dear all
I have a three lines of codes, used to create vectors, I would like to put these vectors in two columns and each columns has a title.
simple_code_table.mw
thank you
I am trying to calculate the number of  complete subgraphs K4 of a graph. Based on some similar discussions, like following links,
I wrote the following codes:
NumberOfK4:=proc(g::Graph)
local  n,N, i, j, k,l, g1,G1;
uses GraphTheory;
n:=NumberOfVertices(g);
g1 := RelabelVertices(g, [$ i = 1..n]):
N:=0:
 for i from 1 to n-3 do
    for j from i+1 to n-2 do
         for k from j+1 to n-1 do
             for l from k+1 to n do
                G1:=InducedSubgraph(g1,[i,j,k,l]);
                   if NumberOfEdges(G1)=6 then N:=N+1; fi;
               od;
            od;
         od;
  od;
N;
with(GraphTheory): with(SpecialGraphs):
g:=CompleteGraph(5);
g1:=LineGraph(g);
NumberOfK4(g1)
5
I know the above codes are supposed to be inefficient in terms of speed. We want to improve this codes. One way I know  that is to take advantage of  the efficient graph theory programs such as igraph
Recently I learned how Maple calls external C programs.
The define_external command links in an externally defined function (for example, from a DLL under Windows, or from a shared library under UNIX), and produces a Maple procedure that acts as an interface to this external function.
From the help documentation, we need to compile the DLL files from the  source of C language. If it is a C program that does not need additional libraries, we can compile successfully, such as help documents
    void mat_mult( double *A, double *B, double *C, int I, int J, int K )
      int i, j, k;
      double t;
      for( i = 0; i < I; ++i )
        for( k = 0; k < K; ++k ) {
          t = 0.0;
          for( j = 0; j < J; ++j )
            t += A[i*J+j] * B[j*K+k];
          C[i*K+k] = t;
No offense, maple has relatively few functions on graph theory so far, while Sage has a strong advantage because of its ability to integrate open network resources. I think sage is considered better for graph theory researchers because of this.
I don't know if Maple has any guidance on integrating a publicly available  graph theory library ,such as igraph .
Where is the difficulty of using the written source code? And my computer system is Windows 10 , are there any special requirements. If Maple does this better, it might be a wonderful thing for graph theorists.
My integrals are convolutions.and I know I can evaluate this using numerical integration, but I am seeking a numerical solution of this problem using FFT. I have many many integrals of this type to evaluate and I need FFT for speed reasons.
fft.mw
This might inspire you.
https://www.mathworks.com/matlabcentral/answers/228107-how-to-evaluate-a-convolution-integral-by-fast-fourier-transform
I am searching for high level commands or techniques to show equality of expressions containing square roots that can be complex as here
In an ideal world is() with the right assumptions should show equality. However, in the attached example, I failed already with my manual skills.
What did I miss here?
Equality_of_exp_with_complex_roots.mw
I have a data with one dependent variable Y say and 32 independent variables say X1,X2,X3,....
Now I need to find the best say, a linear fit with the role playing independent variables only choosen so that I get pvalue less and R^2 and adjusted R^2 more than 90%
Even if possible to write for a nonlinear fit too
How to do such a code
Kind help with your advice
I have my data in Excel sheet which I need to import
I have the following code,
for i to 6 do
for j to i do
F[i, j] :=  g(i+1)/g(j);
How can display F as a full matrix
Thak you for your help
Hi, I need a little help please.
I'm writing some code that involves using solve() to solve some simultaneous equations and the output set from solve() is as follows :
{c[1] = 8/3, c[2] = 10/3}
I would now like to used the values 8/3, -10/3 in another calulation. However, I don't know how to extract the values/loose the variable parts of the set (namely "c[1]=" and "c[2]="). Can anyone help please.
FYI - I can't use fsolve as my simultaneous equations contain an another unknown variable, which I need to preserve.
Thanks in advance, Greg
On my PC I can't see the plus and minus sign in the quotient expression when using Student:-Basics:-LongDivision.
Is this a know display issue and is there to correct it?
Windows 10, Maple 2021.2
A:=4*x^4;
B:=3*x^2-60*x+36;
Student:-Basics:-LongDivision(A,B,x); #NOTICE, no + sign shows in quotient
A := 4*x^4
B := 3*x^2-60*x+36
"[[(`%+`(3 x^2,-60 x,36)),[[,(4 x^2)/3,(80 x)/3,1552/3,],[),4 x^4,,,,],[,(4 x^4-80 x^3+48 x^2)/(),],[,,80 x^3-48 x^2,,],[,,(80 x^3-1600 x^2+960 x)/(),,],[,,,1552 x^2-960 x,,,],[,,,(1552 x^2-31040 x+18624)/(),,,],[,,,,30080 x-18624,,,,]]]]"
rem(A,B,x);
quo(A,B,x); #signs shows up here OK
30080*x-18624
(4/3)*x^2+(80/3)*x+1552/3
Download no_signs.mw
Thank you very much, Maple Community !
I have another (hopefully) easy question about a data set
seematrix_start_2_trim.xlsx
matrix_start_2_trim.pdf
I want to imitate Online Encyclopedia of Integer Sequences .b file
reference oeis.ort/A40
Cheers,
Matt
 I have two personal packages I wrote for Maple a few years age. I use them regurlary. They are stored in two differant locations.  Is there of interogerating Maple to find out where they are and some details obout them? What I load is
with(RationalTrigonometry) and with(RonanRoutines)
I finally found them again.
One in C\usersIRonan\Maple\persona\lib\RatTrig.mla
Other in (basically in) My documents\Maple\.A library\RonanRoutines1.mla
So the package load name and the .mla file name are different. I would like to know where the packages are being loaded from and under what name they are saved as.
The loglogplot procedure in the plots package labels the axes using "10 to the power notation" that looks like what you would see in LaTeX from the expresion "10^{-4}".
I"m at a loss about how to do the same.  If I try typesest(10^(-4)) the argument is converted to a rational before typeset gets the argument and the result is something equivlent to LaTeX's "\frac{1}{10000}".
Example:
    loglogplot(x, x = 0.1*10^(-5) .. 10, title = typeset(10^(-4)));
produces:
I build a small simple custom library in MapleSim, for some reaon MapleSim is keep giving me that a variable can't be resolved and that there is no "LibraryName" visible.
The library loads successfully with no error though.
exact msg:
Cannot resolve type `MyLibrary.Dh_Revolute` of variable `Main.DR1` in model `Main`; there is no `MyLibrary` visible
thanksf or your help.
I have an algorithm  to solve a first order odes, all steps of the algorithm ( as presented in the book are coded) but unfortunately something wrong.
The algorithm and the code are attached in the following code.
Thank you in advantage for your help.
sol_odes.mw
I am a new user of Maple. I use Mathcad to plot n*n*n 3D mesh as shown in my sheet.
Please show me the way how to plot3D by Maple. I want to make f(n) to make n*n*n 3D mesh with points and lines.
Tokoro.
Hi again,
Are there any Maple experts out there that can help me save a matrix full of data?
two_column_matrix.pdf
Matt
First 372 373 374 375 376 377 378 Last Page 374 of 2458
