Hello everyone!
I am confronted with a problem that seems to result from different definition of spherical coordinates in Maple and in Student[VectorCalculus] package.
I want to visualize a vector field defined in spherical coordinates (r,theta,phi).
A simple exampe is < 0, theta, 0 >. If I want to see just one slice of the field in OXY plane, I type:
fieldplot3d(<0, theta, 0>, r = 0 .. 1, theta = 0 .. 2*Pi, phi = 0 .. Pi, coords = spherical, grid = [10, 20, 3], color = black, fieldstrength = fixed(1), arrows = THICK)
And get:
which looks OK more or less but I don't like the nonuniform distribution of arrows. But since the field is defined in spherical coordinates there seems to be no way to produce a uniform distribution with fieldplot3d command.
However VectorField command in Student[VectorCalculus] package seems to do just what I want. But a similar call to it:
SetCoordinates('spherical'[r, theta, phi])
VectorField(<0, theta, 0>, output = plot, view = [-5 .. 5, -5 .. 5, -10 .. 10], fieldoptions = [arrows = THICK, color = black, grid = [10, 10, 3], view = [-5 .. 5, -5 .. 5, -1 .. 1]])  produces quite a different result:
which means that the second argument 'theta' is not the azimuthal angle but the angle from the Z axis, and amounts to Pi/2 since we look at the OXY plane.
The result of: VectorField(<0, 0, theta>, output = plot, view = [-5 .. 5, -5 .. 5, -10 .. 10], fieldoptions = [arrows = THICK, color = black, grid = [10, 10, 3], view = [-5 .. 5, -5 .. 5, -1 .. 1]])  looks better:
but is not correct since the magnitude of the field does not change with the azimutal angle. Finally,
VectorField(<0, 0, phi>, output = plot, view = [-5 .. 5, -5 .. 5, -10 .. 10], fieldoptions = [arrows = THICK, color = black, grid = [10, 10, 3], view = [-5 .. 5, -5 .. 5, -1 .. 1]]) produces almost what I want:
but it's quite different from what you get with fieldplot3d command. Apparently, not only azimuthal angle is now the third argument but it varies from -Pi to Pi, not from 0 to 2Pi as it does in fieldplot3d. I hoped to use both fieldplot3d and VectorField  with my vector fields but I cannot since they are not consistent in the definition of spherical coordinates.
My questions therefore are:
1) Is there a way to redifine spherical coordinates in VectorField command to make them consistent with the rest of Maple?
2) Can I produce a uniform 3D distribution of arrows for a field in spherical coordinates without VectorField command?
Many thanks for your help in advance!
Figure;
                             Figure
A[0] := 0;
A[1] := sqrt(2*(k[1]^2-w[1]^2))/sqrt(lambda);
                                       (1/2)
                    /      2         2\
                    \2 k[1]  - 2 w[1] /
                                (1/2)
                          lambda
A[2] := sqrt(2*(k[2]^2-w[2]^2))/sqrt(lambda);
                                       (1/2)
                    /      2         2\
                    \2 k[2]  - 2 w[2] /
                                (1/2)
                          lambda
c[1] := 1;
c[2] := 1;
c[3] := 1;
c[4] := 1;
c[5] := 1;
c[6] := 1;
k[1] := 10.5;
                              10.5
k[2] := 3.5;
                              3.5
w[1] := 5.05;
                              5.05
w[2] := .5;
                              0.5
m := 1.9;
                              1.9
lambda := 1.75;
                              1.75
xi[1] := -t*w[1]+x*k[1];
                        -5.05 t + 10.5 x
xi[2] := -t*w[2]+x*k[2];
                         -0.5 t + 3.5 x
a := m/sqrt(k[1]^2-w[1]^2);
                          0.2063907138
b := m/sqrt(k[2]^2-w[2]^2);
                          0.5484827558
g := a*(c[2]*cos(a*xi[1])-c[3]*sin(a*xi[1]));
0.2063907138 cos(2.167102495 x) - 0.2063907138 sin(2.167102495 x)
h := c[1]+c[2]*sin(a*xi[1])+c[3]*cos(a*xi[1]);
          1 + sin(2.167102495 x) + cos(2.167102495 x)
G := b*(c[5]*cos(b*xi[2])-c[6]*sin(b*xi[2]));
0.5484827558 cos(1.919689645 x) - 0.5484827558 sin(1.919689645 x)
H := c[4]+c[5]*sin(b*xi[2])+c[6]*cos(b*xi[2]);
          1 + sin(1.919689645 x) + cos(1.919689645 x)
u := A[0]+A[1]*[g/h]+A[2]*[G/H];
  [                     1
  [------------------------------------------- (3.703280398
  [1 + sin(1.919689645 x) + cos(1.919689645 x)
    (0.5484827558 cos(1.919689645 x)
     - 0.5484827558 sin(1.919689645 x))) +
    ------------------------------------------- (9.841457496
    (0.2063907138 cos(2.167102495 x)
     - 0.2063907138 sin(2.167102495 x)))]
plot3d(Re(u), x = -20 .. .20, t = -20 .. .20);
Error, invalid input: `simpl/Re` expects its 1st argument, x, to be of type {boolean, algebraic}, but received [3.703280398*(.5484827558*cos(1.919689645*x)-.5484827558*sin(1.919689645*x))/(1+sin(1.919689645*x)+cos(1.919689645*x))+9.841457496*(.2063907138*cos(2.167102495*x)-.2063907138*sin(2.167102495*x))/(1+sin(2.167102495*x)+cos(2.167102495*x))]
t := 0;
plot(u, x = -15 .. 15);
I don't know how to simplify the expression A/B in the worksheet below.  I know that it should simplify to exp(I*Pi/3).  How do I lead Maple to discover that result without telling it the solution ahead of the time?  All variables other than A and B are real.
