I find eval(Diff(x,x)) still is Diff(x,x)
how to make become 1
or how to evaluate Capital Diff ?
and I find sum(diff(x^k,x)/k! , k=1..n)
return exp(x) *gamma(n,x)/gamma(n)
why not exp(x)?
and diff( m(x+ diff(...) ...) / diff without m(x) , why return 0
i still have not define m(x)
I know how to define functions and generally how to pass them to another function and usually everything works out... rarely though I run in to problems and my lack of how maple works internally becomes a stumbling block. I usually just hack things together. I'd rather understand what exactly is happening.
It seems that apply and unapply have something to do with this.
I usually define functions like this, e.g.,
f := x->x^2 + 3;
g := (f,x)->cos(f(x));
and things like g(f,x) work as expected.
But this doesn't always work.
E := proc(f, depth)
    if depth <= 0 then return f; fi:
     E(f(x), depth-1); # Trying to actually compute f(f(x)), say. I know we can just loop.
E(x->2*x, 3);
2*x(x)(x)
rather than 8x
I see that maple is somehow applying the function but in some odd way(it seems to be creating a function from the variable x and then another function from that).
Anyways, I don't understand the mechanics of it. In some cases f works other one must add the variablef(x), etc...
There seems to be some subtle difference between f and f(x)...  In a programing language like C. f is sort of a function pointer and f(x) is an evaluation of f at x. I guess there is something similar goingn on with maple but i've not been able to figure it out. Any ideas?
I have been able implement this procedure here.
AreaBetween := overload([proc(fnc::{list}, a::anything, b::anything, col::list) option overload; plottools:-transform(unapply([x, y + fnc[2]], x, y))(plot([fnc[1]] + [-fnc[2]], x = a .. b, col = [col[2], col[3]], gridlines, size = [600, 600], thickness = 3, filled = [color = col[1]])); end proc])
1) How do get to construct a larger canvas? Meaning if I want a xy axis, x = -10..10, y = -10..10 however only x = a..b is suppose to be shaded. Can I do that with my procedure?
2) Only the lower graph is colored currently. How do I get it to color the upper graph?
Many thanks in advance.
Hello;
Maple 2019.2.1 on windows 10
Is there a trick to make inttrans:-fourier(erf(x),x,k) return the Fourier transform of the error function? Now, using Maple 2019.2.1 it returns unevaluated. But direct application of Fourier transform integral does return the correct result. So why inttrans does not work?
fourier(erf(x), x, k)
1/sqrt(2*Pi)*int(erf(x)*exp(-I*x*k),x=-infinity..infinity)
-I*2^(1/2)*exp(-(1/4)*k^2)/(Pi^(1/2)*k)
Download erf.mw
I have a set of functions of the form P :=  { a(t), b(t), f(g(t)), u(v(w(t)), A(a(t), b(t)), ... } and I want to obtain the set Q := { a(t), b(t), g(t), w(t) } (that is the set of the innermost functions)
Since more than an hour I'm fighting without success with select and parmatch and I'm desperatly askink for your help.
PS : the list P only contains functions of t, never of t and of another variables.
Any one help me  to remove the error.
I want to plot the curve for different values of alpha.
here is my codes.
thanks in advance
with(linalg):with(plots):
ge[1]:=diff(u[1](x,t),t)=alpha*diff((u[2](x,t)-1)*diff(u[1](x,t),x),x)+(16*x*t-2*t-16*(u[2](x,t)-1))*(u[1](x,t)-1)+10*x*exp(-4*x):
ge[2]:=diff(u[2](x,t),t)=diff(u[2](x,t),x$2)+alpha*diff(u[1](x,t),x)+4*(u[1](x,t)-1)+x^2-2*t-10*t*exp(-4*x):
bc1[1]:=u[1](x,t)-1:
bc1[2]:=u[2](x,t)-1:
bc2[1]:=3*u[1](x,t)+diff(u[1](x,t),x)-3:
bc2[2]:=5*diff(u[2](x,t),x)-evalf(exp(4))*(u[1](x,t)-1):
IC[1]:=u[1](x,0)=1:
IC[2]:=u[2](x,0)=1:
NN:=2:
N:=2:
L:=1:
for i to NN do
dydxf[i]:=1/2*(-u[2,i](t)-3*u[0,i](t)+4*u[1,i](t))/h:
dydxb[i]:=1/2*(u[N-1,i](t)+3*u[N+1,i](t)-4*u[N,i](t))/h:
dydx[i]:=1/2/h*(u[m+1,i](t)-u[m-1,i](t));
d2ydx2[i]:=1/h^2*(u[m-1,i](t)-2*u[m,i](t)+u[m+1,i](t)):od:
 for i to NN do bc1[i]:=subs(diff(u[1](x,t),x)=dydxf[1],
diff(u[2](x,t),x)=dydxf[2],u[1](x,t)
=u[0,1](t),u[2](x,t)=u[0,2](t),x=0,bc1[i]):od:
for i to NN do bc2[i]:=subs(diff(u[1](x,t),x)=dydxb[1],
diff(u[2](x,t),x)=dydxb[2],u[1](x,t)
