with(GraphTheory);
with(SpecialGraphs);
with(StringTools);
GT := GraphTheory;
G := GT:-SpecialGraphs:-GridGraph(3, 3);
G := Graph(AdjacencyMatrix(G));
H := GT:-SpecialGraphs:-GridGraph(3, 2);
H := Graph(AdjacencyMatrix(H));
GH := CartesianProduct(G, H);
V := Vertices(GH);
P := [];
flag := 0
f := proc(K::string) local L; global P; L := Split(K, ":"); P := [op(P), cat("(", L[1], ",", L[2], ")")]; end proc
if flag = 0 then
    for i to NumberOfVertices(GH) do f(V[i]); end do;
end if
GH := RelabelVertices(GH, P)
DrawGraph(GH, stylesheet = "legacy")
I need the graph with those exact relabed vertices type i have done
Now the problem i want my graph a little better in output  i want my vertices a better visible the edges as they more not a issue atleast want the verices a little more visbile and distictive  kind help i apologize for the distubance kind help
the below is output i get i want it more better
Dear experts;
I would like to know the angle between lines P0-P1 and P0-P3. I believe I need to solve for all the angles to get this.
I have attempted to set this up in maple but... maple doesn't like what I've done. Can you tell me what I've done wrong?
geometry.mw
It seems that plottools:-extrude doesn't support the "style" option: no error returned, just the extusion being always of surface style.
Am I correct ?
G := GridGraph(3, 3);
 DrawGraph(G);
Now in place  of (1,3) i want label 1 , in place  of (2,3) i want label 2, in place  of (3,3) i want label 3, in place  of (1,2) i want label 4, in place  of (2,2) i want label 5,in place  of (3,2) i want label 6,in place  of (1,1) i want label 7,in place  of (2,1) i want label 8,in place  of (3,1) i want label 9
And i want the graph to straight like the above and the edges should be correct and strainght kind help
Similary for below
G := GridGraph(2, 3);
DrawGraph(G);
Now in place  of (1,3) i want label 1 , in place  of (2,3) i want label 2, in place  of (1,2) i want label 3, in place  of (2,2) i want label 4, in place  of (1,1) i want label 5, in place  of (2,1) i want label 6
Kind help in such vertex labeled graph outputs and graphs should be strainght with edges and presented
If i can get both in legacy mode the above all in the above form in the legacy mode it will be more good as i want the color etc like that in my output exactly
kind help  i apologize for the disturbance kind help please
Vertices should not have have any of the (1,1),(2,1) etc in the output it should be labeled with the vertex labels as told in that order
And the edges straingth and good.
Hi to all!
I have the following problem: I need to compute the Hilbert Polynomial of the polynomial ideal ((y-xn)*(y^2-xm)), where the variables are x and y while m and n are parameteres. So, i need the Hilbert Polynomial deending by n and m. Unfortunately i don't know how to "say" to Maple that it have to consider x and y as variabled and m and n as paramaters. Can i do this?
Thanks to all!
I like to show a domain as a roster of gridlines
The plotbuilder has not this option gridlines , so i must program this ?
How would you highlight specific numbers in a list?
For example, using
a:=[1,3,4,5,3,4,9,4,5,3,9,2,3,4,2,5,21,32,22,12,15,3,2,5,4]
Highlight all the 5's in the list to red for example like this
I have 2   equations that must be zero, and 2 ODE's for phi and theta
Vector(2, {(1) = `ϕ`(tau)-1.5*sin(`ϑ`(tau)), (2) = -`ϕ`(tau)^2+1.5*cos(`ϑ`(tau))})
how can i implement this quations with event statment .  this dose't work
event1 := [[`and`(gln[1], gln[2]), halt]]
A complicated programmed task for me
I must analyze this
In this plot there are vertical  walls connected with the step area's , but that its not wanted.
Also the domain is showed by adding 0 in the plot 3d( {0, 'g(x,y)'}, ...) and this distract the plot with the step area's
Its not needed the domain in the plot ( in order to get the 0 value for z )
The 3 axis x,y,z  are not visible in the plot
Seems to be not complete programmed as it just to be.
f:=proc(A,B,T,x,y)
     local n,m,i,j,val;
     n:=nops(A);m:=nops(B);
       for i from 1 to n-1 do
         for j from 1 to m-1 do
         if (A[i]<=x and x<A[i+1]) and
            (B[j]<=y and y< B[j+1]) then val:=T[i,j];
     val;
A:=[0,1,2];B:=[0,1,2];T:=array([[1,2],[1.5,1]]);
A := [0, 1, 2]
B := [0, 1, 2]
array( 1 .. 2, 1 .. 2, [( 2, 1 ) = (1.5), ( 1, 1 ) = (1), ( 2, 2 ) = (1), ( 1, 2 ) = (2)  ] )
g:=(x,y)->f(A,B,T,x,y);
proc (x, y) options operator, arrow; f(A, B, T, x, y) end proc
plot3d({0,'g(x,y)'},x=0..2,y=0..2,axes=normal,
           scaling=constrained,orientation=[-37,75],
           projection=0.8,tickmarks=[3,0,2],
           shading=XYZ,lightmodel='light3');
Download texc_set_4_-task_3_-forumvraag.mw
 I want to find all real roots of   equation x^2 + floor(x) - 10=0
solve(x^2+floor(x)-10,x) assuming x::real
maple tells me:
  RootOf(_Z^2 + floor(_Z) - 10)
allvalues(%)
RootOf(_Z^2 + floor(_Z) - 10, 2.828427125 + 0.*I)
even though  usRealDomain.
use RealDomain in  solve(x^2+floor(x)-10,x) end use
We get nothing!
So I trun to use fsolve.
plot(x^2+floor(x)-10,x=-5..5)
s:=fsolve(x^2+floor(x)-10,{x});
fsolve(x^2+floor(x)-10,x,avoid={s})
                     s := {x = 2.828427125}
                          -3.741657387
I try to use mathematica, it is good:
Solve[x^2 + Floor[x] - 10 == 0, x, Reals]
Could Maple  do that?
In the same spirit of my previous question about converting a Mathapp to a GIF format, ( for educational goal)  Ideas?
Fibonacci.mw
With showstat( )  i can see procedure body
But it is also possible for tools : assistant, math apps, tutors and tasks ?
In library all proc are public.
I'm willing to draw phase portrait for the equation of ode fifth order
u'''''+6(u'u'''+(u'')^2)-u'''(a+2b)=0
where a and b are arbitrary constant not equal to zero and (') represents derivative w.r.t  'x'.
I'm getting no solution for the attached pdf.  Kindly suggest!
Maple Worksheet - Error
pde.mw
First 561 562 563 564 565 566 567 Last Page 563 of 2458
