What I mean by shortest distance between vertex and edge is
In the above petersen graph consider the vertex say 1 it's distance to
(1,6) will be 0 as 1 is part of the same edge
((1,2) will be 0 again
(1,5) it will zero again
(5,8) will be 1 that is (1,5)-(5,8)
(8,9) it will be 2 that is (1,5)-(5,8)-(8,9)
(5,4) it will be 1 that is (1,5)-(5,4)
(9,10) it will be 2 (1,5)-(5,4)-(9,10)
Etc for all edges the graph from a given vertex v given a Graph G
The order in which the edges are chosen to find the distances should be maintained so that each index in the list correspond to distance of that vertex from the same edge in different vertex lists in a order
Kind help I apologize to take your time
In output I need a list say T=[0, 0,1,2,..]
   Data given
   List Given
  L:=[A,B,A,C,A,B,D,E,A,F,G,H,H,G,I,P,Q,W,A]
    I want the output to be a frequency table
    Frequency says number of times each Data occurs in the list
    I want output in the form of a table
    Data need not be always A,B,C,D etc it can be any text.
Data
Frequency
A
5
B
C
D
E
F
G
H
I
P
Q
W
I want to export this outputed table to word or Excel
Anyone have a problem with non-appearance of the animation toolbar in Maple 2021????
Whilst coming up with a response for the problem here
https://www.mapleprimes.com/questions/231862-Have-You-Ever-Heard-Of-Vector-Asterisks-
I found an issue with the non-appearance of the animation toolbar in Maple 2021. This is rather difficult to illustrate without the use of screenshots, for which I apologise.
Normally(?) I would just select a plot and the animation toolbar appears "as if by magic"
First screen shot is using Maple 2020, The blue highlighting rectangle around the plot was visible when I initiated the snip, but disappeared when the snipping tool activated. However this shows that the animation toolbar is available (and works)
I do exactly the same thing in  Maple 2021 and I can't make the animation toolbar appear - see below. Aagain the plot wa highlighted when I initiated the snip but the highlighting disappeared when the snipping tool activated. Now there is no sign of the animation toolbar
It is still possible to do very basic animation in Maple 2021 by clicking on the plot and using the context menu - but this is very basic
The code used in the above plots is given supplied below
  kernelopts(version);
  plots:-display
         ( [ seq
             ( plot
               ( Vector([1, 3, 4, 6]),
                 Vector([8, 6, 2, 5]),
                 style = point,
                 symbol = j,
                 symbolsize = 40,
                 color = blue
               j in [ asterisk, box, circle, cross, diagonalcross,
                      diamond, point, solidbox, solidcircle, soliddiamond
           insequence = true
Is it just me?
From old memory, I recall some boolean algebra.  We have zeros and ones.
Some of us are familiar with logic gates.
The simplest is the simple inverter.  It inverts.
Very interesting.
https://en.wikipedia.org/wiki/Boolean_algebra
I have defined a function pp(x).  It plots correctly
but pp(2020); should return 410, and it returns 98000. Maybe I am doing something stupid, but I just can't figure out what!
a := 0.340699639252428*10^13;
b := -0.118229737138742*10^11;
c := 0.175816922773262*10^8;
d := -14523.7138112711;
e := 7.19782673654200;
f := -0.00214008825847444;
g := 0.353463615941623*10^(-6);
h := -0.250170509163729*10^(-10);
pp := x -> a + b*x + c*x^2 + d*x^3 + e*x^4 + f*x^5 + g*x^6 + h*x^7;
plot([pp(x)], x = 1960 .. 2100, gridlines = true, size = [900, 600])
Good day, all. I hope we are staying safe.
Please I need help with the regard to the following codes.
The major issue is with rho:=x[n]/h. The rho needs to change values as x[n] changes in the computation. This I think I have gotten wrong. Your professional modifications or/and corrections to the code would be appreciated.
Thank you and kind regards.