local gamma:
A := I*sqrt(3) + 2*c*exp(I*(gamma+(1/3)*Pi)) + 2*a*exp(I*alpha) - 2*a*exp(I*(alpha+(1/3)*Pi)) - 2*b*exp(I*beta) - 1;
I*3^(1/2)+2*c*exp(I*(gamma+(1/3)*Pi))+2*a*exp(I*alpha)-2*a*exp(I*(alpha+(1/3)*Pi))-2*b*exp(I*beta)-1
B := I*sqrt(3) - 2*a*exp(I*(alpha+(1/3)*Pi)) - 2*b*exp(I*beta) + 2*b*exp(I*(beta+(1/3)*Pi)) + 2*c*exp(I*gamma) + 1;
I*3^(1/2)-2*a*exp(I*(alpha+(1/3)*Pi))-2*b*exp(I*beta)+2*b*exp(I*(beta+(1/3)*Pi))+2*c*exp(I*gamma)+1
How to show that A/B = e^((1/3)*i*Pi)?
Download mw.mw
How to find the closed formula for the sum of this sequence:
sum = n + n/2 + n/4 + n/8 + ... + 1
If n is 2 in some power, then the sum should be 2*n - 1. How to get this answer using Maple?
can anyone explain to me the  meaning of this result ?trial.mw
Is possible to solve this differential equation by maple?
thaks...
Hello everyone!
I have a vector field defined in spherical coordinates and I want to plot a sphere colored according to the magnitude of the vector field on that sphere. Is there a simple way to do this?
Many thanks in advance!
I wonder how I could use Maple commands to do the following:
An irrational number, ir, (a huge symbolic expression as a result of iterating a discrete map) is converted to single precision (Real16) and then to hexadecimal as a string. Example: using matlab it will be something like single(ir)=0.25(float representation) =3e800000 (hexadecimal representation).
I am not sure if single precision is available in Maple 2017 but I guess Real32, Real64 and Real128 are.
Once the hexadecimal representation is acquired I need to convert it back to Real16, Real 32 and etc.
Your help is much appreciated.
Many thanks
Ed
I am trying element-wise addition of two arrays where one array is Cauchy distribution. but this calculation using much memory. Please help.
CAUCHY_DISTRIBUTION.mw
Dear members, Can anyone help me, how to adjust the spacing between lines, sections in adjacent paragraphsand sections within a paragragraph.
"line 1"
" line 2  line 3"
Sec 1
Sec 2
Sec2
How do I vary the spacing between the lines?
Download spacingDoubt.mw
How do I display the area between two curves? ( for example the area in sin and cos?) I tried with the option 'filled ' and 'display'
Deuxcourbes.mw
I'm using the eBookTools package to convert a .mw file as a chapter into a PDF file. However, a problem arises when I convert a document with a few repeated plotting commands (such as plot(x^2)). The issue is that in the final PDF the images of the various plots overlap, and that the individual plots can't be clearly seen. Is there a resolution to this?
Bart
I am generating gaussian distribution by decreasing standard deviation but the distribution generation is getting very slow.
GAUSSIAN.mw
A book I am reading has the following
I cannot produce this in Maple 2017. Please tell me where I go wrong. Thank
"P(t):=(r*Q[inf])/(2+2 cosh(b-r*t))"
proc (t) options operator, arrow; r*Q[inf]/(2+2*cosh(b-r*t)) end proc
"Q(t):=(&int;)[0]^(t)P(t) &DifferentialD;t"
proc (t) options operator, arrow; int(P(t), t = 0 .. t) end proc
Download Hubbert.mw
the following maple code is to solve the SYS of ODE x',y',z'
then plot z' agianst t
i got confused each plot give me zero
N:=1:M:=sqrt(N*(N+1)):N1:=1+N:w:=10:f:=1;
                             f := 1
ini1:= x(0)=0.5,y(0)=0.5,z(0)=0;
            ini1 := x(0) = 0.5, y(0) = 0.5, z(0) = 0
var:={x(t),y(t),z(t)}:
dsys:={diff(z(t),t)=-(N1+M*cos(2*w*t))*z(t)-1+f*(x(t)+y(t)), diff(x(t),t)=-(N1-I*w-2*M*exp(-2*I*w*t))*x(t)-f*(N1+(z(t)))-2*f*M*exp(2*I*w*t),diff(y(t),t)=-(N1+I*w-2*M*exp(2*I*w*t))*y(t)-f*(N1+(z(t)))-2*f*M*exp(-2*I*w*t)}:
zd:=diff(z(t),t);
                                d
                         zd := --- z(t)
                                dt
res:=dsolve(dsys union {x(0)=0.5,y(0)=0.5,z(0)=0},numeric,output=listprocedure):
tit:=sprintf("F=%g,N=%g",f,N):
P1:=plots[odeplot](res,[[t,(zd)]],0..6,axes=boxed,titlefont=[SYMBOL,14],font=[1,1,18],color=blue,linestyle=1,tickmarks=[3, 4],font=[1,1,14],thickness=2,titlefont=[SYMBOL,12]);
First 724 725 726 727 728 729 730 Last Page 726 of 2428
