i can do is using this:
printf("%f\n",something)
So, for example i want to calculate
123456789/123
It gives me:
1003713.732000 (only gives 6 digits after comma)
I don't want the output looks like this:
But, for example i want the result has 9 digits after comma and gives me:
1003713.731707317
How to do this? Please help me. Thanks.
I should solve the diffusivity equation using Maple. The equation and BSc are as follow:
pde := W*diff(C(z, t), z $ 2) - diff(C(z, t), t $ 1) = 0
bc[1] := C(x, 0) = 0;
bc[2] := D[1](f)(0, t) = VMK*D[1](f)(t)/ZRTWA;
bc[3] := C(infinity, t) = 0;
The equation should be solved using Laplace method. Can anyone please help me ?
I will appreciate your insightful comments.
using the Physics package version:
  The "Physics Updates" version in the MapleCloud is 899 and is the same as the version installed in this computer, created 2021, January 2, 19:51 hours Pacific Time.
I end up with:
Latex:-Settings(useimaginaryunit=i,
      usecolor = false,
      powersoftrigonometricfunctions= computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false
resluting in an error:
Error, module does not export `ModuleApply`
Maybe some changes in the interface in the latest version?
Hello there,
First of all, happy new year to you and those around you!
One question: would you teach me how to replace the 'Zs/Z_AB' expression in the last term of the expression 'eq_5_m5'?
In other words, I wanted to see the 'desired' expression, but the 'subs()' command repalced the first occurance of the 'Zs/Z_AB' expression.
(Perhaps, this applet behind of this edit box does not like the Microsoft Edge browser)
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Q20210103.mw .
Download Q20210103.mw
here is my try
for ploting points of data ( d(n(, sum(n))
new.mw
Hello. I have certain requirements for drawings. Please tell me, is it possible to implement them when plotting in Maple? Thanks.
Drawing width 15 cm
Be sure to frame and mesh. The thickness of the frame and serifs on the axes is 0.5 pt. Mesh thickness 0.25 pt. The length of the serifs is 1.2 mm.
The thickness of the graph itself is 1 pt
Axis names 10 pt
Is there a similar function as (cylinderplot) to plot convex or concave toroidal shell segments?
This type of shell is as follows.
Recently, I encountered warnings and errors when size of my list is big. Maple says use array instead of list because of ... . When the list is just a list of numbers or a list of lists of the same size, I can rewrite it as an array, but how about a list like the following?
[seq([[0,0],0],i=1..10)]
This is just an example. So the elements of this list are lists containing a vector (a point in the plane) and a number (a property of this point). One idea is to use two arrays, a two dimensional array for recording the vectors, and one 1-dimensional array for recording the numbers and keep in mind that the i-th number of the second array is related to the i-th vector (row) in the first array. But is there any possibility to have this data recorded similar to when we are using lists, i.e. similar to the above code?
How can I get the follow graph of paraboloidal surfaces (ξ=1,η=2) with the coordinate vectors ξ, η0 , φ0 as shown in the picture.
Realation between cartesian coordinates and paraboloidal :
x=1/2 (ξ2 - η2), y=ξ η cos(φ), z=ξ η sin(φ)
I wrote the following code:
Student:-VectorCalculus
S1 := PositionVector([1/2*(-eta^2 + 1), eta*cos(phi), eta*sin(phi)], cartesian[x, y, z]):
LH := PlotPositionVector(S1, eta = -2 .. 0, phi = 0 .. 2*Pi, coordcurve = [eta = -2, tangent = true, binormal = true, vectornum = 1], scaling = constrained)
S2 := PositionVector([1/2*(xi^2 - 4), 2*xi*cos(phi), 2*xi*sin(phi)], cartesian[x, y, z]):
LG := PlotPositionVector(S2, xi = -1 .. 1, phi = 0 .. 2*Pi, coordcurve = [xi = 1, tangent = true, vectornum = 1], scaling = constrained)
And I got the two paraboloidal surfaces with the vectors separently.How can I get only one graph with these two surfaces as shown in the picture (with ξ=1, η=2) ?
If I have a vector like u:=<-2+m,3+m> and then I put m:=5 (for exemple) when I repeat u it doesnot replace the value of m by 5,
instead repeats the initial expression. I would like to find a way to achieve this in order to automate calculations.
This website suggests that the viewer write equations containing differentials and use them to plot topographical lines.
https://mathcurve.com/courbes3d.gb/topographic/topographic.shtml
I am basically familiar with equations containing derivatives, but not with equations containing differentials.
How can one employ these to draw the lines shown in the website's various plots of surfaces?
S := proc (n) local i; for i to n do if i <= n and type(i, divisors(n)) and type(n/i, odd) then sum(i) end if end do end proc
First 486 487 488 489 490 491 492 Last Page 488 of 2458