Digits:=20:
#assume(alpha>0,alpha < 1):
f:=proc(n)
	-y[n]-x[n]+(x[n])^2+(2*(x[n])^(2-alpha))/GAMMA(3-alpha)+((x[n])^(1-alpha))/GAMMA(2-alpha):
e2:=y[n+2] = y[n]+(1/2)*((alpha^2-alpha)*rho^2+(2*alpha^2-2)*rho+(4/3)*alpha^2-(2/3)*alpha)*(rho*h)^alpha*GAMMA(2-alpha)*f(n)/rho-alpha*GAMMA(2-alpha)*((-1+alpha)*rho^2+(2*alpha-2)*rho+(4/3)*alpha-8/3)*(h*(rho+1))^alpha*f(n+1)/(rho+1)+(1/2)*((alpha^2-alpha)*rho^2+2*(-1+alpha)^2*rho+(4/3)*alpha^2-(14/3)*alpha+4)*(h*(rho+2))^alpha*f(n+2)*GAMMA(2-alpha)/(rho+2):
e1:=y[n+1] = y[n]+(1/4)*((alpha^2-alpha)*rho^2+(alpha^2+3*alpha-4)*rho+(1/3)*alpha^2+(4/3)*alpha)*GAMMA(2-alpha)*f(n)/((rho*h)^(-alpha)*rho)-(1/2)*GAMMA(2-alpha)*((alpha^2-alpha)*rho^2+(alpha^2+alpha-2)*rho+(1/3)*alpha^2+(1/3)*alpha-2)*f(n+1)/((h*(rho+1))^(-alpha)*(rho+1))+(1/4)*((-1+alpha)*rho^2+(-1+alpha)*rho+(1/3)*alpha-2/3)*alpha*GAMMA(2-alpha)*f(n+2)/((h*(rho+2))^(-alpha)*(rho+2)):
alpha:=0.25:
inx:=0:
iny:=0:
#x[0]:=0:
h:=1/20:
N:=solve(h*p = 1, p):
n:=0:
c:=1:
rho:=x[n]/h:
err := Vector(round(N)):
exy_lst := Vector(round(N)):
for j from 0 to 2 do
	t[j]:=inx+j*h:
vars:=y[n+1],y[n+2]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%4s%15s%15s%16s\n",
	"h","Num.y","Ex.y","Error y");
st := time():
for k from 1 to N/2 do
	par1:=x[n]=t[0],x[n+1]=t[1],x[n+2]=t[2]:
	par2:=y[n]=iny:
	res:=eval(<vars>, fsolve(eval({e||(1..2)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		exy:=eval(-c*h+(c*h)^2):
		printf("%5.3f%17.9f%15.9f%15.5g\n",
		h*c,res[i],exy,abs(res[i]-exy)):
		err[c] := abs(evalf(res[i]-exy)):
		exy_lst[c] := exy:
		numerical_y1[c] := res[i]:
		c:=c+1:
		rho:=rho+1:
	iny:=res[2]:
	inx:=t[2]:
		t[j]:=inx + j*h:
v:=time() - st;
printf("Maximum error is %.13g\n", max(err));
numerical_array_y1 := [seq(numerical_y1[i], i = 1 .. N)]:
time_t := [seq](step[i], i = 1 .. N):
numerical_plot_y1 := plot(time_t, numerical_array_y1, style = [point], symbol = [asterisk],
				color = [blue,blue],symbolsize = 15, title="y numerical",legend = ["Numerical"]);
exact_plot_y1 := plot(time_t, exy_lst, style = [line], symbol = [box],
				color = [red,red], symbolsize = 10, title="y exact",legend = ["Exact"]);
display({numerical_plot_y1, exact_plot_y1}, title = "Exact and Numerical Solution of Example 1 ");
how can i solve this operate differential equation
convert(expand((D[1] - 1)*(D[1]^2 + 2)*y(x) = 0), diff);
dsolve(%)
Consider an easy example of a table.
myTable:=table(["a"=1,"b"=-1,"c"=1]);
We can give an index to it and get its corresponding entry if exists.
myTable["b"];
We can also get the set of all indices, or the set of all entries. But what about receiving the index or set of indices with a specific entry. for example asking what indices have the entry `1`?
