Dear MaplePrimes community,
I'm trying to calculate the (Moore-Penrose) pseudoinverse of a matrix using the following code:
Identity := Matrix(2, 2, [[1, 0], [0, 1]]):
A := Matrix(2, 2, [[0.5661180126, 0.4338819876], [0.8316071431, 0.1683928571]]):
MatrixInverse(Identity - A, method = pseudo)
Unfortunately, the output appears to be meaningless (and it conincides with what I'm getting by calculating a simple matrix inverse using "MatrixInverse(Identity - A)"). Am I missing something? (And how do I calculate the (Moore-Penrose) pseudoinverse of the matrix (Identity-A)?)
Special characters like æ,ø,å are causing some troubles when used in Maple Code attachments in workbooks.
I've managed to get around the problem by using HTML equivalents in the first run, but then this will cause problems when exporting the same strings to Excel.
Funnily this problem just arises in Workbooks, not when using the same code in a code edit region.
Special.zip
I have two functions u(x,y,t) and p(x,y,t).
I want to find the total derivative of D_x( p*u) (where * is the multiplication)
where D_x is as given in the attached file formula_of_D_x.pdf
Also, it is given in the following link but it's not clear to me. I think it somehow resembles my query, but not clear about the syntax so that I should implement it on mine.
https://www.maplesoft.com/support/help/Maple/view.aspx?path=DifferentialGeometry/JetCalculus/TotalDiff
Strange phenomena...Every thing is well coded.
Using numeric solution pdsolve and  and solution based on iterative solution, gives a slighty different curve..
All matrices are well coded, and everything is okay... But  what happen... to get two different curves at same time.
New_code.mw
Thank you for any help
if I have a vector defined as u[1..11,1]:=
How can display the coeffients of  this vectors
can I plot the vector
Thanks for any help
I have a complex PDE as follows:
where u(x, t) is a complex function.
The following function u_11(x, t) is a solution for the PDE above.
where
I want to check whether the u_11(x,t) is a solution for the PDE or NOT.
 How to correctly define the complex PDE in MAPLE?
PDE:=I*diff(u(x,t),t)+diff(u(x,t),x$2)+alpha*(abs(u(x,t))^2)*u(x,t)+ I*( gamma[1]*diff(u(x,t),x$3) + gamma[2]*(abs(u(x,t))^2)*u(x,t) + gamma[3]*diff((abs(u(x,t))^2),x)*u(x,t) )=0;
or
PDE:=I*diff(u(x,t),t)+diff(u(x,t),x$2)+alpha*(evalc(abs(u(x,t))^2))*u(x,t)+ I*( gamma[1]*diff(u(x,t),x$3) + gamma[2]*(evalc(abs(u(x,t))^2))*u(x,t) + gamma[3]*diff((evalc(abs(u(x,t))^2)),x)*u(x,t) )=0;
Let's check the solution is right or not:
k:=(gamma[2]+2*gamma[3]-3*gamma[1]*alpha)/(6*gamma[1]*gamma[3]);
omega:=(((1-3*gamma[1]*k)*(2*k-c-3*gamma[1]*(k^2))  )/(gamma[1]))+(k^2)-gamma[1]*(k^3);
uu[11]:=1/(gamma[2]+2*gamma[3])^(1/2)*(-3*(3*k^2*gamma[1]+c-2*k))^(1/2 )*sin(1/2/gamma[1]*2^(1/2)*(gamma[1]*(3*k^2*gamma[1]+c-2*k))^(1/2)*(-c*t+x))/ cos(1/2/gamma[1]*2^(1/2)*(gamma[1]*(3*k^2*gamma[1]+c-2*k))^(1/2)*(-c*t+x))*exp( I*(k*x-omega*t));
pdetest(u(x,t)=uu[11],PDE);
 download-code.mw
Solve the following problems using computer. Use Algorithm from  Algorithm 4.4 in the textbook with 1) n = 4,m = 8, 2) n = 8,m = 4, and 3) n = m = 6 to approximate the following double integral and compare the results to the exact solution
∫∫cos ydydx (interior integral from 0 to x and exterior integral is from 0 to pi)
I have crreated a transfer function of a rather complex system using TransferFunction() and recived a transfercundtion of a rather high order (n=10). However due to the kinematics of the model I know that is is posible to expres as an second order transfer function.
So I have been locking around Maple for a function that can help me reduce or approwqimate the transfer function as a sencond order but I have not found anything.
Is there a way to reduce/approximate an n order transfer function to a second order transfer function?
Mvh
Eric Ragnarsson
dear all
I have a linear system AX=b , I would like to compute the solution using Gradient conjugate method
CS.mw
I get the following error
Error, (in LinearAlgebra:-LinearSolve) method SparseIterative incompatible with data of type anything
It want to generate all the words from a NL-letter alphabet and whose lengths are at most LW.
I could not find any function in the combinat package do to that (at least without combining some of them, I'm using Maple 2015 right now); maybe the Iterator package has some features do to that?
For the moment I use this procedure (which generates a few words of length LW+1 I have to suppress)
G := proc(d)
 local n, wo:
  global W:
  while max(length~(W)) < d do
    wo := copy(W):
    for n from 1 to nops(L) do
      W := {W[], cat~(wo, L[n])[]};
    thisproc(d)
# Words of length not larger than LW which are made of at most NL letters
NL := 3:
L  := StringTools:-Char~([$65..65+NL-1]);
W  := L:
LW := 3:
G(3):
w3 := W;
                        ["A", "B", "C"]
{"A", "AA", "AAA", "AAB", "AAC", "AB", "ABA", "ABB", "ABC", "AC",
  "ACA", "ACB", "ACC", "B", "BA", "BAA", "BAB", "BAC", "BB",
  "BBA", "BBB", "BBC", "BC", "BCA", "BCB", "BCC", "C", "CA",
  "CAA", "CAB", "CAC", "CB", "CBA", "CBB", "CBC", "CC", "CCA",
  "CCB", "CCC"}
W  := L:
CodeTools:-Usage( G(12) ):
numelems(W);
memory used=0.62GiB, alloc change=422.58MiB, cpu time=13.70s, real time=8.37s, gc time=8.08s
                             797160
Words_Generator.mw
Do you have any idea to improve it from memory used and cpu time points of view)?
How should I find the roots for
5x^3-x^2+x-1=0
If I have a Polynomial of the form say
c1x^{a1} y^{b1} +c2x^{a2} y^{b2} +... +cnx^{an} y^{bn}
Now I want to form a list say of the form
L=[[[a1, b1], c1], [[a2, b2], c2],.... [[an, bn], cn]]
Kind help with a peice of code
Have the following integral to solve in Maple (2020):
Cap_Unit_Length := int((epsilon_0*epsilon_r*d*sqrt(1+(T*Pi*S)^2))/(epsilon_r*S*theta*tan(theta/2)+2*t),theta=0..Pi);
As Maple cannot find a closed expression, it returns the original input.  Is there any other approach in Maple I can use to attack this expression?  BTW, this is the expression for the distributed capacitance in a twisted wire pair.
Chris
I would like to make a function of two variables. It seems that what I can find online on how onthers do it, does not work with my. Can someone help? Here is the document, but it is very simple. eq_of_two_var.mw
I would like to plot two different functions
One constructed using piecewise and second function on the sme interval.
The code run without error but I am not sure that its true, since we have two different function but in the graph we can not see the difference betweem them
codexsqrr.mw
Thank you for your help
First 440 441 442 443 444 445 446 Last Page 442 of 2434
