sometimes I have a need to do an assignment inside  operator call `if`(......) . but it is not possible it seems to do this in Maple.
This happens when I am using `if`(...) inside cat() to build a long string, and  depending on some condition, different string is build.
This works fine in general, until I need to assign new value to a variable at the same time as I am building the string.
An example will make it more clear. Instead of the following
str:="A";
x:=10;
str:=cat(str,`if`(x=10," it was 10","it was not 10"));
if x=10 then
   x:=11;
   x:=9;
fi;
I'd like to do something like this (which does not work in Maple)
str:="A";
x:=10;
str:=cat(str,`if`(x=10,  x:=11;" it was 10" , x:=9; "it was not 10"))
Tried assign() also. Does not work.  I tried different variation on the above, none works.
In Mathematica, the above is possible. But this is using standard `If`, which can be inlined
Is it possible to do something like this in Maple?
The reason is that I do not have to do the checking twice: once to build the string, and once after that is done, in order to do the assignment. It is better if both are done in one place. The above is just an example. I could have more than one `if` inside as I am building the long string.
Btw, how does one look up help on the operator if and not the statement if ? the help page for if does not talk about it or give any examples.
Maple 2020.2
If I set
B:=[1,2^(1/3),2^(2/3),I*sqrt(3),I*sqrt(3)*2^(1/3),I*sqrt(3)*2^(2/3)];
and then let
g:=B[2]+B[4];
I would like to be able to solve for g^2 in terms of the (basis) B, i.e.
solve(expand(g^2)=c[1]*B[1]+c[2]*B[2]+c[3]*B[3]+c[4]*B[4]+c[5]*B[5]+c[6]*B[6],{c[1],c[2],c[3],c[4],c[5],c[6]});
However, Maple does not seem to be able to recognize g^2 as a linear combination of the elements in the set B, in particular that g^2 = -3*B[1] + B[3] + 2*B[5]
A parallel question would be whether one could, for example, do something like this:
coeff(expand(g^2),2^(2/3))
but Maple does not compute coeffiencts except with respect to indeterminates.
Does anyone have an idea how to do such a computation? Thanks.
(The set B is a basis of the field extension of Q given by adjoining 2^(1/3) and sqrt(-3) and I'm trying to find a so-called 'primitive element' for this field extension.)
EDİT:
I wrote a procedure in order to add the legends inside plots as follows:
newlegend:=proc(f::algebraic,g::algebraic,x_left,x_right)
local A,B,location,y_min,y_max,L1,L2,rect,T,F,G:
y_min:=min(minimize(f,x=x_left..x_right),minimize(g,x=x_left..x_right));
y_max:=max(maximize(f,x=x_left..x_right),maximize(g,x=x_left..x_right));
F:=unapply(f,x):
G:=unapply(g,x):
L1, L2:=plottools:-line([x_left,0.9*y_max],[x_left+abs(x_right-x_left)/15,0.9*y_max],color=red), plottools:-line([x_left,0.7*y_max],[x_left+abs(x_right-x_left)/15,0.7*y_max],color=blue):
rect:=plottools:-rectangle([x_left,y_max-abs(y_max-y_min)/3],[x_left+abs(x_left+x_right)/4,y_max],color=cyan);
T:=plots:-textplot([[x_left+abs(x_right-x_left)/9,0.9*y_max,f],[abs(x_left+x_right)/9,0.7*y_max,g]]):
A:=plot(F(x), x=x_left..x_right, style=line, color=red   ):
B:=plot(G(x), x=x_left..x_right, style=line,  color=blue  ):
plots:-display(A, B, L1, L2, T,rect,  scaling=constrained, size=[800,300],axes=boxed);
newlegend(sin(x),cos(x),0,2*3.14)
Question 1: The lines behind the cyan rectangle seem. How to make the rectangle opaque?
Question 2:  Could you help me improving the procedure? Because I have bad results for some functions.
For example;
newlegend(exp(x),x,0,3)
Some Suggestions:
  • If we add an option to change the location of the legends like 'northeast' or 'southwest' etc, it will be a really good procedure.
  • If we add an option to remove the rectangular like "rectangular=off", it will be great.
If you share your valuable ideas and comments, I will be very glad.
I am trying to rearrange the elements of an equation by the absolute value of their coefficients. eg -3y^2 x+2x z^2+6z^2 to
2x z^2 -3y^2 +6z^2
Download Rearange_test.mwRearange_test.mw
test1_03.mw
The solution I'm getting here for v(y), doesn't satisfy my original two equations. Like for example if I choose u(y)=y, for easy check it can be seen that my de2 equation doesn't satisfy that value.