Of course I can define a search procedure myself, but I thought there might be an efficient way which is already implemented as a function/method on tables.
Good afternoon. How do I disable the numbering of _Z constants? Because
of this, you can't use the procedure in a loop
Is it possible to disable numbering or do something else?
restart; with(linalg); t := 3
S := proc (a, b, z) local L, y, s1, s2, sist, chl, lambda1; L := diff(y(x), x, x) = lambda*y(x); assume(lambda < 0); dsolve(L, y(x)); y := unapply(rhs(%), x); s1 := y(a) = 0; s2 := y(b) = 0; sist := {s1, s2}; genmatrix(sist, {_C1, _C2}); det(%); chl := combine(%); _EnvAllSolutions := true; solve(chl); sort(%); lambda1 := subs(_Z1 = k, %); print(lambda1); lambda1 := unapply(%, k); lambda1(z) end proc:
S(0, Pi, 3);
Warning, solve may be ignoring assumptions on the input variables.
-k^2
-9
for i to t do S(0, Pi, i) end do:
-_Z2^2
-_Z3^2
-_Z4^2
Download help.mw
This is new exception generated by Maple pdsolve in 2021. Different from the last post I gave on pdsolve. So I thought it will be better to keep them separate since the causes are different.
interface(version)
pde :=  diff(w(x,y,z),x)+(a1*x^n1*y+b1*x^m1)*diff(w(x,y,z),y)+(a2*x^n2*y+b2*x^m1)*diff(w(x,y,z),z)= 0;
pdsolve(pde,w(x,y,z));
#another example
local gamma:
pde := diff(w(x,y,z),x)+(a1*x^n1*y+ b1*x^m1)*diff(w(x,y,z),y)+(a2*x^n2*y+b2*x^m2)*diff(w(x,y,z),z)=c2*x^k2*y+c1*x^k1*z;
Error, (in GAMMA) numeric exception: division by zero
The same PDE works in 2020.2. The answer it gives is large so will not show it all below.
Screen shots
Maple 2021
Maple 2020.2
All on windows 10.
Do other see the same error? What causes it?
4 %+ 3 %* 2;
                        %*(%+(4, 3), 2)
= (4+3)*2
It makes using % very difficult in complex expressions because one has to constantly use a ton of paranethesis just to get things to work out.
1 + 4%^3  %* 2 %- 6 %/ 4;
1 + ((((4 %^ 3) %* 2) %- 6) %/ 4)
= 1 + (4^3*2 - 6)/4
I noticed number of pde's now fail in Maple 2021 with the error
          int/gbinthm/structure INVALID subscript selector
but they do not fail in Maple 2020.2.
Here are few   examples
pde :=a*x^n*diff(w(x,y),x) + n*x^m*y*diff(w(x,y),y) =s*x^p*y^q+d;
pdsolve(pde,w(x,y));
pde :=a*x^n*diff(w(x,y),x) + n*x^m*y*diff(w(x,y),y)=c*x^k*y^s+d;
pdsolve(pde,w(x,y))
pde :=a*x^n*diff(w(x,y),x)+b*x^m*y*diff(w(x,y),y) =  (c*x^k*y^s + d)*w(x,y);
pdsolve(pde,w(x,y))
pde :=  a*diff(w(x,y),x)+ y*diff(w(x,y),y) = b*w(x,y)+ c*x^n*y^m;
pdsolve(pde,w(x,y))
#etc..
Error, (in int/gbinthm/structure) invalid subscript selector
While in Maple 2020.2 they all work. Screen shot
Maple 2021
Maple 2020.2
Any idea why this happens? Do others see the same error?
How to define n-dimensional metric for arbitrary n in Physics package?
First 427 428 429 430 431 432 433 Last Page 429 of 2427
