Dear Useres!
Hope everyone is fine here! I want to compare the coeficient of exp(k*eta[3]+m*eta[1]+n*eta[2]) for k=0,1,2,3,...,N,n=0,1,2,3,...,N and m=0,1,2,3,...,N for N=10 in the following attached file. But I got some error, please have a look and try to fix it as early as possible. Please take care and thanks
Compare_coeff.mw
How do I set 'symbolicname' in GetEquations()?
There is an error "invalid input" when I do like below.
with(MapleSim);
A := MapleSim:-LinkModel('filename' = "C:/Users/---.msim");
A:-GetEquations('symbolicname = []');
This is a just a general type question. Often reading questions posted to do with modules and packages I see "foo" used. I have put together some simple packages for routines I find useful. I am week in general programming knowledge. I would like to know is "foo" something special or a generic name used for testing? Is is an acronym? ...
hello how do i use bracekt for several lines, like in this picture I need to write this in maple.
i already know how to setup matrices for nX1 or 1Xn (as in vector) or multiples such as
nXn (square matrice) or nXm (a none square matrice)
I also know that we have this premade "sketch"
but I need for several line and some times I need on the right side and some time I need on the left side.
but rarely on both sides (and if I need on both side I will just use a matrice)
can you help me
thx
regards OrbitA
Hello, i stumbled across a function that does not want to plot regularly.
The translation: The tension U(t) (in volts) measured across a resistance in a electric circuit is given by U(t)=cos(2t)*U*e^t/10.
a. Plot the graph of y=U(t)
b.Calculate the limit t->infinity and acquire the horizontal asymtote of the graph of y=U(t).
c. Calculate the intersecting points of the graph of U with horizontal asymptote (dont ask me how, while how can a function intersect with its own asymptotes??).
So the question actually is how to graph this function?
Maybe then i can make up from that how the function intersects with its own asymptotes.
Greetings,
The Function.
"U(t):=U*(e)^(-(t)/(10))*cos(2* t);smartplot(U(t));"
proc (t) options operator, arrow, function_assign; U*exp(-(1/10)*t)*cos(2*t) end proc
Download Question_for_maple_primes_4.mw
Copying and Pasting of parameters (entered data) or text in text boxes does not work on my MapleSim 2021.1 Windows10 installation.
I tired the usual keys and context menus. Cutting works.
Thats what I get back when I paste text here after cutting
<math xmlns='http://www.w3.org/1998/Math/MathML'></math>
Copy&Paste of components works.
Is this a known issue?
This is my first post here and I am really hoping someone can help me. I just started using Maple and I am using Maple 2021.
I generated numbers using a SEQUENCE and the sequence is called y. I am trying to extract the element (y[n]) and the index (n) of that element based on the CONDITION that y[n] has to lie in between 0 and 1 exclusive (so the element of the sequence or y[n] has to be such that 0 < y[n] < 1). How can I achieve this using select commad and also using a LOOP. Are there any other methods that can be used to achive this result. Any or all help would be really appreciated.
Thank you all.
I have piecewise functon:
k := piecewise(t < t1, kmax, t1 <= t, -kmax, 2*t1 + sqrt(2)*t1 <= t, kmax, 3*t1 + 2*sqrt(2)*t1 <= t, -kmax, 4*t1 + 2*sqrt(2)*t1 <= t, 0)
Everything is a constant except time t.
I need to Integrate it 4 times.
sol := int(k, [t = 0 .. t, t = 0 .. t, t = 0 .. t, t = 0 .. t])
I only get result for the first two conditions from the piecewise functon (t < t1, kmax, t1 <= t, -kmax)
I need the result for complete piecewise functon. Also converting to Heaviside doesn't work. I am a complete math moron. Ty
I have made a maple file that is meant to test Maple's solution to the nonlinear pendulum equation.  I am doubtful that Maple is finding the correct solution.  Could someone comment on my analysis?
test_nonlinear_pendulum_solution.mw
As I upgraded to Maple 2021 I quickly noticed the missing text format bar. I've looked into the view tabs and done a bit of search, but I can't figure out how to get it back. I mostly use document mode, so I miss it dearly.
Thank you in advance.
Am calculating using the binomial function, and want to plot the output values. So, need to create a vector and plot the values.
Here is the loop,
x := RandomVariable(Binomial(45, 0.9));
for i from 0 to 45 do
    ProbabilityFunction(x, i);
Cannot seem to find a way to get the output into a list or vector, and then implement the dataplot function .
Many thanks in advance....
Dear Sir/Madam
I want to use explore commad in order to make a plot along with calculating another expression,simultaneously.
The following command does not give the desired result:
Explore([plot(a*x^2+b*x^3,x=-2..2),evalf(a^2+b^2)],parameters = [a = -1.00..1.00, b=-1.00..1.00],placement=right );
I want to have a diagram which depends on both "a" and "b" together with evaluation of the expression "a^2+b^2" somewhere near the control markers.
I appreciate if any one could help.
Thank you very much
I am interested in the inner workings of SignalProcessing:-Convolution. I know I can list it with a higher setting of verboseproc:
with(SignalProcessing);
interface(verboseproc=3); # actually, 2 is enough here...
eval(Convolution);
and get
Obviously the real work happens in IPP:-Convolution, but that seems unknown. How can I list that??
TIA,
Mac Dude
Convolution.mw
Dear Maple users
I have created a simple Explore command in order to display what happens with a Planck curve when the temperature T increases - using the slider. Especially I would like to show how the maximum of the curve lies in relation to the visible spectrum from 400-700 nm, that is from 4*10^-7 to 7*10^-7. My idea was to somehow have this wavelength interval representing the visible spectrum displayed behind the Planck curve as a vertical rectangle. If it was a fixed plot, I could do it using the display command, but is it possible to add an extra plot to an Explore command?
I have uploaded the temporary Maple file and an image to show my intention (I don't expect the coloring ...)
Planck_curve.mw
Maybe someone can help?
Kind regards,
Erik V.
Dear respected colleagues,
The first "ex 1" and second "non linear" codes were sent to me by a colleague. It would be appreciated if they can be modified to look like the one saved with "K2 Nonlinear_Fang 2009". Thank you all for your time and best regards.
ex1.mw
non_linear.mw
K2_Nonlinear_Fang_2009.mw
First 373 374 375 376 377 378 379 Last Page 375 of 2427