Can anyone help me out?
when I use this package, maple makes error like bellow. what is the problem ? thank u
I was applying the Grip Map to the procedure LArip. It apparently finished in less than 5 seconds. But when I wanted to display the results as an Array, this step required minutes. How can this time be reduced? Here is a piece of the code:
n := 8;
r := 2^n;
M := Vector(r, randperm(r) + [-seq(1, i = 1 .. r)], datatype = integer[4]);
LArip := proc(k::integer, r::integer, M::Vector(datatype = integer[4]))
local N, j, t, i, A;
N := Vector(r, 0); A := Vector(r, 0);
i := k - 1;
for j from 0 to r - 1 do
for t from 0 to r - 1 do
N[t + 1] := Occurrences(1, Split(Xor(And(t, i), And(M[t + 1], j)))) mod 2;
A[j + 1] := Occurrences(0, convert(N[], list));
return convert(A, list);
infolevel[Grid:-Map] := 3;
rt := time[real]();
Bb := Grid:-Map(k -> LArip(k, r, M), [$ (1 .. r)]);
GridMapTime := time[real]() - rt;
The worksheet is here:
Magma_GridMap.mw
Thank you for your help.
Hey!
I am using the solve function and I get the following form of the result :
rootsq0 := {z = 9.096986124+3.141592654*I}, {z = 1.138376998+3.141592654*I}, {z = .3074241220+3.141592654*I}, {z = .5854971300+3.141592654*I}, {z = -2.519351300+3.141592654*I}, {z = -5.138371980+3.141592654*I}, {z = -1.759344122+3.141592654*I}, {z = -0.9698634104e-1+3.141592654*I}
I want to convert rootsq0 into a list [9.096986124+3.141592654*I, 1.138376998+3.141592654*I, ...]. So, I would like to remove {} and z=. Any suggestions are welcome! :)
Is it possible to write an equation reduction program that uses only LinearAlgebra.?
restart; with(LinearAlgebra); with(Student[LinearAlgebra]); unprotect(D);
f := proc (x, y) options operator, arrow; 5*x^2+4*y*x+8*y^2+16*x-8*y-16 end proc;
A := coeff(f(x, y), x, 2); B := coeff(coeff(f(x, y), x, 1), y, 1); C := coeff(f(x, y), y, 2); D := coeff(coeff(f(x, y), x, 1), y, 0); E := coeff(coeff(f(x, y), y, 1), x, 0);
F := tcoeff(f(x, y));
MQ:=Matrix([[A,B/2], [B/2,C]]):
Delta := A^2-4*A*C;
ML := `<,>`(D, E);
vp := Eigenvalues(MQ);
Omega := evalm(-`&*`((1/2)*ML, 1/MQ));
M1 := MQ-Eigenvalues(MQ)[1]*IdentityMatrix(2);
M2 := MQ-Eigenvalues(MQ)[2]*IdentityMatrix(2);
D := JordanForm(MQ);
with(linalg);
ma := matrix(2, 2, [A, (1/2)*B, (1/2)*B, C]);
jordan(ma, 'P1'); G := map(normalize, GramSchmidt([col(P1, 1 .. 2)])); P := map(simplify, concat(op(G)));
evalm(`&*`(`&*`(1/P, MQ), P));
nx := [X, Y];
var := [x, y];
x := matrix([seq([nx[i]], i = 1 .. 2)]); y := evalm(`&*`(P, x));
s := seq(var[k] = y[k, 1]+Omega[k], k = 1 .. 2);
eq := unapply(simplify(expand(subs(s, f(x, y)))), X, Y);
alpha := -eq(0, 0);
a := sqrt(alpha/vp[2]); b := sqrt(alpha/vp[1]); c := sqrt(a^2-b^2); print(X^2/a^2+Y^2/b^2 = 1);
This program works;. It is possible to simplify ? Thank you.
eq := 61*x^2 + 1 = y^2;
sols := (isolve(eq) assuming (x::posint, y::posint)):
for sol in sols do
  print(subs(_Z1 = 1, sol));
isolve returns the solution in terms of _Z1, indicating there may be infinite number of solutions?
I think {x = 226153980, y = 1766319049} is the only solution with x::posint, y::posint.
How do I restrict this to only positive integers in the solution?
If you could assist; I am trying to set something like an asymptote or upper limit such that my plot below approaches asymptotically (below y =1 ) from negative infinity:
Download Plotting.mw
Why Float(undefined) appears in calculation integrals
3333.mw
I see this question at here
https://mathematica.stackexchange.com/questions/239874/how-to-reduce-timing-to-find-the-integer-numbers-a-b-c-d-e-f-g-h-k-m-of
How to solve this problem by Maple?
command completion (when hitting the ESC key) in Maple could be made more useful. It does not seem to support type names for example.
What shows up on the command completion window are  possible commands that start with that partial text.
It does not list other known names by Maple, such as type names and other options.
This makes it hard to use in many places, where one have to remember type names exactly instead of the system helping them by listing all possible type names that start with that string.
Is there a way around this? Will Maple next version support smarter and more complete command completion menu?
First 439 440 441 442 443 444 445 Last Page 441 of 2427