=u[N+1,1](t),u[2](x,t)=u[N+1,2](t),x=L,bc2[i]):od:
for i to NN do eq[0,i]:=bc1[i];eq[N+1,i]:=bc2[i]:od:
for i from 1 to N do eq[i,1]:=diff(u[i,1](t),t)= subs(diff(u[1](x,t),x$2) =
subs(m=i,d2ydx2[1]),
diff(u[2](x,t),x$2) = subs(m=i,d2ydx2[2]),diff(u[1](x,t),x) =
subs(m=i,dydx[1]),diff(u[2](x,t),x) = subs(m=i,dydx[2]),u[1](x,t)=u[i,1](t),
u[2](x,t)=u[i,2](t),x=i*h,rhs(ge[1])):od:
for i from 1 to N do eq[i,2]:=diff(u[i,2](t),t)= subs(diff(u[1](x,t),x$2) =
u[2](x,t)=u[i,2](t),x=i*h,rhs(ge[2])):od:
for i to NN do u[0,i](t):=(solve(eq[0,i],u[0,i](t))):od:
 for i to NN do u[N+1,i](t):=(solve(eq[N+1,i],u[N+1,i](t))):od:
 h:=L/(N+1):
for i from 1 to N do eq[i,1]:=eval(eq[i,1]):od:
 for i from 1 to N do eq[i,2]:=eval(eq[i,2]):od:
eqs:=seq(seq((eq[i,j]),i=1..N),j=1..NN):
Y:=seq(seq(u[i,j](t),i=1..N),j=1..NN):
 ICs:=seq(u[i,1](0)=rhs(IC[1]),i=1..N),seq(u[i,2](0)=rhs(IC[2]),i=1..N):
sol:=dsolve({eqs,ICs},{Y},type=numeric,stiff=true,maxfun=1000000,abserr=1e-6,relerr=1e-5,output=listprocedure):
for j to NN do for i to N do U[i,j]:=subs(sol,u[i,j](t)):od:od:
for i to NN do U[0,i]:=subs(u[1,1](t)=U[1,1],u[1,2](t)=U[1,2],
u[2,1](t)=U[2,1],u[2,2](t)=U[2,2],u[0,i](t)):od:
 for i to NN do U[N+1,i]:=eval(subs(u[N,1](t)=U[N,1],u[N,2](t)=U[N,2],
u[N-1,1](t)=U[N-1,1],u[N-1,2](t)=U[N-1,2],u[N+1,i](t))):od:
tf:=1.:
M:=30:
T1:=[seq(tf*i/M,i=0..M)]:
PP:=matrix(N+2,M+1):
for i from 1 to N+2 do PP[i,1]:=evalf(subs(x=(i-1)*h,rhs(IC[1]))):od:
for i from 1 to N+2 do for j from 2 to M+1 do
PP[i,j]:=evalf(subs(t=T1[j],U[i-1,1](t))):od:od:
G1:=[seq([ seq([(i-1)*h,T1[j],PP[i,j]], i=1..N+2)], j=1..M+1)]:
t=0.02:
pars:=[0.1,0.5,1,2,5];
clr:=[black,red,green,gold,blue];
for m from 1 to 5 do
G1[m]:=plot([seq(subs(alpha=pars[m],G1[i])],i=0..N+1)],thickness=3,color=clr[j]):od:
display({seq(G1[i],i=1..5)},title="Figure ",axes=boxed,labels=[x,u]);
Eksamensopgaver_samlet.mw
Hey
Can anyone help me with this file?
I don't know how it happend, but the file somehow got corrupted. Is there anything i can do?
 s0lve  diff(U, x, t) = U by admion decomposition method
if there is a equation subs(...)
how to make a similar symbol like Diff(f(t),t) and diff(f(t),t) use for a new solver procedure use?
Hello Everyone;
I want to make this code complete in proc envirement (Proc command in maple). Kindly help me. Thanks in advance.
There are 10 questions. each question has one negetive point and three positive points. what is the number of students so that there will not be any repeatitive grades so all the students have distinct grades. Thanks in advance
Hello Everyone,
I am new to Maple and I have designed an algorithm to compute multivariate differential dimension Grobner bases. Now I want to add this Maple as a package but I do not how to do that.
Can someone please help with this.
Thank you so much for your help.
My code can be found at https://github.com/Gsparsh/Grobner-bases
I am a newbie and therefore have a rather simple question for the community:
By reading in my measurement data (topographic data) I have generated column vectors:
for i from 1 to k do
    B[i] := Vector(A[1 .. k, i]);
where k is a predefined rank of the original square matrix. The arithmetic mean was then calculated for each individual column vector:
    Am[i] := add(B[i][n], n = 1 .. k)/k;
Now I try to create new column vectors by subtracting the corresponding mean value from each entry of the original vectors, something like that:
C[i]:=B[i][n]-Am[i],n=1..k
But I just can't get it right. Can anyone help me? Thanks in advance!
Cheers
Christian
For example, the column dimension is 6 and I ran the following command,
A := Mod(2,Matrix(3,6,(i,j)->if i<2 and j < 3 then 1  elif i = 2 and j > 2 and j <5 then 1 else 0 end if),float[8])
the result is the following matrix with the last row containing all 0s.
A := Matrix(3, 6, [[1., 1., 0., 0., 0., 0.], [0., 0., 1., 1., 0., 0.], [0., 0., 0., 0., 0., 0.]])
Actually, I want the last row containing all 1s but I do not know how.
Any help?
i want to write a expression without any quotes . for example in this case i want to wrate E*1    E*2
First 613 614 615 616 617 618 619 Last Page 615 of 2428
